NXP IMX93 MCIMX93原厂DEMO板PCB原理图GERBER BOM仿真模型等资料
底板
两个核心板
BH201MOUNT_HOLE_MH202-123T_IC_1.5MM_SMTSO-M2MH202-123T
BH202MOUNT_HOLE_MH202-123T_IC_1.5MM_SMTSO-M2MH202-123T
BH203MOUNT_HOLE_MH202-123T_IC_1.5MM_SMTSO-M2MH202-123T
BH204MOUNT_HOLE_MH202-123T_IC_1.5MM_SMTSO-M2MH202-123T
BH205MOUNT_HOLE_STANDOFF_CIRCLE_5P1-STANDOFFM2.5STANDOFF_CIRCLE_5P1-2P5MM_NSP
BH206MOUNT_HOLE_STANDOFF_CIRCLE_5P1-STANDOFFM2.5STANDOFF_CIRCLE_5P1-2P5MM_NSP
BH207MOUNT_HOLE_STANDOFF_CIRCLE_5P1-STANDOFFM2.5STANDOFF_CIRCLE_5P1-2P5MM_NSP
BH208MOUNT_HOLE_STANDOFF_CIRCLE_5P1-STANDOFFM2.5STANDOFF_CIRCLE_5P1-2P5MM_NSP
BH901MOUNT_HOLE_MH244-166T_202H_IC_5SMTSO-M2.5-5ETMH244-166T_202H
BT1001BATTERY_BATTERY_4P8SQ_S_IC_1.77ML414HBATTERY_4P8SQ_S
D203ZDIODE_SOD523_IC_0.65MM_480-798BZX585-B3V3SOD523
D204LED_LED_0603_IC_0.8MM_370-7665LEDREDLED_0603
D301DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D302ZDIODE_SOD523_IC_0.65MM_480-798BZX585-B3V3SOD523
D401DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D402DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D403DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D404ZDIODE_SOD523_IC_0.65MM_480-798BZX585-B3V3SOD523
D701DIODE_TVS_DO214AC_AK_IC_2.29MMSMAJ20ADO214AC_AK
D901LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D902LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1001LED_GPLY6900_LED4_3P4X3_SM_IC_2RGBLED4_3P4X3_SM
D1002DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D1003DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GDIODE2_SOD523
D1004DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GDIODE2_SOD523
D1005DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1006DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1007DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1008DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1009DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1010DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFDSN0603-2
D1012DIODE_SOD323_IC_1.15MM_480-3003BAT54HT1SOD323
D1101LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D1102LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1104ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2CANFD24V-TSOT23_A
D1301BAV99W_SOT323_3P_IC__480-80093_BAV99W,115SOT323_3P
D1302BAV99W_SOT323_3P_IC__480-80093_BAV99W,115SOT323_3P
D1401DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320SOD323
D1402DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320SOD323
