| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| 0V1 | TP_TEST_C100_TP_SMD | TP_SMD | TEST_C100 |
| 1V1 | TP_TEST_C100_TP_SMD | TP_SMD | TEST_C100 |
| D1 | DIODE_0_SMA_SS34 | SS34 | SMA |
| D2 | DIODEDIAC_0_SMB_SMBJ15CA | SMBJ15CA | SMB |
| D3 | K1100E70/TO_0_SMB_WEOS4-100-270 | WEOS4-100-270AS-EM | SMB |
| D4 | DIODEDIAC_3_SOD2614X116_WS05DL | WS05DLC-B | SOD2614X116 |
| D5 | DIODEDIAC_4_SOD2614X116_WS05DL | WS05DLC-B | SOD2614X116 |
| FB1 | BEAD_L0402_SZ1005K102TF | SZ1005K102TF | L0402 |
| H1 | MHOLE1_HOLE2_3_MHOBL_NC | MHOBL_NC | HOLE2_3 |
| H2 | MHOLE1_HOLE2_3_MHOBL_NC | MHOBL_NC | HOLE2_3 |
| H3 | MHOLE1_HOLE2_3_MHOBL_NC | MHOBL_NC | HOLE2_3 |
| H4 | MHOLE1_HOLE2_3_MHOBL_NC | MHOBL_NC | HOLE2_3 |
| H5 | MHOLE1_HOLE2_0D2_2_MHOBL_NC | MHOBL_NC | HOLE2_0D2_2 |
| J1 | 008_LENS_JACK_IRCUT_JACK_20_3_I | IRCUT_JACK_20_NC | IRCUT_JACK_20_3 |
| J2 | CON8_SMD_SMD_1_25-8P_SMD_LT_1.2 | SMD_LT_1.25*8PIN | SMD_1_25-8P |
| J5 | HEAD1*5_1_DIP_3P-125MM_DIP_125M | DIP_125mmx3pin_NC | DIP_3P-125MM |
| J6 | CON3_SMD_SMD_1_25-3P_SMD_LT_1.2 | SMD_LT_1.25mm*3PIN | SMD_1_25-3P |
| J7 | CON2_0_SMD_WT_125MMX2PIN_SMD_LT | SMD_LT_1.25*2PIN | SMD_WT_125MMX2PIN |
| J9 | CON2_0_SMD_WT_125MMX2PIN_SMD_LT | SMD_LT_1.25*2PIN | SMD_WT_125MMX2PIN |
| J10 | CON4_SMD_SMD_1_25-4P_SMD_LT_1.2 | SMD_LT_1.25mm*4PIN | SMD_1_25-4P |
| JP4 | CON10_0_SMT_FPC-LT-24P_CON11 | CON11 | SMT_FPC-LT-24P |
| L2 | L_SMD_L3015_SWPA3015S4R7NT | SWPA3015S4R7NT | L3015 |
| L4 | L_SMD_L2520_SWPA2520S2R2NT | SWPA2520S2R2NT | L2520 |
| L5 | L_SMD_L3015_SWPA3015S2R2NT | SWPA3015S2R2NT | L3015 |
| LB8 | LB_L0402_LB | LB | L0402 |
| PPRST_N1 | TP_TEST_C100_TP_SMD | TP_SMD | TEST_C100 |
| Q1 | NPN_SOT23_NPN-LMBT2222ALT1G_NC_ | NPN-LMBT2222ALT1G_NC | SOT23 |
| T1 | 000-7090-37R_0_STFM16-50-299_TM | TMS1102NL/SOP-16 | STFM16-50-299 |
| U2 | MP1470GJ_SOT23_6_RY8122 | RY8122 | SOT23_6 |
| U3 | MP2105DJ_SOT235_SOT23_5_RY3410 | RY3410 | SOT23_5 |
| U4 | MP2105DJ_SOT235_SOT23_5_RY3420 | RY3420 | SOT23_5 |
| U5 | T31_QFN88_1_QFN88_0D35_T31_T31N | T31N | QFN88_0D35_T31 |
| U6 | SPI_NOR_SOIC8_M_FM25Q128A | FM25Q128A | SOIC8_M |
| U7 | MP2105DJ_SOT235_1_SOT23_5_WR033 | WR0332-28A50R | SOT23_5 |
| U11 | BD6210F_0_SOIC127P600X175-8N_AE | AE6208G | SOIC127P600X175-8N |
| U12 | RTL8201F-VB-CG_0_QFN-32_RTL8201 | RTL8201F-VB-CG | QFN-32_RTL8201F |
| U24 | F23_0_JX_F37_Q03/F37P | Q03/F37P | JX_F37 |
| Y1 | XTAL_P4_2_CRY3225_24M-YC | 24M-YC | CRY3225 |
