重要提示:PCB作品文件展下载说明
| Name | Part Type | PCB Decal | Value | | ADC2 | TP | TPEAA | <VALUE> | | APD1 | ADP-3--N | APD-3P-N | APDI-50P-R40-H-SM | | B57 | L0603 | L0603 | BLM18HD471/DNI | | B58 | L0603 | L0603 | BLM18HD471 | | CDR1 | CDR1 | CDR1 | 10UH | | CDR2 | CDR1 | CDR1 | 10UH | | CT14 | TC3528 | TC3528B | 10UF | | CT15 | TC3528 | TC3528BA | 22UF | | D1 | SOT23 | SOT23 | BAT54C | | D2 | SOT23 | SOT23 | BAT54 | | D4 | SOD123 | SOD123 | B0540W-7-F | | D5 | LED0805 | LED0805 | GREEN | | D8 | SOT23 | SOT23 | BAT54 | | D9 | SOD123 | SOD123 | B0540W-7-F | | D10 | SOT23 | SOT23 | BAT54 | | D11 | IN4148 | IN4148 | IN4148 | | J1 | HDR_2X7_1-27MM | HDR_2X7_1-27MM | HDR_2X7_1-27MM | | J2 | HEAD3_2-54MM | HEAD3_2-54MM | OLD-6107ARFC | | J3 | HEAD10X2-2MM-SMT | HEAD10X2_2MM-SMT | HDR20X1 | | J6 | JUMP-2P | JUMP-2P | JUMPER | | J10 | JUMP-2P | JUMP-2P | JUMPER | | J11 | CON-FFC-FCI-050-060 | CON-FFC-FCI-050-060 | FPC_SOCKET_60PIN | | J12 | JUMP-2P | JUMP-2P | JUMPER | | J15 | HDR_2X5_1-27MM | HDR_2X5_1-27MM | JATG/DNI | | K1 | 9002 | 9002 | SIL03 | | L1 | MOS6020 | MOS6020 | 6.8UH | | LD1 | APDI-4P-100 | APDI-4P-100 | FU-427SHL-V8 | | LD2 | APDI-4P-100 | APDI-4P-100 | FU-427SHL-V8 | | LED2 | LED0805 | LED0805 | LED/+5V_LD | | M1 | MASK | MASK | | | M2 | MASK | MASK | | | M3 | MASK | MASK | | | M11 | MASK | MASK | | | OSC3 | OSC5X7 | OSC5X7 | ECS-3953M-500 | | Q1 | SOT23 | SOT23 | MMBR931 | | Q2 | SOT23 | SOT23 | MMBR931 | | Q6 | SOT23 | SOT23 | 2N7002K | | Q8 | SOT23 | SOT23 | 2N7002K | | Q10 | SOT23 | SOT23 | MMBT3904 | | Q12 | SOT23 | SOT23 | MMBT3904/DNI | | Q13 | SOT23 | SOT23 | MMBT3904 | | Q14 | SOT23 | SOT23 | 2N7002K | | Q15 | SOT23 | SOT23 | 2N7002K | | Q16 | SOT23 | SOT23 | MMBT3904 | | Q17 | SOT23 | SOT23 | MMBT3904/DNI | | Q18 | SOT23 | SOT23 | 2N7002K | | Q19 | SOT23 | SOT23 | 2N7002K | | Q20 | SOT23 | SOT23 | 2N7002K | | Q21 | SOT23 | SOT23 | FFMT491A | | Q22 | SOT23 | SOT23 | 2N7002K | | U1 | EQFP144-1-7MM | EQFP144-1-7MM | MK60DN512ZVLQ10-EQFP144 | | U2 | SOT23-5 | SOT23-5 | AD8541ARTZ | | U3 | SO-8 | SO-8N | OPA699ID | | U4 | SOP8-225-50 | SOP8-225-50BB | ADA4817-1AR | | U5 | SO-8 | SO-8T | AD8038AR | | U6 | TSOP2-44 | TSOP2-44 | EM680FV8AU-EMLSI/DNI | | U7 | TSOC6 | TSOC6 | DS28E01-100 | | U8 | TSOC6 | TSOC6 | DS28E01-100/DNI | | U9 | TSSOP16 | TSSOP16 | MAX3221IPWR-TI | | U11 | SOT23-5 | SOT23-5 | TPS62207DBV-TI | | U12 | SOT23-5 | SOT23-5 | TPS62205DBV-TI | | U13 | TO-92-3 | TO-92-3 | AD592BN | | U14 | SOT23-5 | SOT23-5 | AD8541ARTZ | | U15 | SO-8 | SO-8M | W25Q16BVSSIG-WINBAND | | U18 | TSOP2-44 | TSOP2-44 | EM680FV8AU | | U20 | SO-8 | SO-8A | W25Q16BVSSIG-WINBAND | | U21 | SOT23-5 | SOT23-5 | SN65LVDS2 | | U22 | SO-8 | SO-8OA | LT1763CS8#PBF | | U24 | LFCSP_VQ32+PAD | LFCSP_VQ32+PAD | AD9649-80 | | U25 | SOP8-225-50 | SOP8-225-50BC | IC-HK | | U26 | BGA484-40-2222 | BGA484-40-2222 | EP4CE40F484 | | U27 | QFN16+PAD | QFN16+PAD | LT3482EUD | | U29 | SOT23-5 | SOT23-5 | AD8541ARTZ | | U30 | SOP8-225-50 | SOP8-225-50BAA | IC-HK | | U31 | MSOP8 | MSOP8 | ADG619BRMZ | | U32 | SOT23-5 | SOT23-5 | LT1964IS5-SD | | U33 | SO-8 | SO-8S | AD8039AR | | U34 | SO-8 | SO-8 | AD8039AR | | U35 | SO-8 | SO-8O | LM2663/SO | | U36 | SO-8 | SO-8 | LT1763CS8#PBF | | U37 | SO-8 | SO-8 | LT1763CS8#PBF | | U38 | SOT23-5 | SOT23-5 | SN65LVDS2 | | U39 | SO-8 | SO-8P | REF192GS | | VR2 | VR-3224-W | VR-3224-W | 10K0 | | Y1 | XTAL_2P_DIP_V | XTAL_2P_DIP_V | 32.768KHZ | | Y2 | XTAL-XS | XTAL-XS | 10MHZ |
重要提示:PCB作品文件展下载说明
