查看: 2437|回复: 1
[技术文章] STM32——USB详细使用说明 附件HID的双向通信
发表于 2016-3-14 07:00 | 显示全部楼层 |阅读模式
说明:使用的是STM32F103ZET6
硬件原理图
在开始枚举设备的一些初始化
void bsp_USBInit(void)
    GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_USB_PULL_UP, ENABLE);
    USB_CABLE_DISABLE();
    GPIO_InitStructure.GPIO_Pin = PIN_USB_PULL_UP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
      NVIC_InitTypeDef NVIC_InitStructure;
      NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
      NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
      NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
      NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
      NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
      NVIC_Init(&NVIC_InitStructure);
    RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);
    USB_Init();
现在开始分析真正的初始化
第一步:初始化,总线复位及向默认地址 0发送 GET_DESCRIPTOR 指令包,请求设备描述
1)Index[4 - 5]:表示 USB插入总线复位;
2)Index[7 - 8]:表示主机向默认地址发送GET_DESCRIPTOR指令包,详细信
息也抓出来了,如(图二)所示
3)Index[15 - 17]:表示设备向主机发送设备描述数据 Index[16]
4)Index[18 - 19]:表示主机完成 GET_DESCRIPTOR指令后,给设备发送一个
空应答
现在具体的分析103的usb的执行过程 按顺序向下执行
***************(1)**************
DEVICE_INFO *pInformation;
DEVICE_PROP *pProperty;
DEVICE_PROP Device_Property =
    Joystick_init,
    Joystick_Reset,
    Joystick_Status_In,
    Joystick_Status_Out,
    Joystick_Data_Setup,
    Joystick_NoData_Setup,
    Joystick_Get_Interface_Setting,
    Joystick_GetDeviceDescriptor,
    Joystick_GetConfigDescriptor,
    Joystick_GetStringDescriptor,
    0,
    0x40
USER_STANDARD_REQUESTS User_Standard_Requests =
    Joystick_GetConfiguration,
    Joystick_SetConfiguration,
    Joystick_GetInterface,
    Joystick_SetInterface,
    Joystick_GetStatus,
    Joystick_ClearFeature,
    Joystick_SetEndPointFeature,
    Joystick_SetDeviceFeature,
    Joystick_SetDeviceAddress
//USB内核将主机发送过来的用于实现USB设备的设置包保存在设备信息结构表中
typedef struct _DEVICE_INFO
  uint8_t USBbmRequestType;
  uint8_t USBbRequest;
  uint16_t_uint8_t USBwValues;
  uint16_t_uint8_t USBwIndexs;
  uint16_t_uint8_t USBwLengths;
  uint8_t ControlState;
  uint8_t Current_Feature;
  uint8_t Current_Configuration;
  uint8_t Current_Interface;
  uint8_t Current_AlternateSetting;
  ENDPOINT_INFO Ctrl_Info;
}DEVICE_INFO;
usb_init.c文件里面的
void USB_Init(void)
  pInformation = &Device_Info;
  pInformation->ControlState = 2;
  pProperty = &Device_Property;
  pUser_Standard_Requests = &User_Standard_Requests;
  pProperty->Init();
***************(2)**************通过函数指针指向这个初始化函数pProperty 在usb_prop.c文件里面
void Joystick_init(void)
  Get_SerialNum();                                       //得到串行号
  pInformation->Current_Configuration = 0;          //
  PowerOn();                                             //将USB上电 连接设备
  USB_SIL_Init();                                        //主要是CNTR寄存器的初始化
  bDeviceState = UNCONNECTED;                        //设备状态标志 当前状态未连接
hw_config.c文件里面 这个和标准的不一样有改动,获取设备版本号,将其存入到版本号字符串。
void Get_SerialNum(void)   //得到串行号
    uint32_t Device_Serial0, Device_Serial1, Device_Serial2;
    Device_Serial0 = *(__IO uint32_t*)(0x1FFFF7E8);
    Device_Serial1 = *(__IO uint32_t*)(0x1FFFF7EC);
    Device_Serial2 = *(__IO uint32_t*)(0x1FFFF7F0);
    Device_Serial0 += Device_Serial2;
    if (Device_Serial0 != 0)
