| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BKT1 | BRACKET_BRKT_ATX_2TAB_1_HDMI_DP | BRACKET | BRKT_ATX_2TAB_1_HDMI_DP_2_HDMI_DP |
| BKT7 | BRACKET_TH3P2_T6P10_BRACKET | BRACKET | TH3P2_T6P10 |
| CN1 | CON_PCI_EXPRESS_CON_FINGER_PEX_ | CON_PCI_EXPRESS | CON_FINGER_PEX_164 |
| D3 | D_SCHOTTKY#2_2_DIODE_SMD_SOD523 | D_SCHOTTKY | DIODE_SMD_SOD523_B_AKP |
| D4 | D_3PIN_CC#1_SOT323_D_3PIN_CC | D_3PIN_CC | SOT323 |
| D5 | D_3PIN_AA_SOT323_D_3PIN_AA | D_3PIN_AA | SOT323 |
| D7 | D_3PIN_AA_SOT323_D_3PIN_AA | D_3PIN_AA | SOT323 |
| D8 | D_3PIN_AA_SOT323_D_3PIN_AA | D_3PIN_AA | SOT323 |
| D9 | D_SCHOTTKY#2_3_DIODE_SMD_SOD523 | D_SCHOTTKY | DIODE_SMD_SOD523_B_AKP |
| D13 | D#1_DIODE_SMD_SOD523_B_AKP_D | D | DIODE_SMD_SOD523_B_AKP |
| D14 | D_3PIN_CC_SOT323_D_3PIN_CC | D_3PIN_CC | SOT323 |
| D17 | D_SCHOTTKY#2_0_DIODE_SMD_SOD523 | D_SCHOTTKY | DIODE_SMD_SOD523_B |
| D1205 | D_SCHOTTKY#2_1_DIODE_SMD_SOD523 | D_SCHOTTKY | DIODE_SMD_SOD523_B |
| D1207 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1208 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1209 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1210 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1213 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1214 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1215 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| D1216 | D_ESD_DIODE_SMD_010X060_D_ESD | D_ESD | DIODE_SMD_010X060 |
| F9605 | R#1_1206_1206 FUSE_SMD1206P110T | 1206 fuse_SMD1206P110TFT | 1206 |
| G1 | U_GPU_GB5B_128_BGA_1358_P070_29 | U_GPU_GB5B_128 | BGA_1358_P070_290X290 |
| J2 | CON_DISPLAYPORT#1_CON_DP_020_SM | CON_DISPLAYPORT | CON_DP_020_SMT_RA_F_B |
| J3 | CON_HDMI_CON_HDMI_019_SMT_RA_F_ | CON_HDMI | CON_HDMI_019_SMT_RA_F_P005_R |
| J4 | CON_HDMI_CON_HDMI_019_SMT_RA_F_ | CON_HDMI | CON_HDMI_019_SMT_RA_F_P005_R |
| J6 | CON_DISPLAYPORT#1_CON_DP_020_SM | CON_DISPLAYPORT | CON_DP_020_SMT_RA_F_B |
| J9 | HDR_3_CON_PWR_002X003_TH_RA_M_P | HDR_2X3 | CON_PWR_002X003_TH_RA_M_P042_OP |
| J49 | HDR_0_DIP_POWERCON_8P_R_HDR_2X4 | HDR_2X4 | DIP_POWERCON_8P_R |
| J51 | HDR_1X4#1_CON_WAFER232_004_TH_S | HDR_1X4 | CON_WAFER232_004_TH_ST_P020 |
| L1 | L#1_IND_NONRKO_SMD_050X050_F_4. | 4.7uH | IND_NONRKO_SMD_050X050_F |
| L5 | L_IND_NONRKO_SMD_118X081_0.22UH | 0.22uH | IND_NONRKO_SMD_118X081 |
| L1201 | L_IND_NONRKO_SMD_044X041_1UH_20 | 1uH | IND_NONRKO_SMD_044X041 |
| L1202 | L#1_IND_NONRKO_SMD_025X020_1UH_ | 1uH | IND_NONRKO_SMD_025X020 |
| L1203 | L#1_IND_NONRKO_SMD_025X020_1UH_ | 1uH | IND_NONRKO_SMD_025X020 |
| LB1 | L_IND_SMD_0402_600OHM_25% | 600ohm | IND_SMD_0402 |
| LB1208 | L_IND_SMD_0805_220OHM_25% | 220ohm | IND_SMD_0805 |
| M9 | U_MEM_SG_GDDR6#1_BGA_0180_P075_ | U_MEM_SG_GDDR6#1 | BGA_0180_P075_120X140 |
| M10 | U_MEM_SG_GDDR6#2_BGA_0180_P075_ | U_MEM_SG_GDDR6#2 | BGA_0180_P075_120X140 |
| M11 | U_MEM_SG_GDDR6_BGA_0180_P075_12 | U_MEM_SG_GDDR6 | BGA_0180_P075_120X140 |
| M12 | U_MEM_SG_GDDR6#7_BGA_0180_P075_ | U_MEM_SG_GDDR6#7 | BGA_0180_P075_120X140 |
| MEC2 | SOCKET_BGA_0_SKT_BGA_POGO_290X2 | SOCKET_BGA | SKT_BGA_POGO_290X290_P070_SMT |
| MEC3 | MOUNTING_HOLE_MECH_PEX_02122X01 | MOUNTING_HOLE | MECH_PEX_02122X01112_SQ_TR_E4736_HOLES |
