查看: 57|回复: 0
[Pads_VX.2x] 新塘 NuMaker-IoT-MA35D0-A1_202505 参考板评估板PCB 原理图等整套资料 NUMAKER-IOT-MA35D03F80_V11
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 7 天前 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NuMaker-IoT-MA35D0-A1_20250514.7z (6.83 MB, 下载次数: 1)
    NamePart TypePCB DecalValue
    CON1MICRO_USB_5PIN_1USB_TYPE_C_22C2416051_SMDUSB TypeC_24pin
    CON3USB_TYPE_B_0MICRO_USB_AB_LSmicro USB 5pin
    CON7RJ45_SHLD_2RJ45\8P\JA\LEDRJ-45 8P8C_LED R/A
    CON8SJ-435107RS_9PHONE-PJK-634M_AS2SJ3080-000111F SMD
    CON9USB_TYPE_B_0MICRO_USB_AB_LSmicro USB 5pin
    CON13USB_TYPE_A_CONNECTORUSB4PUSB_TYPE-A_RECAP.
    CON24CONNECTOR_DB9_0DB9_FMALEDB9_FEMALE
    CON25CONNECTOR_DB9_0DB9_FMALEDB9_FEMALE
    CON32AXA2R63061_1AXA2R63061SD_Card
    CON34B8502A-13SB-HPA_(T-FLASH_CARD)B8502A-13SB-HPAT-Flash Card(B8502A-13SB-HPA )
    CON37RJ45_SHLD_2RJ45\8P\JA\LEDRJ-45 8P8C_LED R/A
    D1ZENAR_0SOD-523RB521S-30
    D2ZENAR_0SOD-523RB521S-30
    D12ZENAR_0SOD-523RB521S-30
    D13DIODE_TAZ_BI-DIRDFN1006ES014005F4_AZ5825-01F
    F1FUSER0603FUSE (6V/1A)
    H1T_POINT_2H-250H-250(NC)
    H2T_POINT_2H-250H-250(NC)
    H3T_POINT_2H-250H-250(NC)
    H4T_POINT_2H-250H-250(NC)
    J2HEADER_2SIP/2P_3.5MMHD-351-02P
    J10HEADER_2_2HEADER2X1HEADER 2x1 (2.54mm, male)
    J14HEADER_8X1(2_1.54MM__MALE)HEADER_8X1HEADER 8x1 (2.54mm, male)
    J15HEADER_2_2HEADER2X1HEADER 2x1 (2.54mm, male)
    J16HEADER_5HEADER5X1HEADER 5x1 (2.54mm, male) (NC)
    J35HEADER_14X2_MALE_2_0.54MMHEADER-14X2HEADER 14X2 male 2.54mm
    J37HEADER_20X2HEADER20X2/2.54MM_MHEADER 20x2 (2.54mm, male)
    J63HEADER_2_2HEADER3X1HEADER3x1_2.54mm
    J65HEADER_2SIP/2P_3.5MMHD-351-02P
    J68HEADER_2_2HEADER3X1HEADER3x1_2.54mm
    J71HEADER_2SIP/2P_3.5MMHD-351-02P
    J72HEADER_2_2HEADER2X1HEADER 2x1 (2.54mm, male)
    J73HEADER_2_2HEADER2X1HEADER 2x1 (2.54mm, male)
    J75HEADER_2SIP/2P_3.5MMHD-351-02P
    J76HEADER_2SIP/2P_3.5MMHD-351-02P
    L1R_0R0603
    L2INDUCTOR_2L0603FB
    L3INDUCTOR_2L0603FB
    L4INDUCTOR_IRONSMT40X400.33uH
    L6INDUCTOR_2L0603FB
    L7INDUCTOR_IRONSMTDR43NR3015-4R7M-4.7uH
    L8INDUCTOR_IRONSMTDR43NR3015-4R7M-4.7uH
    L9INDUCTOR_2L0603FB
    L10INDUCTOR_2L0603FB
    L11INDUCTOR_IRONSMTDR43NR3015-4R7M-4.7uH
    L12INDUCTOR_IRONSMTDR43NR3015-4R7M-4.7uH
    LED2LEDLED08050805 LED G (厚) 炊
    LED3LEDLED08050805 LED Y (独) 蔼獹
    LEDG1LED_0LED08050805 LED G (厚) 炊
    LEDG3LED_0LED08050805 LED G (厚) 炊