        IntToUnicode (Device_Serial0, &Joystick_StringSerial[2] , 8);
        IntToUnicode (Device_Serial1, &Joystick_StringSerial[18], 4);
usb_pwr.c文件里面 在这个文件里面只是使能了复位,挂起,唤醒中断,在PowerOn函数使能了复位中断以后,将进入到USB的复位中断里面去。
然后再执行函数USB_SIL_Init 将所有的USB中断都打开。在D+被接通上拉以后,设备就能被主机检测到。
RESULT PowerOn(void)
#ifndef STM32F10X_CL
  uint16_t wRegVal;
USB_Cable_Config(ENABLE);                    //将USB上电连接
//对USB模块强制复位,类似于USB总线上的复位信号。USB模块将一直保持在复位状态下
//直到软件清除此位。如果USB复位中断被使能,将产生一个复位中断。
  wRegVal = CNTR_FRES;                      //强制复位
  _SetCNTR(wRegVal);
  wInterrupt_Mask = 0;
  _SetCNTR(wInterrupt_Mask);                 //清除复位信号
  _SetISTR(0);
//复位中断屏蔽位 挂起中断屏蔽位 唤醒中断屏蔽位使能
  wInterrupt_Mask = CNTR_RESETM | CNTR_SUSPM | CNTR_WKUPM;
#endif
  return USB_SUCCESS;
usb_istr.c文件里面,下面只写了进入到复位中断函数,进入到USB连接状态
void USB_Istr(void)
   wIstr = _GetISTR();
  #if (IMR_MSK & ISTR_RESET)                       //USB复位请求中断
  if (wIstr & ISTR_RESET & wInterrupt_Mask)
    _SetISTR((uint16_t)CLR_RESET);                //清楚复位中断标志
    Device_Property.Reset();                      //进入到复位中断
  #ifdef RESET_CALLBACK
    RESET_Callback();
  #endif
#end
usb_prop.c文件里面,实现对端点的设置。
void Joystick_Reset(void)
  pInformation->Current_Interface = 0;
  pInformation->Current_Feature = Joystick_ConfigDescriptor[7];        //供电模式选择
#ifdef STM32F10X_CL
  OTG_DEV_EP_Init(EP1_IN, OTG_DEV_EP_TYPE_INT, 4);
#else
  SetBTABLE(BTABLE_ADDRESS);                  //分组缓冲区描述表地址设置
  SetEPType(ENDP0, EP_CONTROL);               //初始化为控制端点类型
  SetEPTxStatus(ENDP0, EP_TX_STALL);          //端点以STALL分组响应所有的发送请求。
  //也就是端点状态设置成发送无效,也就是主机的IN令牌包来的时候,回送一个STALL。
  SetEPRxAddr(ENDP0, ENDP0_RXADDR);          //设置端点0描述符的接受地址,
  SetEPTxAddr(ENDP0, ENDP0_TXADDR);           //设置端点0描述符的发送地址
  Clear_Status_Out(ENDP0);
  //仅用于控制端点 如果STATUS_OUT位被清除,OUT分组可以包含任意长度的数据
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize);
  //设置端点0的接受字节寄存器的最大值是64
  SetEPRxValid(ENDP0);                                 //设置接受端点有效
  SetEPType(ENDP1, EP_INTERRUPT);                      //初始化为中断端点类型
  SetEPTxAddr(ENDP1, ENDP1_TXADDR);                    //设置发送数据的地址
  SetEPTxCount(ENDP1, 4);                              //设置发送的长度
  SetEPRxStatus(ENDP1, EP_RX_DIS);                     //设置接受端点关闭
  SetEPTxStatus(ENDP1, EP_TX_NAK);                     //设置发送端点端点非应答
  SetDeviceAddress(0);                                 //设置设备用缺省地址相应
#endif
  bDeviceState = ATTACHED;                          //当前状态连接
usb_sil.c的文件里面,主要是使能了如下这些中断
CNTR_CTRM   正确传输(CTR)中断使能   CNTR_WKUPM 唤醒中断使能
CNTR_SUSPM  挂起(SUSP)中断使能      CNTR_ERRM  出错中断使能
CNTR_SOFM   帧首中断使能            CNTR_ESOFM 期望帧首中断使能CNTR_RESETM 设置此位将向PC主机发送唤醒请求。根据USB协议,如果此位在1ms到15ms内保持有效,主机将对USB模块实行唤醒操作。
uint32_t USB_SIL_Init(void)
  _SetISTR(0);                              //清除中断标志
  wInterrupt_Mask = IMR_MSK;
//这组寄存器用于定义USB模块的工作模式,中断的处理,设备的地址和读取当前帧的编号
  _SetCNTR(wInterrupt_Mask);              //设置相应的控制寄存器
#else
  OTG_DEV_Init();
#endif
  return 0;
***************(3)**************
1.获取设备描述符
usb_int.c的文件里面
低优先级中断  在控制 中断  批量传输下使用(在单缓冲模式下使用)
当一次正确的OUT,SETUP,IN数据传输完成后,硬件会自动设置此位为NAK状态,使应用程序有足够的时间处理完当前传输的数据后,响应下一个数据分组
void CTR_LP(void)
  __IO uint16_t wEPVal = 0;
  while (((wIstr = _GetISTR()) & ISTR_CTR) != 0)
