老吴 发表于 2025-9-18 09:36
千兆路由器PCB文件 GPY211 +MT7531+MT7976+MT7981+SKY85755-11 +SKY85337-11
   NamePart TypePCB Decal
CON13COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEX
CON14COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEX
CP376C0805/EN0C0805/EN0
D13LED0603LED0603
D500D/SMD/P3.325/SOD-123/1N4148D/SMD/P3.325/SOD-123/1N4148
D501LED0603LED0603
D502LED0603LED0603
D503LED0603LED0603
D504LED/2P/SMD/0603/LT8A22-54-UR86-T5LED/2P/SMD/0603/LT8A22-54-UR86-T5
D505VARISTOR/SMD/TVM5B150L103RYVARISTOR/SMD/TVM5B150L103RY
D2514LED0603LED0603
D2515LED0603LED0603
D2516LED0603LED0603
D2517LED0603LED0603
D2518LED0603LED0603
ESD500ESD/SMD/AZ5315-02FESD/SMD/AZ5315-02F
ESD501DFN2510A/10P/SMD/P0.5/IP4294CZ10-TIPDFN2510A/10P/SMD/P0.5/IP4294CZ10-TIP
F1F1812F1812
FB1L0402L0402
GC8C/2P/SMD/GR442QR73D102KW01C/2P/SMD/GR442QR73D102KW01
GL5L0603L0603
GL6L/IND/SMD/SF20121-1R0ML/IND/SMD/SF20121-1R0M
GL7L0603L0603
GP1RJ45/8P/DIP/R/N3612-002RJ45/8P/DIP/R/N3612-002
GR36R0402R0402
GTP1TP0.3MMTP0.3MM
GTP2TP0.3MMTP0.3MM
GTR1TRANSFORMER/24P/SMD/HN2429CGTRANSFORMER/24P/SMD/HN2429CG
GU1VQFN56/SMD/P0.4/GPY211VQFN56/SMD/P0.4/GPY211
GU2SOIC-208-MILSOIC-208-MIL
GY1CRYS/SMD/3.2X2.5/FD2000030CRYS/SMD/3.2X2.5/FD2000030
H4HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H5HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H6HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H7HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H11HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H12HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H13HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H21TOOLING_HOLE/4MMTOOLING_HOLE/4MM
H22TOOLING_HOLE/4MMTOOLING_HOLE/4MM
H23TOOLING_HOLE/4MMTOOLING_HOLE/4MM
H24SCREW_HOLE/PTH/R6.5D3.3SCREW_HOLE/PTH/R6.5D3.3
H120HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H121HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H122HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H125HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H126HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H127HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H128SCREW_HOLE/PTH/R6.5D3.3SCREW_HOLE/PTH/R6.5D3.3
H129SCREW_HOLE/PTH/R6.5D3.3SCREW_HOLE/PTH/R6.5D3.3
H130SCREW_HOLE/PTH/R6.5D3.3SCREW_HOLE/PTH/R6.5D3.3
H131HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H132HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H133HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
H134HOLE/PTH/R1.3X0.7D1X0.4HOLE/PTH/R1.3X0.7D1X0.4
J7JP13X2/DIP/P2.54JP13X2/DIP/P2.54
J500DIP4/P2.54DIP4/P2.54
J503USB3.0/9P/SMD/UEA5119C-4EG1-7HUSB3.0/9P/SMD/UEA5119C-4EG1-7H
J506DIP3/P2.54DIP3/P2.54
J507DIP3/P2.54DIP3/P2.54
J508SW-2P2T-6.3SW-2P2T-6.3
J509CON\DC-JACK\4.7CON\DC-JACK\4.7
J510DIP10X2/W/H/IDE/P2.54DIP10X2/W/H/IDE/P2.54
J511DIP10X2/W/H/IDE/P2.54DIP10X2/W/H/IDE/P2.54
