| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BA1 | INDUCTOR_0_L0603_600R@100M | 600R@100M | L0603 |
| BA2 | INDUCTOR_0_L0603_600R@100M | 600R@100M | L0603 |
| D1 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D2 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D3 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D4 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D5 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D6 | DIO-XBS104S14_SOD155_270H118_XB | XBS104S14 | SOD155_270H118 |
| D7 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D8 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D9 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D10 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D11 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D12 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| D13 | DIO-1N4148_SOD130_264H140_1N414 | 1N4148 | SOD130_264H140 |
| DA1 | ESD9B5VL_0_ESD0402_ESD5451X-2/T | ESD5451X-2/TR/NC | ESD0402 |
| DA2 | ESD9B5VL_0_ESD0402_ESD5451X-2/T | ESD5451X-2/TR/NC | ESD0402 |
| DA3 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA4 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA5 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA6 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA7 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA8 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA9 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA10 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA11 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA12 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DA13 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA14 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA15 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA16 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA17 | ESD9B5VL_0_ESD0402_ESD5451X-2_1 | ESD5451X-2/TR | ESD0402 |
| DA18 | ESD9B5VL_0_ESD0201_PESDEC2XD5VB | PESDEC2XD5VBF | ESD0201 |
| DC1 | ESD9B5VL_ESD0402_NC/PT2C051N | NC/PT2C051N | ESD0402 |
| DC2 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DC3 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DC4 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DC5 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DC6 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DC7 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DC8 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DL1 | D_1_SOD180_270H110_DSK24 | DSK24 | SOD180_270H110 |
| DL2 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL3 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL4 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL5 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL6 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL7 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DL8 | ESD9B5VL_ESD0201_PESDEC2XD5VBF | PESDEC2XD5VBF | ESD0201 |
| DL9 | ESD9B5VL_ESD0201_PESDEC2XD5VBF | PESDEC2XD5VBF | ESD0201 |
| DP1 | DIODE SCHOTTKY_1_DFN3P130B200_2 | PTVSHC3N4V5B | DFN3P130B200_200H65 |
| DP2 | LED-0805-G_LED0402_LED-0402-G/N | LED-0402-G/NC | LED0402 |
| DP3 | D_1_SOD155_270H118_DSK24 | DSK24 | SOD155_270H118 |
| DU1 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU2 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DU3 | ESD9B5VL_ESD0402_PT2C051U | PT2C051U | ESD0402 |
