[/free][hide=1,money]
mx6x_.pcb
(8.61 MB, 下载次数: 4)
在发一次飞思卡尔IMX6的硬件。原理图和人PCB,PADS_VX打开
mx6.sch
(2.37 MB, 下载次数: 5)
[/hide][free]
PCB图
原理图
****************以下信息由管理员
@老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
| Name | Part Type | PCB Decal | Value |
| BH2 | SPACER | MH244-147T | SMTSO-M2-2.0ET |
| BT500 | BATTERY_SKT_3V | SKT_BATT_4X8 | 2994TR |
| CON1 | SF7W006S1A | CON_SIM_CD_2P54MM | CON 6 SIM CARD |
| CON2 | CONN_HDR_4X1 | CON_TB_4F_2P5_9X10P5 | CON_1X4 |
| CON4 | CONN_HDR_4X1 | HDR104 | HDR 1X4 |
| CON500 | SM04B | CON_4M_1MM_SM_RA | SM04B-SRSS-TB |
| D9 | DIODE_SCHTKY | SOD123LF | MBR140SFT |
| D10 | DIODE_SCHTKY | SOD323 | NSR0320 |
| D11 | LED | LED_0603 | LED_ORANGE |
| D12 | LED_DUAL_SEP_RG | LED_DUAL_3025MM_SM | LED_RED-GRN |
| D500 | DIODE | DO_VMN2 | RB521CS-30 |
| D501 | DIODE_TVS | SOD-923 | ESD9L5.0ST5G |
| D502 | DIODE | DO214AB_SM | SMLJ60S6 |
| D503 | ZDIODE | SOD123 | MMSZ5231BT1G |
| D504 | DIODE | SOD323 | BAT54HT1 |
| F500 | FUSE | FUSE_3P4X1P8 | 5A/32V |
| J1 | MINI_PCI_LATCH_52P | CON_2X26_0P8_SMT_A | MINI PCI EXPRESS |
| J2 | 3.5MM_AUDIO_JACK | SJ-43514 | Audio Jack |
| J3 | CONN_HDR_3X2 | HDR203 | HDR_2X3 |
| J4 | 3.5MM_AUDIO_JACK | SJ-43514 | Audio Jack |
| J5 | FX12B-40P | CON_BBC_40P_0P4_SM | CONN PLUG 40 |
| J6 | HDR_2X10 | HDR_20M_100_TH | HDR_2X10 |
| J7 | V890-1AX1-A1_14P | CON_RJ45_2X5_TH | V890-1AX1-A1 |
| J8 | CONN_HDMI_19P_TYPE_A | CON_HDMI_19F_20_SM_RA | 10029449-001RLF |
| J9 | FX12B-40P | CON_BBC_40P_0P4_SM | CONN PLUG 40 |
| J10 | CONN_DB9F_MTGTABS | CON_DB_9F_2P74_TH | DB9 |
| J11 | QSH030 | CON_60S_QSH_SM_A | QSH-030-01-L-D-A-K-TR |
| J12 | CONN_UMC_3P_M | CON3_VER_SMT | 128-0711-20 |
| J500 | CONN_SDC013_19P | CON19_SDCARD_28X16_SM | CONN CRD 19 |
| J501 | CONN_HDR_2X1 | HDR102 | HDR 1X2 TH |
| J502 | CON30_DF19G-30P-1H | CON_DF_30F_1MM_SM_RA | CON 30 |
| J503 | CON30_DF19G-30P-1H | CON_DF_30F_1MM_SM_RA | CON 30 |
| J504 | QSH060 | CON_120S_QSH_SM_05PITCH | QSH-060-01-L-D-A |
| J505 | USB_MINI_AB_RECEPTACLE | CON5_MICROUSB_CUST | MICRO USB AB 5 |
| J506 | CONN_SATA_22P | CON_SATA_22F_50_SM_RA_A | 10029364-001LF |
| J507 | CONN_SDC013_19P | CON19_SDCARD_28X16_SM | CONN CRD 19 |
| J508 | QSH060 | CON_120S_QSH_SM_05PITCH | QSH-060-01-L-D-A |
| J509 | USB_MINI_AB_RECEPTACLE | CON5_MICROUSB_CUST | MICRO USB AB 5 |
| L1 | IND | IND_VLCF4018 | 1.2uH |
| L2 | INDUCTOR | IND_VLS252010 | 1UH |
| L9 | INDUCTOR | IND_5015 | 1uH |
| L12 | INDUCTOR_FERRITE_A | IND_LPS4018 | 2.2uH |
| L500 | DLW43 | IND4_CHOKE_0805 | 90OHM |
| L520 | DLW43 | IND4_CHOKE_0805 | 90OHM |
| P1 | DC_POWER_JACK | PJ-202B | CONN PWR 1 |
| Q1 | PNP_DUAL | SOT363 | MBT3906DW1T1 |
| Q2 | 2N7002 | SOT23 | 2N7002 |
| Q3 | MOSFET_P | SOT-23 | IRLML6401 |
| Q4 | 2N7002 | SOT23 | 2N7002 |
| Q5 | MOSFET_P | SOT-23 | IRLML6401 |
| Q500 | FDMS6681Z | SO8_PAK | FDMS6681Z |