D1403LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1404LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D1405LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D1406LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1407DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320SOD323
D1408DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320SOD323
D1409DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320SOD323
D1410LED_LED_0603_IC_0.8MM_370-7665LEDREDLED_0603
D1411LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1412LED_LED_0603_IC_0.8MM_370-7665LEDREDLED_0603
D1413LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D1414LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D1415LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
F301FUSE_FUSE_3P4X1P8_DISCRETE_0.867AFUSE_3P4X1P8
F302FUSE_FUSE_3P4X1P8_DISCRETE_0.867AFUSE_3P4X1P8
F401FUSE_FUSE_3P4X1P8_DISCRETE_0.867AFUSE_3P4X1P8
J101CONN_HDR_40X2_A_CON80_0P4_18P8XDF40C-80DS-0.4V(51)CON80_0P4_18P8X3P1_SM
J102HDR_2X50_M_CON100_0P4_22P8X3P1_DF40C-100DS-0.4V(51)CON100_0P4_22P8X3P1_SM
J103CONN_HDR_40X2_A_CON80_0P4_18P8XDF40C-80DS-0.4V(51)CON80_0P4_18P8X3P1_SM
J201CONN_HDR_2X1_CON2_2P5_7P96X5P96CON_1X2CON2_2P5_7P96X5P96_TH
J301USB6_TYPEC_SH4_1_A_USB6P_TYPEC_USB6 TYPE CUSB6P_TYPEC_RA_SM
J302USB24_TYPEC_SH4_CON24_USB_TYPEC23K20101#LCP-872-2LF-L22-S22CON24_USB_TYPEC_RA_SMT_TH_2P2L
J401USB24_TYPEC_SH4_CON24_USB_TYPEC23K20101#LCP-872-2LF-L22-S22CON24_USB_TYPEC_RA_SMT_TH_2P2L
J501RJ45_2DUAL_LED_10P_CON_RJ45_10RJ-45CON_RJ45_10_2LED_TH
J601RJ45_2DUAL_LED_10P_CON_RJ45_10RJ-45CON_RJ45_10_2LED_TH
J701CON_2X18_SH6_CON2X18_RECEP_WSHECON2X18CON2X18_RECEP_WSHELL_0P8_SM_RA
J702CONN_HDR_20X2_CON_2X20_2P0_42P3CON2X20CON_2X20_2P0_42P3X5P4MM_TH
J703CONN_HDR_3X1_HDR103_78MIL_IO_5.HDR_1X3HDR103_78MIL
J704CONN_HDR_3X1_HDR103_78MIL_IO_5.HDR_1X3HDR103_78MIL
J705CONN_HDR_3X1_HDR103_78MIL_IO_5.HDR_1X3HDR103_78MIL
J801CON22_1_CON_FPC_22F_0P5_SM_RA_IXF2M-2215-1ACON_FPC_22F_0P5_SM_RA
J901CON_67_FEMALE_RA_B_CON_75_0P5_2M.2SKT KEY-ECON_75_0P5_22X9_RA1
J1001CONN_HDR_20X2_HDR220_TSM_A_SM_ITSM-120-01-F-DV-AHDR220_TSM_A_SM
J1002CONN_MICRO_SDCARD_CON9_SDCARD_1CONN_SD_CARD9CON9_SDCARD_1P1MM
J1003CONN_HDR_4X2_HDR204_2MM_TH_IO_5HDR2x4HDR204_2MM_TH
J1005CONN_HDR_4X2_CON_2X4_SKT_100_SMSSM-104-L-DVCON_2X4_SKT_100_SM
J1006CONN_HDR_3X2_HDR203_TMM_210H_IOHDR2X3HDR203_TMM_210H
J1101CONN_HDR_4X1_CON1X4_2MM_TH_303HCON1X4 PLUGCON1X4_2MM_TH_303H
