君正T31 +JX_F37 +RTL8201F-VB-CG 做的网络摄像头 PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME0V1TP_TEST_C100_TP_SMDTP_SMDTEST_C1001V1TP_TEST_C100_TP_SMDTP_SMDTEST_C100D1DIODE_0_SMA_SS34SS34SMAD2DIODEDIAC_0_SMB_SMBJ15CASMBJ15CASMBD3K1100E70/TO_0_SMB_WEOS4-100-270WEOS4-100-270AS-EMSMBD4DIODEDIAC_3_SOD2614X116_WS05DLWS05DLC-BSOD2614X116D5DIODEDIAC_4_SOD2614X116_WS05DLWS05DLC-BSOD2614X116FB1BEAD_L0402_SZ1005K102TFSZ1005K102TFL0402H1MHOLE1_HOLE2_3_MHOBL_NCMHOBL_NCHOLE2_3H2MHOLE1_HOLE2_3_MHOBL_NCMHOBL_NCHOLE2_3H3MHOLE1_HOLE2_3_MHOBL_NCMHOBL_NCHOLE2_3H4MHOLE1_HOLE2_3_MHOBL_NCMHOBL_NCHOLE2_3H5MHOLE1_HOLE2_0D2_2_MHOBL_NCMHOBL_NCHOLE2_0D2_2J1008_LENS_JACK_IRCUT_JACK_20_3_IIRCUT_JACK_20_NCIRCUT_JACK_20_3J2CON8_SMD_SMD_1_25-8P_SMD_LT_1.2SMD_LT_1.25*8PINSMD_1_25-8PJ5HEAD1*5_1_DIP_3P-125MM_DIP_125MDIP_125mmx3pin_NCDIP_3P-125MMJ6CON3_SMD_SMD_1_25-3P_SMD_LT_1.2SMD_LT_1.25mm*3PINSMD_1_25-3PJ7CON2_0_SMD_WT_125MMX2PIN_SMD_LTSMD_LT_1.25*2PINSMD_WT_125MMX2PINJ9CON2_0_SMD_WT_125MMX2PIN_SMD_LTSMD_LT_1.25*2PINSMD_WT_125MMX2PINJ10CON4_SMD_SMD_1_25-4P_SMD_LT_1.2SMD_LT_1.25mm*4PINSMD_1_25-4PJP4CON10_0_SMT_FPC-LT-24P_CON11CON11SMT_FPC-LT-24PL2L_SMD_L3015_SWPA3015S4R7NTSWPA3015S4R7NTL3015L4L_SMD_L2520_SWPA2520S2R2NTSWPA2520S2R2NTL2520L5L_SMD_L3015_SWPA3015S2R2NTSWPA3015S2R2NTL3015LB8LB_L0402_LBLBL0402PPRST_N1TP_TEST_C100_TP_SMDTP_SMDTEST_C100Q1NPN_SOT23_NPN-LMBT2222ALT1G_NC_NPN-LMBT2222ALT1G_NCSOT23T1000-7090-37R_0_STFM16-50-299_TMTMS1102NL/SOP-16STFM16-50-299U2MP1470GJ_SOT23_6_RY8122RY8122SOT23_6U3MP2105DJ_SOT235_SOT23_5_RY3410RY3410SOT23_5U4MP2105DJ_SOT235_SOT23_5_RY3420RY3420SOT23_5U5T31_QFN88_1_QFN88_0D35_T31_T31NT31NQFN88_0D35_T31U6SPI_NOR_SOIC8_M_FM25Q128AFM25Q128ASOIC8_MU7MP2105DJ_SOT235_1_SOT23_5_WR033WR0332-28A50RSOT23_5U11BD6210F_0_SOIC127P600X175-8N_AEAE6208GSOIC127P600X175-8NU12RTL8201F-VB-CG_0_QFN-32_RTL8201RTL8201F-VB-CGQFN-32_RTL8201FU24F23_0_JX_F37_Q03/F37PQ03/F37PJX_F37Y1XTAL_P4_2_CRY3225_24M-YC24M-YCCRY3225 PCB文件来了。回复可见下载
**** Hidden Message ***** 谢谢分享 学习学习了 好好学习
