| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D2 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D3 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D4 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D5 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D6 | DIODE_SCHTKY_SOD123LF_IC_MBR140 | MBR140SFT | SOD123LF |
| D7 | DIODE_SCHTKY_SOD123LF_IC_MBR140 | MBR140SFT | SOD123LF |
| D8 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D9 | MBRD835LG_DPAK_IC_MBRD835L | MBRD835L | DPAK |
| D10 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D11 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D12 | DIODE_BIDIR_DSN0603-2_IC_PESD5V | PESD5V0R1BSF | DSN0603-2 |
| D13 | DIODE_BIDIR_DSN0603-2_IC_PESD5V | PESD5V0R1BSF | DSN0603-2 |
| D14 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D15 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D16 | DIODE_BIDIR_DSN0603-2_IC_PESD5V | PESD5V0R1BSF | DSN0603-2 |
| D25 | DIODE_TVS_BIDIR_C_A1_DIO-DSN060 | PESD5V0V1BSF | DIO-DSN0603-2_A1 |
| D26 | DIODE_TVS_UNIDIR_DIO_SOD-923_A_ | ESD3V3D9 | DIO_SOD-923_A_A1 |
| D27 | DIODE_SCHTKY_SOD123LF_IC_MBR140 | MBR140SFT | SOD123LF |
| D28 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D29 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D33 | DIODE_TVS_UNIDIR_DIO-SOD128_PTV | PTVS15VP1UP | DIO-SOD128 |
| D40 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D43 | DIODE_SCH_DIO_SMA_B130-13-F | B130-13-F | DIO_SMA |
| D44 | LED_LED_0603_IC_RED | RED | LED_0603 |
| D45 | LED_LED_0603_IC_RED | RED | LED_0603 |
| DA1 | DIODE_NETX2_PN_3P_B_SOT23-3L_1P | BAV99 | SOT23-3L_1P9_2P92X1P3_A_A1 |
| DA2 | DIODE_NETX2_PN_3P_B_SOT23-3L_1P | BAV99 | SOT23-3L_1P9_2P92X1P3_A_A1 |
| F1 | FUSE_FUSE_BLOCK_154_IC_10A | 10A | FUSE_BLOCK_154 |
| FD1 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FD2 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FD3 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FD4 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FD5 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FD6 | MECH_FID_G_GFD40_120_GLOBAL | Global | GFD40_120 |
| FL1 | FIL_COM-MODE_4P_C_POL_CM_CHK4_0 | DLW21HN900SQ2L | CM_CHK4_0P8_2X1P2 |
| FL2 | FIL_COM-MODE_4P_C_POL_CM_CHK4_0 | DLW21HN900SQ2L | CM_CHK4_0P8_2X1P2 |
| FL7 | FIL_6P_FILT4_4P2_12P1X9P1_50E | 50E | FILT4_4P2_12P1X9P1 |
| HS1 | HEATSINK_FAN_2P_HS_2_175D125_44 | 30-1944-01 | HS_2_175D125_44P8X44P8 |
| J1 | CONN_IPASS-1X36_44P_CUST_A1_CON | CON_IPASS_INTX1 | CON_IPASS_36F_0P8_TH_ST_B_A1 |
| J2 | CONN_IPASS-1X36_44P_CUST_A1_CON | CON_IPASS_INTX1 | CON_IPASS_36F_0P8_TH_ST_B_A1 |
| J3 | CONN_IPASS-1X36_44P_CUST_A1_CON | CON_IPASS_INTX1 | CON_IPASS_36F_0P8_TH_ST_B_A1 |
| J4 | CONN_HDR_5X2_HDR205_10M_50_SM_K | FTSH-105-01-L-DV-K | HDR205_10M_50_SM_K |
| J5 | CONN_NGFF-E_1X67_69P_A1_CON_NGF | CON_NGFF_MINIx1 | CON_NGFF_75F_0P5_SM_RA_CST_A_A1 |
| J6 | CONN_HDR_3X1_HDR103_IO_68000-10 | 68000-103HLF | HDR103 |
