| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| B1 | MOLEX_QSFPDD_CAGE_QSFPDD_CAGE_UE36-C16221-06A3A_UE36-C16221-06A3A | UE36-C16221-06A3A | QSFPDD_CAGE_UE36-C16221-06A3A |
| B2 | MOLEX_ZQSFP_CAGE_0_ZQSFP_CAGE_U95-T1C1-101A_U95-T1C1-101A | U95-T1C1-101A | ZQSFP_CAGE_U95-T1C1-101A |
| BT1 | BATTERY_0_16MM_BAT_HOLDER_CR1620HOLDER | CR1620Holder | 16MM_BAT_HOLDER |
| D1 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D2 | LED_0_LED_0603_BLUELED | BLUELED | LED_0603 |
| D3 | LED_WURTH_LED_0603_YELLOW_LED | YELLOW_LED | LED_0603 |
| D4 | LED_WURTH_LED_0603_YELLOW_LED | YELLOW_LED | LED_0603 |
| D5 | LED_WURTH_LED_0603_RED_LED | RED_LED | LED_0603 |
| D6 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D7 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D8 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D9 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D10 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D11 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D12 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D13 | TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A | 5p0SMDJ12A | TVS_5P0SMDJ12A |
| D14 | STPS30L30DJF-TR_POWERFLAT_5X6_STPS30L30DJF-TR | STPS30L30DJF-TR | POWERFLAT_5X6 |
| D15 | TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A | 5p0SMDJ12A | TVS_5P0SMDJ12A |
| D16 | STPS30L30DJF-TR_POWERFLAT_5X6_STPS30L30DJF-TR | STPS30L30DJF-TR | POWERFLAT_5X6 |
| D17 | TVS_5P0SMDJ12A_SOD-80_FDLL4148 | FDLL4148 | SOD-80 |
| D18 | TVS_5P0SMDJ12A_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D19 | TVS_5P0SMDJ12A_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D20 | TVS_5P0SMDJ12A_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D21 | TVS_5P0SMDJ12A_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D22 | TVS_5P0SMDJ12A_SOD-80_FDLL4148 | FDLL4148 | SOD-80 |
| D23 | TVS_5P0SMDJ12A_SOD-80_FDLL4148 | FDLL4148 | SOD-80 |
| D24 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D25 | LED_WURTH_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D26 | TVS_2_SOT-23-3_BAT54 | BAT54 | SOT-23-3 |
| D27 | TVS_2_SOT-23-3_BAT54 | BAT54 | SOT-23-3 |
| D28 | LT1389_S8_LT1389 | LT1389 | S8 |
| EU1 | MAX31730ATC_LCC12_S30_50DF25X17MA_MAX31730ATC+ | MAX31730ATC+ | LCC12_S30_50DF25X17MA |
| EU2 | MAX31730ATC_LCC12_S30_50DF25X17MA_MAX31730ATC+ | MAX31730ATC+ | LCC12_S30_50DF25X17MA |
| FB1 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB2 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB3 | INDUCTOR_805_120OHM,800MA | 120ohm,800mA | 805 |
| FB4 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB5 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB6 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB7 | INDUCTOR_SL1616A-R10MHF_0.1UH,19A | 0.1uH,19A | SL1616A-R10MHF |
| FB8 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB9 | BEAD_FERRITE_SM_0805_80OHM@ 100MHZ | 80ohm@ 100Mhz | 805 |
| FB10 | BEAD_FERRITE_SM_0805_80OHM@ 100MHZ | 80ohm@ 100Mhz | 805 |
| FB11 | BEAD_FERRITE_SM_0805_80OHM@ 100MHZ | 80ohm@ 100Mhz | 805 |
