查看: 1318|回复: 0
[资料贡献] spi从机
发表于 2015-12-28 21:36 | 显示全部楼层 |阅读模式
     ****************** name:SPI_Slaver_Driver **************
            ********** author:made by zzuxzt **********
     ****************** time:2014.4.29 **********************
//use SPI 3 mode,CHOL = 1,CHAL = 1
module spi(input clk,
              input rst_n,
              input CS_N,
              input SCK,
              input MOSI,
              input [7:0] txd_data,
              output reg MISO,
              output reg [7:0] rxd_data,
              output rxd_flag);
//-------------------------capture the sck-----------------------------
reg sck_r0,sck_r1;
wire sck_n,sck_p;
always@(posedge clk or negedge rst_n)
begin
    if(!rst_n)
        begin
            sck_r0 <= 1'b1;   //sck of the idle state is high
            sck_r1 <= 1'b1;
        end
    else
        begin
            sck_r0 <= SCK;
            sck_r1 <= sck_r0;
        end
end
assign sck_n = (~sck_r0 & sck_r1)? 1'b1:1'b0;   //capture the sck negedge
assign sck_p = (~sck_r1 & sck_r0)? 1'b1:1'b0;   //capture the sck posedge
//-----------------------spi_slaver read data-------------------------------
reg rxd_flag_r;
reg [2:0] rxd_state;
begin
    if(!rst_n)
        begin
            rxd_data <= 1'b0;
            rxd_flag_r <= 1'b0;
            rxd_state <= 1'b0;
        end
    else if(sck_p && !CS_N)
        begin
            case(rxd_state)
                3'd0:begin
                        rxd_data[7] <= MOSI;
                        rxd_flag_r <= 1'b0;   //reset rxd_flag
                        rxd_state <= 3'd1;
                      end
                3'd1:begin
                        rxd_data[6] <= MOSI;
                        rxd_state <= 3'd2;
                      end
                3'd2:begin
                        rxd_data[5] <= MOSI;
                        rxd_state <= 3'd3;
                      end
                3'd3:begin
                        rxd_data[4] <= MOSI;
                        rxd_state <= 3'd4;
                      end
                3'd4:begin
                        rxd_data[3] <= MOSI;
                        rxd_state <= 3'd5;
                      end
                3'd5:begin
                        rxd_data[2] <= MOSI;
                        rxd_state <= 3'd6;
                      end
                3'd6:begin
                        rxd_data[1] <= MOSI;
                        rxd_state <= 3'd7;
                      end
                3'd7:begin
                        rxd_data[0] <= MOSI;
                        rxd_flag_r <= 1'b1;  //set rxd_flag
                        rxd_state <= 3'd0;
                      end
                default: ;
            endcase
        end
end
//--------------------capture spi_flag posedge--------------------------------
reg rxd_flag_r0,rxd_flag_r1;
begin
    if(!rst_n)
        begin
            rxd_flag_r0 <= 1'b0;
            rxd_flag_r1 <= 1'b0;
        end
    else
        begin
            rxd_flag_r0 <= rxd_flag_r;
            rxd_flag_r1 <= rxd_flag_r0;
        end
end
assign rxd_flag = (~rxd_flag_r1 & rxd_flag_r0)? 1'b1:1'b0;
//---------------------spi_slaver send data---------------------------
reg [2:0] txd_state;
begin
    if(!rst_n)
        begin
            txd_state <= 1'b0;
        end
    else if(sck_n && !CS_N)
        begin
            case(txd_state)
                3'd0:begin
                        MISO <= txd_data[7];
                        txd_state <= 3'd1;
                      end
                3'd1:begin
                        MISO <= txd_data[6];
                        txd_state <= 3'd2;
                      end
                3'd2:begin
                        MISO <= txd_data[5];
                        txd_state <= 3'd3;
                      end
                3'd3:begin
                        MISO <= txd_data[4];
                        txd_state <= 3'd4;
                      end
                3'd4:begin
                        MISO <= txd_data[3];
                        txd_state <= 3'd5;
                      end
                3'd5:begin
                        MISO <= txd_data[2];
                        txd_state <= 3'd6;
                      end
                3'd6:begin
                        MISO <= txd_data[1];
                        txd_state <= 3'd7;
                      end
                3'd7:begin
                        MISO <= txd_data[0];
                        txd_state <= 3'd0;
                      end
                default: ;
            endcase
        end
end
endmodule