| J7 | CONN_RJ45-14X1_16P_A_CON_RJ45_1 | CON_RJ45 | CON_RJ45_14F_2P54_TH_RA |
| J8 | CONN_AUDJACK_6P_B_CON_AUDIOJACK | CON_AUDJACK | CON_AUDIOJACK_6F_2P8_SM_RA |
| J9 | CONN_PWRJACK_9P_A1_CON_PWR_2X2F | CON_PWRJACK | CON_PWR_2X2F_5_TH_RA_A1 |
| J10 | USB_24_TYPE_C_USB24_TYPE_C_DX07 | DX07S024JJ2R1300 | USB24_TYPE_C_DX07S024_SM |
| J11 | MICRO_USB_CONN_10PIN_CON_MICROA | USB_MICRO_AB | CON_MICROAB_10F_25_SM_RA |
| J12 | CONN_SD-CARD-11_14P_A1_CON_SDCA | CON_SD-CARD-11 | CON_SDCARD_11F_2P5_SM_RA_A_A1 |
| J13 | CONN_B2B_6X50_300P_A1_CON_B2B_6 | CON_B2B_6X50 | CON_B2B_6X50F_1P27_SM_ST_A1 |
| L1 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L2 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L3 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L4 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L5 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L6 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L7 | INDUCTOR_IND2520_DISCRETE_1UH | 1uH | IND2520 |
| L8 | INDUCTOR_IND_1P8X1MM_SM_DISCRET | 600OHM | IND_1P8X1MM_SM |
| L9 | INDP_IND_0603_DISCRETE_47NH | 47nH | IND_0603 |
| L10 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L11 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L12 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L13 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L14 | IND_IND2_8_10P2X10P2_A1_1UH | 1uH | IND2_8_10P2X10P2_A1 |
| L15 | BEAD_0_IND_0603_DISCRETE_120OHM | 120OHM | IND_0603 |
| L16 | INDUCTOR_IND_VLS3012_SM_DISCRET | 4.7UH | IND_VLS3012_SM |
| L17 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L19 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L20 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L21 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L22 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L23 | IND_CORE_A_IND2_3P31_XAL5030-60 | 2.2uH | IND2_3P31_XAL5030-601ME |
| L24 | IND_CORE_A_IND2_2P37_4X4_1UH | 1uH | IND2_2P37_4X4 |
| L25 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L26 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L27 | BEAD_0_IND_0603_DISCRETE_120OHM | 120OHM | IND_0603 |
| L28 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L29 | BEAD_0_IND_0603_DISCRETE_120OHM | 120OHM | IND_0603 |
| MH1 | MECH_MH_PL_MH197D126_126MILS | 126MILS | MH197D126 |
| MH2 | MECH_MH_PL_MH197D126_126MILS | 126MILS | MH197D126 |
| MH3 | MECH_MH_PL_MH197D126_126MILS | 126MILS | MH197D126 |
| MH4 | MECH_MH_PL_MH197D126_126MILS | 126MILS | MH197D126 |
| P10 | PROT_ZEN_UNIDIR_DIO_SOD-882_C_A | PESD5V0S1UL | DIO_SOD-882_C_A1 |
| P11 | PROT_ZEN_UNIDIR_DIO_SOD-882_C_A | PESD5V0S1UL | DIO_SOD-882_C_A1 |
| Q1 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q2 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q3 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q4 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q6 | TRANS_PMOS-ENX1_5P_A_QFN8_1P27_ | FDMS6681Z | QFN8_1P27_4P9X5P75_EP_CUST_A1 |
