| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BAT1 | BATTERY_2_CR1220-Z_BATTERY | BATTERY | CR1220-Z |
| C413 | CAP POL_CAPD16L31_25V/4700UF | 25V/4700uF | CAPD16L31 |
| C414 | CAP POL_CAPPRD350W70D800H1400B_35V/100UF | 35V/100uf | CAPPRD350W70D800H1400B |
| D1 | DIODE_DIOM5226X262N_SS34 | SS34 | DIOM5226X262N |
| D2 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ30CA | SMBJ30CA | DIOM5436X265N |
| D3 | LED 2_2_LED_0805_LED_0805-R | LED_0805-R | LED_0805 |
| D5 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D6 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D7 | LED 2_2_LED_0603_LED_0603 | LED_0603 | LED_0603 |
| D8 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D14 | DIODE 2_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D43 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D46 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D47 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D48 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D49 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D50 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D51 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D52 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D53 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ15CA | SMBJ15CA | DIOM5436X265N |
| D56 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D57 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D58 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D59 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D60 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D61 | SM05_SOT95P280X135-3N_SM05T1 | SM05T1 | SOT95P280X135-3N |
| D62 | NUP2105L_SOT95P280X135-3N_NUP2105L | NUP2105L | SOT95P280X135-3N |
| D63 | NUP2105L_SOT95P280X135-3N_NUP2105L | NUP2105L | SOT95P280X135-3N |
| D64 | NUP2105L_SOT95P280X135-3N_NUP2105L | NUP2105L | SOT95P280X135-3N |
| D70 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D71 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ7.0CA | SMBJ7.0CA | DIOM5436X265N |
| D72 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ7.0CA | SMBJ7.0CA | DIOM5436X265N |
| D73 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D74 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ7.0CA | SMBJ7.0CA | DIOM5436X265N |
| D75 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ7.0CA | SMBJ7.0CA | DIOM5436X265N |
| D76 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D77 | DIODE ACC_SOT95P280X135-3N_BAV99LT1 | BAV99LT1 | SOT95P280X135-3N |
| D95 | DIODE_DIOM5226X262N_MBRA210LT3G | MBRA210LT3G | DIOM5226X262N |
| D97 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D98 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D102 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D103 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D104 | NUP2105L_SOT95P280X135-3N_NUP2105L | NUP2105L | SOT95P280X135-3N |
| D105 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D106 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D110 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D111 | DIODE_DIOM5226X262N_SS34 | SS34 | DIOM5226X262N |
| D112 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D113 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D114 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D115 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D116 | DIODE_DIOMELF3514N_FDLL4148 | FDLL4148 | DIOMELF3514N |
| D117 | B3D090L_0_B3D090L_B3D090L | B3D090L | B3D090L |
| D118 | B3D090L_0_B3D090L_B3D090L | B3D090L | B3D090L |
| D119 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D120 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D121 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D122 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D123 | B3D090L_0_B3D090L_B3D090L | B3D090L | B3D090L |
| D124 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D125 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D126 | B3D090L_0_B3D090L_B3D090L | B3D090L | B3D090L |
| D127 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D128 | DIODE BI-DIR TRIG_DIOM5436X265N_SMBJ12CA | SMBJ12CA | DIOM5436X265N |
| D129 | DIODE_DIOM5226X262N_SS34 | SS34 | DIOM5226X262N |
| F1 | FUSE_FUSE_2920L_2920L185DR | 2920L185DR | FUSE_2920L |