J1201CON_KJ366EYS_AUDIOJACK_6P_CON6_KJ366EYSCON6_AUDIOJACK_RA_TH
J1202CONN_HDR_4X1_CON1X4_2MM_TH_303HCON1X4 PLUGCON1X4_2MM_TH_303H
J1301CON_KJ366EYS_AUDIOJACK_6P_CON6_KJ366EYSCON6_AUDIOJACK_RA_TH
J1401USB24_TYPEC_SH4_CON24_USB_TYPEC23K20101#LCP-872-2LF-L22-S22CON24_USB_TYPEC_RA_SMT_TH_2P2L
J1402CONN_HDR_20X2_HDR220_50X50_SM_2HDR_2X20HDR220_50X50_SM_247H
J1403CONN_HDR_20X2_HDR220_50X50_SM_2HDR_2X20HDR220_50X50_SM_247H
J1404CONN_HDR_6X2_B_CON12_0P4_5P2X3PCON_2X6CON12_0P4_5P2X3P08_SM
J1405CONN_HDR_5X2_HDR205_10M_50_SM_KFTSH-105-01-L-DV-KHDR205_10M_50_SM_K
JP701CONN_HDR_6X1_CON_1X6_2_TH_IO_7.CON1X6 PLUGCON_1X6_2_TH
L202INDUCTOR_IND_IHLP_DISCRETE_3MM_1.5uHIND_IHLP
L203INDUCTOR_IND2_11P5X10P3_SM_DISC10uHIND2_11P5X10P3_SM
L501BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L502BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L601BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L602BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L901INDUCTOR_IND_SPH2520_DISCRETE_10.47uHIND_SPH2520
L1001BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1002BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1003BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1101DLW43_IND_DLW43_DISCRETE__180-7DLW43SH510XK2IND_DLW43
L1201BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1202BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1203BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1204BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1205BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1301BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1401BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1402BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1403BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1404BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
L1405BEAD_0_IND_0603_DISCRETE_0.95MM120OHMIND_0603
Q301NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q302NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q701NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q901NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q902NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1001NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1002NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1003NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1401NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1402NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1403MOSFET_P_SC70_3_IC_1.1MM_480-79AO7401SC70_3
