TA的每日心情 | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 8346
重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | D1 | HSOD882 | * | HSOD882 | D2 | HSOD882 | * | HSOD882 | D3 | HSOD882 | * | HSOD882 | D4 | HSOD882 | * | HSOD882 | D1000 | SD1710A | SMAJ13CA-TR | SD1710A | D1151 | HSD0603-LED | LED | HSD0603-LED | D2651 | HSOD323A | D_A | HSOD323A | D2951 | SD0705B | D4-2 | SD0705B | D3701 | SD0805-LED | LED | SD0805-LED | D3702 | SD0805-LED | LED | SD0805-LED | D3703 | SD1714D | TISP4350H3BJR_S | SD1714D | D3853 | SOT23 | D2-3_D | SOT23 | D3854 | HSOD882 | * | HSOD882 | D3855 | HSOD882 | * | HSOD882 | D4301 | HSOD323A | D_A | HSOD323A | D4304 | MLF10D-050-0301L | OVEL608A1 | MLF10D-050-0301L | D4305 | MLF10D-050-0301L | OVEL608A1 | MLF10D-050-0301L | D5051 | MLF10D-050-0301L | CLAMP0524P | MLF10D-050-0301L | D5052 | SD0402K | ESD63031N-2_TR | SD0402K | D5053 | SD0402K | ESD63031N-2_TR | SD0402K | D5054 | SD0402K | ESD63031N-2_TR | SD0402K | D5055 | SD0402K | ESD63031N-2_TR | SD0402K | D5653 | HSOD882 | NC* | HSOD882 | D5654 | HSOD882 | NC* | HSOD882 | D5801 | HSOD882 | LESD8LF50CT5G | HSOD882 | D5802 | HSOD882 | LESD8LF50CT5G | HSOD882 | F1000 | SF6127 | SEF005 | SF6127 | ID1 | ID-BOARD | ID-BOARD | ID-BOARD | ID2 | ID-BOARD | ID-BOARD | ID-BOARD | ID3 | ID-BOARD | ID-BOARD | ID-BOARD | ID4 | ID-BOARD | ID-BOARD | ID-BOARD | ID5 | ID-BOARD | ID-BOARD | ID-BOARD | ID6 | ID-BOARD | ID-BOARD | ID-BOARD | J1 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J2 | HEAD0101-T-B | * | HEAD0101-T-B | J3 | HEAD0101-T-B | * | HEAD0101-T-B | J4 | HEAD0101-T-B | * | HEAD0101-T-B | J5 | HEAD0101-T-B | * | HEAD0101-T-B | J6 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J1000 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J1001 | RPWC0103-RM-A | 86-100-00010-1 | RPWC0103-RM-A | J1002 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J1003 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J1004 | SWBC0104-79T-B | 86-104-00401-1 | SWBC0104-79T-B | J2951 | VAF2 | AV_84_5Y_HW | VAF2 | J3701 | MJ8-SR-BZ-A | B563S-8830-U004 | MJ8-SR-BZ-A | J3851 | IDC20-DTM1-A | HU5_200PNA_S53T_FA | IDC20-DTM1-A | J3852 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J3854 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J4301 | MOLEX_47151 | HDMI_CON | MOLEX_47151 | J4451 | DF17_7MH-60DP_P05 | DF40HC40_60DS_04V51 | DF17_7MH-60DP_P05 | J4452 | DF17_7MH-60DP_P05 | DF40HC40_60DS_04V51 | DF17_7MH-60DP_P05 | J4751 | HSDC10-1614B | DM3AT_SF_PEJM5 | HSDC10-1614B | J4901 | PDIM0409-79A | 2EG91827-D2DS-DF | PDIM0409-79A | J5051 | USB9-200-1516 | BUSB_A1D328F_9L9C_W | USB9-200-1516 | J5052 | USB4-1415 | 292303_1 | USB4-1415 | J5201 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J5202 