全志Allwinner V851S 原厂DEMO 板PCB和原理图
PCB 和原理图都有。一起打包了。
D4ESD9B5VL_ESD0402_ESD5451XESD5451XESD0402
D5ESD9B5VL_ESD0402_ESD5451XESD5451XESD0402
D6ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D7ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D8XYC-PT3528BC-I6_LED2_350X280X20XYC-PT3E550BC-I6LED2_350X280X200
D14DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118
D18DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118
D19ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D20ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D22DIO-B5819W_SOD155_270H118_NC/B5NC/B5819WSOD155_270H118
D23LED-0805-G_LED0805_LED-0805-GLED-0805-GLED0805
D24LED-0805-B_LED0805_LED-0805-BLED-0805-BLED0805
D25LED-0805-R_LED0805_LED-0805-RLED-0805-RLED0805
D26XYC-PT3528BC-I6_LED2_C590H1040_HANB30LED2_C590H1040_P254_DIP
DC8ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DL1DIO-SS16F_SOD250_380H100_SS16FSS16FSOD250_380H100
DP1LED-0603-R_LED0603_LED-0603-RLED-0603-RLED0603
DP2LED-0805-R_LED0805_LED-0805-RLED-0805-RLED0805
DP4ZENER-BZT52C5V6_SOD155_270H118_NC/PT1A071VSOD155_270H118
DP5DIO-SS24_SOD362_432H229_SS24SS24SOD362_432H229
DP6DIO-SS24_SOD362_432H229_NC-SS24NC-SS24SOD362_432H229
DP10DIO-B5819W_SOD155_270H118_NC/B5NC/B5819WSOD155_270H118
DU1ESD9B5VL_ESD0402_NC/ESD9B5VL-2-NC/ESD9B5VL-2-TRESD0402
DU2ESD9B5VL_ESD0402_NC/ESD9B5VL-2-NC/ESD9B5VL-2-TRESD0402
DU3ESD5451X_ESD0402_NC/ESD5451X-2-NC/ESD5451X-2-TRESD0402
DW1DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118
DW2DIO-B5819W_SOD155_270H118_NC/B5NC/B5819WSOD155_270H118
FB5FB-0603_L0603_100R-1A100R-1AL0603
FB6FB-0603_L0603_100R-1A100R-1AL0603
J11XH2.54MM-5P-M_HDR1_5P250B570_15XH2.54MM-5P-MHDR1_5P250B570_1500H700
J14CON1X2-2.54-M_HDR1_2P254B250_50NC/CON1X2-2.54-MHDR1_2P254B250_508H254
J24FPC-50P-0.5MM-V_FPC52P50B450_30FPC-50P-0.5MM-VFPC52P50B450_3065H520
J59XH1.25MM-2P-M_CON2-PT1_25-3_2X4NC/XH1.25MM-2P-MCON2-PT1_25-3_2X4_35H4_8B-UP
J69XH2.54MM-5P-M_HDR1_5P250B570_15XH2.54MM-5P-MHDR1_5P250B570_1500H700
J71JUMPER-2_HDR1_2P254B250_508H254NC/DBG-CLKHDR1_2P254B250_508H254
J72CON1X2-2.54-M_HDR1_2P254B250_50NC/CON1X2-2.54-MHDR1_2P254B250_508H254
J79CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
J81CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
JA5JUMPER-2_HDR1_2P254B250_508H2_1PSHDR1_2P254B250_508H254
JC1TF-SLOT_SDC13B1450_1472H245_TF-TF-SLOTSDC13B1450_1472H245
JF1JUMPER-2_HDR1_2P254B250_508H2_2DVDDHDR1_2P254B250_508H254
JL5FPC-6P-0.5MM-V_FPC8P50B233_850HFPC-6P-0.5MM-VFPC8P50B233_850H300
JP4DCIN-12V_PWR3B900_1400H1100_DCIDCIN-12VPWR3B900_1400H1100
JP9JUMPER-3_HDR1_3P254B250_762H2545V-INHDR1_3P254B250_762H254
JP10CON2X10-2.54-M_HDR2_10P254B500_CON2X10-2.54-MHDR2_10P254B500_2540H254
JU1USB2.0-MICRO-01F_USB9P65B500_69USB2.0-MICRO-01FUSB9P65B500_690H240
JW1ANT-IPX_ANT3B300_310H125_ANT-IPANT-IPXANT3B300_310H125
JW2CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
JW4CON2X6-2.54-M_HDR2_6P254B500_15CON2X6-2.54-MHDR2_6P254B500_1524H254
K6KEY-04P-SMD-03_KEY4B450_450H380UBOOTKEY4B450_450H380
KP2KEY-04P-SMD-03_KEY4B450_450H3_1PWRONKEY4B450_450H380
KW1KEY-04P-SMD-03_KEY4B450_450H3_2CHIP-PWDKEY4B450_450H380