Q1404NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1405NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1406NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1407NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
Q1408NX3008NBKW_SOT323_SC70_3_IC_1.1NX3008NBKW,115SC70_3
TVS1401DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GDIODE2_SOD523
U101PCAL6524HE_QFN_UQFN32_0P5_5X5_EPCAL6524HEAZUQFN32_0P5_5X5_EP3X3
U102TMUX1574RSVR_A_PQFN16_0P4_2P65XTMUX1574RSVRPQFN16_0P4_2P65X1P85
U103ADP5585ACPZ_LFCSP16_A_LFCSP_16_ADP5585ACPZ-00-R7LFCSP_16_0P5_3X3_A
U104TMUX1574RSVR_A_PQFN16_0P4_2P65XTMUX1574RSVRPQFN16_0P4_2P65X1P85
U10574AUP1G07GW_SC70-5_IC_1.1MM_31274AUP1G07GWSC70-5
U106TMUX1574RSVR_A_PQFN16_0P4_2P65XTMUX1574RSVRPQFN16_0P4_2P65X1P85
U107PCA9617A_1_TSSOP8_A_IC_1.1MM_31PCA9617ADPJTSSOP8_A
U201MP8759GD_QFN12P_QFN12_0P5_3P1X2MP8759GDQFN12_0P5_3P1X2P1
U202MP2263GD_DFN15_A_DFN15_0P4_2X3_MP2263GDDFN15_0P4_2X3
U203DML3006LFDS-7_A_DFN2020_0P5_SQ2DML3006LFDS-7DFN2020_0P5_SQ2
U204PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U301PTN5110_QFN16_HX2QFN16_0P4_2P7XPTN5110HX2QFN16_0P4_2P7X2P7
U302NX20P5090UK_15P_A_WLCSP15_0P5_1NX20P5090UKWLCSP15_0P5_1P57X2P59
U303NX20P0407_WLCSP12_A_WLCSP12_0P4NX20P0407WLCSP12_0P4_1P3X1P7MM_SMDP
U304SGM8709YN5G_SOT-23-5_IC_1.25MM_SGM8709YN5GSOT-23-5
U305NX20P3483UK_42P_WLCSP42_0P4_2P9NX20P3483UKWLCSP42_0P4_2P94X2P54_SMDP
U306PESD1USB30_5P_WLCSP5_0P4_0P82X1PCMF1USB3SWLCSP5_0P4_0P82X1P22
U307PTN5110_QFN16_HX2QFN16_0P4_2P7XPTN5110HX2QFN16_0P4_2P7X2P7
U308NX20P0407_WLCSP12_A_WLCSP12_0P4NX20P0407WLCSP12_0P4_1P3X1P7MM_SMDP
U309TMUX1574RSVR_A_PQFN16_0P4_2P6_1TMUX1574RSVRPQFN16_0P4_2P65X1P85
U401PTN5110_QFN16_HX2QFN16_0P4_2P7XPTN5110HX2QFN16_0P4_2P7X2P7
U402NX20P3483UK_42P_WLCSP42_0P4_2P9NX20P3483UKWLCSP42_0P4_2P94X2P54_SMDP
U403PESD1USB30_5P_WLCSP5_0P4_0P82X1PCMF1USB3SWLCSP5_0P4_0P82X1P22
U404SGM8709YN5G_SOT-23-5_IC_1.25MM_SGM8709YN5GSOT-23-5
U405LM3480IM3_SOT-23_IC_1.12MM_315TLV76033DBZRSOT-23
U408PCMF2USB3S_1_WLCSP10_0P4_1P2X1PPCMF2USB3SWLCSP10_0P4_1P2X1P6MM_SMDP
U409PCMF2USB3S_1_WLCSP10_0P4_1P2X1PPCMF2USB3SWLCSP10_0P4_1P2X1P6MM_SMDP
U410CBTL02043ABQ_20P_A_DHVQFN20_0P5CBTL02043ADHVQFN20_0P5_2P6X4P6
U411NX20P0407_WLCSP12_A_WLCSP12_0P4NX20P0407WLCSP12_0P4_1P3X1P7MM_SMDP
U501RTL8211FD-40P_A_QFN40_0P4_5X5MMRTL8211FDI-VD-CGQFN40_0P4_5X5MM
