| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1 | JC-442022A1Q1G_3_ANT-4D5X2D2_QQ | QQ-36K1G | ANT-4D5X2D2 |
| ANT2 | JC-442022A1Q1G_3_ANT-4D5X2D2_QQ | QQ-36K1G | ANT-4D5X2D2 |
| ANT3 | JC-442022A1Q1G_3_ANT-4D5X2D2_QQ | QQ-36K1G | ANT-4D5X2D2 |
| CN_BAT | CPBA206-0101F_CON6_POWER_CPBA20 | CPBA206-0102E | CON6_POWER_CPBA206-0102E |
| CN_BTN | CONN_1_FPC6P_0D5M_Y5BAYF530635 | Y5B AYF530635 | FPC6P_0D5M |
| CN_DLP | AXF361500_0_CON10_POWER_CPBA206 | AXF361500 | CON10_POWER_CPBA206-B01 |
| CN_EC | CON6_WTB_MTG2_0_1X6_P8MM_WTB_NC | NC_50208-00601-001 | 1X6_P8MM_WTB |
| CN_HDMI | CONN_0_FPC30_05_17X3D2_H1D75_FH | FH34SRJ-30S-0.5SH | FPC30_05_17X3D2_H1D75 |
| CN_RTC | SUR08T-WT-2A_ACES50278_2P_1D25_ | 50278-00201-001 | ACES50278_2P_1D25 |
| CN_SPI | CON6_WTB_MTG2_0_1X6_P8MM_WTB_NC | NC_50208-00601-001 | 1X6_P8MM_WTB |
| CN_SPKL | SUR08T-WT-5A_0_FPC4P_0D5M_Y5BA | Y5B AYF530435 | FPC4P_0D5M |
| CN_SPKR | SUR08T-WT-5A_0_FPC4P_0D5M_Y5BA | Y5B AYF530435 | FPC4P_0D5M |
| CN_SSD | M2_KEY_B_0_NGFF_75P_0D5_H2D15_S | SM3ZS067U215ABR1500 | NGFF_75P_0D5_H2D15_SMT_S |
| CN_USB | CON24_USB_TYPEC_1_CON24_USB_C_M | DX07B024JJ1 | CON24_USB_C_MIDMT_AUSB0129 |
| CR1 | ESD9X7V_0_SMCR_1P0XP6_FBP02C_ES | ESD9X7V-2T/R | SMCR_1P0XP6_FBP02C |
| CR2 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR3 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR4 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR5 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR6 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR7 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR8 | ESD5344D_0_LCC10_NS_2P5X1P0_P65 | ESD5344D-10TR | LCC10_NS_2P5X1P0_P65H |
| CR9 | ESD5344D_0_LCC10_NS_2P5X1P0_P65 | ESD5344D-10TR | LCC10_NS_2P5X1P0_P65H |
| CR10 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR11 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR12 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR13 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR14 | ZENER_SOD523F_BZX584C22 | BZX584C22 | SOD523F |
| CR15 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR16 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR17 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR18 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR19 | DIO_ESD_SMCR_P6X1P0_P40H_ESD531 | ESD5311X-2/TR | SMCR_P6X1P0_P40H |
| CR20 | DIO_ESD_SMCR_P6X1P0_P40H_ESD531 | ESD5311X-2/TR | SMCR_P6X1P0_P40H |
| CR30 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR31 | DIO_ESD_SMCR_P6X1P0_P40H_ESD545 | ESD5451X-2/TR | SMCR_P6X1P0_P40H |
| CR32 | ESD9X7V_0_SMCR_1P0XP6_FBP02C__1 | ESD5401N-2/TR | SMCR_1P0XP6_FBP02C |
| CT1 | CAPT_F93_2P_H1D9_33UF/16V | 33uF/16V | F93_2P_H1D9 |
| CT2 | CAPT_F93_2P_H1D9_33UF/16V | 33uF/16V | F93_2P_H1D9 |
| CT3 | CAPT_F93_2P_H1D9_150UF/6V | 150uF/6V | F93_2P_H1D9 |
| CT6 | CAPT_F93_2P_H1D9_150UF/6V | 150uF/6V | F93_2P_H1D9 |
| D1 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D2 | DIODETWIN_SOT23_BAT54C | BAT54C | SOT23 |
