REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
B1 | L_1_L0402_UPZ1005D100-2R0TF | UPZ1005D100-2R0TF | L0402 |
B2 | L_1_L0402_UPZ1005D100-2R0TF | UPZ1005D100-2R0TF | L0402 |
D1 | LED_GREEN_D0603_LED_RED | LED_RED | D0603 |
D2 | TRISIL_BIDIR_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D3 | TRISIL_BIDIR_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D4 | LED_GREEN_D0603_GREEN | Green | D0603 |
D5 | LED_GREEN_D0603_GREEN | Green | D0603 |
D6 | LED_GREEN_D0603_GREEN | Green | D0603 |
D7 | TRISIL_BIDIR_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D8 | TRISIL_BIDIR_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D9 | LED_GREEN_D0603_LED_RED | LED_RED | D0603 |
D10 | VS3V3BC1HS-E_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D11 | VS3V3BC1HS-E_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D12 | VS3V3BC1HS-E_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D13 | VS3V3BC1HS-E_D0201_VS3V3BC1HS-E | vs3v3bc1hs-e | D0201 |
D14 | LED_GREEN_D0603_LED_BLUE | LED_BLUE | D0603 |
H1 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
H2 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
H3 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
H4 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
H5 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
H6 | HOLE_HOLE126P_HOLE | Hole | HOLE126P |
J1 | SSMA-KWHD3_CON10-9R5X17R1-N_SMA | SMA-JHD | CON10-9R5X17R1-N |
J3 | SSMA-KWHD3_CON10-9R5X17R1-N_SMA | SMA-JHD | CON10-9R5X17R1-N |
J4 | SSMA-KWHD3_CON10-9R5X17R1-N_MCX | MCX-KHD-P | CON10-9R5X17R1-N |
J6 | SSMA-KWHD3_CON10-9R5X17R1-N_SMA | SMA-JHD | CON10-9R5X17R1-N |
J7 | SSMA-KWHD3_CON10-9R5X17R1-N_MCX | MCX-KHD-P | CON10-9R5X17R1-N |
J8 | POWER_CON_2X2_DIP_2X2_5569_04A2 | 39301040 | DIP_2X2_5569_04A2 |
J9 | 2MM_1X4_CON21VP2R00-4TM-55932_2 | 2mm_1x4 | CON21VP2R00-4TM-55932 |
J10 | KHS02E_1_KSS42S_KHS04E | KHS04E | KSS42S |
J11 | 67503-1020_CON50SM-5-7R7X7R7-N_ | Mini_USB-SD67503-010 | CON50SM-5-7R7X7R7-N |
J13 | 2MM_1X4_CON20VP2R54-1X4TM-0R8-W | CON20VP2R54-1X4TM-0R8-W | CON20VP2R54-1X4TM-0R8-W |
J14 | MM4829-2700_0_U_FL_R_SMT_U.FL-R | U.FL-R-SMT/NC | U_FL_R_SMT |
J15 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J16 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J17 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J18 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J19 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J20 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J21 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J22 | MM4829-2700_0_U_FL_R_SMT_U.FL_1 | U.FL-R-SMT | U_FL_R_SMT |