U502DIODE_ESD_4CH_10P_A_1_XSON10_0PPUSB3FR4XSON10_0P5_1P1X2P6MM
U503DIODE_ESD_4CH_10P_A_1_XSON10_0PPUSB3FR4XSON10_0P5_1P1X2P6MM
U601RTL8211FD-40P_A_QFN40_0P4_5X5MMRTL8211FDI-VD-CGQFN40_0P4_5X5MM
U602DIODE_ESD_4CH_10P_A_1_XSON10_0PPUSB3FR4XSON10_0P5_1P1X2P6MM
U603DIODE_ESD_4CH_10P_A_1_XSON10_0PPUSB3FR4XSON10_0P5_1P1X2P6MM
U701PESD3USB3S_15P_WLCSP15_0P4_2P42PESD3USB3SWLCSP15_0P4_2P42X1P22_SMDP
U702PESD2USB3S_WLCSP_10P_WLCSP10_0PPESD2USB3SWLCSP10_0P4_1P2X1P6MM_SMDP
U703PCMF3USB3S_15P_WLCSP15_0P4_2P42PCMF3USB3SWLCSP15_0P4_2P42X1P22_SMDP
U704PCMF2USB3S_WLCSP10_0P4_1P2X1P6MPCMF2USB3SWLCSP10_0P4_1P2X1P6MM_SMDP
U705NTS0104GU12_12P_XQFN12_0P4_1P8XNTS0104GU12XQFN12_0P4_1P8X2P1
U70674LV1T34GWH_TSSOP6_SC70-5_IC_1.74LV1T34GWHSC70-5
U801PCMF3USB3S_15P_WLCSP15_0P4_2P42PCMF3USB3SWLCSP15_0P4_2P42X1P22_SMDP
U802NLSX5011_6P_UDFN6_0P4_1P2X1_IC_NLSX5011MUTCGUDFN6_0P4_1P2X1
U901MP2147GD_QFN_11P_QFN12_0P5_2X3MMP2147GDQFN12_0P5_2X3MM_EP
U902TXB0304RUT_12P_B_UQFN12_1P7X2MMTXB0304RUTRUQFN12_1P7X2MM
U90474AVC4T3144_12P_A_XQFN12_0P4_1P74AVC4T3144XQFN12_0P4_1P8X2P1
U905TXB0304RUT_12P_B_UQFN12_1P7X2MMTXB0304RUTRUQFN12_1P7X2MM
U1001LSM6DSO_LGA14P_LGA14_0P5_3X2P5_LSM6DSOXTRLGA14_0P5_3X2P5
U100274LV1T126GVH_SOT753_5P_1P7X3P1M74LV1T126GVHSOT753_5P_1P7X3P1MM
U1003FPF1504UCX_CSP4_A_WLCSP4_0P5_0PFPF1504WLCSP4_0P5_0P99X0P99
U1004PCF2131_4_SO16_0P5_3P5X4P5_MM_IPCF2131SO16_0P5_3P5X4P5_MM
U1005AP22615_1_SOT26_1P7X3P10_IC_1.0AP22615AWU-7SOT26_1P7X3P10
U1006AP22615_1_SOT26_1P7X3P10_IC_1.0AP22615AWU-7SOT26_1P7X3P10
U1101TJA1057GT3_8P_SO8_1P27_4X5_IC_1TJA1057GT/3SO8_1P27_4X5
U1201WM8962_BGA_49P_A_BGA49_0P5_3P62WM8962BECSN/RBGA49_0P5_3P62X4
U1202AP22818AKB_SOT23-5_IC_1MM_315-8AP22818AKBWTSOT23-5
U1301SPK0641HT4H_8P_A_LGA8_3P1X4P1MMSPK0641HT4H-1LGA8_3P1X4P1MM_SPK0641
U1302SPK0641HT4H_8P_A_LGA8_3P1X4P1MMSPK0641HT4H-1LGA8_3P1X4P1MM_SPK0641
U1303TMUX1574RSVR_A_PQFN16_0P4_2P65XTMUX1574RSVRPQFN16_0P4_2P65X1P85
U1304SPK0641HT4H_8P_A_LGA8_3P1X4P1MMSPK0641HT4H-1LGA8_3P1X4P1MM_SPK0641
U1305SPK0641HT4H_8P_A_LGA8_3P1X4P1MMSPK0641HT4H-1LGA8_3P1X4P1MM_SPK0641
U1306NCP161ASN180T1G_A_SOT-23-5_IC_1NCP161ASN180T1GSOT-23-5
U130774LV1T34GWH_TSSOP6_SC70-5_IC_1.74LV1T34GWHSC70-5
U130874LV1T34GWH_TSSOP6_SC70-5_IC_1.74LV1T34GWHSC70-5
U130974LV1T34GWH_TSSOP6_SC70-5_IC_1.74LV1T34GWHSC70-5
U1401FT4232HL_LQFP64_LQFP64_0P5_10X1FT4232HLQFP64_0P5_10X10
U1402SN74AXC8T245RHLR_VQFN24_A_VQFN2SN74AXC8T245RHLRVQFN24_0P5_5P6X3P6_EP