J512CONSG/54/MINICARD/AS0B22-S68-7F/HALF/FULCONSG/54/MINICARD/AS0B22-S68-7F/HALF/FUL
J513DIP3/P2.54DIP3/P2.54
L2L/IND/DIP/D6H14L/IND/DIP/D6H14
L3L/IND/DIP/D6H14L/IND/DIP/D6H14
L5L/IND/SMD/GSTD6030PW-6R8ML/IND/SMD/GSTD6030PW-6R8M
L55L/IND/SMD/2520L/IND/SMD/2520
L56L0201L0201
L57L0201L0201
L60L0201L0201
L61L0201L0201
L2592L/IND/SMD/LVS5045L/IND/SMD/LVS5045
L2600L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2M
L2603L/IND/SMD/LVS5045L/IND/SMD/LVS5045
L2604L/IND/SMD/LVS5045L/IND/SMD/LVS5045
L2605L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2M
L2606L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2M
L2607L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2M
LG2650L0201L0201
P1202RJ45/32P/DIP/R/N3642-001RJ45/32P/DIP/R/N3642-001
RD5093NC/SB/0805NC/SB/0805
RD8362R0805R0805
S1SW-TACT\4.5MMSW-TACT\4.5MM
S2SW-TACT\4.5MMSW-TACT\4.5MM
T301TRANSFORMER/48P/DIP/G2PM109NTRANSFORMER/48P/DIP/G2PM109N
T600TRANSFORMER/24P/DIP/G1PM109NTRANSFORMER/24P/DIP/G1PM109N
T601TRANSFORMER/48P/DIP/G2PM109NTRANSFORMER/48P/DIP/G2PM109N
U1MT7981/TFBGA338/P0.65/B0.3/13X11.7MT7981/TFBGA338/P0.65/B0.3/13X11.7
U2FILTER/4P/SMD/TCF0504H90002AFILTER/4P/SMD/TCF0504H90002A
U3FILTER/4P/SMD/TCF0504H90002AFILTER/4P/SMD/TCF0504H90002A
U4MT7976/DRQFN144/SMD/P0.5/12.5X10MT7976/DRQFN144/SMD/P0.5/12.5X10
U5BARCODE-33X7BARCODE-33X7
U6SOT23-6SOT23-6
U7FBGA96/SMD/P0.8/10X14/DDR3L/16BFBGA96/SMD/P0.8/10X14/DDR3L/16B
U8SOT23-5SOT23-5
U9CRYS/SMD/D3.2X2.5/E3SB40/HOSONICCRYS/SMD/D3.2X2.5/E3SB40/HOSONIC
U10SOT23-5SOT23-5
U11SOT23-6SOT23-6
U12SOT23-5SOT23-5
U23MT7531/LQFP128/SMD/P0.4/14X14/SMT7531/LQFP128/SMD/P0.4/14X14/S
U27SOIC-208-MILSOIC-208-MIL
U28QFN16/SMD/P0.5/SKY85337-11QFN16/SMD/P0.5/SKY85337-11
U30QFN16/SMD/P0.5/SKY85337-11QFN16/SMD/P0.5/SKY85337-11
U36QFN16/SMD/P0.5/SKY85755-11QFN16/SMD/P0.5/SKY85755-11
U38QFN16/SMD/P0.5/SKY85755-11QFN16/SMD/P0.5/SKY85755-11
U57CRYS/4P/SMD/2.0X1.6/EOS-K40430-1CRYS/4P/SMD/2.0X1.6/EOS-K40430-1
U2633SOT23-6SOT23-6
U2635SOT23-6SOT23-6
U2638SOT23-6SOT23-6
U2641SOT23-6SOT23-6
U2642SOT23-6SOT23-6
U2643SOT23-6SOT23-6
U2644FBGA153/P0.5/B0.27/11.5X13X1.0/TOSHIBAFBGA153/P0.5/B0.27/11.5X13X1.0/TOSHIBA
U2645SON8/SMD/P1.27/4080-0218SON8/SMD/P1.27/4080-0218
U2646QFN16/SMD/P0.5/SKY85755-11QFN16/SMD/P0.5/SKY85755-11
UP18DFN6/SMD/P0.4/RT9081ADFN6/SMD/P0.4/RT9081A
WC1C0201/FCSC0201/FCS
WC2C0201/FCSC0201/FCS
WC5C0201/FCSC0201/FCS
WC6C0201/FCSC0201/FCS
WC7C0201/FCSC0201/FCS
Y1CRYS/DIP/D5X10.6/GB2000025/ECERACRYS/DIP/D5X10.6/GB2000025/ECERA
ydm82 发表于 2025-9-18 18:43
收藏
adminuser 发表于 2025-11-13 22:22
这个是什么软件的pcb文件,本人是小白,用AD20打不开
这个就是pads啊,标题有
77777 发表于 2025-12-5 10:23
有没有ddr是竖着放着的呢老吴
kanxue_nmg 发表于 2025-12-5 12:53
666666666666
dywfmbb 发表于 2026-2-2 15:46
这是好东西,正需要,要怎么才能升级到2级啊
lipen 发表于 2026-2-2 18:09
dywfmbb 发表于 2026-2-2 20:39
我有多少积分啊
新围梁 发表于 2026-2-3 08:58
感谢分享、
页: [1] 2 3
查看完整版本: 千兆路由器PCB文件 GPY211 +MT7531+MT7976+MT7981+SKY85755-11 +SKY85337-11
