查看: 12645|回复: 5
[Allegro16.6以下] T4240RDB-PB, QorIQ T4240 Reference Design Board using part PT4240PSE7QQA by N
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-23 21:08:56 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Part Number
Product Name
Description
Part Reference
Quantity
3BD0338403X00
(N)10-BIT FET BUS SWITCHTI:SN74CB3Q3384APWR
SMD TSSOP-PW VCC:2.3V-3.6V
U57
3BP0971104X00
(N)(H)USB POWER SWITCH RICHTEK:RT9711CGB
SMD SOP-23-5 5PIN
U47 U48
3BT3035E01X00
(N)(H)SENSING LOGIC LEVEL TRANSLATORINTERSIL:ISL3035EIRTZ
SMD TQFN 16PIN
U45
3G01270F01X00
GAL CPLD ALTERA:EPM1270F256C5N BLANK
SMD 256PIN FBGA BLANK 250D/10-20S
U27
3I001G0803X00
CMOS IC TI:SN74LVC1G08DBV
SMD SOT23-5
U1 U4 U5
3I01G12602X00
(T)CMOS IC TI:SN74LVC1G126DBV
SMD SOT23-5 Buffer with 3-State output
U71 U72
3K00200201X00
(N)LEVEL TRANSLATING REPEATERNXP:NVT2002DP
SMD TSSOP8 8PIN
U18 U54 U56 U59 U73 U74
3K00951701X00
(N)LEVEL TRANSLATING I2C BUS REPEATERNXPCA9517ADP
SMD TSSOP 8PIN
U58
3K08510801X00
(N)LOW SKEW 1TO 8 CLOCK BUFFERIDT:ICS85108AGILF
SMD TSSOP 24PIN 3.3V
U29
3K08535A01X00
(N)LOW SKEW 1 TO 4 FANOUT BUFFERIDT:ICS8535AGI-31LF
SMD TSSOP 20PIN 3.3V
U32
3K49N22201X00
(N)(H)UNIVERSAL FREQUENCY TRANSLATORIDT:8T49N222B-110NLGI
SMD VFQFN 48PIN 3.3V
U35
3K840NT401X00
(N)(H)DDR CLOCK GEN. IDT:840NT4NLGI-FRE
U36
3K840NT402X00
(N)(H)USB CLOCK GEN. IDT:840NT4-01NLGI
U34
3KMC100L01X00
LOW SKEW 1 TO 5 DIFF CLOCK BUFFERON:MC100LVEP14DTG
U64
3MB0001G01X00
(N)FLASH MEMORY MirrorBitSPANSION:S29GL01GS10TFI010
SMD TSOP56 2.7-3.6V
U37
3MB0016G01X00
(N)FLASH MEMORYMICRON:MT29F16G08ABABAWP:B
SMD TSOP48 3.3V BOTTOM BOOT BLOCK FLASH
U38
3ME24C0207X00
(H)EEPROM ATMEL:AT 24C02C-SSHM-T
1.7V-5.5V SMD SO8
U13
3P00355001X00
(N)(H)PWM CONTROLLER IR:IR3550MTRPBF
SMD PQFN 32PIN
U10 U11 U12 U7 U8 U9
3P00356503X00
(H)PWM CONTROLLER IR:IR3565AMTRPBFCOLOR:R
Code Name:NSB5640_4n2_AC_RevA_032913 SMDQFN 48PIN
U3
3P00389701X00
(N)(H)PWM CONTROLLER IR:IR3897MTRPBF
SMD PQFN 17 PIN
U23 U25 U28 U33 U44 U70
3P05120601X00
(N)(H)DDR TERMINATION REGULATORTI:TPS51206DSQR
SMD SON 10PIN 2x2mm
U14 U17
3P07440101X00
(N)(H)LDO REGULATOR TI:TPS74401RGWR
SMD VQFN 20PIN Vin:1.04V-5.5VVOUT:0.796V-3.6V 3A
U39 U68 U69
3S83793G02X00
H/W MONITORING IC WINBOND:W83793G
SMD SSOP 56PIN 260D/20-40S
U6
3T00010401X00
(N)(H)VOLTAGE-LEVEL TRANSLATORTI:TXB0104PWRG4
SMD TSSOP 14PIN
U40 U41
3T00434001X00
(N)10GE PHY 4 PORTCORTINA:WPCS4340C.A0-900031
SMD BGA 196PIN
U65
3T00866401X00
GIGA PHY VITESSE:VSC8664XIC
SMD BGA 256PIN
U42 U43
3TADM21301X00
TRANSCEIVER AD:ADM213EARSZ
TRANSCEIVER,ANALOG DEVICE,ADM213EARSZ,SMDSSOP 28PIN,PBFREE
U46
3XC0002527X00
(N)(H)XTAL 25MHz AKER:CXA-025000-3X4X22
SMD(3.2x2.5) 20pF +-30ppm
X4
3XC3276817X00
(H)XTAL 32.768KHz AKER26-032768-2FRD41
DIP(6x2) 12.5pF +-10ppm
X2
3XQ0004801X00
(N)(H)OSC 48MHz AKER:SMA-048000-5BL0TC
3.3V SMD(5x3.2) 15pF +-50ppm
X1
3XQ1562507X00
(N)(H)OSC 156.25MHz LVPECLDISCERASC1122AI2-156.2500T
2.25V-3.6V SMD(7x5)  +-25ppm -45-85
U63
3XQ3276801X00
(N)(H)OSC 32.768KHzAKER:SMA-000032-5XL2T0
3.3V SMD(5x3.2) 15pF +-30ppm
X3
4BS05640C1X10
(N)PCB NSB5640 VER:C
285x253mm LAY:16 THICKNESS:1.6mm OSP
PCB
4CB337E251X00
(T)NP CAP 330uF/25VNCC:EMZA250ADA331MHA0G
+-20% 8x10mmSMD ESR:160m RP:600mA
CT6 CT27 CT50
4CC100B501X00
(H)MLCC 10pF/50V +-0.5pF 0402 NPO PBFREE
WALSIN:0402N100D500LT
C99 C1248 C1258
4CC101B501X00
(H)MLCC 100pF/50V +-5% 0402 NPO PBFREE
WALSIN:0402N101J500LT
C22 C243 C247 C292 C298 C336 C344 C429C437 C441 C465 C1168 C1175 C1178
14
37
4CC102B501X00
(H)MLCC 0.001uF/50V +-10% 0402 X7R PBFREE
WALSIN:0402B102K500CT
C9 C12 C23 C24 C290 C381 C386 C881 C882C883 C886 C887 C888 C890 C892 C893
16
38
4CC103B501X00
(H)MLCC 0.01uF/50V +-10% 0402 X7R
WALSIN:0402B103K500CT
C1 C4 C6 C10 C352 C353 C354 C355 C402C406 C422 C425 C524 C525 C526 C527 C536 C537 C884 C1014 C1016 C1208 C1209C1210 C1211 C1212 C1213 C1214 C1215 C1216 C1217 C1218 C1219 C1220 C1221 C1222C1223 C1259 C1260
