| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CR1 | DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123 | MBR0540T1G | SOD-123 |
| CR2 | DIODE_2PIN_SOD-123-480-30006-SOD123 | MBR140SFT | SOD123 |
| CR3 | DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123 | MBR0540T1G | SOD-123 |
| CR4 | DIODE_2PIN_SOD-123-480-75176-SOD123 | MBR0520LT1G | SOD123 |
| CR5 | DIODE_2PIN_SOD-123-480-75176-SOD123 | MBR0520LT1G | SOD123 |
| CR6 | DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123 | MBR0540T1G | SOD-123 |
| D1 | LED_LED_0603_C1-370-75078-LED_0603_C1 | BLUE | LED_0603_C1 |
| F46 | FERRITE_IND_0603-180-75106-IND_0603 | 60 OHM 100MHZ | IND_0603 |
| GVDD | TP_COLORS_TP040-210-75685-TEST_LOOP | TEST POINT WHITE | TEST_LOOP |
| J1 | DDR3_240P_CON_240_DDR3_DIMM_SKT-TMP-WF-6058-CON_240_DDR3_DIMM_SKT | CON_240_DIMM | CON_240_DDR3_DIMM_SKT |
| J2 | CONN_DVI_RTANGLE_CONN_DVI_24POS_RA_TH-210-76354-CONN_DVI_24POS | DVI_D_24 | CONN_DVI_24POS |
| J3 | CONN_RJ45_2X1VERT_LED_RA_CONN_RJ45_2X1VERT_LED-210-76036-CON_RJ45_2X1_MAG_LED | RJ45 13X2PORTS | CON_RJ45_2X1_MAG_LED |
| J4 | HDR_1X4_FRICTION_HEADER_1X4-210-79420-HDR4_2P54_TH | HDR 1X4 WLOCK | HDR4_2P54_TH_CUST |
| J5 | HEADER_1X2_WLOCK_HEADER_1X2-TMP-WF-12516-HDR102_E | HDR 1X2 WLOCK | HDR102_E |
| J6 | CONN_DF14_20P_125_20POS_CONN_1X20_RA_SMT-211-75624-CONN_1X20_RA_SMT | CON_20 | CONN_1X20_RA_SMT |
| J7 | PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049-CONN_2X32_THRUHOLE | PCI EXPRESS 64 | CONN_2X32_THRUHOLE |
| J8 | PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049 | PCI EXPRESS 64 | CONN_2X32_THRUHOLE |
| J9 | PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049-CONN_2X32_THRUHOLE | PCI EXPRESS 64 | CONN_2X32_THRUHOLE |
| J10 | CONN_MINIPCIE_RA_SMT-211-78711-CON_2X26_0P8_SMT | CON 2X26 MINI PCIEXPRESS | CON_2X26_0P8_SMT |
| J11 | HDR_2X5_SHROUDED_HDR_2X5-210-76356-HDR205_4W | CON_2X5 | HDR205_4W |
| J12 | CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SM | HDR 1X7 | CON_7_SATA_V_SM |
| J13 | CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SM | HDR 1X7 | CON_7_SATA_V_SM |
| J14 | CONN_SDC013_19P_CON19_SDCARD_28X16_SM-TMP-WF-6202-CON19_SDCARD_28X16_SM | CONN CRD 19 | CON19_SDCARD_28X16_SM |
| J15 | CONN_SDC013_19P_CON19_SDCARD_28X16_SM-TMP-WF-6202-CON19_SDCARD_28X16_SM | CONN CRD 19 | CON19_SDCARD_28X16_SM |
| J16 | HEADER_2X5_HEADER_2X5-210-76042 | HDR_2X5 | HDR205 |
| J17 | PCIEXPRESS_CONN_X16_CONN_PCIEXPRESS16-210-76047-CONN_PCIEXPRESS16 | PCI EXPRESS 164 | CONN_PCIEXPRESS16 |
| J18 | ATXPWR_2X12VERT_NOPEG_ATXPWR_2X12_VERT-TMP-WF-6398 | CON_2X12_PWR | CON_ATXPWR_2X12_A |
| J19 | HEADER_2X5_HEADER_2X5-210-76042-HDR205 | HDR_2X5 | HDR205 |
| J20 | HEADER_1X2_HEADER_1X2-210-76037 | HDR 1X2 | HDR102 |
| J21 | HEADER_1X2_HEADER_1X2-210-76037-HDR102 | HDR 1X2 | HDR102 |
| J22 | HEADER_1X3_HEADER_1X3_PTH-210-76038 | HDR_1X3 | HDR103 |
| J23 | HEADER_RISCWATCH_HEADER_RISCWATCH-210-30058-HDR208_B | CON_2X8 | HDR208_B |
| J24 | HEADER_1X2_HEADER_1X2-210-76037 | HDR 1X2 | HDR102 |
| J25 | CONN_MEC6_DV_2X20_STRAIGHT-TMP-WF-9353-CONN2X20_20X7MM | CONN MICRO EDGE 2X20 | CONN2X20_20X7MM |