| F2 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F3 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F4 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F5 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F6 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F7 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F8 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| F9 | FUSE_F0805_0805L010 | 0805L010 | F0805 |
| H3 | PTH_C2_2X4_PTH_C2P2C4P0 | PTH_c2p2c4p0 | C2_2X4 |
| H4 | PTH_C2_2X4_PTH_C2P2C4P0 | PTH_c2p2c4p0 | C2_2X4 |
| H5 | PTH_C2_2X4_PTH_C2P2C4P0 | PTH_c2p2c4p0 | C2_2X4 |
| H6 | PTH_C2_2X4_PTH_C2P2C4P0 | PTH_c2p2c4p0 | C2_2X4 |
| J2 | CON4F_0_EIA-364-2_54-4_CON4F | CON4F | EIA-364-2_54-4 |
| J5 | CON2M_EIA-364-2_54-2_MJA-2PS | MJA-2PS | EIA-364-2_54-2 |
| J6 | CON2M_EIA-364-2_54-2_MJA-2PS | MJA-2PS | EIA-364-2_54-2 |
| J14 | CON3F_2EDGRM-5_08-3P_5.08-3P | 5.08-3P | 2EDGRM-5_08-3P |
| J15 | CON18M_6_DIP-3_81-14PIN-LC_3.81-14P | 3.81-14P | DIP-3_81-14PIN-LC |
| J16 | CON18M_5_DIP-3_81-15PIN-LC_3.81-15P | 3.81-15P | DIP-3_81-15PIN-LC |
| J18 | CON16M_DIP-3_81-16PIN-LC_3.81-16P | 3.81-16P | DIP-3_81-16PIN-LC |
| J21 | CON12M_DIP-3_81-12PIN-LC_3.81-12P | 3.81-12P | DIP-3_81-12PIN-LC |
| J23 | CON8M_2_DIP-3_81-6PIN-LC_3.81-6P | 3.81-6P | DIP-3_81-6PIN-LC |
| J24 | CON12M_0_KF2EDG15R-5_08-8P_5.08-8P | 5.08-8P | KF2EDG15R-5_08-8P |
| J25 | CON8M_3_DIP-3_81-7PIN-LC_3.81-7P | 3.81-7P | DIP-3_81-7PIN-LC |
| L1 | INDUCTOR_IND_PRS6028_PRS6028-4R7MT | PRS6028-4R7MT | IND_PRS6028 |
| L2 | INDUCTOR_IND_3316X76N_10UH/1206 | 10uH/1206 | IND_3316X76N |
| L3 | INDUCTOR_IND_3316X76N_10UH/1206 | 10uH/1206 | IND_3316X76N |
| L5 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L22 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L23 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L24 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L25 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L28 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L29 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L30 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L31 | RC-0805-10UH_RESC1608X84N_CBG160808U601T | CBG160808U601T | RESC1608X84N |
| L38 | WCM-3216_IND_CUBF-T4P-4532_CUBF-T4P-4532-S510 | CUBF-T4P-4532-S510 | IND_CUBF-T4P-4532 |
| L43 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L44 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L45 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L46 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L47 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L48 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L49 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L50 | INDUCTOR_IND_3316X76N_CBM321609U800T | CBM321609U800T | IND_3316X76N |
| L51 | WCM-3216_IND_CUBF-T4P-4532_CUBF-T4P-4532-S510 | CUBF-T4P-4532-S510 | IND_CUBF-T4P-4532 |
| L52 | WCM-3216_IND_CUBF-T4P-4532_CUBF-T4P-4532-S510 | CUBF-T4P-4532-S510 | IND_CUBF-T4P-4532 |
| L53 | WCM-3216_IND_CUBF-T4P-4532_CUBF-T4P-4532-S510 | CUBF-T4P-4532-S510 | IND_CUBF-T4P-4532 |
| Q2 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q3 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q4 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q5 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q7 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q8 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q9 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q11 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q12 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q13 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q15 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q16 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q17 | MOS P GDS_1_TO-220_IRFZ44N | IRFZ44N | TO-220 |
| Q36 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q37 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q38 | MOS P GDS_1_TO-220_IRFZ44N | IRFZ44N | TO-220 |
| Q39 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q40 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q41 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q42 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| Q43 | NPN BEC_SOT95P280X135-3N_MMBT5551 | MMBT5551 | SOT95P280X135-3N |
| RL1 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL2 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL3 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL4 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL6 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL7 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL8 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL10 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL11 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL12 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL14 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL15 | T9SV1K15-12_RELAY_HF46F_5-HS1_HF46F/5-HS1 | HF46F/5-HS1 | RELAY_HF46F_5-HS1 |