39
39
4CC104B163X00
(H)MLCC 0.1uF/16V +-10% 0402 X7R
WALSIN:0402B104K160CT
C7 C19 C25 C26 C27 C28 C35 C40 C41 C42C43 C44 C50 C57 C58 C60 C62 C63 C65 C66 C67 C76 C78 C79 C80 C81 C82 C85 C86C88 C90 C92 C95 C96 C101 C102 C103 C104 C106 C107 C108 C111 C112 C113 C117C118 C119 C126 C128 C129 C130 C132 C137 C138 C141 C144 C145 C147 C149 C150C152 C153 C157 C158 C159 C161 C162 C163 C164 C165 C166 C167 C168 C171 C172C176 C179 C182 C185 C186 C187 C189 C190 C191 C192 C193 C196 C197 C201 C202C208 C209 C211 C215 C216 C218 C220 C221 C224 C225 C226 C227 C228 C229 C230C231 C240 C242 C246 C248 C251 C255 C276 C291 C295 C296 C297 C299 C300 C301C303 C304 C309 C310 C311 C332 C333 C339 C340 C345 C346 C347 C350 C351 C360C361 C362 C363 C366 C367 C370 C371 C379 C382 C383 C385 C387 C388 C391 C395C396 C397 C398 C400 C401 C404 C405 C409 C410 C411 C412 C414 C416 C417 C418C419 C428 C433 C434 C438 C439 C442 C443 C444 C445 C446 C447 C448 C449 C450C451 C452 C453 C454 C455 C456 C457 C458 C459 C470 C471 C481 C482 C489 C490C493 C496 C500 C501 C502 C503 C504 C505 C506 C507 C508 C509 C510 C511 C512C513 C515 C516 C517 C518 C519 C520 C521 C522 C523 C574 C575 C576 C577 C578C579 C580 C581 C582 C583 C584 C585 C586 C587 C590 C591 C593 C594 C595 C596C597 C598 C599 C600 C601 C602 C603 C605 C606 C612 C613 C615 C621 C622 C623C625 C626 C629 C632 C633 C634 C635 C636 C637 C639 C643 C644 C645 C646 C650C651 C652 C653 C654 C655 C656 C657 C665 C666 C667 C668 C677 C678 C679 C680C689 C690 C692 C693 C702 C703 C704 C705 C708 C714 C718 C719 C727 C737 C741C742 C743 C752 C753 C754 C755 C764 C765 C766 C770 C779 C780 C781 C786 C787C788 C796 C801 C803 C805 C806 C807 C808 C809 C810 C811 C812 C813 C817 C818C819 C823 C824 C827 C828 C829 C830 C831 C832 C834 C835 C836 C838 C840 C844C846 C848 C849 C850 C851 C852 C853 C854 C855 C856 C857 C858 C861 C862 C863C864 C865 C866 C869 C870 C872 C873 C874 C875 C876 C885 C900 C902 C903 C904C905 C906 C907 C908 C909 C910 C911 C912 C913 C914 C915 C916 C917 C918 C919C920 C921 C922 C923 C924 C925 C926 C927 C928 C929 C930 C931 C932 C933 C934C935 C936 C937 C938 C939 C940 C941 C942 C943 C944 C945 C946 C947 C948 C949C950 C951 C952 C953 C954 C955 C956 C957 C959 C960 C961 C962 C963 C964 C965C966 C967 C968 C969 C970 C971 C972 C973 C974 C975 C976 C977 C978 C979 C980C981 C982 C983 C984 C985 C988 C989 C991 C992 C993 C994 C995 C996 C997 C998C999 C1000 C1001 C1002 C1003 C1004 C1015 C1017 C1018 C1022 C1023 C1025 C1027C1028 C1029 C1031 C1032 C1033 C1034 C1035 C1036 C1037 C1038 C1039 C1040 C1043C1044 C1045 C1046 C1047 C1049 C1052 C1053 C1054 C1055 C1056 C1058 C1061 C1062C1063 C1064 C1065 C1067 C1069 C1070 C1071 C1072 C1073 C1074 C1075 C1077 C1080C1081 C1082 C1083 C1084 C1104 C1105 C1106 C1107 C1109 C1110 C1111 C1113 C1114C1117 C1118 C1119 C1122 C1123 C1124 C1126 C1127 C1128 C1129 C1131 C1134 C1135C1136 C1139 C1140 C1141 C1143 C1144 C1146 C1147 C1149 C1150 C1152 C1160 C1169C1176 C1179 C1181 C1184 C1185 C1186 C1187 C1190 C1191 C1192 C1193 C1196 C1197C1198 C1199 C1202 C1203 C1204 C1205 C1233 C1235 C1236 C1237 C1238 C1240 C1245C1247 C1250 C1255 C1257
586
40
4CC104B252X00
(H)MLCC 0.1uF/25V +-10% 0402 X5R
TAIYO:TMK105BJ104KV-F/WALSIN:0402X104K250CT
C335 C466
4CC104C161X00
(H)MLCC 0.1uF/16V +-10% 0603 X7R PBFREE
WALSIN:0603B104K160CT
C204 C267 C315 C376 C483 C1172
4CC105B101X00
(H)MLCC 1uF/10V +-10% 0402 X5R
WALSIN:0402X105K100CT
C100 C374 C436 C487 C488 C607 C608 C609C610 C611 C638 C715 C800 C802 C889 C891 C1042 C1048 C1051 C1057 C1060 C1066C1076 C1079 C1085 C1112 C1116 C1121 C1130 C1133 C1138 C1156 C1164 C1183 C1189C1195 C1201
37
43
4CC105C162X00
(H)MLCC 1uF/25V +-10% 0603 X5R
WALSIN:0603B105K160CT
C20
4CC105C251X00
WALSIN:0603X105K250CT
C46 C47 C48 C49 C59 C61 C83 C142 C203C266 C316 C377 C427 C484 C1167
4CC105D162X00
(H)MLCC 1uF/16V +-10% 0805 X5R PBFREE
TAIYO:EMK212BJ105KG-T/WALSIN:0805X105K160CT
C1153 C1161
4CC106C631X00
(H)MLCC 10uF/6.3V +-20% 0603 X5R