| FB12 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB13 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB14 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB15 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB16 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB17 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB18 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB19 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB20 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB21 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB22 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB23 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB24 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB25 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB26 | BEAD_FERRITE_SM_0603_22OHM@100MHZ8A | 22ohm@100Mhz8A | 603 |
| FB27 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB28 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB29 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB30 | BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR | 600Ohm, 0.5A, 0.35DCR | 603 |
| FB37 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB38 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB39 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB40 | BEAD_FERRITE_SM_0402_220OHM,.6AMAX, 0.18DCR | 220ohm,.6Amax, 0.18DCR | 402 |
| FB41 | BEAD_FERRITE_SM_0805_80OHM@ 100MHZ | 80ohm@ 100Mhz | 805 |
| FB42 | BEAD_FERRITE_SM_0603_DNI | DNI | 603 |
| J1 | PCIE_BRACKET_X16_1_PCIX-16PORT_PCIE_SLOT | PCIE_Slot | PCIX-16PORT |
| J2 | FAN_CONN_0_MOLEX_0470533000_FAN_CONN | FAN_Conn | MOLEX_0470533000 |
| J3 | J23 | MOLEX70247-1051 | MOLEX_70247-1051 |
| J4 | DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288 | DDR4x72x288 | DDR4DIMM_SMT |
| J5 | DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288 | DDR4x72x288 | DDR4DIMM_SMT |
| J6 | QSH-030-01-C-D-A_QSH-030-01-C-D-A_QSH-030-01-F-D-A | QSH-030-01-F-D-A | QSH-030-01-C-D-A |
| J7 | 2027180100_UE36-A1015-2000T_UE36-A1015-2000T | UE36-A1015-2000T | UE36-A1015-2000T |
| J8 | MOLEX_ZQSFP_CONN_FS1-K38-20ZA-A0_FS1-K38-20ZA-A0 | FS1-K38-20ZA-A0 | FS1-K38-20ZA-A0 |
| J9 | CON_MCIO_74P_G42V12312HR_G97R12322HR_G97R12322HR | G97R12322HR | G97R12322HR |
| J10 | MICRO_USB_CONN_MOLEX-MICRO-USB-47589-001_MICRO_USB_CONN | MICRO_USB_CONN | MOLEX-MICRO-USB-47589-001 |
| J11 | 2X4_PCIE_ATX_1_MOLEX_455860005_PCIE2X4 ATX | PCIe2x4 ATX | MOLEX_455860005 |
| J12 | 1X3_HDR_TH_1X3_HDR_TH_1X3_HDR_TH | 1x3_HDR_TH | 1X3_HDR_TH |
| J13 | DF3-4P-2DSA_DF3-4P-2DSA_01_DF3-4P-2DSA | DF3-4P-2DSA | DF3-4P-2DSA_01 |
| J14 | SMA_CONN_SMA_LTI-SASF546-P26-X1_SMA | SMA | SMA_LTI-SASF546-P26-X1 |
| J15 | SMA_CONN_SMA_LTI-SASF546-P26-X1_SMA | SMA | SMA_LTI-SASF546-P26-X1 |
| J105 | CON2_HDR2X1_100MIL_CON2 | CON2 | HDR2X1_100MIL |
| J106 | CON2_HDR2X1_100MIL_CON2 | CON2 | HDR2X1_100MIL |
| J107 | DF3-4P-2DSA_DF3-4P-2DSA_01_DF3-4P-2DSA | DF3-4P-2DSA | DF3-4P-2DSA_01 |
| L1 | INDUCTORIRON_IFSC1008ABER1R0M01_1UH | 1uH | IFSC1008ABER1R0M01 |
| L2 | INDUCTORIRON_IFSC1008ABER1R0M01_1UH | 1uH | IFSC1008ABER1R0M01 |
| L3 | INDUCTORIRON_IFSC1008ABER1R0M01_1UH | 1uH | IFSC1008ABER1R0M01 |
| L5 | INDUCTOR_IRON_ALT_EATON_FP0805R1-R07-R_DISCRETE_72NH_ | 72nH | EATON_FP0805R1-R07-R |
| L6 | INDUCTOR_IRON_ALT_EATON_FP0805R1-R07-R_DISCRETE_72NH_ | 72nH | EATON_FP0805R1-R07-R |
| L7 | INDUCTOR_IRON_ALT_EATON_FP0805R1-R07-R_DISCRETE_72NH_ | 72nH | EATON_FP0805R1-R07-R |
| L8 | INDUCTOR_IRON_ALT_EATON_FP0805R1-R07-R_DISCRETE_72NH_ | 72nH | EATON_FP0805R1-R07-R |
