| Comment | Pattern | Quantity | Components |
| 6N60_TO-251AA_NDD04N60Z-1G | TO-251AA | 1 | Q1 |
| BRIDGE_2_MINI-BRIDGE_HD06-T | MINI-BRIDGE | 1 | D2 |
| CAP NP_PFCAP-10X5LS7_5_0.033UF | PFCAP-10X5LS7_5 | 1 | C7 |
| CAP NP_RC320LS140P60_3.3UF | RC320LS140P60 | 1 | C12 |
| CAP NP_TDK-X1Y1-250V_1000PF-Y1 | TDK-X1Y1-250V | 1 | C1 |
| CAP POL_RC200LS100P65_220UF | RC200LS100P65 | 1 | C73 |
| CAP POL_RC320LS140P60_1000UF | RC320LS140P60 | 1 | C10 |
| COMMON MODE_UTB01385_20MH | UTB01385 | 1 | L3 |
| DIODE DUALSCHOTTKY_SOT-23DF3_B | SOT-23DF3 | 2 | D18, D19 |
| DIODESCHOTTKY_SBR1U150_SK34A-L | SBR1U150 | 1 | D3 |
| DIODESCHOTTKY_SOD-123_1N5819HW | SOD-123 | 4 | D8, D10, D14, D23 |
| DIODEZENER_CASE403A_1SMB5915BT | CASE403A | 1 | D12 |
| DIODE_SOD-123FL_BAV21W-7-F | SOD-123FL | 1 | D27 |
| DIODE_SOD-123FL_SM4007PL-TP | SOD-123FL | 2 | D6, D20 |
| DIODE_SOD-523_1N4148WT-7 | SOD-523 | 1 | D17 |
| ERZ-V0D471_ERZ-VD_S07K320E2 | ERZ-VD | 1 | MOV1 |
| FAN6862_SSOT-6_FAN6862R | SSOT-6 | 1 | U9 |
| FUSIBLE-RES_RV200BD170P100D50_0 | RV200BD170P100D50 | 1 | FR1 |
| GBLC05C_SOD323-GBLC-BIDI_GBLC08 | SOD323-GBLC-BIDI | 1 | D43 |
| INDUCTOR_0402_60 OHM | 402 | 7 | L13, L35, L36, L37, L46, L47, L53 |
| INDUCTOR_0402_820NH | 402 | 4 | L22, L23, L32, L33 |
| INDUCTOR_0603_12UH | 603 | 2 | L28, L29 |
| INDUCTOR_0805_300 OHM | 805 | 1 | L24 |
| INDUCTOR_0805_60 OHM | 805 | 1 | L7 |
| INDUCTOR_IND-ELLV-3X3MM_3.3UH | IND-ELLV-3X3MM | 1 | L49 |
| INDUCTOR_IND-MI1206_600 OHM | IND-MI1206 | 1 | L15 |
| INDUCTOR_IND-NR4018_100UH | IND-NR4018 | 1 | L8 |
| INDUCTOR_IND-NR4018_10UH | IND-NR4018 | 2 | L2, L31 |
| INDUCTOR_VLF4014ST_2.2UH | VLF4014ST | 1 | L54 |
| J0026D01NL_RJ45-J0026_J0026D01N | RJ45-J0026 | 1 | J2 |
| LED_DUAL_ALT_LED-DUAL-0603_QSMF | LED-DUAL-0603 | 1 | D9 |
| LED-AC_LED-0603-SML41_SML-410MW | LED-0603-SML41 | 1 | D15 |
| LYNX-COUPLING-1PRI-2SEC_5345-XF | 5345-XFMR-LYNX-PLC | 1 | T2 |
| M25P16-VMWP6TP_UFDFPN-8_M25P16- | UFDFPN-8 | 1 | U7 |
| NCP1529A_SOT23-5_NCP1529A | SOT23-5 | 1 | U16 |
| OPTO-ISOLATOR_SMD-4_HMHA281 | SMD-4 | 2 | U3, U15 |
| PWR-SKT_AC-ASOKA1_ACIN (PADS) | AC-ASOKA1 | 1 | Designator1 |
| QCA6410_QFN68-8X8_QCA6410 | QFN68-8X8 | 1 | U8 |
| RES_1206_SMALL_220 | 1206_SMALL | 2 | R132, R133 |
| RM4-2FLY_0_RM4-2FL-SHIELDED_RM4 | RM4-2FL-SHIELDED | 1 | T3 |
| SPST_B3U-1000B_B3U-1000P-B | B3U-1000B | 1 | SW1 |
| TLV431CLP_SOT23-3-TLV431_TLV431 | SOT23-3-TLV431 | 1 | D4 |
| XTAL-3.2X2.5_XTAL-3_2X2_5_25.0M | XTAL-3_2X2_5 | 1 | Y2 |
