armclub 发表于 2026-9-4 17:41
18层PCB Altera Arria 10 GX 10AX115F1932C 原理图和PCB文件
D1LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D2LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D3BILED_0_LITE-ON_LTST-C195GEKT_LLED_GRLITE-ON_LTST-C195GEKT
D3982401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D40LT1389_SO8_LT1389LT1389SO8
D4182401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D42LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D43LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D44D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D45D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D46D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D47D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
F1FUSE_0805_500MA,RESETTABLE500mA,Resettable805
FB1INDUCTOR_805_120OHM,800MA120ohm,800mA805
J110X40_VITA57_10X40_ASP_VITA57_AASP-134486-0110X40_ASP_VITA57
J210X40_VITA57_10X40_ASP_VITA57_AASP-134486-0110X40_ASP_VITA57
J3MICRO_USB_CONN_MOLEX-MICRO-USB-MICRO_USB_CONNMOLEX-MICRO-USB-47589-001
J42X4_PCIE_ATX_MLX_SD-5569_8POS_RPCIe2x4 ATXMLX_SD-5569_8POS_RA
J5DISPLAYPORT_POST_CONN_MOLEX_SD-472720024MOLEX_SD-47272-0024
J6SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J7SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J9HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02ERJ45
J10LCD_HEADER_NEWHAVEN_LCD_LCD_HEALCD_HEADERNEWHAVEN_LCD
J12SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGESAMTEC_SFP_MECT20
J13CUI_PD-40S_CUI_PD-40S_4PIN-DIN-PD-40SCUI_PD-40S_4PIN-DIN-JACK_RA
J14EMI_HLS-180324-B-12_ISI_HILO-SKHLS-180324-B-12ISI_HILO-SKT_324-KEYED
J15SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J16SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J172X5_HDR2X5_100MIL_SMT_2X5_100MI2X5_100milHDR2X5_100MIL_SMT
J18QSFP_AND_CAGE_0_TYCO_QSFP_38_QSQSFP_AND_CAGETYCO_QSFP_38
J19CON2_MLX_22_23_2021_MLX_22_23_222_23_2021MLX_22_23_2021_VRT_HDR_2P
J20BNC_VERTICAL_4POST_LIGHTHORSE_SSMBLIGHTHORSE_SMB_JACK_VERT_SMT
J21BNC_VERTICAL_4POST_LIGHTHORSE_SSMBLIGHTHORSE_SMB_JACK_VERT_SMT
J22PCIE_BRACKET_X8_PCIX-8PORT_PCIEPCIE_SlotPCIX-8PORT
J232X5_HDR2X5_100MIL_SMT_DNIDNIHDR2X5_100MIL_SMT
J242X6HDR_2X6HDR-2MMX2MM_2X6HDR2x6HDR2X6HDR-2MMX2MM
L5BEAD_FERRITE_SM_0603_120OHM FB120Ohm FB603
L6BEAD_FERRITE_SM_0603_DNIDNI603
L7BEAD_FERRITE_SM_0603_120OHM FB120Ohm FB603
L8BEAD_FERRITE_SM_0402_DNIDNI402
L9BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L10INDUCTOR_0402_3.9NH3.9nH402
L11INDUCTOR_0402_5.6NH5.6nH402
L12INDUCTOR_0402_3.9NH3.9nH402
L13BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L14BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L15BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L16INDUCTOR_SM_1008_IND_4.7UH4.7uHSM_1008_IND
L17INDUCTOR_SM_1008_IND_4.7UH4.7uHSM_1008_IND
L19INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L20INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L21INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L22BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L24BEAD_FERRITE_SM_IND_WURTH_7427910A,RDC 4mOhmIND_WURTH_74279223560
L25INDUCTOR,DISCRETE_IND_744301020.25uHIND_744301025
L26INDUCTOR,DISCRETE_IND_744301020.25uHIND_744301025
L27INDUCTOR,DISCRETE_IND_744301020.25uHIND_744301025
L28INDUCTOR,DISCRETE_IND_744301020.25uHIND_744301025
Q3PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q23FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q24PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q25FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q26PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q27FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q28PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q29FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q30PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q31FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q32PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q33FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q34PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q39FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q40FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q41FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q42FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q43FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q44FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q45FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q46FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q47PWRMOSFET_EN_GSD_0_SOT23_2N70022N7002SOT23
Q48PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q49PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q50FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q51FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q52FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q53PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q54PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q55FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
RN1RES_PACK_0_RES_PACK_8_S1+S2+S3+10KRES_PACK_8