KW2KEY-04P-SMD-03_KEY4B450_450H3_3XR806-FELKEY4B450_450H380
KW3KEY-04P-SMD-03_KEY4B450_450H3_4DOLLBELLKEY4B450_450H380
KW4KEY-04P-SMD-03_KEY4B450_450H3_5POWERON/OFFKEY4B450_450H380
LCD2CON25-0.5MM_CON25-PT0_6-3_6X9H1CON25CON25-PT0_6-3_6X9H1B
LL1L-L2520_LP200_250H100_10UH-0.9A10uH-0.9A-DCR<0.02RLP200_250H100
LP1L-L3225_CD32_1UH-2A1uH-2ACD32
LP2L-L3225_CD32_1UH-2A1uH-2ACD32
LP3L-L3225_CD32_NC/1UH-2ANC/1uH-2ACD32
LP4L-L3225_CD32_1UH-2A1uH-2ACD32
LP5L-L3225_CD32_1UH-2A1uH-2ACD32
LP6L-L2520_LP200_250H100_2.2UH-1.52.2uH-1.5ALP200_250H100
LP8L-L3225_CD32_4.7UH4.7UHCD32
LW1R-R0402-5%_L0806_NC/0RNC/0RL0806
LW2L-L2520_LP200_250H100_2.2UH-1.52.2uH-1.5ALP200_250H100
MIC1MIC-DGHSEM6050_MIC2B600H500_DGHDGHSEM6050MIC2B600H500
Q21NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q22NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q23NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q25NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q28NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q29NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q30NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
Q31NMOS-BSN20_SOT3P95B130_290H103_BSN20SOT3P95B130_290H103
QC1PMOS-STS2301_SOT3P95B130_290H10STS2301SOT3P95B130_290H103
QP1PMOS-STS2301_SOT3P95B130_290H10STS2301SOT3P95B130_290H103
QP6NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
QP7PMOS-AO3423_SOT3P95B130_290H103NC/AO3423SOT3P95B130_290H103
QP8NMOS-2N7002_SOT3P95B130_290H103NC/NP2300SOT3P95B130_290H103
U1AW8010CSR_BGA9P50B145_145H65_AWAW8010CSRBGA9P50B145_145H65
U3SGM2028_SOT5P95B160_300H130_RT9RT9078-2.8VSOT5P95B160_300H130
U4SPI-NOR-SO8_SOP8P127B528_528H19SPI-NOR-SO8SOP8P127B528_528H195
U5CS8302_MSOP-8P_NC/NS4890NC/NS4890MSOP-8P
U25AL412_SENSOR_4C910H420_AL412AL412SENSOR_4C910H420
U47SENSOR-BMA250_LGA12P50B200_200HNC/SC7A20TRLGA12P50B200_200H100
U48SGM2028_SOT5P95B160_300H130_AP2AP2127-1.2VSOT5P95B160_300H130
U49PYD1598_SENSOR_4C910H480_P824MP824MSENSOR_4C910H480
UL1SY7200A_SOT6P95B160_290H145_LP3LP3380B6FSOT6P95B160_290H145
UL5SGM2028_SOT5P95B160_300H130_A_1AP2127-2.8VSOT5P95B160_300H130
UP1AXP2102_QFN41P40B500_500H75_AXPAXP2101QFN41P40B500_500H75
UP2SGM2028_SOT5P95B160_300H130_S_1SGM2040-3.3V/TMI6033SOT5P95B160_300H130
UP3SY8008B_SOT5P95B160_300H130_TMITMI3181/ETA3425SOT5P95B160_300H130
UP4SY6288_SOT5P95B160_300H130_NC/SNC/SY6288DAACSOT5P95B160_300H130
UP7ETA7014_SOT23-6_NC/ETA7014NC/ETA7014SOT23-6
UP8ET9528_SOT23-6_NC/ET9528NC/ET9528SOT23-6
UP9XB5352A_SOT5P95B160_300H130_NC/NC/XB5352ASOT5P95B160_300H130
UP10SGM2028_SOT5P95B160_300H130_SGMSGM2040-3.3VSOT5P95B160_300H130
UP13SY8120B1ABC_SOT6P95B180_310H100SY8120B1ABCSOT6P95B180_310H100
UU1V851S_QFN88_QFN89P35B900_900H90V851SQFN89P35B900_900H90
UW1SY8008B_SOT5P95B160_300H130_TMITMI3181/ETA3425SOT5P95B160_300H130
UW3XR806AF2L_QFN41P40B500_500H75_XXR806BF2LQFN41P40B500_500H75
Y1CRY-24MHZ-3225-SMD_X4B250_320H124M-16pF-10ppmX4B250_320H120_SMD
YW1CRY-24MHZ-3225-SMD_X4B250_320_140MHz-E3SB40MHzX4B250_320H120_SMD
YW2CRY-32.768KHZ-3215-SMD_CRYSTAL-ETST00327000JECRYSTAL-2P-3215-H0_85A
感谢分享 感谢分享 感谢分享 感谢分享
感谢分享
