| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | LED_0_LED_0603_LED_GREEN | LED_Green | LED_0603 |
| D9 | 1N4148-DIP_1_SOD-523_1N4148 | 1N4148 | SOD-523 |
| E1 | ESD-SOD523_1_SOD-523_IC_ESD5Z3. | ESD5Z3.3T1G/T5G | SOD-523 |
| E2 | ESD-SOD523_1_SOD-523_IC_ESD5Z_1 | ESD5Z3.3T1G/T5G//NA | SOD-523 |
| E3 | ESD-SOD523_1_SOD-523_IC_ESD5Z_1 | ESD5Z3.3T1G/T5G//NA | SOD-523 |
| E4 | ESD-SOD523_1_SOD-523_IC_ESD5Z_2 | ESD5Z3.3T1G/T5G/NA | SOD-523 |
| E5 | ESD-SOD523_1_SOD-523_IC_ESD5Z_2 | ESD5Z3.3T1G/T5G/NA | SOD-523 |
| F1 | FUSE_R0805-MINI_FUSE 0R/0805 | FUSE 0R/0805 | R0805-MINI |
| F2 | FUSE_R0805-MINI_NA/FUSE 0R/0805 | NA/FUSE 0R/0805 | R0805-MINI |
| FB1 | BEAD_L0402-MINI_BEAD | BEAD | L0402-MINI |
| FB2 | BEAD_L0402-MINI_BEAD | BEAD | L0402-MINI |
| GF1 | GF_M2_M_V2_9_M2-M_GF_75P_M2_HOS | M2_Host_M KEY | M2-M_GF_75P |
| J3 | HEADER_JTAG_4X2_0_JTAG_2_0_NC(H | NC(Header2x4,2.0mm) | JTAG_2_0 |
| J6 | CON4_SIP1X4-D20-H-DIP_CON4 | CON4 | SIP1X4-D20-H-DIP |
| J8 | CON1_TP-S-UMASK_CON1 | CON1 | TP-S-UMASK |
| J9 | CON1_TP-S-UMASK_CON1 | CON1 | TP-S-UMASK |
| L8 | INDUCTOR_0_L_2016_1UH/2016/ZTFL | 1uH/2016/ZTFL-201610TA-1R0M | L_2016 |
| L9 | INDUCTOR_0_L_2016_1UH/2016/ZTFL | 1uH/2016/ZTFL-201610TA-1R0M | L_2016 |
| L10 | INDUCTOR_0_L_2016_1UH/2016/ZTFL | 1uH/2016/ZTFL-201610TA-1R0M | L_2016 |
| U1 | YS9205_1120_BGA204_P650_7750X11 | YS9205 | BGA204_P650_7750X11100 |
| U2 | FLASH_BGA152_1_BGA152C100P_1400 | NAND_152_BALL_BGA | BGA152C100P_1400X1800X140 |
| U3 | FLASH_BGA152_1_BGA152C100P_1400 | NAND_152_BALL_BGA | BGA152C100P_1400X1800X140 |
| U4 | FLASH_BGA152_1_BGA152C100P_1400 | NAND_152_BALL_BGA | BGA152C100P_1400X1800X140 |
| U5 | FLASH_BGA152_1_BGA152C100P_1400 | NAND_152_BALL_BGA | BGA152C100P_1400X1800X140 |
| U6 | RICHTEK RT8008_0_QFN7-1515_SY88 | SY8843 | QFN7-1515 |
| U7 | RICHTEK RT8008_0_QFN7-1515_SY88 | SY8843 | QFN7-1515 |
| U8 | LDO-BL8563CKETR_0_UTDFN-1X1-4L_ | BL8563CKETR18 | UTDFN-1X1-4L |
| U9 | RICHTEK RT8008_0_QFN7-1515_SY88 | SY8843 | QFN7-1515 |
| Y1 | CRYSTAL4/SM_XTAL135P200X160X70- | 25MHz/SMD/2016-4/8pF/+-30ppm | XTAL135P200X160X70-4 |
