| Name | PCB Decal | Value | Part Type | | D1 | HSOD323A | D_A | HSOD323A | | D2 | SOT23 | NC | SOT23 | | D9 | SOT23 | NC | SOT23 | | D13 | SOT23 | S23T05C | SOT23 | | D15 | SOT23 | S23T05C | SOT23 | | D18 | SOD-123 | LBZT52C12 | SOD-123 | | D19 | HSOD323A | D_A | HSOD323A | | D20 | HSOD323A | D_A | HSOD323A | | D21 | SD0805-LED | LED_GREEN | SD0805-LED | | D24 | SOT23 | S23T05C | SOT23 | | D34 | LL-34 | 1N4148 | LL-34 | | D35 | SD0805-LED | LED_BLUE | SD0805-LED | | D36 | SD0805-LED | LED_RED | SD0805-LED | | D37 | SD0805-LED | LED_YELLOW | SD0805-LED | | D46 | SMA | SS32A | SMA | | D47 | SMA | SS32A | SMA | | D48 | SMA | SS32A | SMA | | F1 | 1812 | SMD_PPTC-1A | 1812 | | J9 | PCIE_4X_MALE_64 | NC | PCIE_4X_MALE_64 | | J17 | MJ8-SRLFY | MJ8-SL | MJ8-SRLFY | | J26 | WBC0119-20R-A | 0 | WBC0119-20R-A | | J32 | 4PIN_2.0MM | 4PIN_2.0MM | 4PIN_2.0MM | | J33 | 2PIN_2.54MM | 2PIN_2.54MM | 2PIN_2.54MM | | J35 | 4PIN_2.0MM | 4PIN_2.0MM | 4PIN_2.0MM | | J36 | USBX2 | DUAL_USB-A_TYPE | USBX2 | | J37 | VAF6-1406D | MIC6M1_A | VAF6-1406D | | J38 | 2PIN_2.54MM | 2PIN_2.54MM | 2PIN_2.54MM | | J39 | 2PIN_2.54MM | NC | 2PIN_2.54MM | | L5 | CD42 | CD42-4R7_4.7UH | CD42 | | L6 | SL0402 | 220NH | SL0402 | | L7 | CD75 | CD75-4R7_4.7UH | CD75 | | M1 | HOLE160 | NC | HOLE160 | | M2 | HOLE160 | NC | HOLE160 | | Q16 | SOT23 | MMBT3904 | SOT23 | | S2 | SSW-3X6X2.5MM-2PIN | KEY | SSW-3X6X2.5MM-2PIN | | T2 | STFM16-50-285 | 000-7090-37R | STFM16-50-285 | | TVS7 | SOT23 | S23T05 | SOT23 | | TVS8 | SOT23 | S23T05 | SOT23 | | U1 | TFBGA395-32-2323 | S40V300_19X19 | TFBGA395-32-2323 | | U2 | TSOT23-8 | MP1495 | TSOT23-8 | | U3 | BGA96-32-1609I | MT41J256M16RE-15E-D | BGA96-32-1609I | | U4 | SOT23A-6L | ESD5305F_CS0806U | SOT23A-6L | | U6 | BGA96-32-1609I | MT41J256M16RE-15E-D | BGA96-32-1609I | | U8 | RN8-0402 | CS2203-25 | RN8-0402 | | U19 | SOP48-20-720B | NC | SOP48-20-720B | | U21 | SOP8-50-150 | MAX3485E | SOP8-50-150 | | U22 | TSOT23-8 | MP1495 | TSOT23-8 | | U23 | DFN2510P10E | ESD5304D_CS0806S | DFN2510P10E | | U24 | DFN2510P10E | ESD5304D_CS0806S | DFN2510P10E | | U25 | SOT-DPAK | BL1117CY-ADJ | SOT-DPAK | | U26 | MLF32-050-0505LE | TLV320AIC31 | MLF32-050-0505LE | | U27 | TSOT23-8 | MP1495 | TSOT23-8 | | U28 | TSOT23-8 | MP1495 | TSOT23-8 | | U29 | TSOT23-8 | MP1495 | TSOT23-8 | | U30 | SOT-143 | IMP811T | SOT-143 | | X2 | SM-49 | 24MHZ | SM-49 |