S1TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S8TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
SW1SW_SLIDE_DPDT_EG2207_SW_SLIDE_DSW_SLIDE_DPDTEG2207
SW276SB08_DIPSWITCH_SMT_OCTAL_DIPSDIPSWITCH8DIPSWITCH_SMT_OCTAL
SW3SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW4SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW5SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW6SPST5_DIPSWITCH_SMT_TEN_DIPSWITDIPSWITCH5DIPSWITCH_SMT_TEN
SW7DIPSW06_DIPSW06_DIPSW06DIPSW06DIPSW06
U1CY7C68013A_56QFN_QFN56_CY7C6801CY7C68013A_QFNQFN56
U2MAX811_SOT-143_MAX811MAX811SOT-143
U4PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AG18F64_10X8
U5PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AG18F64_10X8
U9EN6360QI_1_QNF68_EN6360QIEN6360QIQNF68
U10EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76
U13FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U14SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMQFN24
U1588E1111_0_BCC96_88E111188E1111BCC96
U165M2210ZF256_3_F256_(S1+S3+S4),S5M2210ZF256F256
U17FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U20EN6347_QFN38_EN6347QIEN6347QIQFN38
U22FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U23EN6347_QFN38_EN6347QIEN6347QIQFN38
U24EN6360QI_1_QNF68_EN6360QIEN6360QIQNF68
U25LTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1DFN6-2X2_EPAD
U26SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMQFN24
U27FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U2810AX115F1932C_3_F1932_(S1+S2+S310AX115F1932CF1932
U29EPCQL_24TBGA_T-PBGA-24_6X8MM_EPEPCQ1024LT-PBGA-24_6X8MM
U31EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76
U35FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U36LT3082_DFN8_EPAD_LT3082LT3082DFN8_EPAD
U39FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U40M22544_QFN24_M22544M22544QFN24
U41M22468_MLF-16_M22468M22468MLF-16
U42SI53301_11_QFN32-FTDI_SI53301_1Si53301_11QFN32-FTDI
U44LTC2418_SSOP28_NAR_LTC2418LTC2418SSOP28_NAR
U45TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRT
U46MAX1619_5_QSOP16_MAX1619MAX1619QSOP16
U47LEVELTRANSLATOR_QFN-12_ST2149BST2149BQFN-12
U49EPM1270M256_2_M256_(S1+S4),(S2+EPM1270_M256FBGAM256
U50LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U51EN6337_QFN38-ENPIRON_EN6337EN6337QFN38-ENPIRON
U52LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365-1DFN8-EPAD_3X2
U53SL18860DC_TDFN-10_SL18860DCSL18860DCTDFN-10
U54LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U55LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U57EN6337_QFN38-ENPIRON_EN6337EN6337QFN38-ENPIRON
U58MAX13042_0_UCSP-12_MAX13042MAX13042UCSP-12
U59MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U60MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U61MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U62MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U64MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U65MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U66MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U68MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U69MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U70MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U71MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U7274VCX08BQX_DQFN14_74VCX08BQX74VCX08BQXDQFN14
U73MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U74MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U75SN74LVC1G08_6PIN_PSON-6-DSF_SN7SN74LVC1G08_6PINPSON-6-DSF
U76MAX13042_0_UCSP-12_MAX13042MAX13042UCSP-12
U79LTC4315_MSOP12_LTC4315LTC4315MSOP12
U80LTC4315_MSOP12_LTC4315LTC4315MSOP12
U81LTC2977_QFN-64_9MMX9MM_LTC2977LTC2977QFN-64_9MMX9MM
U86FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U87LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365-1DFN8-EPAD_3X2
U88FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U89LTM4620A_BGA-144_REVERSE_LTM462LTM4620ABGA-144_REVERSE
U90LTM4620A_BGA-144_REVERSE_LTM462LTM4620ABGA-144_REVERSE
U91LTC3877EUK_QFN-44_LTC3877EUKLTC3877EUKQFN-44
U95LTC3874IUFD#PBF_QFN-28_LTC3874ILTC3874IUFD#PBFQFN-28
U96LTM4637_LGA-133_LTM4637EV#PBFLTM4637EV#PBFLGA-133
X1SI516_571_XTAL_SI570_SI516_148.Si516_148.5M_148.35MXTAL_SI570
X2635L3C3_XTAL_EG2100_125.0MHZ125.0MHzXTAL_EG2100
X3SI570_ALT1_XTAL_SI570_SI570SI570XTAL_SI570
X4OSC_ALT_0_ECS3525_50MHZ50MHzECS3525
X5OSC_ALT_SM55-OSC_125MHZ125MHzSM55-OSC
X6OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzXTAL_SG310
X7OSC_ALT_SM55-OSC_100MHZ100MHzSM55-OSC
Y1CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzXTAL_FA-128
Y2CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzXTAL_FA-128
Y3CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzXTAL_FA-128
Limx122 发表于 2026-9-4 18:03
学习一下
bidezhi7777 发表于 2026-9-4 19:34
private80 发表于 2026-9-4 20:30
感谢版主的分享,赞一个;P
c_azrael 发表于 2026-9-4 23:28
谢谢分享
kanxue_nmg 发表于 2026-9-5 05:44
江波波 发表于 2026-9-5 07:40
谢谢分享
飞扬11 发表于 2026-9-5 08:03
感谢分享
13412678220 发表于 2026-9-5 08:05
io357 发表于 2026-9-5 08:24
谢谢分享
页: [1] 2 3 4 5 6 7
查看完整版本: 18层PCB Altera Arria 10 GX 10AX115F1932C 原理图和PCB文件
