RD1022 发表于 2025-11-11 20:15
Zynq7010/Zynq7020 +AD9361BBCZ做的无限通讯板SDR PCB 原理图等
D8ZM4740A_ZM4740A_ZM4740AZM4740AZM4740A
FB3BLM15PX330SN1_L0402_BLM15PX330SN1_NCBLM15PX330SN1_NCL0402
FB25BLM18PG330SN1_L0603_BLM18PG330SN1BLM18PG330SN1L0603
J1FPGA_JTAG_0_SMDX6X125MM_FPGA_JTAGFPGA_JTAGSMDX6X125MM
J2ON/OFFX2_SMDON_OFF254X2_ON/OFFX2ON/OFFX2SMDON_OFF254X2
J19MICRO_SD_MICRO_SD_MICRO_SDMicro_SDMICRO_SD
J20TYPEC-16P_USB_TYPEC_U20401_TYPEC-16PTYPEC-16PUSB_TYPEC_U20401
J22BEEP_BEEP_BEEPBEEPBEEP
J23BWIPX-1-001E_IPEX1_BWIPX-1-001EBWIPX-1-001EIPEX1
JP2HR911130A_HY911130A_HR911130AHR911130AHY911130A
JP3SMA.PIN5.RA_DIP_254X2_FR_SIP3SIP3DIP_254X2_FR
JP4SMA.PIN5.RA_DIP_254X2_FR_SIP3SIP3DIP_254X2_FR
JP5SMA.PIN5.RA_DIP_254X2_FR_SIP3SIP3DIP_254X2_FR
JP6SMA.PIN5.RA_DIP_254X2_FR_SIP3SIP3DIP_254X2_FR
JP8HEADER1X2_254_DIP_254X2_SIP3SIP3DIP_254X2
JP9HEADER2X22_BOX_DV_2_54MM_HERD254X2X22_HD2X20_BOX_DV_2_54MMHD2X20_BOX_DV_2_54mmHERD254X2X22
L4NR2520-2UH2_SMD2_5X2X1_2MM_ANR252010T2R2MANR252010T2R2MSMD2_5X2X1_2MM
L8330NH.0603_L0603_LQM18NNR33K00DLQM18NNR33K00DL0603
L9330NH.0603_L0603_LQM18NNR33K00DLQM18NNR33K00DL0603
L10330NH.0603_L0603_LQM18NNR33K00DLQM18NNR33K00DL0603
L11330NH.0603_L0603_LQM18NNR33K00DLQM18NNR33K00DL0603
L16FXL0530-1R5-M_L4520_FXL0420-1R5-MFXL0420-1R5-ML4520
L18FXL0530-1R5-M_L4520_FXL0420-1R5-MFXL0420-1R5-ML4520
L20FXL0530-2R2-M_L4520_FXL0530-2R2-MFXL0530-2R2-ML4520
L21FXL0530-1R5-M_L4520_FXL0420-1R5-MFXL0420-1R5-ML4520
Q8S8050_SOT23-3_S8050S8050SOT23-3
U1ZYNQ7010/7020_CLG400_ZYNQ7010/7020Zynq7010/7020CLG400
U3W25Q16JVSSIQ_SOP8_208MIL_W25Q16JVSSIQW25Q16JVSSIQSOP8_208MIL
U7TPS562200DDCR_SOT23-6_TPS562200DDCRTPS562200DDCRSOT23-6
U8YT8531C_QFP_40P_R_YT8531C/RTL8211FYT8531C/RTL8211FQFP_40P_R
U9MT41J256M16RE_FBGA96_BGA96_0P8_8P15X14P15_R_IC_<VALUE><Value>BGA96_0P8_8P15X14P15_R
U10AD9361BBCZ_BGA-144-0_8_AD9361BBCZAD9361BBCZBGA-144-0_8
U11TCM1-63AX+_SMD-6P_TCM1-63AX+TCM1-63AX+SMD-6P
U12TCM1-63AX+_SMD-6P_TCM1-63AX+TCM1-63AX+SMD-6P
U16TPS562200DDCR_SOT23-6_TPS562200DDCRTPS562200DDCRSOT23-6
U17TPS562200DDCR_SOT23-6_TPS562200DDCRTPS562200DDCRSOT23-6
U1974LVC1G125DBVRG4_SOT-23-5_74LVC1G125SE-774LVC1G125SE-7SOT-23-5
U2074LVC1G125DBVRG4_SOT-23-5_74LVC1G125SE-774LVC1G125SE-7SOT-23-5
U21CH340E_MSOP-10_CH340ECH340EMSOP-10
U22TCM1-63AX+_SMD-6P_TCM1-63AX+TCM1-63AX+SMD-6P
U23TCM1-63AX+_SMD-6P_TCM1-63AX+TCM1-63AX+SMD-6P
U24SCT2230_SOT23-6_SCT2230SCT2230SOT23-6
U25TXS02612RTWR_WQFN-24-EP-4X4_TXS02612RTWRTXS02612RTWRWQFN-24-EP-4X4
U27TPS7A8101DRBR_VSON-8-EP-3X3_TPS7A8101DRBRTPS7A8101DRBRVSON-8-EP-3X3
U28TPS7A8101DRBR_VSON-8-EP-3X3_TPS7A8101DRBRTPS7A8101DRBRVSON-8-EP-3X3
X13225.33.333333MHZ_SMD3225-4P_33.333333.3333SMD3225-4P
X23225.50MHZ_SMD3225-4P_3225.50MHZ3225.50MHZSMD3225-4P
X33225.40MHZ.1V8_SMD3225-4P_3225.40MHZ.1V83225.40MHZ.1V8SMD3225-4P
Y125M,5032_SMD5032-2P_25MHZ25MHZSMD5032-2P
rfuexu 发表于 2025-11-12 06:36
jesty_ma 发表于 2026-2-28 09:25
厉害,还在咸鱼花了20块买的
雨果不是秋收 发表于 2026-2-28 09:26
oooooooooooooooo
小周0124 发表于 2026-2-28 11:18
非常感谢,很实用,可以参考学习一下!
aokema124 发表于 2026-2-28 14:51
:Q:Q:Q:Q:Q:Q:Q:Q
5520752 发表于 2026-2-28 15:20
shuszhao 发表于 2026-3-2 14:02
正好需要,感谢分享
lishanghai 发表于 2026-3-2 14:19
感谢分享,不错不错
yfchen1003 发表于 2026-3-2 14:48
谢谢分享路过
页: [1] 2 3 4
查看完整版本: Zynq7010/Zynq7020 +AD9361BBCZ做的无限通讯板SDR PCB 原理图等
