老吴 发表于 2017-7-15 19:04
联芯4核 LC1813 方案手机PCB和原理图(IRIS304+SKY77590+LC1132)
联芯的东西,网上少之又少。 难找的很。
NamePart TypePCB DecalValueANT1100ANT1X2.7MMANT1X2.7MMANTANT1101ANT1X2.7MMANT1X2.7MMANTANT1200ANT1X2.7MMANT1X2.7MMANTANT1201ANT1X2.7MMANT1X2.7MMANTB700FB0603L0603HMM8B729FB0603L0603HMM8B750BEAD-1KOHM-0402B04021KohmB751BEAD-1KOHM-0402B04021KohmB752TVS0402_0.05PFRV04020.05PFB753BEAD-1KOHM-0402B04021KohmB754BEAD-1KOHM-0402B04021KohmB755BEAD-1KOHM-0402B04021KohmB756BEAD-1KOHM-0402B04021KohmB757RES0402_100RRES0402100RB758RES0402_100RRES0402100RB759RES0402_100RRES0402100RB800R0201_75RR020175RB1200BEAD-75OHM-0402B040275ohmCON400CONJTAGCONJTAGNCCON1000CON_5PIN4PIN_0.4X1.5NCCON1050USB-VE107-028-X3USB-VE107-028-X3CON1051CON_5PIN4PIN_0.4X1.5NCD400DIODE-RB521S-30DIODE-RB521S-30RB520G-30D800RB400VA_D300025RB400VA_D300025RB400VAD1000PZ3D4V2H_D300024/CDZT2R5PZ3D4V2H_D300024/CDZT2R5PZ3D4V2H_D300024D1001DIODE-RB521S-30DIODE-RB521S-30RB520G-30D1002DIODE-RB521S-30DIODE-RB521S-30RB520G-30D1050TVS0402_15PFTVS040215PFD1051WE-SP195UHRUYG4-AD1052DIODE-RB521S-30DIODE-RB521S-30RB520G-30FB701IND0603_82NSL060382nHFB702IND0603_82NSL060382nHGB200IC_XH311HG_B180007IC_XH311HG_B180007XH311HGJ100MM8130-2600B/RA2/RB8MUR_MM8130_2602X_SMM8130-2600RA2J750BL509-10G31BL509-10G31J800AXE530124AXE530124J801BL509-06G31BL509-06G31BL509-06G31J802AXE530124AXE530124J1000MS00D_12135MS00D_12135L100C0201_NCC0201NCL205SPH252012HR47MTMPL2012S2R2MHT/SWPA2520121uHL750L0402_100NHL0402HMM5100nHL751L0402_1.2NHL0402HMM5NCL800SWPA3012S220MTMPL2012S2R2MHT/SWPA25201222uHL801IND0603_82NHL0603HMM882nHL802SWPA252012S1R0NTMPL2012S2R2MHT/SWPA2520121uHL1100MPH201210S1R0MTMPL2016S1R5MHT1UHL1101L0201_5.6NHL02015.6nHL1200L0402_6.8NHL0402HMM56.8nHL1201L0402_5.1NHL0402HMM55.1nHLNA1200MAX2659MAX2659Max2659 or CAN5120LMARK1MARK2MMMARKD2MMMARK2MARK2MMMARKD2MMMARK3MARK2MMMARKD2MMMARK4MARK2MMMARKD2MMMIC750MOE-C110T42-K1Q1050PDTA123JEPDTA123JEPDTA123JEREC750REC1.6X4MMREC1.6X4MM2403 260 00031REC751REC2X3.3MMREC2X3.3MM2403 260 00031RT200R0402_NTC-10KRES0402NTC-10KRV700MLV-AVLC5S02050SMLV0402RV729MLV-AVLC5S02050SMLV0402RV750MLV-AVLC5S02050SMLV0402SAW1100SAFEB1G57KE0F00_W201031SAFEB1G57KE0F00_W201031SAFEA2G45MC0F0ASAW1200MUR_SAFEA1G58KA0F00SAFEA1G58KA0F00SAW1201SAFEB1G57KE0F00_W201031SAFEB1G57KE0F00_W201031SAFEA2G45MC0F0ATP200TP_0.5TESTD0MM5TP0301TP0201TP_0.5TESTD0MM5TP0302TP300TP_0.5TESTD0MM5NCTP400TP_0.5TESTD0MM5NCTP401TP_0.5TESTD0MM5NCTP800FLASH0.7X3FLASH0.7X3NCTP801FLASH0.7X3FLASH0.7X3NCTP1050TP-2MMTESTD2MMTP1051TP-2MMTESTD2MMTP1052TP-2MMTESTD2MMTP1053TP-2MMTESTD2MMTP1054TP_0.5TESTD0MM5NCTP1055TP_0.5TESTD0MM5NCTP1056TP_0.5TESTD0MM5NCTP1057TP_1.5MMTESTD1MM51.5MMTP1058TP_1.5MMTESTD1MM51.5MMTP1059TP-1.1MMTESTD1MMTP1060TP-1.1MMTESTD1MMTP1061TP-1.1MMTESTD1MMU100IC_SKY77590_W101046IC_SKY77590_W101046IC_SKY77590_W101046U101IRIS304IRIS304U102SKY77709SKY77709U103SAFEA942MFL0F00SAFEA2G35MB0F00SAFEA942MFL0F00U104SAWFD881MAA0F0A(P)SAWFD881MAA0F0A(P)U105SAWFD1G84KA0F0A_ES1SAWFD1G84KA0F0A_ES1U106SAFEA942MFL0F00SAFEA2G35MB0F00SAFEA942MFL0F00U200FN5404U202NCP6335DFCT1GNCP6335DFCT1GNCP6335DFCT1GU401SGM4062YDE8G/TRSGM4062U500IC_LC1813_XXXXLC1813U600H9TP32A8JDMCPRH9TP32A8JDMCPRFLHMEM_162P_17NC_13DNU_32P27GU601H9TP26ABLDMCNR/KMI8U000MA-B605-AU701LC1132LC1132U800TCF03025H90002ATCF03025H90002AMCE1012E900FBU801TCF03025H90002ATCF03025H90002AMCE1012E900FBU802TCF03025H90002ATCF03025H90002AMCE1012E900FBU803TCF03025H90002ATCF03025H90002AMCE1012E900FBU804TCF03025H90002ATCF03025H90002AMCE1012E900FBU805RT9293_J6SOT23-6U806LDO_SGM2031_P101018LDO_SGM2031_P101018SGM2031-3.3YUDH4G/TRU807TCF03025H90002ATCF03025H90002AMCE1012E900FBU808TCF03025H90002ATCF03025H90002AMCE1012E900FBU809TCF03025H90002ATCF03025H90002AMCE1012E900FBU810SGM3782YTDP14G/TRU900LIS3DH_B121021LIS3DH_B121021LIS3DHU901MPL3115A2U902PS_MPU3050CU903STK3310U904AK8963C_B121036AK8963C_B121036AK8963CU1050ET7222U1100SKY13317-373GW2151U1101CW1100CW1100U1105AW8733AU1200CG2900CG2900VIB1050MOTOR-ZT40S01AMOTOR-ZT40S01ANCX10026M_7Q26002005_W15101726M_7Q26002005_W15101726M_7Q26002005_W151017X20032K_DST310S_W15003832K_DST310S_W15003832.768KHzX1200TG-5035CGTG-5035CG26M_1XTW26000CGA_W151016XCS01008522A0000A00C-8522A0000A00XJ600TF005-08115TF_E728XJ750NJP359JACK_AJ011PH005-06353XJ800AXE524124AXE524124BTBF_J301040XJ1000BA1050324BA105032402-032113SXJ1050AXE524124AXE524124BTBF_J301040
老吴 发表于 2017-7-15 19:06
PCB和原理图都是PADS9.5格式
RMB 有需要的下载,没需要的看看就好。
cyp554 发表于 2017-7-15 21:18
老师真的很厉害,这些资料都可以找到。不过为什么是要人民币而不是金币呢?
o桃花岛主o 发表于 2017-7-16 00:06
厉害啊
单枪舞九州 发表于 2017-7-16 07:03
支持
bidinghong 发表于 2017-7-16 07:22
顶顶顶顶
wcjcn 发表于 2017-7-16 07:25
freeerror 发表于 2017-7-16 07:34
谢谢分享
ksgt00865899 发表于 2017-7-16 08:04
谢谢分享这些稀有资料
longxuekai 发表于 2017-7-16 08:12
来看一下来了
页: [1] 2 3
查看完整版本: 联芯4核 LC1813 方案手机PCB和原理图(IRIS304+SKY77590+LC1132)