J23 | KHS02E_1_KSS42S_KHS04E | KHS04E | KSS42S |
J24 | SSMA-KWHD3_CON10-9R5X17R1-N_SMA | SMA-JHD | CON10-9R5X17R1-N |
J25 | SSMA-KWHD3_CON10-9R5X17R1-N_MCX | MCX-KHD-P | CON10-9R5X17R1-N |
J26 | SSMA-KWHD3_0_D550B12E_SMA/D550B | SMA/D550B12E03-023 | D550B12E |
J27 | SSMA-KWHD3_0_D550B12E_SMA/D550B | SMA/D550B12E03-023 | D550B12E |
L1 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L2 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L3 | INDUCTOR_L0603_LQW18ANR33G00D | LQW18ANR33G00D | L0603 |
L5 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L22 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L23 | INDUCTOR_L0603_82NH | 82nH | L0603 |
L24 | INDUCTOR_L0603_82NH | 82nH | L0603 |
L25 | INDUCTOR_L0603_LQW18ANR33G00D | LQW18ANR33G00D | L0603 |
L26 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L27 | L_1_L0603_BLM18PG471SN1 | BLM18PG471SN1 | L0603 |
L28 | INDUCTOR_L0402_HCB1005KF-100T20 | HCB1005KF-100T20 | L0402 |
L29 | INDUCTOR_L0603_82NH | 82nH | L0603 |
L30 | INDUCTOR_L0603_82NH | 82nH | L0603 |
L31 | INDUCTOR_L0603_82NH | 82nH | L0603 |
L32 | INDUCTOR_L0603_82NH | 82nH | L0603 |
LED1 | LED_SMT_0_LED_SMT_0603_SMD-0603 | SMD-0603-3.3V-green | LED_SMT_0603 |
LED2 | LED_SMT_1_LED_SMT_0603_SMD-0603 | SMD-0603-3.3V-green | LED_SMT_0603 |
LED3 | LED_SMT_1_LED_SMT_0603_SMD-0603 | SMD-0603-3.3V-green | LED_SMT_0603 |
LED4 | LED_SMT_1_LED_SMT_0603_SMD-0603 | SMD-0603-3.3V-green | LED_SMT_0603 |
M1 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
M2 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
M3 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
M4 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
M5 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
M6 | HOLE_2_6.6_MARK1R0_HOLE | HOLE | MARK1R0 |
Q1 | MMBT2222A/SOT_4_SOT89-NPN_BC868 | BC868 | SOT89-NPN |
Q2 | MMBT2222A/SOT_5_SOT89-NPN_BC868 | BC868 | SOT89-NPN |
Q3 | MMBT2222A/SOT_SOT-416_BC848C | BC848C | SOT-416 |
S1 | SW1_SMT_SW4SM-N_4PINKEY-6X5-EVQ | 4pinKEY-6x5-EVQ9P105M-Panasonic | SW4SM-N |
T1 | TEST_POINT_TPS-0R80_0V675 | 0V675 | TPS-0R80 |
T3 | TCM1_0_TCM1_63AX_TCM1_63AX+ | TCM1_63AX+ | TCM1_63AX |
T4 | TCM1_0_TCM1_63AX_TCM1_63AX+ | TCM1_63AX+ | TCM1_63AX |
T5 | TEST_POINT_TPS-0R80_0V675 | 0V675 | TPS-0R80 |
TP28 | TESTPOINT_TPS-0R80_SYNC_OUT | SYNC_OUT | TPS-0R80 |
U1 | DO2525H_DO2525H_YZXO25K-1989/O2 | YZXO25K-1989/O22B-Q426-100.00MHz-B | DO2525H |
U2 | YZXO14-1980_YZXO14-1980_YZXO14- | YZXO14-1980/NC | YZXO14-1980 |
