armclub 发表于 2026-11-2 11:34
N32H785XIB7EC方案两个网口开发板PCB文件
PCB文件,没原理图
    NamePart TypePCB DecalValue
D4LED08050805-LED
D5DIODE_2SOD123SS14L
D6LED08050805-LED
D7LED08050805-LED
D8DIODE_2SOD123
D9DIODE_2SOD123
D10DIODE_SOD323SOD323NC
D11DIODE_SOD323SOD323NC
F6BEAD0402BEAD0402120R-100M
FB10INDUCTOR_2FB0603BLM18PG121SN1D
J1HEAD2X302.54MM_CON2X30P
J2HEAD2X302.54MM_CON2X30P
J4CONDIP2_ACON_254_2P
J5HEAD2X222.54MM_CON2X22P
J6TYPE-C_16PINTYPE-C_16PIN
J7CONDIP2_ACON_254_2P
J8TYPE-C_16PINTYPE-C_16PIN
J9MINIUSBCON_MINIUSB
J10CON-SIP-4PSIP-4P
J11HEADER-8X2HEADER16
J12CON1X32.54MM_CON3P
J13CONDIP2_ACON_254_2P
J14CONDIP2_ACON_254_2P
J15CON_2X2PIN_2.54MM_J114CON_2X2PIN_2.54MMCON_2X2PIN_2.54MM
J16RJ45_HR911105ARJ45-TH_HR911105AHR911105A
J17RJ45_HR911105ARJ45-TH_HR911105AHR911105A
L40INDUCTOR_SMD4.0X4.0IND-SMD_L2.5-W2.0-VLS252012CX-150M1μH_VLS252012HBX-1R0M-1
Q1NPN_SOT23SOT23PMBT3904
Q2NPN_SOT23SOT23PMBT3904
Q3P_MOSSOT23DMP2035P
Q6P_MOSSOT23DMP2035P
U1N32H785XIB7ECTFBGA14X14X1P2P0P8240+25-1LN32H785xxx7ec_SOCKET_TFBGA265
U2LP38501TSX-ADJ/NOPBPG-TO-263-5_L10.2-W8.7-P1.70-LS14.4-BR
U3NET1001AN-QFN32-50P500X500X80
U4N32G4XCQFP48-3N32G452CCL7
U5NET1001AN-QFN32-50P500X500X80
U6RT2516GSPESOP8
U8TLV70212DBVRSOT-23-5_L3.0-W1.7-P0.95-LS2.8-BL
U9M24C32SOIC-8AT24M01
XTAL_OUT1TP1TP1TP
XTAL_OUT2TP1TP1TP
Y1XTAL_2PIIN_SMD3215XTAL_32.768K_3215NX3215SA-EXS00A-MU00554-32.768K/12.5pF
Y2XTAL_SMD3225XTAL_322525MHZ/18pF
Y3CRYSTAL_2PINSMD32258MHz (AV08000301) 12pF
Y4XTAL_SMD3225_POWERXTAL_322532MHZ
Y5XTAL_SMD3225_POWERXTAL_322532MHZ
huayutiangong 发表于 2026-11-2 13:46
感谢分享
bidezhi7777 发表于 2026-11-2 20:03
jinniuxing 发表于 2026-11-2 23:28
谢谢分享
private80 发表于 2026-11-3 08:55
感谢版主的分享,赞一个;P
小杰也行 发表于 2026-11-3 09:01
rome2008ok 发表于 2026-11-3 09:21
不错不错
小杰也行 发表于 2026-11-3 10:08
zzr1974418 发表于 2026-11-3 13:37
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
查看完整版本: N32H785XIB7EC方案两个网口开发板PCB文件