YAGEO:CC0603MRX5R5BB106/WALSIN:0603X106M6R3CT
C93 C131
4CC106D101X00
(H)MLCC 10uF/10V +/-10% 0805 X5R
WALSIN:0805X106K100CT / TDK:C2012X5R1A106KT
C64 C73 C97 C98 C110 C124 C252 C289 C306C317 C318 C327 C334 C341 C375 C432 C461 C462 C468 C469 C472 C473 C495 C498C499 C566 C567 C568 C569 C571 C572 C728 C782 C878 C879 C1041 C1050 C1059C1078 C1155 C1163 C1182 C1188 C1194 C1200 C1228 C1239 C1241 C1242 C1243 C1244C1246 C1249 C1251 C1252 C1253 C1254 C1256
58
48
4CC106E251X00
(H)MLCC 10uF/25V +-10% 1206 X5R
WALSIN:1206X106K250CT
C13 C15 C16 C17 C18 C212 C213 C214 C244C245 C277 C278 C279 C293 C294 C322 C323 C324 C337 C338 C392 C393 C394 C430C431 C463 C464 C467 C477 C478 C479 C528 C529 C530 C531 C532 C533 C534 C535C538 C539 C540 C541
43
49
4CC121B501X00
(H)MLCC 120pF/50V +-5% 0402 NPO
WALSIN:0402N121J500LT
C364
4CC180B501X00
(H)MLCC 18pF/50V +-5% 0402 NPO PBFREE
WALSIN:0402N180J500LT
C330
4CC220B501X00
(H)MLCC 22pF/50V +-5% 0402 NPO PBFREE
WALSIN:0402N220J500LT
C2 C3 C194 C329
4CC222B501X00
(H)MLCC 2200pF/50V +-10% 0402 X7R PBFREE
WALSIN:0402B222K500CT
C188 C195 C254 C257 C313 C365 C491 C1180
4CC224B101X00
(H)MLCC 0.22uF/10V +-10% 0402 X5R
TAIYOMK105BJ224KV-F/WALSIN:0402X224K100CT
C29 C30 C31 C32 C33 C34 C89 C125
4CC224C101X00
(H)MLCC 0.22uF/10V +-10% 0603 X7R PBFREE
WALSIN:0603B224K100CT
C36 C37 C38 C39 C55 C56
4CC224D161X00
(H)MLCC 0.22uF/16V +-10% 0805 X7R
WALSIN:0805B224K160CT
C51 C52 C53 C54 C68 C69
4CC225B101X00
MLCC 2.2u/10V +-20% 0402 X5R
TAIYOMK105BJ225MV-F
C259 C265 C273 C275 C280 C281 C282 C285C286 C563 C565 C604 C614 C620 C624 C691 C716 C859 C867 C1013
4CC225C101X00
(H)MLCC 2.2uF/10V +-10% 0603 X5R PBFREE
WALSIN:0603X225K100CT
C206 C272 C319 C384 C480 C1174
4CC226C631X00
(H)MLCC 22uF/6.3V +-20% 0603 X5R
SAMSUNG:CL10A226MQ8NRNE
C249 C302 C342 C435 C460
4CC226D631X00
(H)MLCC 22uF/6.3V +-20% 0805 X5R PBFREE
KYOCERA:CV21X5R226M06AT/WALSIN:0805X226M6R3CT
C87 C91 C542 C543 C544 C545 C1068 C1142C1145 C1148 C1151 C1207
4CC226E161X00
(H)MLCC 22uF/16V +-10% 1206 X5R
KYOCERA:CM316X5R226K16AT/WALSIN:1206X226K160CT
C288 C343 C348 C349 C357 C359 C378 C380C389 C390 C408 C413 C421 C423 C426 C860 C868 C1019 C1170 C1206
4CC272B501X00
(H)MLCC 2700pF/50V +-10% 0402 X7R
WALSIN:0402B272K500CT
C308
4CC331B502X00
(H)MLCC 330pF/50V +-5% NPO 0402
TAIYO:UMK105CH331JV-F/WALSIN:0402N331J500LT
C1021
4CC332B501X00
(H)MLCC 3300pF/50V +-10% 0402 X7R
WALSIN:0402B332K500CT
C11 C14 C258 C274 C283 C284 C497 C562C564 C616 C617 C618 C619 C627 C709 C833 C837 C841 C842 C843 C845 C847
22
64
4CC334C161X00
(H)MLCC 0.33uF/16V +80%-20% 0603 Y5VPBFREE
WALSIN
C1020
4CC390B501X00
(H)MLCC 39pF/50V +-5% 0402 NPO
WALSIN:0402N390J500LT
C256 C312 C492
4CC470B501X00
(H)MLCC 47pF/50V +-5% 0402 NPO PBFREE
WALSIN:0402N470J500LT
C21
4CC472B501X00
(H)MLCC 4700pF/50V +-10% 0402 X7R
WALSIN:0402B472K500CT
C1158 C1165
4CC472C501X00
(H)MLCC 4700pF/50V +-20% 0603 X7R
WALSIN
C356 C440
4CC474C161X00
(H)MLCC 0.47uF/16V +-10% 0603 X7R PBFREE
TAIYO:EMK107BJ474KA-T/WALSIN:0603B474K160CT
C1157
4CC475B632X00
(H)MLCC 4.7uF/6.3V +-20% 0402 X5R
TDK:C1005X5R0J475MT
C630 C631 C640 C641 C642 C647 C648 C649C658 C659 C660 C661 C662 C663 C664 C669 C670 C671 C672 C673 C674 C675 C676C681 C682 C683 C684 C685 C686 C687 C688 C694 C695 C696 C697 C698 C699 C700C701 C706 C707 C711 C712 C713 C720 C721 C722 C723 C724 C725 C726 C729 C730C731 C732 C733 C734 C735 C736 C744 C745 C746 C747 C748 C749 C750 C751 C756C757 C758 C759 C760 C761 C762 C763 C771 C772 C773 C774 C775 C776 C777 C778C789 C790 C791 C792 C793 C794 C795 C804 C987
92
71
4CC475C101X00
(N)(H)MLCC 4.7uF/10V +-10% 0603 X5R
FUKUI MURATA:GRM188R61A475KE15D
C8 C84 C105 C133 C134 C135 C136 C260 C261C262 C263
4CC476D631X00
(H)MLCC 47uF/6.3V +-20% 0805 X5R
WALSIN:0805X476M6R3CT
C120 C121 C122 C123 C143 C148 C151 C169C170 C173 C198 C199 C205 C207 C253 C268 C269 C270 C271 C305 C546 C547 C548C549 C550 C551 C552 C553 C554 C555 C556 C557 C558 C559 C560 C561 C570 C573C588 C589 C592 C628 C710 C717 C821 C822 C839 C877 C880 C1108 C1115 C1120C1132 C1137