| J26 | CONN_DUAL_DE9M_STACKED_RA_CONN_DUAL_STACKED_DB9-210-76331-DUALDB-9M_RA | 2XDB9 | DUALDB-9M_RA |
| J27 | ATXPWR_12V_2X2VERT_CONN_ATX12V_2X2-211-30025-CONN_ATX12V_2X2 | CON_2X2 | CONN_ATX12V_2X2 |
| J28 | SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
| J29 | SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
| J30 | CONN_BATTERY_VERT_BATTERY_VERT-801-75534-SKT_BAT_225X886_3V | WBA-3B2 U | SKT_BAT_225X886_3V |
| J31 | HEADER_1X2_HEADER_1X2-210-76037 | HDR 1X2 | HDR102 |
| J32 | HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_TH | HDR 1X3 | HDR1X3_TH |
| J33 | CONN_SMA_CONN_SMA-210-30138-CON_SMA | CON 1 SMA | CON_SMA |
| J34 | SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
| J35 | HEADER_1X2_HEADER_1X2-210-76037 | HDR 1X2 | HDR102 |
| J36 | SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
| J37 | HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_TH | HDR 1X3 | HDR1X3_TH |
| J39 | HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_TH | HDR 1X3 | HDR1X3_TH |
| J40 | CONN_8PIN_SMT_RA_CON20-211-77725-CONN_HDR_RA8 | 53261-0871 | CONN_HDR_RA8 |
| J41 | SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
| J42 | HDR_2X4_TH-TMP-WF-12518-HDR_2X4_SHRD_TH | CON 8 PLUG | HDR_2X4_SHRD_TH |
| L1 | INDUCTOR_IND_IHLP-TMP-WF-9765-IND_IHLP-5050 | 0.47UH | IND_IHLP-5050 |
| L2 | INDUCTOR_IND_0806-TMP-WF-10412-IND_0806_SM | 4.7UH | IND_0806_SM |
| L3 | INDUCTOR_IND_0806-TMP-WF-10412-IND_0806_SM | 4.7UH | IND_0806_SM |
| L4 | INDUCTOR_IND_IHLP-180-75018-IND_IHLP | 2.2UH | IND_IHLP |
| L5 | INDUCTOR_4PIN_CHOKE_0805-180-75108-CHOKE_0805 | 90OHM | CHOKE_0805 |
| L6 | INDUCTOR_4PIN_CHOKE_0805-180-75108-CHOKE_0805 | 90OHM | CHOKE_0805 |
| L7 | INDUCTOR_IND_IHLP-TMP-WF-4949-IND_IHLP | 1UH | IND_IHLP |
| L8 | INDUCTOR_IND_IHLP-TMP-WF-4949-IND_IHLP | 1UH | IND_IHLP |
| L9 | INDUCTOR_IND_IHLP-TMP-WF-6346-IND_IHLP | 0.68UH | IND_IHLP |
| MH1 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH2 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH3 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH4 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH5 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH6 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH7 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| MH8 | MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725 | MOUNTING HOLE | MTG156_PTH |
| OVDD | TP_COLORS_TP040-210-75685-TEST_LOOP | TEST POINT WHITE | TEST_LOOP |
| Q1 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-10090-TDSON8_1P27_6X5MM | BSC080N03MSG | TDSON8_1P27_6X5MM |
| Q2 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-10090-TDSON8_1P27_6X5MM | BSC080N03MSG | TDSON8_1P27_6X5MM |
| Q3 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q4 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q5 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| Q6 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| Q7 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| Q8 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q9 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q10 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| Q11 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q12 | MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4 | BSZ035N03LSG | TDSON8_0P65_SQ3P4 |