| Q502 | NPN | SOT23 | MMBT3904LT1G |
| Q503 | MOSFET_N | SC70_3 | NTS4001NT1G |
| Q504 | 2N7002 | SOT23 | 2N7002 |
| Q506 | MOSFET_P | SOT-23 | IRLML6401 |
| Q507 | 2N7002 | SOT23 | 2N7002 |
| Q512 | MOSFET_2N_CHAN | SC70-6 | BSS138DW-7 |
| QZ500 | XTAL | XTAL2-3P2X1P5-SM | 32.768KHZ |
| SW1 | EDGE_MOUNT_PB_SW_2 | SW_SPST_PB_4P8X3P5_SM | EVQPUA02K |
| SW2 | SW_TACT-SPST-2_SM | SW4_4MM | PB switch |
| SW3 | SW3_RA_SLIDE | SW_SPDT_RA | SW SPDT |
| SW4 | EDGE_MOUNT_PB_SW_2 | SW_SPST_PB_4P8X3P5_SM | EVQPUA02K |
| SW5 | EDGE_MOUNT_PB_SW_2 | SW_SPST_PB_4P8X3P5_SM | EVQPUA02K |
| SW6 | SW_DIP_8 | SW_DIP16_8POS_SM | SW DIP-8 |
| TVS505 | DIODE_TVS_BIDIR | SOD-923_NP | ESD9B3.3ST5G |
| U1 | PCIMX6Q6VV1A | BGA624_0P8_21X21 | iMX6Q |
| U2 | SDRAM_128MX16_96P | BGA96_0P8_9P15X14P15 | MT41J128M16HA-15E |
| U6 | MAX8815A_TDFN_10P | TDFN10_0P5_3P1X3P1 | MAX8815AETB+ |
| U7 | WM8962_BGA_49P_CUST | BGA49_0P5_3P62X4 | WM8962 |
| U8 | MMPF0100NPEP_56P | QFN56_0P5_8X8_EP4P6 | MMPF0100NPEP |
| U9 | LTC3025 | DFN6_2X2MM | LTC3025 |
| U10 | TXB0102 | PSOP8 | TXS0102 |
| U11 | MAX11801_TQFN_12P | QFN12 | MAX11801 |
| U12 | SRV05-4 | SOT23_S6 | SRV05-4 |
| U13 | 1G126 | SOT353 | M74VHC1GT126DF1G |
| U14 | M25P32 | SO8WST | M25P32-VMW6TG |
| U15 | NLSV1T34 | ULLGA6_1P45X1_0P5MM | NLSV1T34 |
| U16 | CM2020_TSSOP_38P | TSSOP38_0P5_4P5X9P8 | CM2020 |
| U17 | ISL29023 | DFN_6_0P65_2P1X2 | ISL29023 |
| U18 | MMA8451Q_16P_A | QFN5X3_0P5_3X3 | MMA8451Q |
| U19 | MODULE_AH-1613 | MODULE_AH-1613 | AH-1613 |
| U20 | MAG3112_DFN_10P | DFN_10_0P4_2X2 | MAG3110 |
| U21 | PPL3115A2_LGA_8P | LGA8_1P25_3X5_0P5 | MPL3115A2 |
| U22 | FT232RQ | QFN32_MC1320X | FT232RQ |
| U500 | NC7SZ125 | SC-70 | NC7SZ125 |
| U501 | WM7230_LGA5 | MIC_LGA5_CAV_4P1X3P1MM | WM7230 |
| U502 | MAX8903A_TQFN_28P | TQFN28_0P4_4X4 | MAX8903 |
| U503 | MAX8903A_TQFN_28P | TQFN28_0P4_4X4 | MAX8903 |
| U504 | 1G125 | SC70-5_A | NC7SP125P5X |
| U505 | NC7SB3157_6P | SC70-6 | NC7SB3157 |
| U506 | NC7SB3157_6P | SC70-6 | NC7SB3157 |
| U507 | 9S08SG8_8P | SO8_1P27_4X5 | S9S08SG8E2MSC |
| U508 | FDC6331L | SSOT6_1P7X3 | FDC6331L |
| U509 | FDC6321C | SOT23-6 | FDC6321C_NL |
| U510 | NC7WZ17 | SC70_6LEAD | NC7WZ17 |
| U511 | 1G125 | SC70-5_A | NC7SP125P5X |
| U512 | SDIN5C2_TFBGA_169P | BGA169_0P5_12X16 | SDIN5C2-8G |
| U513 | 1G125 | SC70-5_A | NC7SP125P5X |
| U514 | NLSV1T34 | ULLGA6_1P45X1_0P5MM | NLSV1T34 |
| U515 | MIC2526_8P | SO8 | MIC2026-1YM |
| U516 | AR8031_QFN48 | QFN48_0P4_6X6MM_EPAD | AR8031 |
| U517 | NLSV1T34 | ULLGA6_1P45X1_0P5MM | NLSV1T34 |
| U518 | TJA1040T_SO_8P | SO8_1P27_4X5 | TJA1040T |
| U519 | SN74LVC2G126DCTR | SSOP8 | SN74LVC2G126 |
| U520 | 100201_SO-1 | SC-70 | NL17SZ126DF |
| U521 | WM7230_LGA5 | MIC_LGA5_CAV_4P1X3P1MM | WM7230 |
| Y1 | XTAL_13Y_A | XTAL4_SX_3225 | 24MHz |
| Y500 | XTAL_13Y | XTAL_4_7P2X5P2 | 25MHZ |