| DU4 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU6 | DIODE SCHOTTKY_1_DFN3P130B200_1 | PTVSHC3N18VU | DFN3P130B200_200H65 |
| DU7 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU8 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU9 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU10 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU11 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| DU12 | ESD9B5VL_ESD0402_PT2C051N | PT2C051N | ESD0402 |
| FID1 | T POINT R_2_FIDICALMARK_MARK_ | MARK | FIDICALMARK |
| FID2 | T POINT R_2_FIDICALMARK_MARK_ | MARK | FIDICALMARK |
| FID3 | T POINT R_2_FIDICALMARK_MARK_ | MARK | FIDICALMARK |
| FID4 | T POINT R_2_FIDICALMARK_MARK_ | MARK | FIDICALMARK |
| H1 | CONN PWR 2-J_0_KEZI_HOLE-C9 | HOLE-C9 | KEZI |
| H2 | CONN PWR 2-J_0_KEZI_HOLE-C9 | HOLE-C9 | KEZI |
| H3 | CONN PWR 2-J_0_KEZI_HOLE-C9 | HOLE-C9 | KEZI |
| H4 | CONN PWR 2-J_0_KEZI_HOLE-C9 | HOLE-C9 | KEZI |
| H5 | CONN PWR 2-J_0_KEZI_HOLE-C9 | HOLE-C9 | KEZI |
| J1 | CLAP070LF02CW_5_FPC6-0_3-2_5X4_ | FPC6-0_3-2_5X4_5H1_0L | FPC6-0_3-2_5X4_5H1_0L |
| J2 | CLAP070LF02CW_13_FPC6-0_3-2_5X4 | CON6 | FPC6-0_3-2_5X4_5H1_0L |
| J3 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J4 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J5 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J6 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J7 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J8 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J9 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J10 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J11 | MOTOR AC_0_WF_080_2P_MOTOR AC | MOTOR AC | WF_080_2P |
| J12 | CLAP070LF02CW_13_FPC6-0_3-2_5X4 | CON6 | FPC6-0_3-2_5X4_5H1_0L |
| J13 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| J14 | CON5_CA0103021-R_CON5 | CON5 | CA0103021-R |
| JA1 | CONN RCPT 1_1_WF_080_2P_MIC/NC | MIC/NC | WF_080_2P |
| JA2 | CONN RCPT 1_1_WF_080_2P_MIC | MIC | WF_080_2P |
| JA3 | CONN RCPT 1_1_WF_080_2P_SPK | SPK | WF_080_2P |
| JA4 | CONN RCPT 1_1_WF_080_2P_SPK | SPK | WF_080_2P |
| JA5 | CONN RCPT 1_1_WF_080_2P_SPK | SPK | WF_080_2P |
| JA6 | CONN RCPT 1_1_WF_080_2P_SPK | SPK | WF_080_2P |
| JA7 | CLAP070LF02CW_5_FPC6-0_3-2_5X4_ | FPC6-0_3-2_5X4_5H1_0L | FPC6-0_3-2_5X4_5H1_0L |
| JC1 | CLAP070LF02CW_6_FH26-21S_FPC-21 | FPC-21P-0.3MM | FH26-21S |
| JL1 | CON51PIN_CTP_1_45PIN_UD_FPC_863 | CON45PIN_LCM | 45PIN_UD_FPC_863 |
| JP1 | J_BAT_CON-R5S-P1_3-H1_5-R_5P_1. | 5P_1.25MM | CON-R5S-P1_3-H1_5-R |
| JP2 | J_BAT_TS_BAT_SMD-3_NC/J_BAT_TS | NC/J_BAT_TS | BAT_SMD-3 |
| JU1 | CLAP070LF02CW_0_FH26-31S_CON31 | CON31 | FH26-31S |
| JV1 | HEADER 31_0_FH26-31S_HEADER 31_ | HEADER 31_0 | FH26-31S |
| JV2 | FPC-39P-0.3MM_PFC41P60B13500_35 | FPC-39P-0.3MM | PFC41P60B13500_350H100 |
| JV3 | FPC-21P-0.3MM_FH26-21S_FPC-21P- | FPC-21P-0.3MM | FH26-21S |
| JW1 | ANT-IPX_2_RF-CD-ARF003-P01A-PAD | ANT-IPX | RF-CD-ARF003-P01A-PAD10 |
| JW2 | ANT-IPX_2_RF-CD-ARF003-P01A-PAD | ANT-IPX | RF-CD-ARF003-P01A-PAD10 |
| K1 | MTP1112E_0_KEY_3X3_UPDATA_ | UPDATA | KEY_3X3 |
| LL1 | INDUCTOR_LP400_400H180_4.7UH@2A | 4.7uH@2A DCR<0.1R | LP400_400H180 |
| LL2 | INDUCTOR_LP400_400H180_10UH@1A | 10uH@1A DCR<0.1R | LP400_400H180 |
| LP1 | INDUCTOR_LP200_250H100_1UH-4A | 1uH-4A | LP200_250H100 |
| LP2 | INDUCTOR_LP200_250H100_0.33UH-5 | 0.33uH-5A | LP200_250H100 |
| LP3 | INDUCTOR_LP200_250H100_0.33UH-5 | 0.33uH-5A | LP200_250H100 |