U1403PESD1USB30_5P_WLCSP5_0P4_0P82X1PCMF1USB3SWLCSP5_0P4_0P82X1P22
U140474AVC4T245GU_XQFN16_XQFN16_0P4_74AVC4T245GUXQFN16_0P4_2P7X1P9
U140593AA56BT_SOT23-6_SOT23-6_IC_1.493LC56BTSOT23-6
U140674HC3G06DC_SSOP8_DCU_IC_1.0MM_374HC3G06DCSSOP8_DCU
U140774AUP1G126GM_UDFN6_1X1P5MM_IC_074AUP1G126GMUDFN6_1X1P5MM
U140874AVC4T3144_12P_A_XQFN12_0P4_1P74AVC4T3144XQFN12_0P4_1P8X2P1
U1409PCA9655EMTTXG_WQFN24_A_QFN24_4XPCA9655EMTTXGQFN24_4X4_EP2P25MM
U1410RT9193-33PB_SOT23-5_IC_1.295MM_RT9193SOT23-5
U141174AVC4T245GU_XQFN16_XQFN16_0P4_74AVC4T245GUXQFN16_0P4_2P7X1P9
X1401XTAL_13_XTAL_4_3P3X2P6MM_IC_0.812MHzXTAL_4_3P3X2P6MM
Y501XTAL_13_XTL4_2P5X2MM_SM_IC_0.5525MHzXTL4_2P5X2MM_SM
Y601XTAL_13_XTL4_2P5X2MM_SM_IC_0.5525MHzXTL4_2P5X2MM_SM
D601LED_LED_0603_IC_0.8MM_370-7667LEDGREENLED_0603
D901DIODE_SCHTKY_SOD323_IC_0.8MM_48PMEG2010EJSOD323
D902DIODE_SCHTKY_SOD323_IC_0.8MM_48PMEG2010EJSOD323
D903DIODE_SCHTKY_SOD323_IC_0.8MM_48PMEG2010EJSOD323
D904DIODE_SCHTKY_SOD323_IC_0.8MM_48PMEG2010EJSOD323
J801CON_2X40_A_CON80_0P4_17P7X2P05_CON2X40CON80_0P4_17P7X2P05_SM
J802CON_2X40_A_CON80_0P4_17P7X2P05_CON2X40CON80_0P4_17P7X2P05_SM
J803HDR_2X50_M_A_CON100_0P4_21P7X2PDF40C-100DP-0.4V(51)CON100_0P4_21P7X2P05_SM
J901CONN_HDR_6X2_A_CON12_0P4_4P12X2CON2X6CON12_0P4_4P12X2P05_SM
L102INDUCTOR_FERRITE_0_IND_0603_DIS1.0KOHM@100MHzIND_0603
L701INDUCTOR_IND_SPH2520_DISCRETE_10.47uHIND_SPH2520
L702INDUCTOR_IND_SPH2520_DISCRETE_10.47uHIND_SPH2520
L703INDUCTOR_IND_SPH2520_DISCRETE_10.47uHIND_SPH2520
L704INDUCTOR_IND_SPH2520_DISCRETE_10.47uHIND_SPH2520
L705INDUCTOR_IND_2016A_DISCRETE_1.20.47uHIND_2016A
L706INDUCTOR_IND_2016A_DISCRETE_1.20.47uHIND_2016A
QZ401XTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_32.768KHZXTAL2-3P2X1P5-SM
QZ701XTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_32.768KHZXTAL2-3P2X1P5-SM
U101MIMX9352DVNXLAA_SKT_BGA306_0P5_SKTBGA 306 + MIMX9352CVVxMABSKT_BGA306_0P5_SQ16P23_ELAST
U201MT53E1G16D1FW-046_200P_A_BGA200MT53E1G16D1ZW-046AAT:CBGA200_0P65X0P8_10X14P5
U501SDINBDA6_32G_I_VFBGA_153P_FBGA1SDINBDA6-16G-IFBGA153_0P5_11P5X13
U701PCA9451AHNY_HVQFN56_0P4_7X7_EP4PCA9451AHNYHVQFN56_0P4_7X7_EP4P7MM
U901DML3006LFDS-7_A_0_DFN2020_0P5_SDML3006LFDS-7DFN2020_0P5_SQ2
U902PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U903TPS22990NDMLT_WSON10_2_WSON10_0TPS22990NWSON10_0P5_2P1X3P1
U904PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U905RT9193-33PB_SOT23-5_IC_1.295MM_RT9193SOT23-5