| Q13 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| Q14 | TRANSISTOR_PNP_SOT23-480-76358-SOT23 | MMBT2907A | SOT23 |
| Q15 | FDV301N_NFET-480-30061-SOT23-40X40 | FDV301N | SOT23-40X40 |
| Q16 | IRF7821_SO8-480-30 027-SO_8_1P27_4X5 | IRF7821PBF | SO_8_1P27_4X5 |
| Q17 | MMBT3904_SOT23-480-75757-SOT23 | MMBT3904 | SOT23 |
| SW1 | SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM | 218-8LPST | SW_DIP16_8POS_SM |
| SW2 | SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM | 218-8LPST | SW_DIP16_8POS_SM |
| SW3 | SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM | 218-8LPST | SW_DIP16_8POS_SM |
| SW4 | SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM | 218-8LPST | SW_DIP16_8POS_SM |
| SW5 | SW_8SPST_SW_SOM16-510-30020 | 218-8LPST | SW_DIP16_8POS_SM |
| SW6 | SW_8SPST_SW_SOM16-510-30020 | 218-8LPST | SW_DIP16_8POS_SM |
| SW7 | SW_8SPST_SW_SOM16-510-30020 | 218-8LPST | SW_DIP16_8POS_SM |
| SW8 | SW_8SPST_SW_SOM16-510-30020 | 218-8LPST | SW_DIP16_8POS_SM |
| SW9 | SW_8SPST_SW_SOM16-510-30020 | 218-8LPST | SW_DIP16_8POS_SM |
| SW10 | SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SM | G3B15AH-XC-RO | SW_3P_7P5X8P5_RA_SM |
| SW11 | SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SM | G3B15AH-XC-RO | SW_3P_7P5X8P5_RA_SM |
| SW12 | SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SM | G3B15AH-XC-RO | SW_3P_7P5X8P5_RA_SM |
| TP1 | TP_SMT_TPAD_015-TMP-WF-3724-TPAD_015 | TPAD_015 | TPAD_015 |
| TP100 | TP_COLORS_TP040-210-75683 | TEST POINT BLACK | TEST_LOOP |
| TP101 | TP_COLORS_TP040-210-75683 | TEST POINT BLACK | TEST_LOOP |
| TP103 | TP_SMT_TPAD_015-TMP-WF-3724-TPAD_015 | TPAD_015 | TPAD_015 |
| TP105 | TP_PTH_TP_PTH-TMP-WF-3719 | TP_PTH | TP_PTH |
| U1 | OSC_4PIN_7X5MM-230-77750-7X5MM | 11.2896MHZ | 7X5MM |
| U2 | 7SZ08P5_SC70-5P-312-30302-SC70-5 | NC7SZ08P5 | SC70-5 |
| U3 | TXB0102_SOT70_8-TMP-WF-11423-PSOP8 | TXS0102 | PSOP8 |
| U4 | WM8776_TQFP48-TMP-WF-11277-TQFP48 | WM8776SEFT | TQFP48 |
| U5 | OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_5 | 33.333M | XTLOSC4_5X7_5 |
| U6 | OSC_4PIN_XTLOSC4_5X7_5-230-75482 | 14.318MHZ | XTLOSC4_5X7_5 |
| U7 | ICS9FG108_TSSOP48-312-75881 | ICS9FG108 | TSSOP48 |
| U8 | P1022_TEPBGA689_1MM_31X31-TMP-WF-10934-TEPBGA689_1MM_31X31 | P1022 | TEPBGA689_1MM_31X31 |
| U9 | ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6 | ZL6100 | QFN36_0P5_6X6 |
| U10 | VSC8601_LQFP-312-77544-LQFP64_TAB_SQ158 | VSC8601XKN | LQFP64_TAB_SQ158 |
| U11 | VSC8601_LQFP-312-77544-LQFP64_TAB_SQ158 | VSC8601XKN | LQFP64_TAB_SQ158 |
| U12 | TI_TFP_410_64HTQFP-312-75880-64HTQFP | TFP410PAP | 64HTQFP |
| U13 | TXB0102_SOT70_8-TMP-WF-11423-PSOP8 | TXS0102 | PSOP8 |
| U14 | 74ALVCH16373_TSSOP48-312-79574-TSSOP48_PH | 74ALVCH16373DGGRG4 | TSSOP48_PH |
| U15 | 74ALVCH16373_TSSOP48-312-79574-TSSOP48_PH | 74ALVCH16373DGGRG4 | TSSOP48_PH |
| U16 | S29GL01GP_TSOP56-342-00096-TSOP56 | S29GL01GP11TFIR1 | TSOP56 |
| U17 | 8G_FLASH_1024MX8_TSOP_48P-TMP-WF-11658-TSOP48_12X20 | NAND08GW3B2CN1E | TSOP48_12X20 |