    EPindex = (uint8_t)(wIstr & ISTR_EP_ID);                 //读出端点ID
    if (EPindex == 0)                                         //如果是端点0
        SaveRState = _GetENDPOINT(ENDP0);                    //读取端点0寄存器USB_EP0R
        SaveTState = SaveRState & EPTX_STAT;                 //保存发送状态位
        SaveRState &=  EPRX_STAT;                            //保存接受状态位
        _SetEPRxTxStatus(ENDP0,EP_RX_NAK,EP_TX_NAK);         //端点以NAK分组响应所有的发送和接受请求(解释在上面)
      if ((wIstr & ISTR_DIR) == 0)    //IN令牌,数据被取走
        _ClearEP_CTR_TX(ENDP0);                                 //清除正确发送标志位
        In0_Process();                                          //处理INT事件
        _SetEPRxTxStatus(ENDP0,SaveRState,SaveTState);
        return;
      else
        wEPVal = _GetENDPOINT(ENDP0);                   //得到端点0寄存器的数据
        if ((wEPVal &EP_SETUP) != 0)                    //SETUP分组传输完成标志
          _ClearEP_CTR_RX(ENDP0);
          Setup0_Process();                           //处理SETUP事件
                                                       //程序会进入到这个函数里面
          return;
        else if ((wEPVal & EP_CTR_RX) != 0)
          Out0_Process();                              //处理OUT事件
          return;
    else                                             //如果是除端点0以外的端点
      wEPVal = _GetENDPOINT(EPindex);               //得到相应端点寄存器值
      if ((wEPVal & EP_CTR_RX) != 0)                //检测正确接收标志 PC-USB OUT int
        _ClearEP_CTR_RX(EPindex);                 //清除相应的标志
        (*pEpInt_OUT[EPindex-1])();               //调用OUT int服务功能
      if ((wEPVal & EP_CTR_TX) != 0)               //检测正确发送标志  USB-PC IN int
        _ClearEP_CTR_TX(EPindex);                 //清除相应的标志
        (*pEpInt_IN[EPindex-1])();                 //调用IN int服务功能
usb_coer.c的文件里面,主要是得到主机发来的标准请求命令
uint8_t Setup0_Process(void)
  union
    uint8_t* b;
    uint16_t* w;
  } pBuf;
#ifdef STM32F10X_CL
  USB_OTG_EP *ep;
  uint16_t offset = 0;
  ep = PCD_GetOutEP(ENDP0);
  pBuf.b = ep->xfer_buff;
#else
  uint16_t offset = 1;
                             //得到接受缓冲区地址寄存器地址
  pBuf.b = PMAAddr + (uint8_t *)(_GetEPRxAddr(ENDP0) * 2);
#endif
  if (pInformation->ControlState != PAUSE)
    pInformation->USBbmRequestType = *pBuf.b++;
    pInformation->USBbRequest = *pBuf.b++;
    pBuf.w += offset;
    pInformation->USBwValue = ByteSwap(*pBuf.w++);
    pBuf.w += offset;
    pInformation->USBwIndex  = ByteSwap(*pBuf.w++);
    pBuf.w += offset;
    pInformation->USBwLength = *pBuf.w;
  pInformation->ControlState = SETTING_UP;
  if (pInformation->USBwLength == 0)
    NoData_Setup0();
  else
    Data_Setup0();  //由于是有数据的传输,所有要进入到这个函数
  return Post0_Process();
usb_core.c的文件里面,这里只是选取了GET DESCRIPTOR
的程序部分,其他的部分删除了
void Data_Setup0(void)
  uint8_t *(*CopyRoutine)(uint16_t);
  RESULT Result;
  uint32_t Request_No = pInformation->USBbRequest;
  uint32_t Related_Endpoint, Reserved;
  uint32_t wOffset, Status;
  CopyRoutine = NULL;
  wOffset = 0;
                           //看标准请求码格式就知道了
  if (Request_No == GET_DESCRIPTOR)
     //pInformation->USBbmRequestType是下面的两种 标准请求或设备请求
    if (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT))
      uint8_t wValue1 = pInformation->USBwValue1;   //高一字节得到描述表种类 一共有5种
      if (wValue1 == DEVICE_DESCRIPTOR)             //设备描述