| Q1 | Q_NPN_SC70_6_Q_NPN | Q_NPN | SC70_6 |
| Q2 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q3 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q4 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q5 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q6 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q7 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q23 | Q_FET_N_ENH#2_SOT323_Q_FET_N__1 | Q_FET_N_ENH_2N7002W | SOT323 |
| Q25 | Q_NPN#1_SOT23_Q_NPN | Q_NPN | SOT23 |
| Q26 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q29 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q33 | Q_FET_N_ENH#2_SOT323_D_Q_FET_N_ | Q_FET_N_ENH | SOT323_D |
| Q34 | Q_FET_N_ENH#1_SC70_6_Q_FET_N_EN | Q_FET_N_ENH | SC70_6 |
| Q35 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q38 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q515 | Q_FET_N_ENH#2_SC70_6_Q_FET_N_EN | Q_FET_N_ENH | SC70_6 |
| Q1210 | Q_NPN_SC70_6_Q_NPN | Q_NPN | SC70_6 |
| Q1224 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q1225 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q1230 | Q_FET_N_ENH#2_SOT23_Q_FET_N_ENH | Q_FET_N_ENH | SOT23 |
| Q1231 | Q_FET_N_ENH#2_SOT23_Q_FET_N_ENH | Q_FET_N_ENH | SOT23 |
| Q1233 | Q_FET_N_ENH#2_SOT323_Q_FET_N_EN | Q_FET_N_ENH | SOT323 |
| Q1234 | Q_FET_N_ENH#2_SOT23_Q_FET_N_ENH | Q_FET_N_ENH | SOT23 |
| Q1235 | Q_FET_N_ENH#2_SOT23_Q_FET_N_ENH | Q_FET_N_ENH | SOT23 |
| Q1236 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1237 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q1238 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1239 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1240 | Q_FET_N_ENH#2_SOT323_D_Q_FET_N_ | Q_FET_N_ENH | SOT323_D |
| Q1241 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1243 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q1244 | Q_FET_N_ENH#2_SOT323_D_Q_FET_N_ | Q_FET_N_ENH | SOT323_D |
| Q1245 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q1246 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1247 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1248 | Q_NPN#1_SOT323_D_Q_NPN | Q_NPN | SOT323_D |
| Q1268 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH_ | Q_FET_N_ENH_PJT7828 | SC70_6 |
| Q1272 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1273 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1274 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1275 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| Q1276 | Q_FET_N_ENH_SC70_6_Q_FET_N_ENH | Q_FET_N_ENH | SC70_6 |
| RS8 | R_SENSE#1_RES_04_SMD_064X032_RK | 0.005ohm | RES_04_SMD_064X032_RKO |
| RS12 | R_SENSE#1_RES_04_SMD_064X032_RK | 0.005ohm | RES_04_SMD_064X032_RKO |
| RS16 | R_SENSE#1_RES_04_SMD_064X032_RK | 0.005ohm | RES_04_SMD_064X032_RKO |
| RS1260 | R_SENSE#1_RSENSE_VIRTUAL_04_SMD | 0 Ohm | RSENSE_VIRTUAL_04_SMD_1206_B |
| RT1 | THERMISTOR#1_0402_100K_B25/50=4 | 100k_B25/50=4250K | 402 |
| RT2 | THERMISTOR#1_0603_100K_B25/85=4 | 100k_B25/85=4550K | 603 |
| RT3 | THERMISTOR_0402_1K_B25/100=0K_5 | 1k_B25/100=0K | 402 |
| RT4 | THERMISTOR#1_0603_100K_B25/85=4 | 100k_B25/85=4550K | 603 |