| L9 | INDUCTOR_IRON_ALT_EATON_FP0805R1-R07-R_DISCRETE_72NH_ | 72nH | EATON_FP0805R1-R07-R |
| L10 | INDUCTOR_IRON_ALT_XAL5030_DISCRETE_0.33UH_ | 0.33uH | XAL5030 |
| L11 | INDUCTOR_IRON_ALT_XAL5030_DISCRETE_0.33UH_ | 0.33uH | XAL5030 |
| L12 | INDUCTOR_IRON_ALT_XEL4030_DISCRETE_0.47UH_ | 0.47uH | XEL4030 |
| L13 | INDUCTOR_IRON_ALT_XAL6030_DISCRETE_0.33UH_ | 0.33uH | XAL6030 |
| MTH1 | MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GND | MT_HOLE_GND | MH_D125C175T_TB315 |
| MTH2 | MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GND | MT_HOLE_GND | MH_D125C175T_TB315 |
| MTH3 | MNTHOLE_1_MH_PTH_3_8MM_MT_HOLE_GND | MT_HOLE_GND | MH_PTH_3_8MM |
| MTH4 | MNTHOLE_1_MTH250R125_MT_HOLE_GND | MT_HOLE_GND | MTH250R125 |
| MTH5 | MNTHOLE_1_MH_PTH_3_8MM_MT_HOLE_GND | MT_HOLE_GND | MH_PTH_3_8MM |
| MTH6 | MNTHOLE_1_MTH250R125_MT_HOLE_GND | MT_HOLE_GND | MTH250R125 |
| MTH7 | MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GND | MT_HOLE_GND | MH_D125C175T_TB315 |
| MTH8 | MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GND | MT_HOLE_GND | MH_D125C175T_TB315 |
| MTH9 | MNTHOLE_1_MH_PTH_3_8MM_MT_HOLE_GND | MT_HOLE_GND | MH_PTH_3_8MM |
| MTH10 | MNTHOLE_1_MH_PTH_3_8MM_MT_HOLE_GND | MT_HOLE_GND | MH_PTH_3_8MM |
| MTH11 | MNTHOLE_1_MTH250R125_MT_HOLE_GND | MT_HOLE_GND | MTH250R125 |
| Q1 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q2 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| Q3 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| Q4 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q7 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q8 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q9 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q10 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q11 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q12 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q13 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q14 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q15 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q16 | PSMN1R0-30YLD_0_NFET_PSMN1R0-30YLD_PSMN1R0-30YLD | PSMN1R0-30YLD | NFET_PSMN1R0-30YLD |
| Q17 | PWRMOSFET_EN_GSD_1_SOT23_SI2302CDS-T1-GE3 | SI2302CDS-T1-GE3 | SOT23 |
| Q18 | MOSFETN-DIODE-A-SO8_1_POWER-SO8_PSMN1R0-30YLC,115 | PSMN1R0-30YLC,115 | POWER-SO8 |
| Q19 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q20 | PWRMOSFET_EN_GSD_0_SOT23_FDV305N | FDV305N | SOT23 |
| Q21 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| Q22 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| Q23 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| Q24 | 2N3906_0_SC75_SOT416_MMBT3906 | MMBT3906 | SC75_SOT416 |
| S1 | S7 | PBSwitch | WURTH_6X3P5_TACT_SWITCH |
| S2 | S7 | PBSwitch | WURTH_6X3P5_TACT_SWITCH |
| S3 | S7 | PBSwitch | WURTH_6X3P5_TACT_SWITCH |
| S4 | S7 | PBSwitch | WURTH_6X3P5_TACT_SWITCH |
| S6 | S7 | PBSwitch | WURTH_6X3P5_TACT_SWITCH |