| RL22 | HFD4_RELAY_G6S_G6S-2 DC5 | G6S-2 DC5 | RELAY_G6S |
| RL23 | HFD4_RELAY_G6S_G6S-2 DC5 | G6S-2 DC5 | RELAY_G6S |
| RL27 | HFD4_RELAY_G6S_G6S-2 DC5 | G6S-2 DC5 | RELAY_G6S |
| RL28 | HFD4_RELAY_G6S_G6S-2 DC5 | G6S-2 DC5 | RELAY_G6S |
| RL29 | T9SV1K15-12_3_SFK-105DMP_SFK-105DMP-F-H-33 | SFK-105DMP-F-H-33 | SFK-105DMP |
| RL30 | T9SV1K15-12_3_SFK-105DMP_SFK-105DMP-F-H-33 | SFK-105DMP-F-H-33 | SFK-105DMP |
| RL31 | T9SV1K15-12_3_SFK-105DMP_SFK-105DMP-F-H-33 | SFK-105DMP-F-H-33 | SFK-105DMP |
| RL32 | T9SV1K15-12_3_SFK-105DMP_SFK-105DMP-F-H-33 | SFK-105DMP-F-H-33 | SFK-105DMP |
| SW1 | SW DS-04-V_SW_DS-04-V_DS-04-V | DS-04-V | SW_DS-04-V |
| U1 | MJWI10_1_URB_YMD-15WR3_URB2405YMD-15WR3 | URB2405YMD-15WR3 | URB_YMD-15WR3 |
| U2 | NCV1117/DPAK_TO228P991X239-3N_NCV1117DT33T5 | NCV1117DT33T5 | TO228P991X239-3N |
| U3 | WRE2412S-3WR2_0_B0505S_B1212S-1WR2 | B1212S-1WR2 | B0505S |
| U4 | NCV1117/DPAK_0_SOT230P700X180-4N_AMS1117-5.0 | AMS1117-5.0 | SOT230P700X180-4N |
| U5 | STM32F413ZGT6_2_QFP100-4_N32G457VEL7 | N32G457VEL7 | QFP100-4 |
| U6 | NCV1117/DPAK_0_SOT230P700X180-4N_AMS1117-5.0 | AMS1117-5.0 | SOT230P700X180-4N |
| U8 | M25P16/SO8_3_SON127P800X600X80-8N_MKDV8GIL-AS | MKDV8GIL-AS | SON127P800X600X80-8N |
| U23 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U24 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U25 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U26 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U27 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U28 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U29 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U30 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U31 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U33 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U35 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U37 | TLP521-1_SOIC254P1016X460-4N_CYPC817 | CYPC817 | SOIC254P1016X460-4N |
| U44 | ACPL-C87_HCPL-7840_NSI1200-DDBR | NSi1200-DDBR | HCPL-7840 |
| U45 | LM358_SOIC127P600X175-8N_LMV358B-SR | LMV358B-SR | SOIC127P600X175-8N |
| U46 | ACPL-C87_HCPL-7840_NSI1200-DDBR | NSi1200-DDBR | HCPL-7840 |
| U47 | MAX232_SOIC127P600X175-16N_SP202EEN-L | SP202EEN-L | SOIC127P600X175-16N |
| U49 | ISO3082_1_SOIC127P1030X265-16N_CA-IS3092VW | CA-IS3092VW | SOIC127P1030X265-16N |
| U50 | ISO3082_1_SOIC127P1030X265-16N_CA-IS3092VW | CA-IS3092VW | SOIC127P1030X265-16N |
| U51 | ISO1050_2_SOIC254P1040X485-8N_CA-IS3062VM | CA-IS3062VM | SOIC254P1040X485-8N |
| U52 | ISO1050_1_SOIC254P1040X485-8N_CA-IS3062VM | CA-IS3062VM | SOIC254P1040X485-8N |
| U53 | ISO1050_2_SOIC254P1040X485-8N_CA-IS3062VW | CA-IS3062VW | SOIC254P1040X485-8N |
| U54 | ISO1050_2_SOIC254P1040X485-8N_CA-IS3062VW | CA-IS3062VW | SOIC254P1040X485-8N |
| U59 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U60 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U61 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U62 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U63 | TL432DBZ_SOT95P280X135-3N_CJ431 2.5V 0.5% | CJ431 2.5V 0.5% | SOT95P280X135-3N |
| U65 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U66 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U67 | LM358_SOIC127P600X175-8N_TP5552-SR | TP5552-SR | SOIC127P600X175-8N |
| U98 | MCP6051-E/SN_0_SOT95P280X145-5N_TP5551-TR | TP5551-TR | SOT95P280X145-5N |
| U99 | MCP6051-E/SN_0_SOT95P280X145-5N_TP5551-TR | TP5551-TR | SOT95P280X145-5N |
| U100 | TLP521-1_SOIC254P1016X460-4N_KLY0613HA | KLY0613HA | SOIC254P1016X460-4N |
| U102 | TLP521-1_SOIC254P1016X460-4N_KLY0613HA | KLY0613HA | SOIC254P1016X460-4N |
| U104 | TLP521-1_SOIC254P1016X460-4N_KLY0613HA | KLY0613HA | SOIC254P1016X460-4N |
| U106 | TLP521-1_SOIC254P1016X460-4N_KLY0613HA | KLY0613HA | SOIC254P1016X460-4N |
| U107 | MCP2515_SOP18_MCP2515 | MCP2515 | SOP18 |
| U108 | MCP2515_SOP18_MCP2515 | MCP2515 | SOP18 |
| U109 | WRE2412S-3WR2_1_B0505S_B1212S-1WR2 | B1212S-1WR2 | B0505S |
| X3 | CRYSTAL-2_1_SMD3225-4P_16MHZ | 16MHZ | SMD3225-4P |
| X4 | CRYSTAL-2_1_SMD3225-4P_16MHZ | 16MHZ | SMD3225-4P |
| Y1 | CRYSTAL-4_XTAL_XVGCCC_8MHZ | 8MHZ | XTAL_XVGCCC |
| Y2 | CRYSTAL-2_XTAL_FC-135_32.768KHZ | 32.768KHZ | XTAL_FC-135 |
