leopard 发表于 2016-5-30 22:31
NanoPi2_Fire_1512B_Schematic
The NanoPi 2 Fire is a high performance ARM Board developed by FriendlyARM for Hobbysts, Makers and Hackers for IOT projects.
It features Samsung's Cortex-A9 Quad Core S5P4418@1.4GHz SoC and 1G 32bit DDR3 RAM.
It has a Gbps Ethernet port. It boots Android and Debian from a TF card. It integrates an HDMI and LCD interface.
Its adoption of the Raspberry Pi's GPIO pin header makes it compatible with both Raspberry Pi's external GPIO modules and Arduino's shield boards.
Its PCB dimension is 75 x 40 mm.
Features
CPU: S5P4418, 1.4GHzRAM: 1GB DDR3Connectivity: Gbps Ethernet portPMU Power Management: AXP228, support software power-off, sleep and wakeup functionsUSB 2.0 Type A x 1Debug Serial Port/UART0 x 1microSD Slot x 1microUSB x 1: for data transmission and power inputLCD Interface: 0.5 mm pitch SMT FPC seat, for full-color LCD (RGB: 8-8-8)HDMI: HDMI 1.4A, Type-A, 1080P60DVP Camera Interface: 0.5mm spacing FPC socket. It includes ITU-R BT 601/656 8-bit, I2C and IOGPIO: 2.54mm spacing 40pin, compatible with Raspberry Pi's GPIO. It includes UART, SPI, I2C, PWM, IOetc.Button: Power Button x 1, Reset Button x 1LED: LED for Power Indication x 1, System LED x 1PCB Dimension: 75 x 40mmPower: DC 5V/2Ai>OS: Android, Debian
urverycool 发表于 2016-5-31 08:52
fairy0212 发表于 2016-5-31 08:59
lozgwn 发表于 2016-5-31 10:09
有PCB吗
haleliu 发表于 2016-5-31 11:11
wellnj 发表于 2021-5-11 01:33
谢谢分享
h09721 发表于 2021-5-11 08:48
查看完整版本: NanoPi2_Fire_1512B_Schematic
