查看: 2503|回复: 2
[技术文章] 这是STM32F4系列lan 开发的主文件
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2014-11-21 12:31 | 显示全部楼层 |阅读模式
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "lwip_comm.h"
#include "LAN8720.h"
#include "usmart.h"
#include "timer.h"
#include "lcd.h"
#include "adc.h"
#include "rtc.h"
#include "sram.h"
#include "malloc.h"
#include "beep.h"
#include "tcp_client_demo.h"
#include "tcp_server_demo.h"
#include "udp_demo.h"
#include "httpd.h"
//加载UI
//mode:
//bit0:0,不加载;1,加载前半部分UI
//bit1:0,不加载;1,加载后半部分UI
void lwip_test_ui(u8 mode)
    u8 speed;
    u8 buf[30];
    POINT_COLOR=RED;
    if(mode&1<<0)
        LCD_Fill(30,30,lcddev.width,110,WHITE);    //清除显示
        LCD_ShowString(30,30,200,16,16,"Explorer STM32F4");
        LCD_ShowString(30,50,200,16,16,"Ethernet lwIP Test");
        LCD_ShowString(30,70,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,90,200,16,16,"2014/8/15");
    if(mode&1<<1)
        LCD_Fill(30,110,lcddev.width,lcddev.height,WHITE);    //清除显示
        LCD_ShowString(30,110,200,16,16,"lwIP Init Successed");
        if(lwipdev.dhcpstatus==2)sprintf((char*)buf,"DHCP IP:%d.%d.%d.%d",lwipdev.ip[0],lwipdev.ip[1],lwipdev.ip[2],lwipdev.ip[3]);//打印动态IP地址
        else sprintf((char*)buf,"Static IP:%d.%d.%d.%d",lwipdev.ip[0],lwipdev.ip[1],lwipdev.ip[2],lwipdev.ip[3]);//打印静态IP地址
        LCD_ShowString(30,130,210,16,16,buf);
        speed=LAN8720_Get_Speed();//得到网速
        if(speed&1<<1)LCD_ShowString(30,150,200,16,16,"Ethernet Speed:100M");
        else LCD_ShowString(30,150,200,16,16,"Ethernet Speed:10M");
        LCD_ShowString(30,170,200,16,16,"KEY0:TCP Server Test");
        LCD_ShowString(30,190,200,16,16,"KEY1:TCP Client Test");
        LCD_ShowString(30,210,200,16,16,"KEY2:UDP Test");
int main(void)
    u8 t;
    u8 key;
    Stm32_Clock_Init(336,8,2,7);//设置时钟,168Mhz
    delay_init(168);            //延时初始化
    uart_init(84,115200);        //初始化串口波特率为115200
    usmart_dev.init(84);        //初始化USMART
    LED_Init();                  //LED初始化
    KEY_Init();                  //按键初始化
    LCD_Init();                 //LCD初始化
    BEEP_Init();                //蜂鸣器初始化
    RTC_Init();                  //RTC初始化
    Adc_Init();                  //ADC初始化
    TIM3_Int_Init(100-1,8400-1);//10khz的频率,计数100为10ms
    my_mem_init(SRAMIN);        //初始化内部内存池
    my_mem_init(SRAMCCM);        //初始化CCM内存池
    POINT_COLOR=RED;             //红色字体
    lwip_test_ui(1);            //加载前半部分UI
    //先初始化lwIP(包括LAN8720初始化),此时必须插上网线,否则初始化会失败!!
    LCD_ShowString(30,110,200,16,16,"lwIP Initing...");
    while(lwip_comm_init()!=0)
        LCD_ShowString(30,110,200,16,16,"lwIP Init failed!");
        delay_ms(1200);
        LCD_Fill(30,110,230,110+16,WHITE);//清除显示
        LCD_ShowString(30,110,200,16,16,"Retrying...");
    //等待DHCP获取
     LCD_ShowString(30,130,200,16,16,"DHCP IP configing...");
    while((lwipdev.dhcpstatus!=2)&&(lwipdev.dhcpstatus!=0XFF))//等待DHCP获取成功/超时溢出
        lwip_periodic_handle();
    lwip_test_ui(2);//加载后半部分UI
    httpd_init();    //HTTP初始化(默认开启websever)
    while(1)
        key=KEY_Scan(0);
        switch(key)
            case KEY0_PRES://TCP Server模式
                tcp_server_test();
                 lwip_test_ui(3);//重新加载UI
                break;
            case KEY1_PRES://TCP Client模式
                tcp_client_test();
                break;
            case KEY2_PRES://UDP模式
                udp_demo_test();
                break;
        delay_ms(2);
        t++;
        if(t==100)LCD_ShowString(30,230,200,16,16,&quotlease choose a mode!");
        if(t==200)
            t=0;
            LCD_Fill(30,230,230,230+16,WHITE);//清除显示
            LED0=!LED0;
  • 打卡总天数:2
  • 打卡总奖励:9
  • 最近打卡:2025-10-03 08:40:46
社区居民忠实会员社区劳模最爱沙发优秀斑竹奖终身成就奖
发表于 2014-11-21 13:04 | 显示全部楼层
广告位出租,价格可以商量。
  • 打卡总天数:7
  • 打卡总奖励:26
  • 最近打卡:2025-11-10 15:56:06
29
发表于 2023-3-7 08:30 | 显示全部楼层
