| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D8 | ZM4740A_ZM4740A_ZM4740A | ZM4740A | ZM4740A |
| FB3 | BLM15PX330SN1_L0402_BLM15PX330SN1_NC | BLM15PX330SN1_NC | L0402 |
| FB25 | BLM18PG330SN1_L0603_BLM18PG330SN1 | BLM18PG330SN1 | L0603 |
| J1 | FPGA_JTAG_0_SMDX6X125MM_FPGA_JTAG | FPGA_JTAG | SMDX6X125MM |
| J2 | ON/OFFX2_SMDON_OFF254X2_ON/OFFX2 | ON/OFFX2 | SMDON_OFF254X2 |
| J19 | MICRO_SD_MICRO_SD_MICRO_SD | Micro_SD | MICRO_SD |
| J20 | TYPEC-16P_USB_TYPEC_U20401_TYPEC-16P | TYPEC-16P | USB_TYPEC_U20401 |
| J22 | BEEP_BEEP_BEEP | BEEP | BEEP |
| J23 | BWIPX-1-001E_IPEX1_BWIPX-1-001E | BWIPX-1-001E | IPEX1 |
| JP2 | HR911130A_HY911130A_HR911130A | HR911130A | HY911130A |
| JP3 | SMA.PIN5.RA_DIP_254X2_FR_SIP3 | SIP3 | DIP_254X2_FR |
| JP4 | SMA.PIN5.RA_DIP_254X2_FR_SIP3 | SIP3 | DIP_254X2_FR |
| JP5 | SMA.PIN5.RA_DIP_254X2_FR_SIP3 | SIP3 | DIP_254X2_FR |
| JP6 | SMA.PIN5.RA_DIP_254X2_FR_SIP3 | SIP3 | DIP_254X2_FR |
| JP8 | HEADER1X2_254_DIP_254X2_SIP3 | SIP3 | DIP_254X2 |
| JP9 | HEADER2X22_BOX_DV_2_54MM_HERD254X2X22_HD2X20_BOX_DV_2_54MM | HD2X20_BOX_DV_2_54mm | HERD254X2X22 |
| L4 | NR2520-2UH2_SMD2_5X2X1_2MM_ANR252010T2R2M | ANR252010T2R2M | SMD2_5X2X1_2MM |
| L8 | 330NH.0603_L0603_LQM18NNR33K00D | LQM18NNR33K00D | L0603 |
| L9 | 330NH.0603_L0603_LQM18NNR33K00D | LQM18NNR33K00D | L0603 |
| L10 | 330NH.0603_L0603_LQM18NNR33K00D | LQM18NNR33K00D | L0603 |
| L11 | 330NH.0603_L0603_LQM18NNR33K00D | LQM18NNR33K00D | L0603 |
| L16 | FXL0530-1R5-M_L4520_FXL0420-1R5-M | FXL0420-1R5-M | L4520 |
| L18 | FXL0530-1R5-M_L4520_FXL0420-1R5-M | FXL0420-1R5-M | L4520 |
| L20 | FXL0530-2R2-M_L4520_FXL0530-2R2-M | FXL0530-2R2-M | L4520 |
| L21 | FXL0530-1R5-M_L4520_FXL0420-1R5-M | FXL0420-1R5-M | L4520 |
| Q8 | S8050_SOT23-3_S8050 | S8050 | SOT23-3 |
| U1 | ZYNQ7010/7020_CLG400_ZYNQ7010/7020 | Zynq7010/7020 | CLG400 |
| U3 | W25Q16JVSSIQ_SOP8_208MIL_W25Q16JVSSIQ | W25Q16JVSSIQ | SOP8_208MIL |
| U7 | TPS562200DDCR_SOT23-6_TPS562200DDCR | TPS562200DDCR | SOT23-6 |
| U8 | YT8531C_QFP_40P_R_YT8531C/RTL8211F | YT8531C/RTL8211F | QFP_40P_R |
| U9 | MT41J256M16RE_FBGA96_BGA96_0P8_8P15X14P15_R_IC_<VALUE> | <Value> | BGA96_0P8_8P15X14P15_R |
| U10 | AD9361BBCZ_BGA-144-0_8_AD9361BBCZ | AD9361BBCZ | BGA-144-0_8 |
| U11 | TCM1-63AX+_SMD-6P_TCM1-63AX+ | TCM1-63AX+ | SMD-6P |
| U12 | TCM1-63AX+_SMD-6P_TCM1-63AX+ | TCM1-63AX+ | SMD-6P |
| U16 | TPS562200DDCR_SOT23-6_TPS562200DDCR | TPS562200DDCR | SOT23-6 |
| U17 | TPS562200DDCR_SOT23-6_TPS562200DDCR | TPS562200DDCR | SOT23-6 |
| U19 | 74LVC1G125DBVRG4_SOT-23-5_74LVC1G125SE-7 | 74LVC1G125SE-7 | SOT-23-5 |
| U20 | 74LVC1G125DBVRG4_SOT-23-5_74LVC1G125SE-7 | 74LVC1G125SE-7 | SOT-23-5 |
| U21 | CH340E_MSOP-10_CH340E | CH340E | MSOP-10 |
| U22 | TCM1-63AX+_SMD-6P_TCM1-63AX+ | TCM1-63AX+ | SMD-6P |
| U23 | TCM1-63AX+_SMD-6P_TCM1-63AX+ | TCM1-63AX+ | SMD-6P |
| U24 | SCT2230_SOT23-6_SCT2230 | SCT2230 | SOT23-6 |
| U25 | TXS02612RTWR_WQFN-24-EP-4X4_TXS02612RTWR | TXS02612RTWR | WQFN-24-EP-4X4 |
| U27 | TPS7A8101DRBR_VSON-8-EP-3X3_TPS7A8101DRBR | TPS7A8101DRBR | VSON-8-EP-3X3 |
| U28 | TPS7A8101DRBR_VSON-8-EP-3X3_TPS7A8101DRBR | TPS7A8101DRBR | VSON-8-EP-3X3 |
| X1 | 3225.33.333333MHZ_SMD3225-4P_33.3333 | 33.3333 | SMD3225-4P |
| X2 | 3225.50MHZ_SMD3225-4P_3225.50MHZ | 3225.50MHZ | SMD3225-4P |
| X3 | 3225.40MHZ.1V8_SMD3225-4P_3225.40MHZ.1V8 | 3225.40MHZ.1V8 | SMD3225-4P |
| Y1 | 25M,5032_SMD5032-2P_25MHZ | 25MHZ | SMD5032-2P |
