NanoPi2_Fire_1512B_Schematic
| The NanoPi 2 Fire is a high performance ARM Board developed by FriendlyARM for Hobbysts, Makers and Hackers for IOT projects. |
| It features Samsung's Cortex-A9 Quad Core S5P4418@1.4GHz SoC and 1G 32bit DDR3 RAM. |
| It has a Gbps Ethernet port. It boots Android and Debian from a TF card. It integrates an HDMI and LCD interface. |
| Its adoption of the Raspberry Pi's GPIO pin header makes it compatible with both Raspberry Pi's external GPIO modules and Arduino's shield boards. |
| Its PCB dimension is 75 x 40 mm. |
Features
[li]CPU: S5P4418, 1.4GHz[/li][li]RAM: 1GB DDR3[/li][li]Connectivity: Gbps Ethernet port[/li][li]PMU Power Management: AXP228, support software power-off, sleep and wakeup functions[/li][li]USB 2.0 Type A x 1[/li][li]Debug Serial Port/UART0 x 1[/li][li]microSD Slot x 1[/li][li]microUSB x 1: for data transmission and power input[/li][li]LCD Interface: 0.5 mm pitch SMT FPC seat, for full-color LCD (RGB: 8-8-8)[/li][li]HDMI: HDMI 1.4A, Type-A, 1080P60[/li][li]DVP Camera Interface: 0.5mm spacing FPC socket. It includes ITU-R BT 601/656 8-bit, I2C and IO[/li][li]GPIO: 2.54mm spacing 40pin, compatible with Raspberry Pi's GPIO. It includes UART, SPI, I2C, PWM, IO etc.[/li][li]Button: Power Button x 1, Reset Button x 1[/li][li]LED: LED for Power Indication x 1, System LED x 1[/li][li]PCB Dimension: 75 x 40mm[/li][li]Power: DC 5V/2A[/li]i>OS: Android, Debian
NanoPi2_Fire_1512B_Schematic.pdf
280 KB, 下载次数: 1, 下载积分:金币 -1 枚