54
73
4CC562B501X00
(H)MLCC 5600pF/50V +-10% 0402 X7R
WALSIN:0402B562K500CT
C1177
4CE4771166X00
(N)EC 470uF/16V SANYO:16ME470WG
+-20% 8x11.5mmDIP ESR:36m RP:1140mA 105C2000h
CT28 CT31 CT35
4CM2772161X00
(N)(H)MP CAP 270uF/16VMATSUKI:MP16RL270MD9
+-20% 8x9mmDIP ESR:11m RP:5000mA
CT1 CT2 CT3 CT4 CT5 CT7
4CP107B631X00
KO CAP 100uF/6.3V KEMET:T520B107M006ATE040
+-20% SMD B(3528) ESR:40m RP:1800mA
CT34 CT49
4CP107D161X00
(H)POS CAP 100uF/16V SANYO:16TQC100M
+-20% SMD D3(7343) ESR:50m RP:1800mA
CT38 CT39 CT51
4CP227B021X00
(H)POS CAP 220uF/2.5V SANYO:2R5TPE220MAZB
+-20% SMD B2(3528) ESR:35m RP:1400mA
CT36
4CP477D021X00
KO CAP 470uF/2.5VKEMET:T520V477M2R5ATE009
+-20% SMD V(7343) ESR:9m RP:3200mA
CT8 CT9 CT10 CT11 CT12 CT13 CT14 CT15CT16 CT17 CT18 CT19 CT20 CT21 CT22 CT23 CT30 CT32 CT40 CT42 CT43 CT44 CT45CT46 CT47 CT48 CT54 CT55
4CS227D024X00
(H)SP CAP 220uF/2V PANASONIC:EEFCX0D221R
+-20% (7343)x1.9mmSMD ESR:15m RP:2700mA
CT26 CT52
4CS337D023X00
(H)SP CAP 330uF/2.5VPANASONIC:EEFCX0E331YR
CT33
4CT476B102X00
TC CAP 47uF/10V KEMET:T520B476M010ATE070
+-20% SMD B2(3528) ESR:70 RP:1102mA
CT37
4D00359501X00
(N)(C)SILICON DIODE CENTRAL:CMHD3595
SMD SOD123 Vr:150V If:225mA Vf:1V
D9 D10
4D02B60A01X00
ESD PROTECTION PANASONIC:EZAEG2B60AX
SMD 0402 1 CHANNEL ESD:+-8kV/con,+-15kV/air,C:0.05pF
ESD1 ESD2 ESD3 ESD4 ESD5 ESD6 ESD7 ESD8
4D05V06C02X00
(N)(H)ESD PROTECTIONLITEON15ESDL5V0C6-4
SMD SOT23-6 4 CHANNELESD:+-8kV/con,+-15kV/air,C:3pF
U49 U50
4DED0GD302X00
LED HOUSING BI-LEVEL PINGOOD:2LED3A-40
LED HOUSING DoubleLayers,GREENx2,2LED3A-40,H:9.7x4.4mm,90° DIP,PBFREE
LED5 LED6
4DESCGH002X00
LED LITEONTST-C190KGKT
GREEN 30mA SMD(1.6x0.8mm)
LED1 LED2 LED3 LED4
4DFM501V01X00
(N)(H)SCHOTTKY DIODE FMS:FM501V-NL-H
SMD SOD-323F Vr:40V If:0.1A Vf:0.55V
D12
4DLL414801X00
DIODE VISHAYL4148-GS08
1206 SMD Vrm:100V Ifm:50mA Vf:1V 260D/5S
D1 D2 D3 D4 D5 D8
4DMBR520L2X00
SCHOTTKY DIODE ON:MBR0520LT1G
SMD SOD123 Vr:20V Ifm:0.5A Vf:0.385V
D6 D7
4FSMD29204X00
(N)(H)POLY SWITCH FUSE PTTC:SMD2920P250TF
2.5A VDC 15V SMD
FB37
4H00320301X00
(N)(H)MOSFET N NIKO-SEM3203CMG
Vds:30V Vgs:+-12V Rds(on):52mohm at 2.5VSMD SOT23
M23
4H00700201X00
(N)(T)MOSFET DUAL N CHENMKO:2N7002SPT
Vds:60V Vgs:+-20V Rds(on):4ohm at 4V SMDSC-88
M10 M9
4H01641101X00
(N)(H)POWER MOSFET N TI:CSD16411Q3
Vds:25V Vgs:+16/-12V Rds(on):15mohm at4.5V SMD SON 3.3x3.3
M8
4H044P0201X00
MOSFET P EMC:EMF44P02J
Vds:-20V Vgs=+-12V Rds(on):0.044E at-4.5V SMD SOT-23
M11 M12
4H2N700204X00
MOSFET N PHILIPS:2N7002 SOT-23
Vds:60V Vgs:+-30V Rds(on):5.3ohm at 4.5VSMD SOT23
M14 M15 M21 M22 M27 M6
4HUM6K1N01X00
(T)MOSFET DUAL N ROHM:UM6K1NTN
Vds:30V Vgs:+-20V Rds(on):13ohm at 2.5VSMD UMT6
M13 M16 M18 M19 M24 M25 M26 M28 M29 M2 M3M4 M5 M7
14
98
4IB1201C04X00
(N)(H)CHIP BEAD MURATA:BLM18KG121TN1D
120E +-25% 100MHZ Irms:3A RDC:0.03ohm SMD0603
FB9 FB10 FB11 FB12 FB16 FB17 FB18 FB19FB24 FB25 FB26 FB47 FB48 FB49 FB50 FB51 FB52 FB53 FB54
4IB1201D02X00
(N)(H)FB GOTREND:GBD201209PGH121N
120E+-25% 100MHz IDC:3A RDC:0.04ohm SMD0805
FB20 FB55 FB56 FB60 FB61 FB62 FB63 FB65FB66 FB67 FB68 FB69 FB73 FB74 FB75 FB76
16
100
4IB6000C01X00
(H)FB MAG.LAYERS:MLB-160808-0060P-N2
60E+-25% 100MHz IDC:3A RDC:0.04ohm SMD0603 P-TYPE
FB2 FB23 FB27 FB30 FB31 FB33 FB34 FB59FB77 FB78 FB79 FB80 L13 L14 L15 L16 L17 L18 L19 L21
4IB6001E02X00
(N)(H)CHIP BEAD WURTH:74279218
600E +-25% 100MHZ Irms:2A RDC:0.1ohm SMD1206
FB7 FB8 FB13 FB14 FB15 FB21 FB22 FB28FB29 FB35 FB36
4IB8001DA2X00
(H)FB MAG.LAYERS:MLB-201209-0080P-N2
80E+-25% 100MHz IDC:3A RDC:0.04ohm SMD0805 P-TYPE
FB3 FB4 FB38 FB39 FB40 FB43 FB44 FB46FB70 FB71 FB72 FB81 FB82 FB83 FB84 FB85 FB86 L25 L26 L27
4IC0150S02X00
(N)(H)POWER INDUCTOR COOPERBUSSMANN:FP1007R3-R15-R
0.15uH+-10% Irms:61A Isat:76ADCR:0.29mohm SMD(10.2x7.8x7.3)
L3 L4 L5 L6
4IC0360S05X00
(N)(H)POWER CHOKE PD:MCS1040R36MPBB