| RT5 | THERMISTOR#1_0402_100K_B25/50_1 | 100k_B25/50=4250K_NS | 402 |
| RT10 | THERMISTOR_0402_150K_B25/50=450 | 150k_B25/50=4500K | 402 |
| RT11 | THERMISTOR_0402_150K_B25/50=450 | 150k_B25/50=4500K | 402 |
| TP1201 | LABTESTPOINT_LTPT071C125D_LABTE | LABTESTPOINT | LTPT071C125D |
| U2 | U_PWR_SW_UL_SOT23_5_U_PWR_SW_UL | U_PWR_SW_UL | SOT23_5 |
| U5 | U_BUCK_FET_1PH#1_SOT23_8_B_VIAS | 0.807V_MP1475DJ_GS7311 | SOT23_8_B_VIAS |
| U8 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U9 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U10 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U11 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U18 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U20 | U_MEM_FL_SER_2MX8_SO08_048X038_ | U_MEM_FL_SER_2MX8 | SO08_048X038 |
| U29 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U34 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U35 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U37 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U39 | U_DRMOS_QFN033Q_P050_0050_T036X | U_DRMOS | QFN033Q_P050_0050_T036X020_T017X011_T014X011 |
| U58 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U59 | U_PWR_SW_UL_SOT23_5_U_PWR_SW_UL | U_PWR_SW_UL | SOT23_5 |
| U60 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U61 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U62 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U64 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U65 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U68 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U69 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U70 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U75 | U_OR_2IN_SC70_5_U_OR_2IN | U_OR_2IN | SC70_5 |
| U76 | U_OR_2IN_SC70_5_U_OR_2IN | U_OR_2IN | SC70_5 |
| U79 | U_SW_LOAD_SC70_6_U_SW_LOAD | U_SW_LOAD | SC70_6 |
| U80 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U81 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U82 | U_LDO#1_DFN10_P050_030X030_T024 | 0.8V | DFN10_P050_030X030_T024X017_VIAS |
| U84 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U87 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U88 | U_PWRMTR_NCP4549_QFN032Q_P040_0 | U_PWRMTR_NCP4549 | QFN032Q_P040_0040_T027X027 |
| U90 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U91 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U501 | U_AND_2IN_SC70_5_U_AND_2IN_M74V | U_AND_2IN_M74VHC1GT08DFT2G | SC70_5 |
| U516 | U_AND_2IN_SC70_5_U_AND_2IN | U_AND_2IN | SC70_5 |
| U518 | U_OPENVREG_TYPE4PLUS_QFN040Q_P0 | 2V | QFN040Q_P040_0050_T035X035_VIAS |
| U610 | U_OPENVREG_TYPE3_QFN020Q_P040_0 | 2V | QFN020Q_P040_035X035_T017X017_C |
| U1208 | U_VREG_APL5910_SO08_050X040_T03 | 0.8V | SO08_050X040_T035X028 |
| U1214 | U_PWR_SW_UL_SOT23_5_U_PWR_SW_UL | U_PWR_SW_UL | SOT23_5 |
| U1218 | U_BUCK_FET_1PH_SOT23_6_0.6V_1% | 0.6V | SOT23_6 |
| U1219 | U_BUCK_FET_1PH_SOT23_6_0.6V_1% | 0.6V | SOT23_6 |
| U1220 | U_OPENVREG_TYPE3_QFN020Q_P040_0 | 2V | QFN020Q_P040_035X035_T017X017_C |
| U1221 | U_AND_2IN_SC70_5_U_AND_2IN_M74V | U_AND_2IN_M74VHC1GT08DFT2G | SC70_5 |
| Y1 | XTAL_4PIN_XTAL_SMD_4_032X025_27 | 27MHz | XTAL_SMD_4_032X025 |