U906TPS22990NDMLT_WSON10_2_WSON10_0TPS22990NWSON10_0P5_2P1X3P1
U907PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U908TPS22990NDMLT_WSON10_2_WSON10_0TPS22990NWSON10_0P5_2P1X3P1
U909ADP5585ACPZ_LFCSP16_A_LFCSP_16_ADP5585ACPZ-00-R7LFCSP_16_0P5_3X3_A
U910TPS22990NDMLT_WSON10_2_WSON10_0TPS22990NWSON10_0P5_2P1X3P1
U911PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U912PAC1934_UQFN16_A_QFN16_0P65_4X4PAC1934T-I/JQQFN16_0P65_4X4_A
U913PCT2075_SON8_EP_HWSON8_0P5_3P1PCT2075HWSON8_0P5_3P1X2P1
U91493AA56BT_SOT23-6_SOT23-6_IC_1.493LC56BTSOT23-6
Y401XTAL_13_XTLOSC4_3P2X2P5MM_SM_IC24MHZXTLOSC4_3P2X2P5MM_SM
BH801MOUNT_HOLE_MH188-106T_IC_0.1MM_280-76791_FMCMOUNTING HOLEFMCMOUNTING HOLEMH188-106T
BH802MOUNT_HOLE_MH188-106T_IC_0.1MM_280-76791_FMCMOUNTING HOLEFMCMOUNTING HOLEMH188-106T
BH803MOUNT_HOLE_MH188-106T_IC_0.1MM_280-76791_FMCMOUNTING HOLEFMCMOUNTING HOLEMH188-106T
BH804MOUNT_HOLE_MH188-106T_IC_0.1MM_280-76791_FMCMOUNTING HOLEFMCMOUNTING HOLEMH188-106T
D601LED_LED_0603_IC_0.8MM_370-76672_LED GREENLEDGREENLED_0603
D701DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D702DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D703DIODE_SCHTKY_0_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D901DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D902DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D903DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
D904DIODE_SCHTKY_SOD323_IC_0.8MM_480-80156_PMEG2010EJPMEG2010EJSOD323
J801CON_2X40_A_CON80_0P4_17P7X2P05_SM_IO_1.29MM_211-80176_CON2X40CON2X40CON80_0P4_17P7X2P05_SM
J802CON_2X40_A_CON80_0P4_17P7X2P05_SM_IO_1.29MM_211-80176_CON2X40CON2X40CON80_0P4_17P7X2P05_SM
J803HDR_2X50_M_A_CON100_0P4_21P7X2P05_SM_IO_1.29MM_211-80305_DF40C-100DP-0.4V(51)DF40C-100DP-0.4V(51)CON100_0P4_21P7X2P05_SM
J901CONN_HDR_6X2_A_CON12_0P4_4P12X2P05_SM_IO__211-81502_CON2X6CON2X6CON12_0P4_4P12X2P05_SM
L102INDUCTOR_FERRITE_0_IND_0603_DISCRETE_0.95MM_180-81296_1.0KOHM@100MHZ1.0KOHM@100MHzIND_0603
L701INDUCTOR_IND_SPH2520_DISCRETE_1.2MM_180-78647_0.47UH_20%0.47uHIND_SPH2520
L702INDUCTOR_IND_SPH2520_DISCRETE_1.2MM_180-78647_0.47UH_20%0.47uHIND_SPH2520
L703INDUCTOR_IND_SPH2520_DISCRETE_1.2MM_180-78647_0.47UH_20%0.47uHIND_SPH2520
L704INDUCTOR_IND_SPH2520_DISCRETE_1.2MM_180-78647_0.47UH_20%0.47uHIND_SPH2520
L705INDUCTOR_IND_SPH2520_DISCRETE_1.2MM_180-78647_0.47UH_20%0.47uHIND_SPH2520
Q701NX3008NBKW_SOT323_SC70_3_IC_1.1MM_480-79736_NX3008NBKW,115NX3008NBKW,115SC70_3