| U18 | PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5 | PI3B16226 | BQSOP40_0P5 |
| U19 | PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5 | PI3B16226 | BQSOP40_0P5 |
| U20 | SN74LVC1G125_SC70-5P-312-75240-SC-70 | SN74LVC1G125DCKR | SC-70 |
| U21 | TPS54310_HTSSOP20-312-75584-HTSSOP20 | TPS54310 | HTSSOP20 |
| U22 | TPS72515_DDPAK5-315-75431-DD-PAK5_420X625 | TPS72515KTTR | DD-PAK5_420X625 |
| U23 | 74LVT244_TSSOP20-312-75186-TSSOP20 | 74LVT244APW | TSSOP20 |
| U24 | DS90C387_TQFP100-312-75872-TQFP100 | DS90C387 | TQFP100 |
| U25 | TPS72515_DDPAK5-315-75431-DD-PAK5_420X625 | TPS72515KTTR | DD-PAK5_420X625 |
| U26 | PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TAB | PI2PCIE2412 | TQFN42_TAB |
| U27 | PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TAB | PI2PCIE2412 | TQFN42_TAB |
| U28 | PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TAB | PI2PCIE2412 | TQFN42_TAB |
| U29 | OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_5 | 33.333M | XTLOSC4_5X7_5 |
| U30 | SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16 | SN74CB3Q3253 | TVSOP16 |
| U31 | A3P600_FGG484_BGA484_1MM-TMP-WF-7981-BGA_484_1MM_23X23 | A3P600-FGG484 | BGA_484_1MM_23X23 |
| U32 | IDTQS3VH257_TSSOP16-312-75284 | IDTQS3VH257PA | TSSOP16 |
| U33 | ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6 | ECLAMP2357N.TCT | QFN16_3X3MM_1P6 |
| U34 | ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6 | ECLAMP2357N.TCT | QFN16_3X3MM_1P6 |
| U35 | ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6 | ECLAMP2357N.TCT | QFN16_3X3MM_1P6 |
| U36 | S25FL128P_WSON_8-WSON_8 | S25FL128P | WSON_8 |
| U37 | LT1331_SSOP28-312-75272-SSOP28 | LT1331CG#PBF | SSOP28 |
| U38 | VBUS054B_LLP75_6A-TMP-WF-7575-LLP75_6A | VBUS054B-HS3-GS08 | LLP75_6A |
| U39 | USB3315C_QFN24-312-79159-QFN24_4X4MM_SLUG | USB3315 | QFN24_4X4MM_SLUG |
| U40 | USB3315C_QFN24-312-79159-QFN24_4X4MM_SLUG | USB3315 | QFN24_4X4MM_SLUG |
| U41 | 74LVCH32244A_LFBGA_ZKE-312-75347-LFBGA-GKE | SN74LVCH32244AZKER | LFBGA-GKE |
| U42 | 74LVCH32244A_LFBGA_ZKE-312-75347-LFBGA-GKE | SN74LVCH32244AZKER | LFBGA-GKE |
| U43 | SN74LVC1G04_SOT_5P-312-75339 | SN74LVC1G04DCKRE4 | SC-70 |
| U44 | ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6 | ZL6100 | QFN36_0P5_6X6 |
| U45 | TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P6 | 1.8V/1.0A | DDPAK5_1P7_10P6 |
| U46 | TPS72525_DDPAK5-315-75313-DDPAK5_1P7_10P6 | TPS72525 | DDPAK5_1P7_10P6 |
| U47 | OSC_4PIN_XTLOSC4_5X7_5-TMP-WF-6271-XTLOSC4_5X7_5 | 25MHZ | XTLOSC4_5X7_5 |
| U48 | PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5 | PI3B16226 | BQSOP40_0P5 |
| U49 | TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P6 | 1.8V/1.0A | DDPAK5_1P7_10P6 |
| U50 | AT24C64A_SO8-334-76379-SO_8 | AT24C64C | SO_8 |
| U51 | TPS72525_DDPAK5-315-75313-DDPAK5_1P7_10P6 | TPS72525 | DDPAK5_1P7_10P6 |
| U52 | ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6 | ZL6100 | QFN36_0P5_6X6 |
| U53 | DS3232_SO20W-TMP-WF-6280-SO20W | DS3232 | SO20W |
| U54 | AT24C64A_SO8-334-76379-SO_8 | AT24C64C | SO_8 |
| U55 | OSC_4PIN_XTLOSC4_CB3_SM-230-76093-XTLOSC4_CB3_SM | 12.288MHZ | XTLOSC4_CB3_SM |