| LP4 | INDUCTOR_LP200_250H100_0.47UH-5 | 0.47uH-5A | LP200_250H100 |
| LP5 | INDUCTOR_LP200_250H100_0.47UH-5 | 0.47uH-5A | LP200_250H100 |
| LP6 | INDUCTOR_LP200_250H100_1UH-4A | 1uH-4A | LP200_250H100 |
| LP7 | INDUCTOR_LP200_250H100_1UH-4A | 1uH-4A | LP200_250H100 |
| LP8 | INDUCTOR_LP200_250H100_1UH-4A | 1uH-4A | LP200_250H100 |
| LP9 | INDUCTOR_LP200_250H100_1UH-4A | 1uH-4A | LP200_250H100 |
| LP10 | L-L3225_LP200_250H100_1UH-3A/1U | 1uH-3A/1uH-5A | LP200_250H100 |
| LP11 | L_4012_LP200_250H100_4.7UH/2A | 4.7uH/2A | LP200_250H100 |
| LP16 | L-L2520_LP200_250H100_2.2UH-2A | 2.2uH-2A | LP200_250H100 |
| LU1 | ICMS212B900MFR_0_LC4B120_200H12 | NC/CMF0806UD900MFR | LC4B120_200H120 |
| LW1 | INDUCTORS OF FERRITE_L0603_4.7U | 4.7uH | L0603 |
| LW2 | INDUCTORS OF FERRITE_LP200_250H | NC/2.2uH | LP200_250H100 |
| LW3 | INDUCTOR_L0201_1.4NH | 1.4nH | L0201 |
| LW4 | INDUCTOR_L0201_1.2NH | 1.2nH | L0201 |
| LW5 | INDUCTOR_L0201_1.5NH | 1.5nH | L0201 |
| QC1 | PMOS-STS2301_SOT3P95B130_290H10 | STS2301 | SOT3P95B130_290H103 |
| QV1 | MOSFET N_SOT23_SI2300 | SI2300 | SOT23 |
| U1 | A733-V1.0_BGA570P40_50B1500_150 | A733 | BGA570P40_50B1500_1500H95 |
| U2 | ICM-42670-P_LGA14P50B250_300H81 | QMI8658A/ICM-42670-P | LGA14P50B250_300H81 |
| U5 | AK09918C_BGA4P40B82_82H57_MMC56 | MMC5603NJ | BGA4P40B82_82H57 |
| U7 | MC3433_LGA12P50B200_200H100_DA2 | DA215S/MC3433 | LGA12P50B200_200H100 |
| UA1 | AC101&AC101B V0.2_QFN40P0_40B5_ | AC101 | QFN40P0_40B5_00X5_00H0_75 |
| UA2 | AW87391_BGA16P50B200_250H55_AW8 | AW87391 | BGA16P50B200_250H55 |
| UA3 | AW87391_BGA16P50B200_250H55_AW8 | AW87391 | BGA16P50B200_250H55 |
| UA4 | AW87391_BGA16P50B200_250H55_AW8 | AW87391 | BGA16P50B200_250H55 |
| UA5 | AW87391_BGA16P50B200_250H55_AW8 | AW87391 | BGA16P50B200_250H55 |
| UA6 | AC107S_STANDARD_0_QFN20P40B300_ | AC107 | QFN20P40B300_300H75 |
| UD1 | LPDDR5_FBGA315_BGA315P70_80B150 | LPDDR5_FBGA315 | BGA315P70_80B1500_1240H110 |
| UL1 | UPC8236T6N_2_BGA15P40B144_200H6 | OCP2131WPAD-G | BGA15P40B144_200H63 |
| UL2 | AP3031_0_SOT23-6_STI9287C | STI9287C | SOT23-6 |
| UM2 | UFS_0_BGA153P50B1150_1300H90_(S | UFS | BGA153P50B1150_1300H90 |
| UP1 | AXP318-WBBGA_BGA147P50B800_800H | AXP318-WBBGA | BGA147P50B800_800H113 |
| UP2 | BCT72901_FCQFN12P40B130_180H55_ | BCT72905/AW3291X | FCQFN12P40B130_180H55 |
| UP3 | LP6216_SOT6P95B160_290H145_LP62 | LP6216 | SOT6P95B160_290H145 |
| UP4 | AW1760_6_QFN41P40B500_500H85_AX | AXP515 | QFN41P40B500_500H85 |
| UP5 | HUSB311_BGA9P40B135_140H58_NC/H | NC/HUSB311 | BGA9P40B135_140H58 |
| UP11 | SY8089A_SOT5P95B160_300H130_NC/ | NC/SY8089A1AAC | SOT5P95B160_300H130 |
| UU1 | SY6280_SOT23-5_WS4603E | WS4603E | SOT23-5 |
| UU2 | WAS4766C_BGA9P40B117_117H58D5_W | WAS4766C | BGA9P40B117_117H58D5 |
| UU3 | SGM7237B_QFN10P40B140_180H55_SG | SGM7237B | QFN10P40B140_180H55 |
| UV1 | SGM3141_0_DFN11P50B300_300H75_S | SGM3141B | DFN11P50B300_300H75 |
| UW1 | DPX_1_DPX6P50B60_160H80_SLFD18- | SLFD18-5R950G-07T | DPX6P50B60_160H80 |
| UW2 | MODULE_AP6XXX_0_SUB_WIFI44B1200 | AW8X9X | SUB_WIFI44B1200_1200H150 |
| UW3 | AIC8800D80_0_QFN49P35B500_500H8 | AIC8800D80 | QFN49P35B500_500H85 |
| Y1 | CRY-24MHZ-3225-SMD_X4B250_320H1 | 24M/19.2M/26M-20pF-10ppm | X4B250_320H120_SMD |
| Y2 | CRY-32_0.768KHZ-2X6-DIP_X2B150_ | 32.768K-12.5pF-20ppm | X2B150_320H75_SMD |
| YW1 | CRYSTAL_1_X4B165_205H45_SMD_40M | 40MHz | X4B165_205H45_SMD |