        CopyRoutine = pProperty->GetDeviceDescriptor;
      else if (wValue1 == CONFIG_DESCRIPTOR)
        CopyRoutine = pProperty->GetConfigDescriptor; //配置描述
      else if (wValue1 == STRING_DESCRIPTOR)
        CopyRoutine = pProperty->GetStringDescriptor; //字符串描述
  if (CopyRoutine)
    pInformation->Ctrl_Info.Usb_wOffset = wOffset;  //本子程序的wOffset是0
    pInformation->Ctrl_Info.CopyData = CopyRoutine; //使指针pInformation->Ctrl_Info.CopyData指向CopyRoutine
    (*CopyRoutine)(0);                      //第一次执行时Length=0 返回的是有效数据的长度 存储到pInformation->Ctrl_Info.Usb_wLength
    Result = USB_SUCCESS;
  else
  {                                        //如果标准请求不存在  看类 厂商请求中是否有
    Result = (*pProperty->Class_Data_Setup)(pInformation->USBbRequest);
    if (Result == USB_NOT_READY)
      pInformation->ControlState = PAUSE;
      return;
  if (pInformation->Ctrl_Info.Usb_wLength == 0xFFFF)   //如果字符的长度是0xffff
    return;
  if ((Result == USB_UNSUPPORT) || (pInformation->Ctrl_Info.Usb_wLength == 0))
    pInformation->ControlState = STALLED;
    return;
  if (ValBit(pInformation->USBbmRequestType, 7))                                       //D7表示数据传输方向 1:设备向主机
    __IO uint32_t wLength = pInformation->USBwLength;
    //设置使其为USB主机设置的长度  本程序HID 鼠标  pProperty->MaxPacketSize是0x40
    if (pInformation->Ctrl_Info.Usb_wLength > wLength)                                   //字符的长度大于主机要求的长度
      pInformation->Ctrl_Info.Usb_wLength = wLength;
                                        //将其设置为主机要求的
    else if (pInformation->Ctrl_Info.Usb_wLength < pInformation->USBwLength)                           //字符的长度小于主机要求的
      if (pInformation->Ctrl_Info.Usb_wLength < pProperty->MaxPacketSize)                       //如果字符的长度长度小于每包数据最大字节数
        Data_Mul_MaxPacketSize = FALSE;
      else if ((pInformation->Ctrl_Info.Usb_wLength % pProperty->MaxPacketSize) == 0)  //如果是其整数倍
        Data_Mul_MaxPacketSize = TRUE;
    pInformation->Ctrl_Info.PacketSize = pProperty->MaxPacketSize;
    DataStageIn();
  else                             //主机向设备
    pInformation->ControlState = OUT_DATA;
    vSetEPRxStatus(EP_RX_VALID);
  return;
usb_coer.c的文件里面
void DataStageIn(void)
  ENDPOINT_INFO *pEPinfo = &pInformation->Ctrl_Info;       //端点信息保存在指针变量中
  uint32_t save_wLength = pEPinfo->Usb_wLength;            //得到字符的长度
  uint32_t ControlState = pInformation->ControlState;      //得到当前的状态
  uint8_t *DataBuffer;
  uint32_t Length;
  if ((save_wLength == 0) && (ControlState == LAST_IN_DATA)) //如果字符长度为0 且控制状态是最后输入的数据
    if(Data_Mul_MaxPacketSize == TRUE)         //如果字符的长度是数据包的整数倍
      Send0LengthData();
      ControlState = LAST_IN_DATA;
      Data_Mul_MaxPacketSize = FALSE;          //这一次发送0字节 状态转为最后输入阶段
    else                                      //字符的长度比数据包要小
    {                                          //数据已经发送完
      ControlState = WAIT_STATUS_OUT;
    #ifdef STM32F10X_CL
      PCD_EP_Read (ENDP0, 0, 0);
    #endif
      vSetEPTxStatus(EP_TX_STALL);           //设置端点的发送状态停止
    #endif
    goto Expect_Status_Out;
  Length = pEPinfo-&gtacketSize;              //得到数据包大小 64字节
  ControlState = (save_wLength <= Length) ? LAST_IN_DATA : IN_DATA;//比较大小得到是LAST_IN_DATA还是IN_DATA    18字节<64字节  ControlState = LAST_IN_DATA
  if (Length > save_wLength)