| U56 | ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5 | ICS8304AMLF | SO8_1P27_4X5 |
| U57 | TPS74801_QFN20_THIN-315-78227-QFN20_THIN | TPS74801 | QFN20_THIN |
| U58 | ICS307_02_SO16-312-75752 | ICS307M-02 | SO16 |
| U59 | ICS307_02_SO16-312-75752 | ICS307M-02 | SO16 |
| U60 | OSC_4PIN_XTLOSC4_710_SM-230-75349-OSC4-86X79-EH26 | 125MHZ | OSC4-86X79-EH26 |
| U61 | OSC_4PIN_7X5MM-TMP-WF-6976-7X5MM | 24.000MHZ | 7X5MM |
| U62 | ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5 | ICS8304AMLF | SO8_1P27_4X5 |
| U63 | ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5 | ICS8304AMLF | SO8_1P27_4X5 |
| U64 | TPS51200_QFN_10-TMP-WF-9510-QFN_10_0P5_3X3 | TPS51200 | QFN_10_0P5_3X3 |
| U65 | SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5 | SN74LVC1G86 | SOT-23-5 |
| U66 | SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5 | SN74LVC1G86 | SOT-23-5 |
| U67 | HEADER_2X25_05SP_HEADER_2X25_05SP_SMT-211-75181-CON_FTR-125-01-S-D | HDR_2X25 | CON_FTR-125-01-S-D |
| U68 | SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16 | SN74CB3Q3253 | TVSOP16 |
| U69 | 7SZ08P5_SC70-5P-312-30302-SC70-5 | NC7SZ08P5 | SC70-5 |
| U70 | NC7SB3157_SC70-6XP-312-30204-SC70-6 | NC7SB3157 | SC70-6 |
| U71 | NC7SB3157_SC70-6XP-312-30204-SC70-6 | NC7SB3157 | SC70-6 |
| U72 | MIC2076_1YM_SO8-312-75935-SOP8-1 | MIC2076-1YM | SOP8-1 |
| U73 | ADG804_MSOP10-TMP-WF-9815-MSOP10_60X12 | ADG804YRM | MSOP10_60X12 |
| U74 | ADG804_MSOP10-TMP-WF-9815-MSOP10_60X12 | ADG804YRM | MSOP10_60X12 |
| U75 | ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6 | ZL6100 | QFN36_0P5_6X6 |
| U76 | SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16 | SN74CB3Q3253 | TVSOP16 |
| U77 | IDTQS3VH257_TSSOP16-312-75284-TSSOP16 | IDTQS3VH257PA | TSSOP16 |
| U78 | AT24C02_TSSOP8-334-75798-TSSOP8 | AT24C02B-TH-B | TSSOP8 |
| U79 | ADT7461_SO8-901-30002-SO8 | ADT7461 | SO8 |
| U80 | AT24C02_TSSOP8-334-75798-TSSOP8 | AT24C02B-TH-B | TSSOP8 |
| U81 | LM96163_QFN10-312-79078-QFN10_0P5_3X3 | LM96163 | QFN10_0P5_3X3 |
| U82 | ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5 | ICS8304AMLF | SO8_1P27_4X5 |
| U83 | NC7SB3157_SC70-6XP-312-30204-SC70-6 | NC7SB3157 | SC70-6 |
| U84 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U85 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U86 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U87 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U88 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U89 | SN74LVC1G04_SOT_5P-312-75339 | SN74LVC1G04DCKRE4 | SC-70 |
| U90 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U91 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U92 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U93 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U94 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U95 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| U96 | 74CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5 | SN74CBTLV1G125DBVR | SOT23-5 |
| VDD | TP_COLORS_TP040-210-75684-TEST_LOOP | TEST POINT RED | TEST_LOOP |
| VDDC | TP_COLORS_TP040-210-75684-TEST_LOOP | TEST POINT RED | TEST_LOOP |
| VDDX | TP_COLORS_TP040-210-75684-TEST_LOOP | TEST POINT RED | TEST_LOOP |