| D4 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D5 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D6 | D_2_SOD-123_BZT52C4V3 | BZT52C4V3 | SOD-123 |
| D9 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D10 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D11 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D12 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D13 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D14 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D15 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D16 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D17 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D18 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D19 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D20 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D21 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D22 | SCHOTTKY_SOD923_0_SOD-123_B5819 | B5819W | SOD-123 |
| D23 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D24 | DIODE_SOD323_B5819WS | B5819WS | SOD323 |
| D25 | DIODE_SOD323_NC_B5819WS | NC_B5819WS | SOD323 |
| D3+ | TESTPAD_CIR#2_0_TESTPAD_C40_NC_ | NC_C40 | TESTPAD_C40 |
| D3- | TESTPAD_CIR#2_0_TESTPAD_C40_NC_ | NC_C40 | TESTPAD_C40 |
| F3 | FUSE_FSMD1206P150TS_F1206HI4000 | F1206HI4000V032T | FSMD1206P150TS |
| F4 | FUSE_FSMD1206P150TS_F1206HI4000 | F1206HI4000V032T | FSMD1206P150TS |
| FB1 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB2 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB3 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB4 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB5 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB6 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB7 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB8 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB9 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB10 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB11 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| FB12 | FB0805 | 100ohm@100MHz | SMF0603 |
| FB13 | FB0805 | 100ohm@100MHz | SMF0603 |
| FB14 | FERRITEBEAD_SML0402_120OHM@100 | 120ohm@100MHz,400mA | SML0402 |
| GND | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| GND1 | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| L1 | INDUCTOR_SML2520_1P2H_4.7UH/1.3 | 4.7uH/1.3A | SML2520_1P2H |
| L2 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L3 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L4 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L5 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L6 | BW_3_CHOKE-DLP11SN900HL2L-4P-1_ | NC_DLP11TB800UL2 | CHOKE-DLP11SN900HL2L-4P-1 |
| L7 | BW_3_CHOKE-DLP11SN900HL2L-4P-1_ | NC_DLP11TB800UL2 | CHOKE-DLP11SN900HL2L-4P-1 |
| L8 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L9 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L10 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L11 | BW_4_CHOKE-DLP11SN900HL2L-4P-1_ | NC_EXC24CG900U | CHOKE-DLP11SN900HL2L-4P-1 |