0.36uH+-20% Irms:34A Isat:40A DCR:1.2mohmSMD(10.2x11.3x4)
L7 L8
4IC1000S53X00
(N)(H)POWER CHOKE PD:MCS06301R0MPBB
1uH+-20% Irms:11A Isat:20A DCR:7.5mohmSMD(7.3x6.6x3)
L1 L2
4IC1000S60X00
(N)POWER INDUCTORSPORTONQH4018PE-1R0N-C
1uH+-30% Irms:2.8A Isat:4.1A DCR:32mohmSMD(4x4x2)
L28
4IC2200S19X00
(N)(H)(T)POWER CHOKENEC-TOKIN:MPLCG0630L2R2
2.2uH+-20% Irms:8.2A Isat:7.8A DCR:19mohmSMD(7.5x6.7x3)
L33
4IC2200S28X00
(N)(H)POWER CHOKECOILCRAFT:MSS1048-222NLC
2.2uH +-30% Irms:9.78A Isat:6.62ARDC:7.2mohm SMD(10x10.2x4.8)
L10 L11 L20
4IC4700S12X00
(H)POWER INDUCTORGOTREND:GSDR43P-4R7M-V3R3
4.7uH+-20% Irms:1.7A DCR:94mohm SMD(4.5x4x3.2)
L29 L30 L31 L32
4IC4700S35X00
(N)(H)(C)POWER CHOKE WURTH:74437346047
4.7uH +-20% Irms:3.8A Isat:12A RDC:37mohmSMD
L12
4IC6800S08X00
(N)(H)(C)POWER CHOKE WURTH:74437346068
6.8uH +-20% Irms:3.4A Isat:8A RDC:54mohmSMD
L22
4IM9000D03X00
(N)(H)COMMON CHOKEGOTREND:GLECM2012B-900QT
90E+-25% Irms:350mA DCR:0.3ohm SMD0805(FOR USB3.0)
L23 L24
4NBA001301X00
(N)SD CON CEN:TMB0-06091-00R4
13P 28.3x28.8x2.7mm SMD PUSH-PUSH TYPE
CN3
4NBPA01601X00
(N)PHONE JACK RJ45 2x1 PORTREGO:97310-21488AAD
17.25x28.6x25.3mm 90D 6u DIP w/o LED
LAN1
4NBPA02806X00
PHONE JACK RJ45 2x1 PORT UDE:RM3-138A9V1F
17.27x28.4x25.79mm 90D 30u DIPw/TF&LED(L:G/R:Y,G) 265D/5S
J11 J12 J13 J14
4NBUF00812X00
USB CON DUAL PORT A-TYPE TECHBEST:USAF-8D-HNR0SPJ
8P 90D FEMALE DIP 15.3x17.15x16.6mm
CN4
4NCBM01001X00
(T)BOX HEADER 2x5 CATCH:1137-000-10SN
2.54mm MALE 180° DIP
JP3
4NCBM01601X00
(T)BOX HEADER 2X8 CATCH:1137-000-16SN
J2
4NCGF02004X00
(C)FIBER CON 20P ALL BEST:R-SS-008020-9-N
0.8mm FEMALE 90D SMD
J15 J17 J18 J19
4NCIF00201X00
MINI JUMPER 1x2 CATCH:1132-001-02
2.54mm FEMALE 180D DIP
JP1(1-2) JP4(1-2)
4NCIM00301X00
PIN HEADER 1x3 CATCH:1130-000-03SN
2.54mm MALE 180D DIP
J1 J4 JP1 JP4
4NCIM2X501X00
PIN HEADER 2x5 CATCH:1130-010-10SN
JP5
4NCJM00310X00
(T)WAFER 1x3 CATCH:1190-700-03A
2.54mm H:8.3mm MALE 180D DIP
FAN7
4NCJM00411X00
4PIN W/FAN TECHBEST:W2-03I104132S1WT(A)-L
2.54mm MALE 180° DIP WAFER WIDE:5.08mm TECHBEST 260D/10S
FAN2 FAN3 FAN4 FAN5 FAN6
4NCPF02404X00
ATX POWER CON 2x12ANYTRONIC:25109B2411B1-9LF
4.2mm FEMALE 180D DIP WHITE w/4PIN COVER
J9
4NCPM00803X00
ATX POWER CON 2x4ANYTRONIC:25118A0800B0-9LF
4.2mm MALE 180D DIP WHITE
J8
4NCSM00705X00
(T)SATA CON 7PINTECHBEST:S2-09F107097S1B0
1.27mm MALE 180° DIP
J10
4RC0000B51X00
(H)RES 0E 1/16W 0402 5% PBFREE
YAGEO:RC0402JR-070RL
R1 R3 R6 R8 R9 R11 R15 R16 R17 R24 R25R28 R29 R32 R33 R37 R49 R52 R53 R66 R80 R81 R82 R83 R130 R131 R134 R153 R176R177 R180 R181 R233 R234 R247 R304 R311 R312 R315 R316 R318 R388 R449 R450R452 R453 R471 R500 R501 R505 R529 R558 R559 R602 R605 R609 R612 R615 R628R631 R673 R674 R675 R676 R677 R678 R679 R680 R681 R682 R683 R684 R698 R703 R705R711 R713 R761 R862 R863 R866 R867 R870 R871 R876 R877 R897 R902 R903 R905R909 R910 R919 R962 R968 R974 R985 R1029 R1039 R1041 R1067 R1068 R1074 R1075
104
129
4RC0000C51X00
(H)RES 0E 1/10W 0603 5% PBFREE
YAGEO:RC0603JR-070RL
R114 R115 R116 R117 R122 R123 R238 R248R284 R305 R368 R448 R475 R633 R816 R817 R980 R991 R1044 R1060
4RC0000D51X00
(H)RES 0E 1/8W 0805 5% PBFREE
YAGEO:RC0805JR-070RL
R285 R392 R601 R712 R920 R921
4RC0000E51X00
(H)RES 0E 1/4W 1206 5% PBFREE
YAGEO:RC1206JR-070RL
R325 R334 R688 R704
4RC047AB11X00
(H)RES 0.47E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-0R47L
R175 R178 R179 R182 R313 R314 R317 R319
4RC0510B11X00
(H)RES 5.1E 1/16W 0402 1%
WALSIN:WR04W5R10FTL
R685 R686 R687 R689 R690 R691 R708 R769R770
9
134
4RC1000B11X00
(H)RES 10E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0710RL
R328 R696 R699 R706 R707 R709 R710 R716R725 R745 R807 R810
4RC1000C11X00
(H)RES 10E 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-10RL
R72 R1072 R1073
4RC1000D51X00
(H)RES 10E 1/8W 0805 5% PBFREE
YAGEO:RC0805KR-07-10RL
R437 R503 R504
4RC1001B11X00
(H)RES 100E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-100RL
