老吴 发表于 2017-9-8 09:07
TSUM16AL-1(TSUM16AWL_1) 液晶显示器驱动板 PCB文件共享 MST9036
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECN1DB15_0_DB15F-3B_DB15_0DB15_0DB15F-3BCN2HEADER9_2_L7P-2MM_HEADERHEADERL7P-2MMCN3HEADER9_3_L8P-2MM_HEADER 9HEADER 9L8P-2MMD1BAS70-04/SOT_SOT23_BAV99BAV99SOT23D2BAS70-04/SOT_0_SOT23_BAV99BAV99SOT23D3BAS70-04/SOT_SOT23_BAV99BAV99SOT23D4DIODEZENER_0_D4148_NC/3.6VNC/3.6VD4148D5DIODEZENER_D4148_DIODE ZENERDIODE ZENERD4148D6DIODEZENER_D4148_DIODE ZENERDIODE ZENERD4148D7DIODEZENER_3_D4148_DIODE ZENERDIODE ZENERD4148D8DIODEZENER_D4148_DIODE ZENERDIODE ZENERD4148D9R_R0603_RRR0603D10DIODEZENER_0_D4148_LL5232B 5.6LL5232B 5.6V 5%D4148D11DIODEZENER_D4148_DIODE ZENERDIODE ZENERD4148D12R_R0603_RRR0603D13DIODEZENER_D4148_DIODE ZENERDIODE ZENERD4148D14R_R0603_RRR0603D15DIODE_D4148_1N41481N4148D4148D16DIODE_D4148_1N41481N4148D4148D17BAT54C/SOT_SOT23_BAT54C-GS08BAT54C-GS08SOT23D18DIODE_D4148_SSM12LSSM12LD4148D19DIODEZENER_D4148_3.6V3.6VD4148D20DIODEZENER_D4148_3.6V3.6VD4148D21DIODEZENER_D4148_3.6V3.6VD4148F1FUSE_2_L1206_24V24VL1206FB1CHOKEFERRITE_L0603_CHOKE FERRICHOKE FERRITEL0603FB2CHOKEFERRITE_L0805_600 OHM600 OHML0805FB3CHOKEFERRITE_L0805_600 OHM600 OHML0805FB4CHOKEFERRITE_L0805_600 OHM600 OHML0805FB5CHOKEFERRITE_L0805_600 OHM600 OHML0805FB6CHOKEFERRITE_L0805_600 OHM600 OHML0805FB7CHOKEFERRITE_L0805_600 OHM600 OHML0805FB8CHOKEFERRITE_L0805_600 OHM600 OHML0805JP2HEADER12X2_0_HDR13X2-2MM_HEADEHEADER 13X2HDR13X2-2MMQ1MMBT3904L_0_SOT23_MMBT3904LMMBT3904LSOT23Q22N1132A_3_SOT23_CHT2907CHT2907SOT23Q3MMBT3904L_0_SOT23_MMBT3904LMMBT3904LSOT23Q4MOSFET PGSD_2_SOT23_AO3401AO3401SOT23Q5MMBT3904L_0_SOT23_MMBT3904LMMBT3904LSOT23Q6MMBT3904L_0_SOT23_MMBT3904LMMBT3904LSOT23Q7MMBT3904L_0_SOT23_MMBT3904LMMBT3904LSOT23S1COPPER2_SMDTEST_COPPER2COPPER2SMDTESTS2COPPER2_SMDTEST_COPPER2COPPER2SMDTESTS3COPPER2_SMDTEST_COPPER2COPPER2SMDTESTTC1CAP_1_EC6D_100100EC6DTC2CAPPOL_EC4-2_5_4.7UF/16V4.7uF/16VEC4-2_5TC3CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC4CAPPOL_EC6D_100UF/16V100uF/16VEC6DTC5CAPPOL_EC4-2_5_4.7UF/16V4.7uF/16VEC4-2_5TC6CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC7CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC8CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC9CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC10CAPPOL_EC4-2_5_10UF/16V10uF/16VEC4-2_5TC11CAP_EC4-2_5_10UF/16V10uF/16VEC4-2_5U1LT1117/DD_1_TO-252_LT1117-33LT1117-33TO-252U2MST9036_0_QFP100_TSUM16AL-1&TSUTSUM16AL-1&TSUM16AWL_1QFP100U324C08_1_SOP8_24C08_024C08_0SOP8U424C08_SOP8_24C1624C16SOP8X1CRYSTAL_0_XTAL-HC49_14.318MHZ14.318MHZXTAL-HC49
2层设计
xnima_irumei 发表于 2017-9-8 17:45
kami03372 发表于 2017-9-8 20:26
谢谢分享
miaomiao 发表于 2017-9-9 06:42
厉害了,楼主
学海无涯 发表于 2017-9-9 07:12
单枪舞九州 发表于 2017-9-9 07:28
不错
pads_hj 发表于 2017-9-9 08:09
jopey 发表于 2017-9-9 08:11
shenchengan 发表于 2017-9-9 08:16
jyh5515 发表于 2017-9-9 08:26
页: [1] 2 3 4 5
查看完整版本: TSUM16AL-1(TSUM16AWL_1) 液晶显示器驱动板 PCB文件共享 MST9036