U3 | SCPS-4-62+_2_PL-492_SCPS-4-62+ | SCPS-4-62+ | PL-492 |
U4 | RLM-63-2W+_PL-258_RLM-63-2W+ | RLM-63-2W+ | PL-258 |
U5 | LFCN-630D+_6_PL-137_LFCN-105 | LFCN-105 | PL-137 |
U6 | HMC8038LP4CE_1_QFN16-4X4-0_65_H | HMC8038LP4CE | QFN16-4X4-0_65 |
U7 | PHA-13HLN+_0_SOT89_ADL5602ARKZ- | ADL5602ARKZ-R7 | SOT89 |
U8 | DBTC-7-152+_PL-150_DBTC-7-152L+ | DBTC-7-152L+ | PL-150 |
U9 | LTC6957-2_MSOP_12_MS_LTC6957IMS | LTC6957IMS-2#PBF | MSOP_12_MS |
U10 | AD8317_CP-8_AD8317ACPZ-R7 | AD8317ACPZ-R7 | CP-8 |
U11 | ADA4807-1_0_SC70_ADA4807-1AKSZ- | ADA4807-1AKSZ-R2 | SC70 |
U12 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U13 | LT1965EMS8_MSOP_8_MSE_LT1965EMS | LT1965EMS8 | MSOP_8_MSE |
U14 | AD9508BCPZ_0_QFN24_AD9508BCPZ | AD9508BCPZ | QFN24 |
U15 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U16 | ADA4807-1_0_SC70_ADA4807-1AKSZ- | ADA4807-1AKSZ-R2 | SC70 |
U17 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U18 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U19 | TPS82130_0_SIL0008D_SMD_TPS8213 | TPS82130 | SIL0008D_SMD |
U20 | TPS82130_0_SIL0008D_SMD_TPS8213 | TPS82130 | SIL0008D_SMD |
U21 | TVS1400DRVR_WSON-6_TVS1400DRVR | TVS1400DRVR | WSON-6 |
U22 | TPS82130_0_SIL0008D_SMD_TPS8213 | TPS82130 | SIL0008D_SMD |
U23 | TPS82130_0_SIL0008D_SMD_TPS8213 | TPS82130 | SIL0008D_SMD |
U24 | TPS82130_0_SIL0008D_SMD_TPS8213 | TPS82130 | SIL0008D_SMD |
U25 | TPS7A88_WQFN20_TPS7A8901RTJT | TPS7A8901RTJT | WQFN20 |
U26 | TPS7A88_WQFN20_TPS7A8901RTJT | TPS7A8901RTJT | WQFN20 |
U27 | TPS7A88_WQFN20_TPS7A8901RTJT | TPS7A8901RTJT | WQFN20 |
U28 | TPS7A88_WQFN20_TPS7A8901RTJT | TPS7A8901RTJT | WQFN20 |
U29 | TPS7A88_WQFN20_TPS7A8901RTJT | TPS7A8901RTJT | WQFN20 |
U30 | TCA6416APWR_TSSOP_24_TCA6416APW | TCA6416APWR-TI | TSSOP_24 |
U31 | FT232RL_SSOP_28_FT232RL | FT232RL | SSOP_28 |
U32 | AT24MAC402-SSHM_SOIC-8_AT24MAC4 | AT24MAC402-SSHM-B/NC | SOIC-8 |
U33 | TMP112B_SOT563_TMP112B | TMP112B | SOT563 |
U34 | 7499611420_7499611420_100MHZ/ET | 100MHz/eth-7499611420 | 7499611420 |
U35 | DP83867IRPAP_PQFP_64_EP_DP83867 | DP83867IRPAP-TI | PQFP_64_EP |
U36 | SN74AVC4T245RSVR_QFN_RSV_16_SN7 | SN74AVC4T245RSVR-TI | QFN_RSV_16 |
U37 | LTC6948IUFD-4_QFN4X5-28-0R50-G2 | LTC6948IUFD-4 | QFN4X5-28-0R50-G2R4X3R4-B |
U38 | PHA-13HLN+_0_SOT89_ADL5602ARKZ- | ADL5602ARKZ-R7 | SOT89 |
U39 | GP2Y1+_QFN12-3X3-0_51_GP2Y1+ | GP2Y1+ | QFN12-3X3-0_51 |
U40 | GM4912C_GM4912C_(S1+S2+S3)_GM49 | GM4912C | GM4912C |
U41 | HFCG-3800+_PL-633_HFCG-1230+ | HFCG-1230+ | PL-633 |