R155 R156 R170 R172 R183 R342 R444 R466R467 R637 R667 R669 R670 R930 R939 R948 R957
17
138
4RC1002B11X00
(H)RES 1K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-1KL
R18 R64 R65 R276 R277 R454 R463 R472 R508R540 R541 R542 R543 R544 R545 R546 R547 R548 R549 R550 R551 R552 R553 R554R555 R564 R565 R640 R764 R765 R960
31
139
4RC1002C11X00
(H)RES 1K 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-1KL
R332 R333 R335 R341
4RC1003231X00
THERMISTOR 10K 1/4W DIP +-3%
SEMITEC:103JT-025-3P
RT5 RT6
4RC1003B11X00
(H)RES 10K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-10KL
R31 R39 R41 R43 R45 R47 R50 R67 R68 R69R70 R71 R73 R74 R87 R89 R105 R118 R121 R136 R137 R138 R139 R140 R141 R150R166 R167 R197 R199 R200 R202 R211 R213 R221 R224 R229 R230 R236 R244 R261R264 R267 R269 R282 R291 R293 R364 R386 R393 R394 R443 R447 R523 R530 R531R569 R570 R575 R576 R577 R582 R583 R634 R639 R660 R661 R743 R747 R826 R827R830 R860 R887 R888 R892 R895 R899 R900 R906 R911 R922 R925 R929 R931 R934R938 R940 R943 R947 R949 R952 R956 R963 R976 R978 R979 R1031 R1032 R1033R1035 R1036 R1046 R1047 R1048 R1049 R1050 R1051
108
142
4RC1003C13X00
THERMISTOR 10K 1/4W SMD +-1% 0603260D/10S
TKS:TSM1A103F34D3RY
RT3 RT4
4RC1004B11X00
(H)RES 100K 1/16W 0402 1%
YAGEO:RC0402FR-07100KL
R85 R479 R480 R518 R636 R668 R959 R967R969 R973 R1030 R1034
4RC1005B11X00
(H)RES 1M 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-071ML
R133
4RC1133B11X00
(H)RES 11.3K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0711K3L
R289 R303
4RC1152B11X00
(H)RES 1.15K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-071K15L
R528
4RC1213B11X00
(H)RES 12.1K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0712K1L
R618 R620
4RC1241B11X00
(H)RES 124E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-124RL
R439 R440 R482 R487 R519 R520
4RC1301B11X00
(H)RES 130E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-130RL
R872 R873
4RC1303B11X00
(H)RES 13K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0713KL
R14 R19 R34 R381
4RC1401B11X00
(H)RES 140E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-140RL
R864 R865 R868 R869 R874 R875 R879 R881
4RC1501B11X00
(H)RES 150E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-150RL
R38 R40 R42 R44 R46 R588
4RC1502B11X00
(H)RES 1.5K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-1K5L
R923 R924 R932 R933 R941 R942 R950 R951
4RC1692B11X00
(H)RES 1.69K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-071K69L
R964
4RC1693B11X00
(H)RES 16.9K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-16K9L
R572 R574
4RC1782B11X00
(H)RES 1.78K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-071K78L
R237
4RC1801B51X00
(H)RES 180E 1/16W 0402 5% PBFREE
YAGEO:RC0402JR-07180RL
R1026
4RC1801C51X00
(H)RES 180E 1/10W 0603 5% PBFREE
YAGEO:RC0603JR-07-180RL
R665 R666
4RC1803B11X00
(H)RES 18K 1/16W 0402 1%
WALSIN:WR04X1802FTL
R659 R663
4RC1823B11X00
(H)RES 18.2K 1/16W 0402 1% PBFREE
WALSIN:WR04X1822FTL
R242 R243 R245 R246
4RC1913B11X00
(H)RES 19.1K 1/16W 0402 1%
YAGEO:RC0402FR-07-19K1L
R290 R292
4RC1963B11X00
(H)RES 19.6K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-19K6L
R621 R622
4RC2000B11X00
(H)RES 20E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0720RL
R235 R281 R361 R436 R638
4RC2001B11X00
(H)RES 200E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07200RL
R694 R697 R727 R733
4RC2002B11X00
(H)RES 2K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-2KL
R149 R629 R632
4RC2004B11X00
(H)RES 200K 1/16W 0402 1%
YAGEO:RC0402FR-07200KL
R191 R813 R821 R831 R1061 R1064
4RC2101B11X00
(H)RES 210E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-210RL
R635
4RC2200C11X00
(H)RES 22E 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-22RL
R958
4RC2202B11X00
(H)RES 2.2K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-072K2L
R327 R527 R657 R658 R740 R744 R808 R809
4RC2204B11X00
(H)RES 220K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07220KL
