重要提示:PCB作品文件展下载说明
| Name | PCB Decal | Value | Part Type | | ANAMON1 | T-07 | TEST | T-07 | | ANT1 | ANT | ANT | ANT | | ANT2 | ANT | ANT | ANT | | ANT2701 | ANT | ANT | ANT | | ANT2702 | ANT | ANT | ANT | | ANT2703 | ANT | ANT | ANT | | BAT2 | BAT | LI_3.7V | BAT | | CABC1 | T-07 | TEST | T-07 | | CN19 | CON-FPC-FPC30-T1T1-2021-A | CON30x0.5mm | CON-FPC-FPC30-T1T1-2021-A | | CON2700 | MM8430-2600B | MM8030-2600RJ3 | TST_PORT_0 | | CR9400 | ESD0402 | AZ5825-01F | DIODE_BI_DIR_TRIG | | CR9402 | ESD0402 | ESD5451N | DIODE_BI_DIR_TRIG | | D1 | SOD323 | D1206 | SOD323 | | D2 | D1206 | B5819W | D1206 | | D3 | SOT23 | BAT54S | SOT23 | | D4 | SOD-523 | RB751S-40 | SOD-523 | | D5 | D1206 | 18V | D1206 | | D8 | D1206 | 5.6V | D1206 | | D9 | CMP_419 | DNP/ESD5451X | DIODE_BI-DIR_TRIG | | D11 | CMP_419 | DNP/ESD5451X | DIODE_BI-DIR_TRIG | | D12 | CMP_419 | DNP/ESD5451X | DIODE_BI-DIR_TRIG | | EVCO1 | T-07 | 20MIL | T-07 | | FIL300 | LFB212G45BJ2D721 | LFB212G45BJ2D721 | LFB212G45BJ2D721 | | FIL400 | SAW-5PIN_11_09_05 | SAFFB1G58KF0F0A | SAW-5PIN_11_09_05 | | FIL402 | DPX16 | DPX165950DT-8144A1 | DPX16 | | FIL2701 | SAW-9PIN_2_0_1_6 | SAYFH897MHC0F0A | SAW-9PIN_2_0_1_6 | | FIL2702 | SAW-9PIN_2_0_1_6 | SAYFH1G88CC0B0A | SAW-9PIN_2_0_1_6 | | FIL2703 | SAW-5PIN_1_1_0_9_0_5 | SAFFB1G84FB0F0A | SAW-5PIN_1_1_0_9_0_5 | | FIL2704 | SAW-9PIN_2_0_1_6 | SAYRF1G95HN0F0A | SAW-9PIN_2_0_1_6 | | FIL2705 | SAW-5PIN_1_1_0_9_0_5 | SAFFB881MFL0F0A | SAW-5PIN_1_1_0_9_0_5 | | GNSS_CYCLE1 | T-07 | 20MIL | T-07 | | GNSS_FTA1 | T-07 | 20MIL | T-07 | | J6 | SD_F03 | TF_SD_SOCKET | SD_F03 | | J7 | FPC6PIN | CON6 | CON6_8 | | J8 | UART-2 | CON6 | CON6_1 | | J11 | FPC6PIN | J1 | FPC6PIN | | J12 | VIB-PADA | E-PAD | VIB-PAD | | J2202 | VIB-PADB | SPK-PAD | VIB-PAD | | J6401 | MM8030-2600 | CON4_COAX_2X2_MM4829_2702 | MM8030-2600 | | J7001 | J301-6 | PHONEJACK | J301-6 | | J7089 | C1206 | MIC | C1206 | | J7091 | C1206 | Motor | C1206 | | J9400 | USB-ST-01H5-CA | CON5_USB_MICRO_AB_MTG4 | USB-ST-01H5-CA | | L2 | IND-3X3 | 4.7uH/2A | IND-3X3 | | L61 | L0201 | 0R | INDUCTOR | | L100 | L2016 | VLS201610CX-1R0M | L2016 | | L262 | L0603 | BLM18SG331TN1D | L0603 | | L300 | L0402 | NC | INDUCTOR | | L311 | RES0402 | BLM15AX601SN1 | RES0402 | | L404 | IND0201 | DNP | INDUCTOR | | L405 | RES0201 | 0R | RES0201 | | L408 | IND0402 | 10nH | INDUCTOR | | L533 | L2016 | VLS201610HBX-1R0M | L2016 | | L534 | L2520 | VLS252010HBX-R47M | L2520 | | L540 | IND-4X4 | 10uH/1A | INDCT_PWR_2525_8A_2_0.2UH | | L541 | IND0201 | 10nH | INDUCTOR | | L542 | IND0201 | DNP/10nH | INDUCTOR | | L543 | IND0201 | 0R | INDUCTOR | | L559 | L2520 | VLS252010HBX-R47M | L2520 | | L560 | L2520 | VLS252010HBX-R47M | L2520 | | L2730 | L0201 | 1.2nH/DNP | RESISTOR_5 | | L9000 | SML_4P_43X53_CM_P35H | NC_80OHM_100MHZ | CHOKE_4PIN_ALT | | LEDDRV1 | T-07 | TEST | T-07 | | Q11 | SOT23 | WPM2026 | SOT23 | | Q12 | SOT23 | WPM2431 | SOT23 | | Q316 | SOT23 | WNM2016 | SOT23 | | Q6103 | SOT23 | WNM2016-3/TR | MOSFET_N | | Q6104 | SOT23 | S8050 | NPN | | U4 | SOT26 | TCS3358 | SOT26 | | U6 | QFN10_2R000X2R000X0R850 | DNP | QFN10_2R000X2R000X0R850 | | U402 | SAW-RFDIP1608060TM7T62 | RDALN16 | RFDIP1608060TM7T62 | | U460 | SCL1680-IC | ICN8502 | GSL1680_0 | | U507 | QFN68-7X7 | RK818 | QFN68-7X7 | | U509 | SOT26 | MP1488 | RT8514GJ6_0 | | U510 | 10PIN_DFN_2X2 | MMA8653FC | 10PIN_DFN_2X2 | | U1300 | TMD2771 | TMD27723 | TMD2771 | | U2701 | SKY77589 | SKY77589 | SKY77589 | | U2703 | LCC10_P6MM_NONC_3MMSQ_EP1P5X2P8 | SKY77768 | SKY77768 | | U2704 | LCC10_P6MM_NONC_3MMSQ_EP1P5X2P8 | SKY77761 | SKY77768 | | U4902 | B-168P_12X12 | LPDDR2-32_168 | B-168P_12X12 | | U5602 | INAND_169 | INAND | INAND_169 | | U5702 | TSOP1-48 | NAND_FLASH | TSOP1-48 | | U6501 | SOT23 | ESD5302F | ESD_ESDA6V8UL | | U8401 | IROCK21X21_05PITCH | SOFIA 3G-R ES1.0 | IROCK21X21_05PITCH | | U9012 | CON-FPC-FPC30-T1T12021-A | 30PIN | CON-FPC-FPC30-LCD | | U9018 | A-GOLD620 | A-GOLD620 | A-GOLD620 | | U9019 | CON-FPC-FPC24 | 24PIN | CON-FPC-FPC24 | | VBATMEAS1 | T-07 | TEST | T-07 | | X400 | CRYSTAL_4PIN_2.0_1.6_0.7 | NT2016SA-38.4M-IND3035A | CRY-D2016 | | X800 | CM7V-T1A | 32.768kHz | CM7V-T1A | | Y1 | CRY-MC146 | 32.768K | CRY-MC146 | | Y1501 | CRY4_3R20X2R50X0R80 | 26MHz | CRY4_3R20X2R50X0R80 |
重要提示:PCB作品文件展下载说明