| ST1 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST2 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST7 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST8 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST9 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST10 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST11 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST14 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST20 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST30 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST31 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST32 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST33 | SHORT_SHORT_SHORT | SHORT | SHORT |
| ST34 | SHORT_SHORT_SHORT | SHORT | SHORT |
| SW1 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1 | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| SW2 | SPST4_0_DIPSWITCH_SMT_SINGLE_CVS-01TB | CVS-01TB | DIPSWITCH_SMT_SINGLE |
| SW3 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1 | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| SW4 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1 | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| SW5 | SW_SLIDE_DPDT_EG2207_SW_SLIDE_DPDT | SW_SLIDE_DPDT | EG2207 |
| SW6 | SPST4_0_DIPSWITCH_SMT_SINGLE_CVS-01TB | CVS-01TB | DIPSWITCH_SMT_SINGLE |
| U2 | 24AA024_SOIC-8_24AA024-I/SN | 24AA024-I/SN | SOIC-8 |
| U3 | MT25QU01GBBB_T-PBGA24_MT25QU02GCBB8E12-0SIT | MT25QU02GCBB8E12-0SIT | T-PBGA24 |
| U4 | MT25QU01GBBB_T-PBGA24_MT25QU02GCBB8E12-0SIT | MT25QU02GCBB8E12-0SIT | T-PBGA24 |
| U5 | 1M50DAF256I7G_MAX10_FBGA-256_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10)_10M50DAF256I7G | 10M50DAF256I7G | MAX10_FBGA-256 |
| U6 | TS3A5018RSVR_0_UQFN-16_TS3A5018RSVR | TS3A5018RSVR | UQFN-16 |
| U7 | SILABS_510GBA25M0000BAGR_SMT_OSC_3P2X5MM_4PIN_510CBA50M0000BAG | 510CBA50M0000BAG | SMT_OSC_3P2X5MM_4PIN |
| U8 | AGILEX_FM86_FBGA-2340_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11+S12+S13+S14+S15+S16+S17+S18+S19+S20+S21+S22+S23)_AGILEX_FM86 | AGILEX_FM86 | FBGA-2340 |
| U9 | MT25QU01GBBB_T-PBGA24_MT25QU02GCBB8E12-0SIT | MT25QU02GCBB8E12-0SIT | T-PBGA24 |
| U10 | SILABS_510GBA25M0000BAGR_SMT_OSC_3P2X5MM_4PIN_510KBA125M000BAGR | 510KBA125M000BAGR | SMT_OSC_3P2X5MM_4PIN |
| U12 | SN74AUP1G126DCK_SC70_TI_SN74AUP1G126DCK | SN74AUP1G126DCK | SC70_TI |
| U15 | MT40A2G8VA_FBGA-78_MT40A2G8VA | MT40A2G8VA | FBGA-78 |
| U16 | MT40A2G8VA_FBGA-78_MT40A2G8VA | MT40A2G8VA | FBGA-78 |
| U17 | MT40A2G8VA_FBGA-78_MT40A2G8VA | MT40A2G8VA | FBGA-78 |
| U18 | MT40A2G8VA_FBGA-78_MT40A2G8VA | MT40A2G8VA | FBGA-78 |
| U19 | MT40A2G8VA_FBGA-78_MT40A2G8VA | MT40A2G8VA | FBGA-78 |
| U20 | TPS2557_VSON-9_TPS2557DRBR | TPS2557DRBR | VSON-9 |
| U21 | TPS2557_VSON-9_TPS2557DRBR | TPS2557DRBR | VSON-9 |
| U22 | MAX3378E_0_TSSOP-14_MAX3378E | MAX3378E | TSSOP-14 |
| U23 | ZL30733_ZL30733_ZL30733LDG1Q089 | ZL30733LDG1Q089 | ZL30733 |
| U24 | SILABS_510GBA25M0000BAGR_SMT_OSC_7X5MM_4PIN_VCC1-9004-114M285 | VCC1-9004-114M285 | SMT_OSC_7X5MM_4PIN |
| U25 | SI52204_QFN32L_SI52204-A01BGM | Si52204-A01BGM | QFN32L |
| U26 | SI53254A-D02AM_SI53254_QFN40_SI53254A-D02AM | Si53254A-D02AM | SI53254_QFN40 |
| U27 | SI53254A-D02AM_SI53254_QFN40_SI53254A-D02AM | Si53254A-D02AM | SI53254_QFN40 |
| U28 | SN74LVC2G17DCKR_SC70-6_SN74LVC2G17DCKR | SN74LVC2G17DCKR | SC70-6 |
| U31 | SN74LVC2G17DCKR_SC70-6_SN74LVC2G17DCKR | SN74LVC2G17DCKR | SC70-6 |
| U33 | MAX3002EUP+T_20-TSSOP_TXS0108EPWR | TXS0108EPWR | 20-TSSOP |
| U36 | PCA9306DC,125_VSSOP8_PCA9306DC1/DG,125 | PCA9306DC1/DG,125 | VSSOP8 |
