shuszhao 发表于 2017-10-17 16:58
Acer Aspire 7 A715-71G  M/B 电路图
https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/acer-aspire-7-main.jpg
Specs as reviewed
Acer Aspire 7 A715-71G-79D2
Screen15.6 inch, 1920 x 1080 px, IPS, non-touch, matteProcessorIntel Kaby Lake Core i7-7700HQ CPUVideoIntel HD 630 + Nvidia GT 1050 Ti 4GBMemory24 GB DDR4 (2 x DIMMs, up to 32 GB)Storage512 GB SSD (M.2 SATA) + 2 TB 5400 rpm HDD (2.5″)ConnectivityGigabit LAN, Intel AC 7265 Wireless AC , Bluetooth 4.1Ports1x USB 3.0, 2x USB 2.0, 1x USB 3.1 gen 1, HDMI, mic/earphone, SD card reader, LAN, Kensington LockBattery48 Wh, 135 Wh chargerOperating systemWindows 10Size381 mm or 15.00” (w) x 263 mm or 10.35” (d) x 30 mm or 1.18” (h)Weight5.25 lbs (2.38 kg)Extraswhite backlit keyboard, webcamhttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/fans-exhaust-780x347.jpg
Hardware and performance
Acer offers this laptop in a multitude of configurations and we got to test a top-specked variant, with a Core i7-7700HQ processor, Nvidia GTX 1050 Ti graphics, 24 GB of DDR4 RAM and dual-storage, with an M.2 80 mm SSD and a 2.5″ HDD.
https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/cpuz-gpuz-1-200x150.pnghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/hwinfo-1-200x150.pnghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/storage-hdd-200x150.png
https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/storage-ssd-200x150.pnghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/bloatware-before-200x150.pnghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/bloatware-after-200x150.png
Potential upgrades would imply upping the RAM to 32 GB (there are two DIMMs available) and perhaps replacing the HDD with an SSD if you want a quieter and faster mass-storage solution. The included M.2 SSD only supports SATA speeds, and from what I can tell based on HWInfo, the M.2 slot is not hooked up via 4x PCIe lines, which means you can’t benefit from faster PCIe or NVMe SSDs. That’s to be confirmed though.
Accessing the RAM and HDD is a basic task on this Aspire 7, as they are hidden behind dedicated bays on the back. Accessing the SSD, battery or Wi-Fi chip on the other hand requires taking apart the entire back panel, which takes a bit more effort and knowledge. It’s hold in place by a handful of Philips screws and shouldn’t be hard to pop open with the help of some plastic priers. I wasn’t allowed to get inside this sample, so I can’t show you any interior pictures this time. All I can say is that the Aspire 7 seems to have the same internal build as the Helios 300, showcased in this video.
https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/service-bays-780x480.jpg
When it comes to performance, the sample did well in our tests, as expected from such a configuration. There is some bloatware installed that you should take care of, but that aside, I haven’t notice anything that could interfere with how the laptop handles daily tasks, demanding chores and games. I haven’t noticed any throttling or performance drops either.
You’ll find some benchmarks results below, in case you’re interested in hard numbers.
3DMark 11: P9202;3DMark 13: Sky Driver – 19323, Fire Strike – 6781, Time Spy – 2482;PCMark 08: Home Conventional – 3267;Geekbench 3 32-bit: Single-Core: 3742, Multi-core: 13864;Geekbench 4 64-bit: Single-Core: 4519, Multi-core: 13500;CineBench 11.5: OpenGL 65.34 fps, CPU 8.13 pts, CPU Single Core 1.70 pts;CineBench R15: OpenGL 94.85 fps, CPU 729 cb, CPU Single Core 139 cb;x264 HD Benchmark 4.0 32-bit: Pass 1 – 168.45fps, Pass 2 – 45.87 fps.https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-1080pmkv-1-200x150.jpghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-4kmkv-1-200x150.jpghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-1080pyoutube-1-200x150.jpghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-typing-1-200x150.jpg
https://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-browsing-1-200x150.jpghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-gaming-200x150.jpghttps://cdn.ultrabookreview.com/wp-content/uploads/2017/06/perf-temps-gaming-battery-200x150.jpg
I also ran a few games. Since this laptop will also ship with Nvidia GTX 1050 graphics, I’ve also added what you should expect from those variants in terms of gaming results. In very few words, the 1050 Ti chip is 10-25% faster than the 1050 alternative, so is well worth getting if gaming is one of your priorities, especially since it’s usually only about a $30 – $50 premium.
FHD Ultra – GTX 1050FHD Ultra – GTX 1050 TiShadow of Mordor~45 fps55 fpsDirt Autogrid~75 fps90 fpsTomb Raider~75 fps85 fpsBioshock Infinite~65 fps75 fpsFarcry 4~52 fps63 fps
Acer Aspire 7 A715-71GM/B 电路图
vikey_zhu 发表于 2017-10-17 17:21
文件呢?
shuszhao 发表于 2017-10-17 18:35
回 vikey_zhu 的帖子
vikey_zhu:文件呢? (2017-10-17 17:21) images/back.gif
在二楼
单枪舞九州 发表于 2017-10-17 20:49
文件在哪里
暴走中的 发表于 2017-10-18 01:13
monamemak 发表于 2017-10-18 04:06
COMPAL
monamemak 发表于 2017-10-18 04:13
互联网上几个月。
ilpuyi 发表于 2017-10-18 08:37
weijie0015 发表于 2017-10-18 08:49
附件呢
页: [1] 2 3
查看完整版本: Acer Aspire 7 A715-71G  M/B 电路图