| Q7 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q8 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q9 | TRANS_PMOS-ENX1_5P_A_QFN8_1P27_ | FDMS6681Z | QFN8_1P27_4P9X5P75_EP_CUST_A1 |
| Q10 | TRAN_DUAL_NMOS_BSS138_SOT-363_0 | NX3020NAKS | SOT-363_0P65_SMT |
| Q11 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| Q12 | NMOS_NX3008NBK_SOT23_A_IC_NX300 | NX3008NBK | SOT23_A |
| QZ1 | XTAL_XTAL2-3P2X1P5-SM_IC_32.768 | 32.768KHZ | XTAL2-3P2X1P5-SM |
| SW1 | SW_PB_ESW_SW4G_SPST_6P9X6P2_IC_ | TL6700AF160QG | SW4G_SPST_6P9X6P2 |
| SW2 | SW_DIP4_SW_DIP8_4POS_SM_IC_SWD | SW DIP-4 | SW_DIP8_4POS_SM |
| SW3 | SW_PB_ESW_SW4G_SPST_6P9X6P2_IC_ | TL6700AF160QG | SW4G_SPST_6P9X6P2 |
| TP1 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP2 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP3 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP4 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP5 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP9 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP10 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP11 | T POINTR_TESTPOINT_35MIL_IC_TP | TP_35MIL | TESTPOINT_35MIL |
| U3 | NC7SZ14_SC70-5_IC_74LVC1G04GW | 74LVC1G04GW | SC70-5 |
| U5 | STM6315RDW13F_SOT143-25X60_IC_S | STM6315RDW13F | SOT143-25X60 |
| U6 | 1G125_SC70-5_IC_74AUP1G125GW | 74AUP1G125GW | SC70-5 |
| U7 | MT35XU512ABA1G12_PBGA24_1_6X8MM | MT35XU512ABA1G12-0AATES | PBGA24_1_6X8MM |
| U8 | PF8100_QFN_56P_QFN56_0P5_8P1X8P | PC33PF8100P1ES | QFN56_0P5_8P1X8P1_EP5P1 |
| U9 | IC_SWITCH_SPDT_8P_A_A1_SON8_0P5 | NX3L1G53GT | SON8_0P5_1P95X1_A1 |
| U10 | FXAS21002CQ_QFN_24P_QFN24_0P5_4 | FXAS21002CQ | QFN24_0P5_4X4_ASYM_EXP |
| U11 | MT53B768M32D4NQ_200P_BGA200_0P6 | MT53B768M32D4NQ-062AIT:B | BGA200_0P65X0P8_10P1X14P6 |
| U12 | MX8QXP_609P_FCBGA_609_21X21MM_N | I.MX8QXP | FCBGA_609_21X21MM_NSP |
| U13 | NC7SZ14_SC70-5_IC_74LVC1G04GW | 74LVC1G04GW | SC70-5 |
| U14 | FXOS8700CQ_QFN_16P_QFN5X3_0P5_3 | FXOS8700CQ | QFN5X3_0P5_3X3 |
| U15 | 1G125_SC70-5_IC_74AUP1G125GW | 74AUP1G125GW | SC70-5 |
| U17 | ISL29023_DFN_6_0P65_2P1X2_IC_IS | ISL29023 | DFN_6_0P65_2P1X2 |
| U18 | PPL3115A2_LGA_8P_LGA8_1P25_3X5_ | MPL3115A2 | LGA8_1P25_3X5_0P5 |
| U19 | IC_GATE_NAND-2INX1_5P_A1_TSSOP5 | 74LVC1G38GW | TSSOP5_0P65_2P05X1P25_A1 |
| U21 | 9FGV0241AKLF_24P_QFN24_0P5_4X4_ | 9FGV0241AKILF | QFN24_0P5_4X4_EP2P2 |
| U23 | MTFC32GAKAEEF_TFBGA_169P_FBGA16 | MTFC32GAKAEEF-AIT | FBGA169_0P5_14X18 |
| U24 | NC7WV16_6P_SC70_6LEAD_IC_NC7WV1 | NC7WV16 | SC70_6LEAD |
| U25 | PCA9557PW_TSSOP16_IC_PCA9557PW | PCA9557PW | TSSOP16 |
| U27 | IR3895MTR1PBF_QFN_17P_QFN17_0P6 | IR3895MTRPBF | QFN17_0P65_5X6 |
| U28 | NTS0104PW_14P_TSSOP14_IC_NTS010 | NTS0104PW | TSSOP14 |
| U29 | WM8960_QFN_33P_QFN32_S142EP_IC_ | WM8960 | QFN32_S142EP |
| U30 | AR8031_QFN48_QFN48_0P4_6X6MM_EP | AR8031 | QFN48_0P4_6X6MM_EPAD |
| U31 | NTB0104BQ_DHVQFN14_3X2P5MM_IC_N | NTB0104BQ | DHVQFN14_3X2P5MM |
| U32 | NTB0104BQ_DHVQFN14_3X2P5MM_IC_N | NTB0104BQ | DHVQFN14_3X2P5MM |