R481
4RC2262B11X00
(H)RES 2.26K 1/16W 0402 1% PBFREE
WALSIN:WR04X2261FTL
R283
4RC2323B11X00
(H)RES 23.2K 1/16W 0402 1% PBFREE
WALSIN:WR04X2322FTL
R240 R458 R625
4RC2371B11X00
(H)RES 237E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07237RL
R198 R218 R219 R232 R259 R271
4RC2402B11X00
(H)RES 2.4K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-2K4L
R106 R109 R110 R111
4RC2432B11X00
(H)RES 2.43K 1/16W 0402 1%
YAGEO: RC0402FR-07 2K43
R107 R108
4RC2493B11X00
(H)RES 24.9K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-24K9L
R459
4RC2494B11X00
(H)RES 249K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07249KL
R965 R970
4RC2613B11X00
(H)RES 26.1K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0726K1L
R288
4RC2673B11X00
(H)RES 26.7K 1/16W 0402 1% PBFREE
WALSIN:WR04X2672FTL
R241
4RC2700B11X00
(H)RES 27E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0727RL
R490 R496 R497 R513 R514
4RC2703B11X00
(H)RES 27K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0727KL
R624
4RC2872B11X00
(H)RES 2.87K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-072K87L
R76 R84 R975
4RC2943B11X00
(H)RES 29.4K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-29K4L
R380
4RC3011B11X00
(H)RES 301E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-301RL
R92 R93 R94 R95 R96 R97 R98 R99 R100 R101R102 R103
4RC3012B11X00
(H)RES 3.01K 1/16W 0402 1%
YAGEO:RC0402FR-07 3K01
R382 R387
4RC3300B11X00
(H)RES 33E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0733R0L
R296 R301 R369 R370 R371 R372 R373 R374R375 R376 R417 R418 R419 R420 R421 R422 R614 R1052 R1053 R1054 R1055 R1056R1057 R1058 R1059
25
187
4RC3300C11X00
(H)RES 33E 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-33RL
R462 R494 R499 R506 R515 R516
4RC3301B11X00
(H)RES 330E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-330RL
R270 R714 R722 R1027
4RC3301C11X00
(H)RES 330E 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-330RL
R641 R642 R643 R644 R645 R646 R647 R648R649 R650 R651 R652 R653 R654 R655 R656 R992 R993 R994 R995
4RC3402B11X00
(H)RES 3.4K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-073K4L
R78
4RC3572B11X00
(H)RES 3.57K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-073K57L
R526 R961 R972
4RC3742B11X00
(H)RES 3.74K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-073K74L
R460 R469
4RC3743B11X00
(H)RES 37.4K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0737K4L
R190 R192 R196 R203 R205 R208
4RC3923B11X00
(H)RES 39.2K 1/16W 0402 1%
WALSIN:WR04X3922FTL
R287
4RC4322B11X00
(H)RES 4.32K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-074K32L
R986
4RC4701B11X00
(H)RES 470E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07470RL
R90 R91
4RC4702B11X00
(H)RES 4.7K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-074K7L
R4 R7 R113 R119 R120 R124 R125 R128 R129R132 R142 R143 R145 R146 R151 R160 R206 R209 R210 R214 R217 R222 R251 R252R253 R254 R257 R258 R263 R265 R266 R268 R274 R279 R280 R294 R295 R297 R298R299 R306 R307 R308 R309 R310 R320 R321 R322 R323 R326 R329 R336 R337 R338R340 R344 R346 R348 R349 R350 R351 R352 R363 R367 R378 R385 R389 R398 R399R400 R401 R402 R403 R404 R405 R406 R407 R408 R411 R445 R451 R464 R473 R474R477 R478 R484 R492 R495 R498 R507 R512 R524 R562 R563 R591 R594 R597 R600R604 R607 R671 R672 R717 R720 R726 R732 R734 R735 R739 R742 R746 R749 R751R753 R754 R755 R756 R757 R762 R763 R766 R767 R768 R771 R773 R774 R777 R781R782 R784 R787 R789 R792 R794 R796 R802 R804 R814 R815 R818 R822 R823 R824R825 R829 R884 R885 R889 R890 R891 R912 R913 R914 R1028 R1062 R1063 R1065R1066
159
198
4RC4703C12X00
(N)(H)THERMISTOR 47K 1/10W 0603 1%
MITSUBISHI:TH11-3J473FT
RT1 RT2
4RC4704B51X00
(H)RES 470K 1/16W 0402 5% PBFREE
YAGEO:RC0402JR-07-470KL
R476
4RC4751C11X00
(H)RES 475E 1/10W 0603 1% PBFREE
R424
4RC4872B11X00
(H)RES 4.87K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-074K87L