| L12 | INDUCTOR_TMP0618_7X6D6_H1D6_TMP | TMPC0618H-2R2MG-D | TMP0618_7X6D6_H1D6 |
| L15 | INDUCTOR_TMP0618_7X6D6_H1D6_TMP | TMPC0618H-2R2MG-D | TMP0618_7X6D6_H1D6 |
| L16 | INDUCTOR_TMP0618_7X6D6_H1D6_TMP | TMPC0618H-2R2MG-D | TMP0618_7X6D6_H1D6 |
| L17 | INDUCTOR_TMP0618_7X6D6_H1D6_TMP | TMPC0618H-2R2MG-D | TMP0618_7X6D6_H1D6 |
| L18 | INDUCTOR_SML2520_1P2H_4.7UH/1.3 | 4.7uH/1.3A | SML2520_1P2H |
| L1AP11 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP21 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP31 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP41 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP51 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP61 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP71 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP81 | INDUCTOR_SML2520_1P2H_1UH/2.9A | 1uH/2.9A | SML2520_1P2H |
| L1AP91 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP101 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| L1AP111 | INDUCTOR_SML2520_1P2H_1UH/2.9A | 1uH/2.9A | SML2520_1P2H |
| L1AP121 | INDUCTOR_SML2520_NONC_1P0H_0.47 | 0.47uH/5A | SML2520_NONC_1P0H |
| LED1 | LED_2_LED_4P_BL-HJEGKB534S-TRB_ | BL-HJEGKB534S-TRB | LED_4P_BL-HJEGKB534S-TRB |
| MH1 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH2 | HOLEC335D185_0_HOLE_C157D71_NUL | NC_Hole | HOLE_C157D71_NUL |
| MH3 | HOLEC335D185_0_HOLE_C157D71_NUL | NC_Hole | HOLE_C157D71_NUL |
| MH4 | HOLEC335D185_0_HOLE_C157D71_NUL | NC_Hole | HOLE_C157D71_NUL |
| MH5 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH6 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH7 | HOLEC335D185_0_HOLE_C157D71_NUL | NC_Hole | HOLE_C157D71_NUL |
| MH8 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH9 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH10 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH11 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH12 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MH13 | HOLEC335D185_0_HOLE_C157D71_NC_ | NC_Hole | HOLE_C157D71 |
| MIC1 | MIC_SPK0415HM4H-B_0_ZTS6031_8P_ | ZTS6031 | ZTS6031_8P_3X4_H1D06 |
| MIC2 | MIC_SPK0415HM4H-B_0_ZTS6031_8P_ | ZTS6031 | ZTS6031_8P_3X4_H1D06 |
| MK1 | FMARKC_FIDICALMARK_NC_FMARKS | NC_FMARKS | FIDICALMARK |
| MK2 | FMARKC_FIDICALMARK_NC_FMARKS | NC_FMARKS | FIDICALMARK |
| MK3 | FMARKC_FIDICALMARK_NC_FMARKS | NC_FMARKS | FIDICALMARK |
| MK4 | FMARKC_FIDICALMARK_NC_FMARKS | NC_FMARKS | FIDICALMARK |
| PC3 | CAPNP_SMC0402_1UF/10V,X5R | 1uF/10V,X5R | SMC0402 |
| PC4 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC5 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC6 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC7 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC8 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC9 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC10 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC11 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC12 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC13 | CAPNP_SMC0402_27X47_4.7UF/10V, | 4.7uF/10V,X5R | SMC0402_27X47 |
