查看: 1252|回复: 9
[技术文章] 51单片机初学密码锁代码
社区居民终身成就奖金点子奖
发表于 2021-6-26 01:52 | 显示全部楼层 |阅读模式
51单片机初学密码锁代码
  wanbi=1;        break;
#include
#include
#define uint unsigned int
#define uchar unsigned char
uchar old1,old2,old3,old4,old5,old6; //原始密码000000
uchar new1,new2,new3,new4,new5,new6;  //每次MCU采集到的密码输入
uchar a=16,b=16,c=16,d=16,e=16,f=16; //送入数码管显示的变量
uchar wei,key,temp;
bit allow,genggai,ok,wanbi,retry,close;         //各个状态位
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
sbit sda=P2^0;                          //IO口定义
sbit scl=P2^1;
unsigned char code table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};
/*****************IIC芯片24C02存储器驱动程序************************************/
void nop()
        _nop_();
        _nop_();
/////////24C02读写驱动程序////////////////////
void delay1(unsigned int m)
{        unsigned int n;
          for(n=0;n
void init()  //24c02初始化子程序
        scl=1;
        nop();
        sda=1;
        nop();
void start()        //启动I2C总线
        sda=1;
        nop();
        scl=1;
        nop();
        sda=0;
        nop();
        scl=0;
        nop();
void stop()         //停止I2C总线
        sda=0;
        nop();
        scl=1;
        nop();
        sda=1;
        nop();
void writebyte(unsigned char j)  //写一个字节
        unsigned char i,temp;
           temp=j;
           for (i=0;i<8;i++)
           temp=temp<<1;
           scl=0;
           nop();
           sda=CY;                //temp左移时,移出的值放入了CY中
           nop();
           scl=1;                //待sda线上的数据稳定后,将scl拉高
           nop();
   scl=0;
   nop();
   sda=1;
   nop();
unsigned char readbyte()   //读一个字节
   unsigned char i,j,k=0;
   scl=0; nop(); sda=1;
   for (i=0;i<8;i++)
                nop(); scl=1; nop();
              if(sda==1)
                j=1;
              else
                j=0;
              k=(k<<1)j;
                  scl=0;
           nop();
        return(k);
void clock()         //I2C总线时钟
   unsigned char i=0;
   scl=1;
   nop();
   while((sda==1)&&(i<255))
             i++;
   scl=0;
   nop();
////////从24c02的地址address中读取一个字节数据/////
unsigned char read24c02(unsigned char address)
   unsigned char i;
   start();
   writebyte(0xa0);
   clock();
   writebyte(address);
   clock();
   start();
   writebyte(0xa1);
   clock();
   i=readbyte();
   stop();
   delay1(100);
   return(i);
//////向24c02的address地址中写入一字节数据info/////
void write24c02(unsigned char address,unsigned char info)
   start();
   writebyte(0xa0);
   clock();
   writebyte(address);
   clock();
   writebyte(info);
   clock();
   stop();
   delay1(5000); //这个延时一定要足够长,否则会出错。因为24c02在从sda上取得数据后,还需要一定时间的烧录过程。
/****************************密码锁程序模块********************************************************/
void delay(unsigned char i)
        uchar j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
   dula=0;
   P0=table[a];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table;
   dula=1;
   dula=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(5);
   P0=table[c];
   dula=1;
   dula=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(5);
   P0=table[d];
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   P0=table[e];
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[f];
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=0;
                           wei++;
               break;
          case 0xde:
               key=1;
                           wei++;
               break;
          case 0xbe:
               key=2;
                           wei++;
               break;
          case 0x7e:
               key=3;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=4;
                           wei++;
               break;
          case 0xdd:
               key=5;
                           wei++;
               break;
          case 0xbd:
               key=6;
                           wei++;
               break;
          case 0x7d:
               key=7;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=8;
                           wei++;
               break;
          case 0xdb:
               key=9;
                           wei++;
               break;
          case 0xbb:
               genggai=1;
                           wei=0;
               break;
          case 0x7b:
                             if(allow)
               ok=1;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
          P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xe7:
                             retry=1;
               break;
          case 0xd7:
                             close=1;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
void shumima()                //对按键采集来的数据进行分配
        if(!wanbi)
        switch(wei)
                case 1:new1=key;
                            if(!allow)        a=17;
                           else a=key;        break;
                case 2:new2=key;
                                if(a==17) b=17;
                                else b=key;        break;
                case 3:new3=key;
                                if(a==17) c=17;
                                else c=key;        break;
                case 4:new4=key;
                                if(a==17) d=17;
                                else d=key;        break;
                case 5:new5=key;
                                if(a==17) e=17;
                                else e=key;        break;
                case 6:new6=key;
                                if(a==17) f=17;
                                else f=key;
发表于 2021-6-26 08:51 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:4
  • 最近打卡:2024-05-29 20:33:00
30
发表于 2021-6-26 10:09 | 显示全部楼层
发表于 2021-6-26 10:23 | 显示全部楼层
  • 打卡总天数:694
  • 打卡月天数:14
  • 打卡总奖励:2869
  • 最近打卡:2026-11-16 22:57:47
81
发表于 2021-6-26 11:31 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:17
  • 打卡总奖励:61
  • 最近打卡:2025-01-13 19:11:02
发表于 2021-6-27 16:18 | 显示全部楼层
社区居民终身成就奖金点子奖
 楼主| 发表于 2021-7-27 00:28 | 显示全部楼层
PADS20210616高级班
发表于 2021-7-27 07:46 | 显示全部楼层
社区居民终身成就奖金点子奖
 楼主| 发表于 2021-8-14 00:24 | 显示全部楼层
  • 打卡总天数:621
  • 打卡月天数:12
  • 打卡总奖励:2325
  • 最近打卡:2026-11-16 09:00:00
发表于 2023-1-17 08:38 | 显示全部楼层