| U33 | 1G125_SC70-5_IC_74AUP1G125GW | 74AUP1G125GW | SC70-5 |
| U34 | IC_PUSB3F96_DFN-10P_DFN2510A-10 | IP4292CZ10-TBR | DFN2510A-10L_0P5_2P5X1_A_A1 |
| U35 | IC_PUSB3F96_DFN-10P_DFN2510A-10 | IP4292CZ10-TBR | DFN2510A-10L_0P5_2P5X1_A_A1 |
| U36 | IC_FT2232D_LQFP-48P_A1_LQFP48_0 | FT2232D | LQFP48_0P5_7X7_B_A1 |
| U37 | CBTU02043HEJ_17P_HUQFN16_1P6X2P | CBTU02043 | HUQFN16_1P6X2P4 |
| U38 | IC_PUSB3F96_DFN-10P_DFN2510A-10 | IP4292CZ10-TBR | DFN2510A-10L_0P5_2P5X1_A_A1 |
| U39 | IC_PUSB3F96_DFN-10P_DFN2510A-10 | IP4292CZ10-TBR | DFN2510A-10L_0P5_2P5X1_A_A1 |
| U42 | IC_SWITCHER_16P_EP_P_A1_QFN16_0 | IR3827M | QFN16_0P5_4X5_EP |
| U43 | IC_SWITCHER_16P_EP_P_A1_QFN16_0 | IR3827M | QFN16_0P5_4X5_EP |
| U44 | NX5P3290_16P_BGA16_0P5_2P15X2P1 | NX5P3290 | BGA16_0P5_2P15X2P15 |
| U45 | NX20P5090UK_WLCSP15_0P5_1P57X2P | NX20P5090UK | WLCSP15_0P5_1P57X2P59 |
| U46 | RT9193-33PB_SOT23-5_IC_RT9193 | RT9193 | SOT23-5 |
| U47 | PTN5110_16P_EP_HX2QFN16_0P4_2P7 | PTN5110THQ | HX2QFN16_0P4_2P7X2P7 |
| U144 | IC_GATE_AND-2INX1_6P_A1_SON6_0P | 74AUP1G08GF | SON6_0P35_1P05X1P05 |
| U145 | NC7SZ14_SC70-5_IC_74LVC1G04GW | 74LVC1G04GW | SC70-5 |
| U181 | IC_BD2204_CSP-6P_A1_VCSP50L1-6_ | BD2204GUL | VCSP50L1-6_0P5_1P5X1_A1 |
| U182 | NTB0104BQ_DHVQFN14_3X2P5MM_IC_N | NTB0104BQ | DHVQFN14_3X2P5MM |
| U183 | 74AUP1G08_SC70-5_IC_74AUP1G08GW | 74AUP1G08GW | SC70-5 |
| U184 | IC_GATE_OR-2INX1_5P_B_A1_TSSOP5 | 74AUP1G32GW | TSSOP5_0P65_2P05X1P25_A1 |
| U185 | 1G125_SC70-5_IC_74AUP1G125GW | 74AUP1G125GW | SC70-5 |
| U186 | IC_PUSB3F96_DFN-10P_DFN2510A-10 | IP4292CZ10-TBR | DFN2510A-10L_0P5_2P5X1_A_A1 |
| U187 | PCA9557PW_TSSOP16_IC_PCA9557PW | PCA9557PW | TSSOP16 |
| U188 | NTB0102_8P_XSON_8P_IC_NTB0102GT | NTB0102GT | XSON_8P |
| U190 | NC7WV16_6P_SC70_6LEAD_IC_NC7WV1 | NC7WV16 | SC70_6LEAD |
| U191 | IC_I2C-BUS-EXPANDERX4_16P_TSSOP | PCA9646PW | TSSOP16_0P65_4P4X5 |
| U192 | NC7WV16_6P_SC70_6LEAD_IC_NC7WV1 | NC7WV16 | SC70_6LEAD |
| U194 | NC7WV16_6P_SC70_6LEAD_IC_NC7WV1 | NC7WV16 | SC70_6LEAD |
| U195 | IC_SWITCH_SPDTX2_10P_D_A1_TSSOP | 74LVC2G3157DP | TSSOP10_0P5_3X3_A1 |
| U196 | IC_SWITCH_SPDTX2_10P_D_A1_TSSOP | 74LVC2G3157DP | TSSOP10_0P5_3X3_A1 |
| U197 | IC_SWITCH_SPDTX2_10P_D_A1_TSSOP | 74LVC2G3157DP | TSSOP10_0P5_3X3_A1 |
| U198 | IC_GATE_AND-2INX1_6P_A1_SON6_0P | 74AUP1G08GF | SON6_0P35_1P05X1P05 |
| U199 | IC_GATE_BUFX6_14P_A_A1_TSSOP14_ | MC74LVX50D | TSSOP14_0P65_4P5X5P1_A_A1 |
| U200 | IC_GATE_BUFX6_14P_A_A1_TSSOP14_ | MC74LVX50D | TSSOP14_0P65_4P5X5P1_A_A1 |
| U201 | 1G125_SC70-5_IC_74AUP1G125GW | 74AUP1G125GW | SC70-5 |
| U202 | NC7SZ14_SC70-5_IC_74LVC1G04GW | 74LVC1G04GW | SC70-5 |
| U203 | NTB0102_8P_XSON_8P_IC_NTB0102GT | NTB0102GT | XSON_8P |
| X1 | CRYSTAL_4P_D_XTAL4_2P2_5P2X3P35 | 25MHz | XTAL4_2P2_5P2X3P35 |
| X2 | CRYSTAL_4P_D_XTAL4_2P2_5P2X3P35 | 25MHz | XTAL4_2P2_5P2X3P35 |
| X4 | CRYSTAL_4P_XTAL4_2P54_7X5_A_A1_ | 6MHz | XTAL4_2P54_7X5_A_A1 |
| Y1 | CRYSTAL_XTAL2_3P8_5X3P2_24MHZ | 24MHz | XTAL2_3P8_5X3P2 |