    LEDR1LED_0LED08050805 LED R () 蔼獹
    LEDY1LED_0LED08050805 LED Y (独) 蔼獹
    M1MICROPHONE_2DIP_LF-M6027FMIC
    Q1PNP_0SOT-232N3904 (NPN)
    Q3MOSFET_N_4SOT-23SI2302 (NMOS)
    Q4MOSFET_N_4SOT-23SI2302 (NMOS)
    Q5MOSFET_P_4SOT-23SI2301 (PMOS)
    Q6MOSFET_P_4SOT-23SI2301 (PMOS)
    Q7PNP_0SOT-232N3904 (NPN)
    Q8PNP_2SOT-23S8550 (PNP)
    Q9MOSFET_N_4SOT-23SI2302 (NMOS)
    Q10MOSFET_P_4SOT-23SI2301 (PMOS)
    Q11MOSFET_N_4SOT-23SI2302 (NMOS)
    Q12PNP_0SOT-232N3904 (NPN)
    RP1R-PACK8_08P4RA10K-8P4R
    SW1SW-SSTS-B5SMD 6X6X6H 厚
    SW2SW-SSTS-B5SMD 6X6X5H 
    SW3SW-SSTS-B5SMD 6X6X5H 堵
    SW4SW-SSTS-B5SMD 6X6X5H 堵
    SW5SW-SSTS-B5SMD 6X6X5H 堵
    SW7SW_DIP-7_1SWDIP-8/SMDSW DIP 8 (SMD)
    T11PAD_11PAD_1.25X1.25MMN_PRE (NC)
    T21PAD_11PAD_1.25X1.25MMN_RB2 (NC)
    T31PAD_11PAD_1.25X1.25MMN_CE2 (NC)
    T41PAD_11PAD_1.25X1.25MMN_PSL (NC)
    T391PAD_11PAD_1.25X1.25MMVCOM_3V3 (NC)
    TP11PAD_11PAD_1.25X1.25MMTP1(NC)
    U1MA35D03F867C(LQFP216)LQFP216MA35D03F864C
    U2APW8827AQBI_0TDFN2X2-8MT8593ADAR
    U3ZT7103S_0TSOT-25MT3152NSBR
    U4ZT7103S_0TSOT-25MT3152NSBR
    U5ZT7103S_0TSOT-25MT3152NSBR
    U6ZT7103S_0TSOT-25MT3152NSBR
    U7TCAN332GD_0SOIC8TLE9351VSJ_AZKN6125P
    U11W55X10_3SOIC8_208_EPW25N04KWZEIR(SPI NAND)
    U12NAND_4-8G_4TSOP48-0.5MMW29N08GVSIAA(NAND Flash)
    U13W25Q128BV_4SOIC16_300W25Q128BV(NC)
    U16RTL8201FI-VC32-PIN-QFNRTL8201FI-VC
    U17PE-68515_2ST6200TTS8121CLF
    U20ADM232_0SOP16/150SN75C3232EDR_AZRS1296P
    U21NAU8501_0QFN32L_5X5MM\0.5MM_PITCHNAU88C22YG
    U22NCT3520W-H15_0MSOP-8AP2511M8-13
    U24NUC101_QFN_0QFN33_5X5NUC123ZD4AN0
    U25ADM232_0SOP16/150SN75C3232EDR_AZRS1296P
    U32PJ9293_0TSOP-6NSP4201MR6T1G_AZC615-04S
    U39PJ9293_0TSOP-6NSP4201MR6T1G
    U40PJ9293_0TSOP-6NSP4201MR6T1G
    U43ADM232_1SO-8SN65HVD11DR_AZRS3078
    U44ADM232_1SO-8SN65HVD11DR_AZRS3078
    U45APL5325BISOT-23-5APL5325ABI
    U46TO-247_REGULATOR_10SOT-223-1AMS1117_3.3v
    U47NCT3520W-H15_6VTQFN2X2-9PAPL3561
    U50RTL8201FI-VC32-PIN-QFNRTL8201FI-VC
    U51PE-68515_2ST6200TTS8121CLF
    U52TCAN332GD_0SOIC8TLE9351VSJ_AZKN6125P
    U53TCAN332GD_0SOIC8TLE9351VSJ_AZKN6125P
    X1MA306/SM_2XTAL_2P/1.5MMTXC-9H T9 SMD 32.768KHz 30ppm
    X2CRYSTAL_SMD_2TXC7M-3.2X2.5MMX3225B 24MHz SMD
    X4CRYSTAL_SMD_2TXC7M-3.2X2.5MMX3225B 25MHz SMD
    X5CRYSTAL_SMD_2TXC7M-3.2X2.5MMX3225B 12MHz SMD
    X6CRYSTAL_SMD_2TXC7M-3.2X2.5MMX3225B 25MHz SMD
    重要提示:PCB作品文件展下载说明