| PC14 | CAPNP_SMC0402_1UF/10V,X5R | 1uF/10V,X5R | SMC0402 |
| PC15 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC16 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC17 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC18 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC19 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC20 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC21 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC22 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC23 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC24 | CAPNP_SMC0402_27X47_4.7UF/10V, | 4.7uF/10V,X5R | SMC0402_27X47 |
| PC25 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC26 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC27 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PC28 | CAPNP_SMC0402_0.1UF/25V,X5R | 0.1uF/25V,X5R | SMC0402 |
| PC29 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC30 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC31 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC32 | CAPNP_SMC0603_HI_VALUE_22UF/6. | 22uF/6.3V,X5R | SMC0603_HI_VALUE |
| PC33 | CAPNP_SMC0603_HI_VALUE_10UF/16 | 10uF/16V,X5R | SMC0603_HI_VALUE |
| PD1 | DIODETWIN_SOT23_BAT54C | BAT54C | SOT23 |
| PD2 | DIODETWIN_SOT23_BAT54C | BAT54C | SOT23 |
| PFB1 | FB0805 | 100ohm@100MHz | SMF0603 |
| PFB2 | FB0805 | 100ohm@100MHz | SMF0603 |
| PFB3 | FB0805 | 100ohm@100MHz | SMF0603 |
| PFB4 | FB0805 | 100ohm@100MHz | SMF0603 |
| PR3 | R_SMR0603_0R | 0R | SMR0603 |
| PR4 | R_SMR0603_0R | 0R | SMR0603 |
| PR5 | R_SMR0603_0R | 0R | SMR0603 |
| Q1 | NMOS_SOT723_SOT723_WNM2030-3/TR | WNM2030-3/TR | SOT723 |
| Q18 | TDSON-8_1_CON9-3_2X3_2-H0_9_QM3 | QM3004M3 | CON9-3_2X3_2-H0_9 |
| Q19 | TDSON-8_1_CON9-3_2X3_2-H0_9_QM3 | QM3004M3 | CON9-3_2X3_2-H0_9 |
| Q20 | NMOS_SOT723_SOT723_WNM2030-3/TR | WNM2030-3/TR | SOT723 |
| Q21 | TDSON-8_1_CON9-3_2X3_2-H0_9_Q_1 | QM3006M3 | CON9-3_2X3_2-H0_9 |
| Q22 | TDSON-8_1_CON9-3_2X3_2-H0_9_Q_1 | QM3006M3 | CON9-3_2X3_2-H0_9 |
| Q23 | NMOS_SOT723_SOT723_WNM2030-3/TR | WNM2030-3/TR | SOT723 |
| Q25 | NMOS_SOT723_SOT723_WNM3013-3/TR | WNM3013-3/TR | SOT723 |
| Q27 | NMOS_SOT723_SOT23_2N7002K-H | 2N7002K-H | SOT23 |
| Q28 | PRPAK3_3_CON9-3_2X3_2-H0_9_QM30 | QM3003M3 | CON9-3_2X3_2-H0_9 |
| Q29 | PRPAK3_3_CON9-3_2X3_2-H0_9_QM30 | QM3003M3 | CON9-3_2X3_2-H0_9 |
| Q30 | PRPAK3_3_CON9-3_2X3_2-H0_9_QM30 | QM3003M3 | CON9-3_2X3_2-H0_9 |
| Q33 | PRPAK3_3_CON9-3_2X3_2-H0_9_QM30 | QM3003M3 | CON9-3_2X3_2-H0_9 |
| Q34 | PRPAK3_3_CON9-3_2X3_2-H0_9_QM30 | QM3003M3 | CON9-3_2X3_2-H0_9 |
| Q35 | NMOS_SOT723_SOT723_WNM2030-3/TR | WNM2030-3/TR | SOT723 |
| Q37 | NMOS_SOT723_SOT723_WNM3013-3/TR | WNM3013-3/TR | SOT723 |
