| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| B1 | BEEP_HC12085P_HC12085P_BEEP_HC1 | BEEP_HC12085P | HC12085P |
| BEAD1 | FB_L1812_FBMH4532HM132-T | FBMH4532HM132-T | L1812 |
| D1 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D2 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D3 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D4 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D5 | DIODE13_0_SOD123_MBR0520_SOD123 | MBR0520_SOD123 | SOD123 |
| D6 | DIODE13_0_SOD123_MBR0520_SOD123 | MBR0520_SOD123 | SOD123 |
| D7 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D8 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D9 | D SCHOTTKY_SOD123_MBR0520_SOD12 | MBR0520_SOD123 | SOD123 |
| D10 | D SCHOTTKY_SOD123_MBR0520_SOD12 | MBR0520_SOD123 | SOD123 |
| D11 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D12 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D13 | D SCHOTTKY_SOD123_MBR0520_SOD12 | MBR0520_SOD123 | SOD123 |
| J1 | CONN RCPT 32X2_HEADER32X2_CONN | CONN RCPT 32x2 | HEADER32X2 |
| J2 | CONN RCPT 17X2_1_TFTLCD_3R5_TFT | TFTLCD | TFTLCD_3R5 |
| J3 | CON20_3_HEADER10X2_DIP2/10/2.54 | DIP2/10/2.54MM | HEADER10X2 |
| J4 | CONN RCPT 11X2_HEADER11X2_CONN | CONN RCPT 11x2 | HEADER11X2 |
| J5 | CONN RCPT 9X2_OV2640_OV7620 | OV7620 | OV2640 |
| J6 | CONN RCPT 7X2_HEADER7X2_CONN RC | CONN RCPT 7x2 | HEADER7X2 |
| J7 | CONN RCPT 7X2_HEADER7X2_CONN RC | CONN RCPT 7x2 | HEADER7X2 |
| J8 | CONN RCPT 6X2_HEADER6X2_CONN RC | CONN RCPT 6X2 | HEADER6X2 |
| J9 | HR911105A_HR911105A_HR911105A | HR911105A | HR911105A |
| J10 | CONN RCPT 3_POWER3A_CONN RCPT 3 | CONN RCPT 3 | POWER3A |
| J11 | CONN PLUG 2_0_POWER2A_CAN | CAN | POWER2A |
| J12 | CONN PLUG 2_0_POWER2A_RS485 | RS485 | POWER2A |
| L1 | IND_BEAD_0805_600OHM_200MA_LC08 | BEAD_BLM21PG600 | LC0805 |
| L2 | IND_BEAD_0805_600OHM_200MA_LC08 | BEAD_BLM21PG600 | LC0805 |
| L3 | IND_BEAD_0805_600OHM_200MA_LC_1 | BEAD_BLM18PG600_0805 | LC0805 |
| MH1 | HOLD_1_HOLD250D134_HOLD | Hold | HOLD250D134 |
| MH2 | HOLD_1_HOLD250D134_HOLD | Hold | HOLD250D134 |
| MH3 | HOLD_1_HOLD250D134_HOLD | Hold | HOLD250D134 |
| MH4 | HOLD_1_HOLD250D134_HOLD | Hold | HOLD250D134 |
| MP1 | MARKPOINT_MARKPOINT_R3_MARKPOIN | MarkPoint | MARKPOINT_R3 |
| MP2 | MARKPOINT_MARKPOINT_R3_MARKPOIN | MarkPoint | MARKPOINT_R3 |
| Q1 | L14G1/TO_1_SOT23_123_S8050_SOT2 | S8050_SOT23_NPN | SOT23_123 |
| Q2 | L14G1/TO_1_SOT23_123_S8050_SOT2 | S8050_SOT23_NPN | SOT23_123 |
| RP1 | RESISTOR VAR_0_VISHAY_RES_VAR_6 | 10K | VISHAY_RES_VAR_64W |
| SW1 | SWITCH-SPST-4P_SW-6X6X6-L_KEY1 | KEY1 | SW-6X6X6-L |
| SW2 | SWITCH-SPST-4P_SW-6X6X6-L_RESET | RESET | SW-6X6X6-L |
| SW3 | SWITCH-SPST-4P_SW-6X6X6-L_KEY2 | KEY2 | SW-6X6X6-L |
| SW4 | SWITCH-SPST-4P_SW-6X6X6-L_KEY3 | KEY3 | SW-6X6X6-L |
| SW5 | SWITCH_3P_SWITCH_3P_SWITCH_3P | SWITCH_3P | SWITCH_3P |
| T1 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T2 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T3 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T4 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| TP1 | TESTPOINT_0_TP-0R75_TESTPOINT | TestPoint | TP-0R75 |
| U1 | IS61LV25626_0_TSOP-44_IS62WV512 | IS62WV51216 | TSOP-44 |
| U2 | K60_LQFP144_MK60DN512VLQ10 | MK60DN512VLQ10 | LQFP144 |
| U3 | SP706T_0_SOIC8_SP706REN | SP706REN | SOIC8 |
| U4 | BATTERY_CR1220_BATTERY | BATTERY | CR1220 |
| U5 | KSZ8041NL_MLF-32_KSZ8041NL | KSZ8041NL | MLF-32 |
| U6 | ADXL345_1_LGA-14_ADXL345 | ADXL345 | LGA-14 |
| U7 | AT24C512_0_SOIC8_AT24C512 | AT24C512 | SOIC8 |
| U8 | NRF24L01PACK_NRF24L01PACK_NRF24 | NRF24L01PACK | NRF24L01PACK |
| U9 | LM2904QDR_SOIC8_LM2904QDR | LM2904QDR | SOIC8 |
| U10 | W25Q64_0_SOIC16W_W25Q128FVFG | W25Q128FVFG | SOIC16W |
| U11 | TFCARD_1_TFCARD_TFCARD | TFCARD | TFCARD |
| U12 | TJA1050_SOIC8_TJA1050T/CM | TJA1050T/CM | SOIC8 |
| U13 | MAX3485ESA_0_SOIC8_MAX3485ESA | MAX3485ESA | SOIC8 |
| U14 | CP2102_QFN-28_CP2102 | CP2102 | QFN-28 |
| U15 | TPS7133_0_SOIC8_TPS76833Q | TPS76833Q | SOIC8 |
| USB1 | USB-MICRO_USB-MICRO_USB-MICRO | USB-MICRO | USB-MICRO |
| USB2 | USB-MICRO_USB-MICRO_USB-MICRO | USB-MICRO | USB-MICRO |
| USB3 | USB-A_0_USB-A_USB-A | USB-A | USB-A |
| X1 | XTAL_5032_0_X-2P-3R2X1R5-SMD_XT | XTAL_32768Hz_3215 | X-2P-3R2X1R5-SMD |
| Y1 | SMD_OSC_3_OSC7X5_SG7050CAN-50M- | SG7050CAN-50M-TJGA | OSC7X5 |