Q901NX3008NBKW_SOT323_SC70_3_IC_1.1MM_480-79736_NX3008NBKW,115NX3008NBKW,115SC70_3
QZ401XTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_230-77653_32.768KHZ32.768KHZXTAL2-3P2X1P5-SM
U101MIMX9352DVNXLAA_SKT_BGA306_0P5_SQ16P23_ELAST_IC_10.03MM_TMP-CIP-13974_SKTBGA 306 + MIMX9352CVVXMABSKTBGA 306 + MIMX9352CVVxMABSKT_BGA306_0P5_SQ16P23_ELAST
U201MT53E1G16D1FW-046_200P_A_BGA200_0P65X0P8_10X14P5_IC_1.1_(S1+S2)_334-10016_MT53E1G16D1ZW-046AAT:CMT53E1G16D1ZW-046AAT:CBGA200_0P65X0P8_10X14P5
U501SDINBDA6_32G_I_VFBGA_153P_FBGA153_0P5_11P5X13_IC_1MM_342-00870_SDINBDA6-16G-ISDINBDA6-16G-IFBGA153_0P5_11P5X13
U701MPF0900AVNA5ES_56P_PQFN56_0P5_8X8MM_IC_1.00MM_TMP-CIP-15233_MPF0900AVNA5ESMPF0900AVNA5ESPQFN56_0P5_8X8MM
U702NTS0104GU12_2_XQFN12_0P4_1P8X2P1_IC_0.5MM_312-82046_NTS0104GU12NTS0104GU12XQFN12_0P4_1P8X2P1
U901DML3006LFDS-7_A_0_DFN2020_0P5_SQ2_IC_0.9MM_315-83392_DML3006LFDS-7DML3006LFDS-7DFN2020_0P5_SQ2
U902PAC1934_UQFN16_A_QFN16_0P65_4X4_A_IC__312-82072_PAC1934T-I/JQPAC1934T-I/JQQFN16_0P65_4X4_A
U903TPS22990NDMLT_WSON10_2_WSON10_0P5_2P1X3P1_IC_0.8MM_315-82218_TPS22990NTPS22990NWSON10_0P5_2P1X3P1
U904PAC1934_UQFN16_A_QFN16_0P65_4X4_A_IC__312-82072_PAC1934T-I/JQPAC1934T-I/JQQFN16_0P65_4X4_A
U905RT9193-33PB_SOT23-5_IC_1.295MM_315-76265_RT9193RT9193SOT23-5
U906TPS22990NDMLT_WSON10_2_WSON10_0P5_2P1X3P1_IC_0.8MM_315-82218_TPS22990NTPS22990NWSON10_0P5_2P1X3P1
U907PAC1934_UQFN16_A_QFN16_0P65_4X4_A_IC__312-82072_PAC1934T-I/JQPAC1934T-I/JQQFN16_0P65_4X4_A
U908TPS22990NDMLT_WSON10_2_WSON10_0P5_2P1X3P1_IC_0.8MM_315-82218_TPS22990NTPS22990NWSON10_0P5_2P1X3P1
U909ADP5585ACPZ_LFCSP16_A_LFCSP_16_0P5_3X3_A_IC_0.8MM_312-83328_ADP5585ACPZ-00-R7ADP5585ACPZ-00-R7LFCSP_16_0P5_3X3_A
U910TPS22990NDMLT_WSON10_2_WSON10_0P5_2P1X3P1_IC_0.8MM_315-82218_TPS22990NTPS22990NWSON10_0P5_2P1X3P1
U911PAC1934_UQFN16_A_QFN16_0P65_4X4_A_IC__312-82072_PAC1934T-I/JQPAC1934T-I/JQQFN16_0P65_4X4_A
U912PAC1934_UQFN16_A_QFN16_0P65_4X4_A_IC__312-82072_PAC1934T-I/JQPAC1934T-I/JQQFN16_0P65_4X4_A
U913PCT2075_SON8_EP_HWSON8_0P5_3P1X2P1_IC_0.8 MM_312-81267_PCT2075PCT2075HWSON8_0P5_3P1X2P1
U91493AA56BT_SOT23-6_SOT23-6_IC_1.45MM_334-77717_93LC56BT93LC56BTSOT23-6
Y401XTAL_13_XTLOSC4_3P2X2P5MM_SM_IC_0.60MM_230-77392_24MHZ24MHZXTLOSC4_3P2X2P5MM_SM
Y701OSC4_ST_XTL4_2P6X2P1MM_SM_IC_0.90MM_230-78704_32.768KHZ32.768KHZXTL4_2P6X2P1MM_SM
好好地学习。。。:) :lol:lol:lol:D:D:D感谢分享。。。。💐和掌声响起来。。。。 感谢版主的分享,赞一个;P 感谢版主的分享 :):):):):):) 感谢分享 学习学习