| U38 | PCA9306DC,125_VSSOP8_PCA9306DC1/DG,125 | PCA9306DC1/DG,125 | VSSOP8 |
| U39 | PCA9306DC,125_VSSOP8_PCA9306DC1/DG,125 | PCA9306DC1/DG,125 | VSSOP8 |
| U44 | M24128_SO8_M24128-BWMN6TP | M24128-BWMN6TP | SO8 |
| U45 | W25Q64JVSSIM_WSOIC-8_W25Q64JVSSIM | W25Q64JVSSIM | WSOIC-8 |
| U46 | M24128_SO8_M24128-BWMN6TP | M24128-BWMN6TP | SO8 |
| U47 | MAX811_SOT-143_MAX811 | MAX811 | SOT-143 |
| U48 | TPD2EUSB30_DRT_TPD2EUSB30 | TPD2EUSB30 | DRT |
| U49 | CY7C68013A_56QFN_QFN56_CY7C68013A_QFN | CY7C68013A_QFN | QFN56 |
| U50 | MAX16545B_QFN-22_MAX16545BGPF+T/ MAX16550AGPN+T | MAX16545BGPF+T/ MAX16550AGPN+T | QFN-22 |
| U51 | FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDC | FDMC2514SDC | FDMC8878_VER2 |
| U52 | LTC4357_DFN6_EPAD_LTC4357 | LTC4357 | DFN6_EPAD |
| U53 | LTC4359_MSOP-8_LTC4359 | LTC4359 | MSOP-8 |
| U54 | MAX16545B_QFN-22_MAX16545BGPF+T/ MAX16550AGPN+T | MAX16545BGPF+T/ MAX16550AGPN+T | QFN-22 |
| U56 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U57 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U58 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U60 | LTC1981ES5_LTC1981ES5_SOT23_LTC1981ES5 | LTC1981ES5 | LTC1981ES5_SOT23 |
| U61 | LTC3888-UHG_LTC-UHG-52-1550_IC_LTC3888_LTC3888EUHG#PBF | LTC3888 | LTC-UHG-52-1550 |
| U62 | LTC7501-LGA_1_LTC-LQFN-42-1571_IC_LTC7051IV#PBF_LTC7051IV#PBF | LTC7051IV#PBF | LTC-LQFN-42-1571 |
| U63 | LTC7501-LGA_1_LTC-LQFN-42-1571_IC_LTC7051IV#PBF_LTC7051IV#PBF | LTC7051IV#PBF | LTC-LQFN-42-1571 |
| U64 | LTC7501-LGA_1_LTC-LQFN-42-1571_IC_LTC7051IV#PBF_LTC7051IV#PBF | LTC7051IV#PBF | LTC-LQFN-42-1571 |
| U65 | LTC7501-LGA_1_LTC-LQFN-42-1571_IC_LTC7051IV#PBF_LTC7051IV#PBF | LTC7051IV#PBF | LTC-LQFN-42-1571 |
| U66 | LTC7501-LGA_1_LTC-LQFN-42-1571_IC_LTC7051IV#PBF_LTC7051IV#PBF | LTC7051IV#PBF | LTC-LQFN-42-1571 |
| U70 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U74 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U75 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U76 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U77 | TPS51200_1_VSON-11_TPS51200DRCR | TPS51200DRCR | VSON-11 |
| U78 | TPS51200_1_VSON-11_TPS51200DRCR | TPS51200DRCR | VSON-11 |
| U80 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U81 | EY1501DI-ADJ_DFN-11_ISL80101 | ISL80101 | DFN-11 |
| U87 | NLSX4014MUTAG_UQFN12_NLSX4014MUTAG | NLSX4014MUTAG | UQFN12 |
| U88 | NLSX4014MUTAG_UQFN12_NLSX4014MUTAG | NLSX4014MUTAG | UQFN12 |
| U89 | NLSX4014MUTAG_UQFN12_NLSX4014MUTAG | NLSX4014MUTAG | UQFN12 |
| U90 | NLSX4014MUTAG_UQFN12_NLSX4014MUTAG | NLSX4014MUTAG | UQFN12 |
| U91 | SN74AUP1G126DCK_SC70_TI_SN74AUP1G126DCK | SN74AUP1G126DCK | SC70_TI |
| U93 | LTC7132IY#PBF_BGA-140_LTC7132IY#PBF | LTC7132IY#PBF | BGA-140 |
| U94 | LTM4625IY#PBF_BGA-25_LTM4625IY#PBF | LTM4625IY#PBF | BGA-25 |
| U95 | LTM4620AIY#PBF_BGA-144_REVERSE_LTM4620AIY#PBF | LTM4620AIY#PBF | BGA-144_REVERSE |
| U96 | LTC7132IY#PBF_BGA-140_LTC7132IY#PBF | LTC7132IY#PBF | BGA-140 |
| U97 | PCA9534RGVR_1_TSSOP16_PCA9534PW,118 | PCA9534PW,118 | TSSOP16 |
| X1 | ROM7050PA_ROM7050PA_OCXO- ROM7050PA, DNI | OCXO- ROM7050PA, DNI | ROM7050PA |
| X2 | TX-801_TX801_G320_TX-801,DNI | TX-801,DNI | TX801_G320 |
| Y1 | CRYSTAL_SM_13_XTAL_FA-128_25.00MHZ | 25.00MHz | XTAL_FA-128 |
| Y2 | CRYSTAL_SM_13_XTAL_FA-128_24.00MHZ | 24.00MHz | XTAL_FA-128 |