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J5351 | SED90-F-A | MIPI_90_CON_F | SED90-F-A | J5652 | VAF6-1406E | 3-2-11-0058 | VAF6-1406E | J5801 | VAF6-1406E | 3-2-11-0058 | VAF6-1406E | L1000 | SL2828 | 4.7UH | SL2828 | L1001 | SPL0707G | 2.2UH | SPL0707G | L1151 | SL1008H | 1UH | SL1008H | L1152 | SL2828 | 4.7UH | SL2828 | L1301 | SPL0505N | 300NH | SPL0505N | L1302 | SPL0707G | 470NH | SPL0707G | L1451 | SPL0707G | 470NH | SPL0707G | L1601 | SL1008H | 1UH | SL1008H | L1602 | SL1008H | 1UH | SL1008H | L3701 | HSL1008 | 2.2UH | HSL1008 | L5051 | SL4-1210-AAA | * | SL4-1210-AAA | L5052 | SL4-1210-AAA | * | SL4-1210-AAA | L5201 | HSL1008 | 2.2UH | HSL1008 | L5351 | HSL1008 | 2.2UH | HSL1008 | L5801 | SPL0303A | 4.7U | SPL0303A | LB3 | SL0402 | BLM03AG700SN1D | SL0402 | LB4 | SL0402 | BLM03AG700SN1D | SL0402 | LB5 | SL0402 | BLM03AG700SN1D | SL0402 | LB6 | SL0402 | BLM03AG700SN1D | SL0402 | LB10 | SL0402 | BLM03AG700SN1D | SL0402 | LB11 | SL0402 | BLM03AG700SN1D | SL0402 | LB12 | SL0402 | BLM03AG700SN1D | SL0402 | LB13 | SL0402 | BLM03AG700SN1D | SL0402 | LB15 | SL0402 | BLM03AG700SN1D | SL0402 | LB16 | SL0402 | BLM03AG700SN1D | SL0402 | LB22 | SL0402 | BLM03AG700SN1D | SL0402 | LB28 | SL0402 | BLM03AG700SN1D | SL0402 | LB31 | SL0402 | BLM03AG700SN1D | SL0402 | LB901 | SL0402 | BLM03AG700SN1D | SL0402 | LB3701 | SL0805 | MGLB2012_220T_LF | SL0805 | LB3702 | SL0805 | MGLB2012_220T_LF | SL0805 | LB3703 | SL0805 | MGLB2012_220T_LF | SL0805 | LB3704 | SL0402 | BLM15HG102SN1D | SL0402 | LB3705 | SL0402 | BLM15HG102SN1D | SL0402 | LB4901 | SL1206 | MGLB3216_060T_LF | SL1206 | LB4902 | SL0805 | MGLB2012_220T_LF | SL0805 | LB4903 | SL1206 | MGLB3216_060T_LF | SL1206 | LB4904 | SL0603 | MGLB1608_030T_LF | SL0603 | LB5201 | SL0402 | BLM15HG102SN1D | SL0402 | LB5202 | SL0603 | MGLB1608_030T_LF | SL0603 | LB5203 | SL0603 | MGLB1608_030T_LF | SL0603 | M1 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M2 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M3 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M4 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M5 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M6 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M7 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M8 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M9 | HOLE126 | HOLE | HOLE126 | M10 | HOLE126 | HOLE | HOLE126 | M11 | HOLE100 | 1381028_NONE | HOLE100 | M12 | HOLE100 | 1381028_NONE | HOLE100 | M13 | HOLE100 | 1381028_NONE | HOLE100 | M14 | HOLE100 | 1381028_NONE | HOLE100 | OSC2651 | SX10-0303 | RX8900CEUB | SX10-0303 | Q1001 | SOT23 | NPN-BEC | SOT23 | Q4752 | SOT23 | PMOS-GSD | SOT23 | Q5202 | SOT23 | NPN-BEC | SOT23 | S1000 | PSW3-RA | BR-11C-11P6 | PSW3-RA | S3401 | SSW-PUSH | TL3301AF160RG | SSW-PUSH | S4151 | SSW-PUSH | TL3301AF160RG | SSW-PUSH | SW3851 | SW4_6M6X5M4 | EMR_0415_T_V_T_R | SW4_6M6X5M4 | T3701 | STFM24-40-280 | G24_0413ER | STFM24-40-280 | TP1 | TP24-SMD | TEST-SMD | TP24-SMD | TP3851 | TP24-SMD | TEST-SMD | TP24-SMD | U1 | HBGA997-26-3434 | SOC | HBGA997-26-3434 | U2 | BGA200-26-2212C | K4UBE3D4AA | BGA200-26-2212C | U3 | SOP8-26-118 | SGM822H | SOP8-26-118 | U4 | MLF13A-050-0302L | RT6236BHGQUF | MLF13A-050-0302L | U24 | BGA200-26-2212C | K4UBE3D4AA-MGCL000 | BGA200-26-2212C | U1000 | SOT23-6 | TMI3281 | SOT23-6 | U1151 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1152 | SOT23-5 | ETA3413S2F | SOT23-5 | U1153 | SOT23-6 | ETA8113S2G | SOT23-6 | U1154 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1301 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1302 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1303 | HMLF8-064-0302L | RT5789BGQUF | HMLF8-064-0302L | U1304 | MLF18A-050-0404L | RT6243B | MLF18A-050-0404L | U1451 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1452 | MLF18A-050-0404L | RT6243B | MLF18A-050-0404L | U1601 | SOT23-5 | ETA3413S2F | SOT23-5 | U1603 | SOT23-5 | ETA3413S2F | SOT23-5 | U1605 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U1606 | SOP10-20-124A | TPA626-VR-S | SOP10-20-124A | U2651 | SBAT2-13A | BR_1225F1AN | SBAT2-13A | U2851 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U3401 | SOP16-50-300A | MX25U25635F/NC* | SOP16-50-300A | U3402 | WSON8-MX25L12835ZN-AAA | MX35UF1G14AC | WSON8-MX25L12835ZN-AAA | U3403 | SOT23-5 | TPV6823V-TR-S1 | SOT23-5 | U3551 | BGA153-20-1414 | THGBMHG6C1LBAIL | BGA153-20-1414 | U3701 | QFN40-8211FI | RTL8211FI-CG | QFN40-8211FI | U3851 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U3852 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U3853 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U3854 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U3855 | SOP8-50-150B | TPT75176HL1-SO1R-S | SOP8-50-150B | U3856 | MLF24B-050-0404L | SGM6505HYTQF24G_TR | MLF24B-050-0404L | U4301 | SOT23-6L-FFF | AZ1515-04S | SOT23-6L-FFF | U4451 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U4452 | SOP8-20-91 | 74AVCH2T45DC | SOP8-20-91 | U4453 | SOP8-20-91 | PCA9306DC1_A | SOP8-20-91 | U4901 | SOT23-8 | SGM4553YN8G_TR | SOT23-8 | U4902 | SOP16-26-173 | * | SOP16-26-173 | U5051 | MLF6-065-0202L | SY6287CABC | MLF6-065-0202L | U5052 | MLF6-065-0202L | SY6287CABC | MLF6-065-0202L | U5201 | MLF16W-065-0404L | SY6703 | MLF16W-065-0404L | U5202 | SOP8-50-150 | SGM8270H-2XS8G_TR | SOP8-50-150 | U5801 | SGM8903 | SGM8903 | SGM8903 | X3 | HSX4-0302 | 24MHZ | HSX4-0302 | X3701 | HSX4-0302 | 25MHZ | HSX4-0302 | X4901 | HSX4-0302 | 25MHZ | HSX4-0302 |
重要提示:PCB作品文件展下载说明