R616 R623
4RC4873B11X00
(H)RES 48.7K 1/16W 0402 1%
YAGEO:RC0402FR-07154KL
R987
4RC4990B11X00
(H)RES 49.9E 1/16W 0402 1% PBFREE
R353 R354 R355 R356 R357 R358 R359 R360R413 R414 R427 R428 R429 R430 R431 R432 R441 R442 R700 R701 R736 R741 R878R880 R1014 R1015 R1016 R1017
4RC4990C11X00
(H)RES 49.9E 1/10W 0603 1% PBFREE
YAGEO:RC0603FR-07-49R9L
R158 R163
4RC4992B11X00
(H)RES 4.99K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-4K99L
R26
4RC4993B11X00
(H)RES 49.9K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-49K9L
R239 R286 R379 R457 R626 R983
4RC4994B11X00
(H)RES 499K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07499KL
R966 R971
4RC5100B11X00
(H)RES 51E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0751RL
R55 R57 R59 R61 R63 R568
4RC5102B11X00
(H)RES 5.1K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-5K1L
R75 R79 R415 R416 R425 R426 R719 R721R728 R729
4RC5104B51X00
(H)RES 510K 1/16W 0402 5% PBFREE
YAGEO:RC0402JR-07-510KL
R493
4RC5113C11X00
(H)RES 51.1K 1/10W 0603 1%
YAGEO:RC0603FR-0751K1L
R662 R664
4RC5232B11X00
(H)RES 5.23K 1/16W 0402 1% PBFREE
WALSIN:WR04X5231FTL
R461 R468
4RC5362B11X00
(H)RES 5.36K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-075K36L
R982 R984 R988 R989
4RC6042B11X00
(H)RES 6.04K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-6K04L
R77
4RC6341B11X00
(H)RES 634E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07634RL
R990
4RC6981B11X00
(H)RES 698E 1/16W 0402 1% PBFREE
WALSIN:WR04X6980FTL
R693 R695 R715 R718 R737 R738
4RC7500B11X00
(H)RES 75E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-75RL
R27
4RC7502B11X00
(H)RES 7.5K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-7K5L
R48
4RC7872B11X00
(H)RES 7.87K 1/16W 0402 1% PBFREE
WALSIN:WR04X7871FTL
R383 R391
4RC8200B11X00
(H)RES 82E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-82RL
R1003 R1004
4RC8252B11X00
(H)RES 8.25K 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-078K25L
R579 R580 R590 R593 R596 R599
4RC8450B11X00
(H)RES 84.5E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07-84R5L
R455 R456 R483 R485 R488 R509 R510
4RC8661B11X00
(H)RES 866E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-07866RL
R5
4RC9090B11X00
(H)RES 90.9E 1/16W 0402 1% PBFREE
YAGEO:RC0402FR-0790R9L
R365
4SIPCE6402X00
(T)PCI-E SLOT 64PINWINWIN:WPES064AN41B22UWS
H:11.1mm 180D GOLD FLASH DIP BLACK
U55
4SIPCE9801X00
PCI-E SLOT 98PIN TECHBEST:1-80098-S501
H:11mm 180D DIP
J3
4SRD324006X00
DDR3 DIMM SOCKET 240PINFOXCONN:ATH4017-P3B-4F
DIP PIT:1.0mm H:26mm 180D 15u 1.5V BLACK
J5 J6 J7
4WJ004S002X00
2x4 DIP SWITCH HCH:HPS604-E
DC24V 25mA PIT:1.27mm SMD
SW1 SW2 SW3 SW4
4WP004D024X00
DC12V 50mA H:7mm DIP 4P 180D GREEN
SW6
4WP008D010X00
ILLUMINATED TACT SWITCH HIGHLYB6156RSL-23-101
DC12V 50mA DIP 8P 90D w/LED GREEN/YELLOW
SW5
4ZR0137401X00
I2C 32BIT BINARY COUNTER WATCHDOG RTCDALLASS1374U-33+
SMD uSOP 10PIN 260D/20S-40S
U16
4ZTCR20322X00
BATTERY PANASONIC:CR2032L-DBE
3.0V 20x3.2mm DIP
BAT1
4ZZ0000008X00
BATTERY HOLDER KTS:BHAAA-BAT-014-K01
DIP 260D/10S
BAT1
5050300264X00
HEAT SINK Shyung Shuhm:SH20200618-1
20x20x6mm BLACK
U42 U43
5050300306X00
NT8.8 LAN SINK SHYUNG SHUHM
38x25x15.5mm AL:6063_T5 ANOD COATING
U65
5060200042X00
(C)SFP+ 1x4 CAGE w/EMI GASKETALLBEST:R-SH-008080-6-B-09
Press-Fit Type 62.6x48.73x14.75mm
J16
71F101G201X00
(H)SOC FREESCALE:T4240NSE7T1B
1.8GHz L2:2MB FC-PBGA 1932 Balls
U22
C100000178X00
C EEPROM OF T4240(FREESCALE)
FILE:T4240_20130503_CKS_0C46.bin CKS:0C46
U13
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-23 21:11:48 | 显示全部楼层
[hide=2,money] T4240RDB.DSN.rar (1.63 MB, 下载次数: 8) 4BS05640C1X10.brd.rar (6.85 MB, 下载次数: 13) [/hide]
    昨天 16:51
  • 签到天数: 151 天
    发表于 2018-11-24 03:12:17 | 显示全部楼层
    看感觉论坛有相同的作品??
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-11-24 08:57:28 | 显示全部楼层
    发表于 2018-11-24 09:03:11 | 显示全部楼层
    发表于 2021-6-25 22:04:38 | 显示全部楼层