U42 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U43 | LFCG-3500+_PL-429_LFCG-1800+ | LFCG-1800+ | PL-429 |
U44 | CDCLVC1104_1_TSSOP8_CDCLVC1104 | CDCLVC1104 | TSSOP8 |
U45 | LTC6957-2_MSOP_12_MS_LTC6957IMS | LTC6957IMS-2#PBF | MSOP_12_MS |
U46 | GM4912C_GM4912C_(S1+S2+S3)_GM49 | GM4912C | GM4912C |
U47 | HFCG-3800+_PL-633_HFCG-1230+ | HFCG-1230+ | PL-633 |
U48 | TCM1-63AX+_2_TC1-1-43X_TC1-1-13 | TC1-1-13MX+ | TC1-1-43X |
U49 | LFCG-3500+_PL-429_LFCG-1800+ | LFCG-1800+ | PL-429 |
U50 | LTC6957-2_MSOP_12_MS_LTC6957IMS | LTC6957IMS-2#PBF | MSOP_12_MS |
U51 | 2MM_1X6_559320630_559320630/2MM | 559320630/2mm_1x6 | 559320630 |
U52 | XC7Z020-1CLG400I_CLG400_(S1+S2+ | XC7Z020-1CLG400I | CLG400 |
U54 | TPS3808G01_SOT23-6-N_TPS3808G01 | TPS3808G01 | SOT23-6-N |
U55 | TDC7200PWR_TSSOP14_TDC7200PWR | TDC7200PWR | TSSOP14 |
U57 | MTFC16GAPALBH_R-PBGA11R5X13R0-1 | MTFC8GAMALBH/8G/EMMC-Micron | R-PBGA11R5X13R0-153-0R50-N |
U58 | LP2996_SO8-150-G2R3X2R3-N_LP299 | LP2996AMRX_NOPB | SO8-150-G2R3X2R3-N |
U59 | MT41K256M16TW_R-PBGA10X14-96-0R | MT41K256M16TW | R-PBGA10X14-96-0R80-1-N |
U60 | HFCG-3800+_PL-633_HFCG-2500+ | HFCG-2500+ | PL-633 |
U61 | LFCG-3500+_PL-429_LFCG-2850+ | LFCG-2850+ | PL-429 |
U62 | PHA-13HLN+_0_SOT89_ADL5545 | ADL5545 | SOT89 |
U63 | LFCG-3500+_PL-429_LFCG-1800+ | LFCG-1800+ | PL-429 |
U64 | KC2-19+_PL-045_KC2-19+ | KC2-19+ | PL-045 |
U65 | HMC8038LP4CE_2_QFN16-4X4-0_65_H | HMC8038LP4CE | QFN16-4X4-0_65 |
U66 | HMC8038LP4CE_7_QFN16-4X4-0_65_H | HMC8038LP4CE | QFN16-4X4-0_65 |
U67 | HFCG-3800+_PL-633_HFCG-3000+ | HFCG-3000+ | PL-633 |
U68 | LFCG-3500+_PL-429_LFCG-3700+ | LFCG-3700+ | PL-429 |
U69 | PHA-13HLN+_0_SOT89_ADL5545 | ADL5545 | SOT89 |
U70 | HFCG-3800+_PL-633_HFCG-2500+ | HFCG-2500+ | PL-633 |
U71 | LFCG-3500+_PL-429_LFCG-2850+ | LFCG-2850+ | PL-429 |
U72 | LFCG-3500+_PL-429_LFCG-1800+ | LFCG-1800+ | PL-429 |
U73 | PHA-13HLN+_0_SOT89_ADL5545 | ADL5545 | SOT89 |
U74 | KC2-19+_PL-045_KC2-19+ | KC2-19+ | PL-045 |
U75 | HMC8038LP4CE_2_QFN16-4X4-0_65_H | HMC8038LP4CE | QFN16-4X4-0_65 |
U76 | HMC8038LP4CE_6_QFN16-4X4-0_65_H | HMC8038LP4CE | QFN16-4X4-0_65 |
U77 | HFCG-3800+_PL-633_HFCG-3000+ | HFCG-3000+ | PL-633 |
U78 | LFCG-3500+_PL-429_LFCG-3700+ | LFCG-3700+ | PL-429 |
U79 | PHA-13HLN+_0_SOT89_ADL5545 | ADL5545 | SOT89 |
U95 | MT25QL128ABA1EW7-0SIT_MT25QL128 | MT25QL128ABA1EW7-0SIT | MT25QL128ABA1EW7-0SIT |
X1 | CRYSTAL_3V3_TXC-3225_YSO110TR | YSO110TR | TXC-3225 |
X2 | CRYSTAL_3V3_TXC-3225_SMD-50MHZ- | SMD-50MHz-3.3V-3225,Q33310F70062200,EPSON | TXC-3225 |