| Q38 | NMOS_SOT723_SOT723_WNM3013-3/TR | WNM3013-3/TR | SOT723 |
| Q39 | NMOS_SOT723_SOT723_WNM3013-3/TR | WNM3013-3/TR | SOT723 |
| Q40 | NMOS_SOT723_SOT23_2N7002K-H | 2N7002K-H | SOT23 |
| Q41 | NMOS_SOT723_SOT723_WNM2030-3/TR | WNM2030-3/TR | SOT723 |
| RX | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| RXD | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| SH2 | SHUNT_POINT_SHUNT_0805_NC_SHUNT | NC_SHUNT_0805 | SHUNT_0805 |
| SH2VR11 | SHUNT_POINT_SHUNT_0402_NC_SHUNT | NC_SHUNT_0402 | SHUNT_0402 |
| TX | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| TXD | TESTPAD_CIR_0_TESTPAD_1P0X1P5_N | NC_R1X1P5 | TESTPAD_1P0X1P5 |
| U1 | BIOS_SOIC8_SOIC8_208_GD25LQ64CV | GD25LQ64CVIGR | SOIC8_208 |
| U2 | ASM1061_QFN48_0R5_7X7_EP_ASM106 | ASM1061 | QFN48_0R5_7X7_EP |
| U3 | SST25LF040A_SOIC_8P_50_197X236_ | GD25D05BTIG | SOIC_8P_50_197X236 |
| U4 | WIFI_BT_MODULE_12X16_LCC100_M2_ | 7265.D2WG18V | LCC100_M2_1216_COMBO_1P75H |
| U5 | ALC5672_LCC48_P4MM_SQ6MM_SQ4P4D | ALC5672-VB-CGT | LCC48_P4MM_SQ6MM_SQ4P4DIE |
| U6 | PS8750B_0_QFN52_6D5X4D5_035_H07 | PS8750BQFN52GTR-A0 | QFN52_6D5X4D5_035_H075 |
| U7 | ESD5344D_0_LCC10_NS_2P5X1P0_P65 | ESD5344D-10TR | LCC10_NS_2P5X1P0_P65H |
| U8 | ESD5344D_0_LCC10_NS_2P5X1P0_P65 | ESD5344D-10TR | LCC10_NS_2P5X1P0_P65H |
| U9 | IT8110E_0_LQFP64_0D4_1D6_IT8110 | IT8110E/CX | LQFP64_0D4_1D6 |
| U10 | BIOS_SOIC8_SOIC8_208_GD25D10BTI | GD25D10BTIG | SOIC8_208 |
| U11 | TPS51206_2_DSQ_P04_10PH08_NC_TP | NC_TPS51206DSQR | DSQ_P04_10PH08 |
| U12 | ISL9237_3_QFN32_4X4_ISL9237HRZ | ISL9237HRZ | QFN32_4X4 |
| U15 | APL3526QBI_0_UQFN3_3_16PIN_RT72 | RT7291A | UQFN3_3_16PIN_RT7290A |
| U16 | APL3526QBI_1_UQFN3_3_16PIN_RT72 | RT7290A | UQFN3_3_16PIN_RT7290A |
| U18 | APL3526QBI_1_UQFN3_3_16PIN_RT_1 | RT6220AGQUF | UQFN3_3_16PIN_RT7290A |
| U23 | WL2801E28-5/TR_1_QFN4_PH0P625_1 | RT9073A-18GQZ | QFN4_PH0P625_1X1_H0P4 |
| U47 | SGM4553_SOT23_8_H1D25_SGM4553YN | SGM4553YN8G/TR | SOT23_8_H1D25 |
| U82 | KTD2511CEHD_1_TSOT23_6_BL9342 | BL9342 | TSOT23_6 |
| U3900 | SY6288_SOT23_5_H1D25_SGM2588AYN | SGM2588AYN5G/TR | SOT23_5_H1D25 |
| U3901 | SY6288_SOT23_5_H1D25_SGM2588AYN | SGM2588AYN5G/TR | SOT23_5_H1D25 |
| U3902 | SY6288_SOT23_5_H1D25_SGM2588AYN | SGM2588AYN5G/TR | SOT23_5_H1D25 |
| U1AM1 | K3QF4F40BM-AGCE_BGA253_P5MM_11P | K3QF4F40BM-AGCF | BGA253_P5MM_11P5X11_1P0H |
| U1AM2 | K3QF4F40BM-AGCE_BGA253_P5MM_11P | K3QF4F40BM-AGCF | BGA253_P5MM_11P5X11_1P0H |
| U1AP1 | WHISKEYCOVE_CHT_PMIC_A1_4_BGA24 | PMB6835A.P10 SLKMQ | BGA240_P4MM_6P095X6P495_P635H |
| U1AS1 | CHT_T_FFD_PR0_REV1P3_7_BGA1380_ | X7-Z8700 SR27MFJ8066401715809 | BGA1380_P4MM_17X17_CHV |
| Y1 | XTAL_4P_SMY_4P_79X98_PAD37X39_2 | 20MHz | SMY_4P_79X98_PAD37X39 |
| Y1AP11 | XTAL_2P_SMY2P_49X83_32.768KHZ | 32.768KHz | SMY2P_49X83 |
| Y1AS11 | XTAL_4P_SMY_4P_79X98_PAD37X39_1 | 19.2MHz | SMY_4P_79X98_PAD37X39 |
| Y1AS21 | XTAL_2P_SMY2P_49X83_32.768KHZ | 32.768KHz | SMY2P_49X83 |