    Length = save_wLength;
  DataBuffer = (*pEPinfo->CopyData)(Length); //DataBuffer指向要复制数据的地址 这个地址是随Usb_wOffset变化的
#ifdef STM32F10X_CL
  PCD_EP_Write (ENDP0, DataBuffer, Length);
#else
                                 //GetEPTxAddr(ENDP0) 得到发送缓冲区相应端点的地址
                                 //将DataBuffer中的数据复制到相应的发送缓冲区中
  UserToPMABufferCopy(DataBuffer, GetEPTxAddr(ENDP0), Length);
#endif
  SetEPTxCount(ENDP0, Length);   //设置相应的端点要发送的字节数
  pEPinfo->Usb_wLength -= Length;//等于0
  pEPinfo->Usb_wOffset += Length;//偏移到18
  vSetEPTxStatus(EP_TX_VALID);  //使能发送端点 只要主机的IN令牌包一来 SIE就会将描述符返回给主机
  USB_StatusOut();
                                //设置接收端点有效 这个实际上使接受也有效,
Expect_Status_Out:
  pInformation->ControlState = ControlState; //保存控制状态
***************(4)**************
uint8_t In0_Process(void)
  if ((ControlState == IN_DATA) || (ControlState == LAST_IN_DATA))//进入到这里
    DataStageIn();//第一次取设备描述符只取一次 当前的状态变为WAIT_STATUS_IN表明设备等待状态过程 主机输出0字节
  else if (ControlState == WAIT_STATUS_IN)            //设置地址状态阶段进入这个程序
    if ((pInformation->USBbRequest == SET_ADDRESS) &&
        (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT)))
      SetDeviceAddress(pInformation->USBwValue0);    //设置使用新的地址
      pUser_Standard_Requests->User_SetDeviceAddress();
    (*pProperty-&gtrocess_Status_IN)();
    ControlState = STALLED;                         //变为这个状态
  else
uint8_t Out0_Process(void)
    //主机在完成传输前终止传输
  else if ((ControlState == OUT_DATA) || (ControlState == LAST_OUT_DATA))
    DataStageOut();
  else if (ControlState == WAIT_STATUS_OUT)    //进入到这个里面
    (*pProperty-&gtrocess_Status_OUT)(); //这个函数其实什么也没做
    ControlState = STALLED;                 //状态变成了终止发送和接受
  #endif
  else
***************(5)**************
获取设备描述符以后,主机再一次的复位设备,设备又进入初始状态。开始枚举的第二步设置地址。
void NoData_Setup0(void)
  RESULT Result = USB_UNSUPPORT;
  uint32_t RequestNo = pInformation->USBbRequest;
  uint32_t ControlState;
  if (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT))              //设备请求
   else if (RequestNo == SET_ADDRESS)                                       /设置地址
     if ((pInformation->USBwValue0 > 127) || (pInformation->USBwValue1 != 0)
         || (pInformation->USBwIndex != 0)
         || (pInformation->Current_Configuration != 0))
       goto exit_NoData_Setup0;
     else
     #ifdef STM32F10X_CL
     #endif
ControlState = WAIT_STATUS_IN;
  USB_StatusIn();//准备好发送0字节的状态数据包 SetEPTxCount(ENDP0, 0);
//vSetEPTxStatus(EP_TX_VALID);建立阶段后直接的进入状态阶段
exit_NoData_Setup0:
  return;
  if ((ControlState == IN_DATA) || (ControlState == LAST_IN_DATA))  //控制状态
    DataStageIn();//第一次取设备描述符只取一次 当前的状态变为WAIT_STATUS_IN 表明设备等待状态过程 主机输出0字节
    ControlState = STALLED;                   //终止发送和接受
  else
uint8_t Post0_Process(void)
#ifdef STM32F10X_CL
  USB_OTG_EP *ep;
#endif
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize);   //设置端点0 要接受的字节数
  if (pInformation->ControlState == STALLED)            //这种状态下只接受SETUP命令包
    vSetEPRxStatus(EP_RX_STALL);                  //终止端点0接受
    vSetEPTxStatus(EP_TX_STALL);                       //终止端点0发送
  return (pInformation->ControlState == PAUSE);
***************(6)*************
从新地址获取设备描述符
  • 打卡总天数:1
  • 打卡总奖励:3
  • 最近打卡:2025-02-25 10:16:29
发表于 2019-6-29 09:54 | 显示全部楼层
