sii9000 发表于 2026-9-11 21:00
STM32F407VGT6 + CS43L22-CNZ +STM32F103C8T6+DP83826IRHBR+DRV8701ERGET+DMHT6016LFJ-13 做的PCB和原理图
ESD3V3D9-TPD1, D2, D3, D4DIO_SOD-923DIO-T_3.3V-8.8V-10A-SOD9234
MBRS130LT3GD5, D7DIO_SMB_DO-214AADIO-S_445mV-30V-2A-SMB2
BZT52C3V3-7-FD6DIO_SOD-123DIO-Z_3.3V-500mW-SOD1231
1.8V ZenerD8DIO_DO-213AB_SMDDIO-Z_1.8V-500mW-DO213AA1
RED LEDDS1, DS2LED_0805LED_RED-2V-20mA-08052
1KFB1, FB2, FB3, FB4IND_0805FB_1K-100MHZ-1.6A-08054
USB2.0 MINI BJ1, J5CON_690-005-299-043CON_USB2.0-MINIB-SMD2
B6B-XH-A(LF)(SN)J2CON6_100_B6B-XH-A_TH_STCON-PLG_6X1-100-ST-TH1
RJ45 LANJ3CON10_P106_RJ45_TH_STCON-SKT-RJ_8C8P-RA-TH1
B2B-XH-A(LF)(SN)J4, J10CON2_100_B2B-XH-A_TH_STCON-PLG_2X1-100-ST-TH2
1.25MM Spade 4PINJ6CON4_50_653004117322_TH_RACON-PLG_4X1-50-RA-TH1
4X1 STEREOJ7CON_SJ-2504A-SMT-TR_SMDCON-PLG-STEREO_4X1-100-RA-SMD1
B4B-XH-A(LF)(SN)J8, J9CON4_100_B4B-XH-A_TH_STCON-PLG_4X1-100-ST-TH2
Terminal Block 2.5mmJ11CON3_100_TB_TH_STCON-TB_3X1-100-ST-TH1
4X1 BERG STRIPJ12CON4_100_40D72_TH_ST_MALECON-BS-PLG_4X1-100-ST-TH1
Mounting HoleMH1, MH2, MH3, MH4MOUNTINGMH_3.5H_6D4
DMHT6016LFJ-13Q1, Q2DFN5045-12_33_212_27X15_SMD_1MOSFET-N_60V-14.8A-V-DFN5045-122
TACTILE SWITCHSW1, SW2, SW3SW_342_SMDSW1_RS-282G05A3-SMRT-SMD3
STM32F103C8T6U1LQFP-48_19.6_393_58X11_SMDIC_STM32F103C8T61
DP83826IRHBRU2VQFN32_19_218_23X9_SMDIC_DP83826IRHBR1
DRV8701ERGETU3, U9VFQFN24_19.6_196_12X32_SMD_1IC_DRV8701ERGET2
CH340CU4SOIC16_50_284_25X90_SMTIC_CH340C1
ADS122C04IPWU5TSSOP16_25-59_294_54X14_SMTIC_ADS122C04IPW1
CS43L22-CNZU6QFN40_19_284_33X9_SMDIC_CS43L221
IMP34DT05TRU7HCLGA-4_53_137_15X37_SMDIC_IMP34DT05TR1
STM32F407VGT6U8QFN100_19.6_669_58X10_SMDIC_STM32F407VGT61
LD1117S33CTRU10SOT223_3REG_15V-3.3V-0.9A-12W-SOT2231
LD1117S18TRU11SOT223_3REG_15V-1.8V-0.8A-1.4W-SOT2231
8MhzX1, X2XTAL_314_240X47_SMDXTAL_8MHZ-ECS-80-32-5PX-SMD2
25Mhz -14mmY1XTAL_314_240X47_SMDXTAL_25Mhz-FOXSDLF/250F-201
bidezhi7777 发表于 2026-9-12 05:30
江波波 发表于 2026-9-12 07:33
学习学习学习
13412678220 发表于 2026-9-12 08:15
林枫1314 发表于 2026-9-12 08:22
maogege-chen 发表于 2026-9-12 08:36
caodiren 发表于 2026-9-12 08:39
good good study, day day up
longxuekai 发表于 2026-9-12 08:49
学习一下的
790 发表于 2026-9-12 08:52
lf2k2022 发表于 2026-9-12 08:53
页: [1] 2 3 4
查看完整版本: STM32F407VGT6 + CS43L22-CNZ +STM32F103C8T6+DP83826IRHBR+DRV8701ERGET+DMHT6016LFJ-13 做的PCB和原理图
