国芯车载DSP DEMO板 CCD5001+ADAU1962A+ADAU1979+AD2428WCCSZ
转换的PADS格式。仅供参考。有错误。不要拿去商用
NamePart TypePCB Decal
C414CAP_C0805_2700PF/16VC0805
C415CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
C416CAP_C0805_2700PF/16VC0805
C417CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
C418CAP_C0805_2700PF/16VC0805
C419CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
C420CAP_C0805_2700PF/16VC0805
C421CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
C422CAP0805_C0603_1UF/25VC0603
C423CAP0805_C0603_0.1UF/25VC0603
D1DIODE_0_SOD-323-MA729_CDBU0130LSOD-323-MA729
D2DIODE_0_SOD-323-MA729_ZLLS400SOD-323-MA729
D3DIODE_0_SOD-123_TPSMF4L28ASOD-123
D4DIODE_0_SOD-123_CDBU0130LSOD-123
D5PESDNC3D12VB_DO-214AA_SMBJ12CADO-214AA
D6PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D7PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D8PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D9PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D10PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D11PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D12PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
D13PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
FB2FB_FB0603_120_OHM/2AFB0603
FB3FB_FB0603_120_OHM/2AFB0603
FB5FB_FB0603_120_OHM/2AFB0603
FB9FB_FB0603_120_OHM/2AFB0603
FB10FB_FB0603_120_OHM/2AFB0603
HOLE1HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
HOLE2HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
HOLE3HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
HOLE4HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
J10SIP3_SIP3_SIP3SIP3
J11JUMPER_SIP2_JUMPERSIP2
J12JUMPER_SIP2_JUMPERSIP2
J13JUMPER_SIP2_JUMPERSIP2
J14JUMPER_SIP2_JUMPERSIP2
J15JUMPER_SIP2_JUMPERSIP2
J16SIP3_SIP3_SIP3SIP3
J17SIP2_0_DURACLIK_502352-0200_502DURACLIK_502352-0200
J18SIP2_0_DURACLIK_502352-0200_502DURACLIK_502352-0200
J19SIP2_SIP2_SIP2SIP2
J265SIP4_SIP4_SIP4SIP4
J269CON2X10_CON2X10_254MM_M_CON2X10CON2X10_254MM_M
J270JUMPER_SIP2_JUMPERSIP2
J273DB9_DB9-FM_DB9_FEMALEDB9-FM
J274SIP3_SIP3_SIP3SIP3
J285JUMPER_SIP2_JUMPERSIP2
J286JUMPER_SIP2_JUMPERSIP2
J289TP_SIP1_TPSIP1
J295SIP2_SIP2_SIP2SIP2
J296PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J297PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J298PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J299JUMPER_SIP2_JUMPERSIP2
J300JUMPER_SIP2_JUMPERSIP2
J301PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J302JUMPER_SIP2_JUMPERSIP2
J303JUMPER_SIP2_JUMPERSIP2
J304PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J305PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
J306SIP5_SIP5_SIP5SIP5
J307TP_SIP1_TPSIP1
J308TP_SIP1_TPSIP1
J309TP_SIP1_TPSIP1
J311TP_SIP1_TPSIP1
J313SIP7_SIP7_SIP7SIP7
J314JUMPER_SIP2_JUMPERSIP2
J315SIP6_SIP6_SIP6SIP6
J316JUMPER_SIP2_JUMPERSIP2
J317JUMPER_SIP2_JUMPERSIP2
J318SIP9_3_5MM_EDGE_9P_3_5MM_EDGE_93_5MM_EDGE_9P
L2L_1_FB0603_600FB0603
L3L_1_FB0603_600FB0603
L4L_1_FB0603_600FB0603
L5L_1_FB0603_600FB0603
L6L_1_FB0603_600FB0603
L7L_1_INDC2012X145N_3.3UHINDC2012X145N
L8L_1_INDC1005X55N_180NHINDC1005X55N
L9L_1_INDC2012X105N_1000INDC2012X105N
L10L_1_INDC2012X105N_1000INDC2012X105N
L11L_1_INDC2012X145N_3.3UHINDC2012X145N
L12L_1_INDC1005X55N_180NHINDC1005X55N
L13L_1_INDC2012X145N_3.3UHINDC2012X145N
L14L_1_INDC1005X55N_180NHINDC1005X55N
L15L_1_INDC2012X105N_1000INDC2012X105N
L16L_1_INDC2012X105N_1000INDC2012X105N
L17L_1_INDC2012X145N_3.3UHINDC2012X145N
L18L_1_INDC1005X55N_180NHINDC1005X55N
L19L_LSM2_5R7X5R4_H3_6.8UH_2.0ALSM2_5R7X5R4_H3
L20L_LSM2_5R7X5R4_H3_6.8UH_2.0ALSM2_5R7X5R4_H3
LED1LED_0_LED0805_REDLED0805
LED2LED_0_LED0805_REDLED0805
LED3LED_LED0805_REDLED0805
LED4LED_LED0805_REDLED0805
LED9LED_LED0805_REDLED0805
Q1IRL6402_SOT-23-3_IRML6402SOT-23-3
Q2PNP_1_SOT-223_FZT953SOT-223
SW1SW-P-5_SPDT-SWITCH_SW-P-5SPDT-SWITCH
SW2SWITCH_SW_6X6_SWITCHSW_6X6
U1W25Q128FVSSIG_SOIC8_1R27_5R28X7SOIC8_1R27_5R28X7R9
U45962-9211701_SOP8_AD8606ARZSOP8
U55962-9211701_SOP8_AD8606ARZSOP8
U65962-9211701_SOP8_AD8606ARZSOP8
U75962-9211701_SOP8_AD8606ARZSOP8
U12BL8033_SOT-23-6_BL8033SOT-23-6
U16AD2428WCCSZ_0_QFN50P500X500X80-QFN50P500X500X80-33W4N
U17SCM7038F-701_0_IND_ACT1210_2600IND_ACT1210
U18SCM7038F-701_0_IND_ACT1210_2600IND_ACT1210
U19ICS_ADAU1962A_2_QFP65P1600X1600QFP65P1600X1600X160-80N
U25ADAU1979_QFN50P600X600X80-41W2NQFN50P600X600X80-41W2N
U26CCD5001_LQFP120_1_LQFP120_16MMXLQFP120_16MMX16MM_SCK
U27BL8033_SOT-23-6_BL8033SOT-23-6
U29MAX3232CSE_SOIC16_MAX3232IDRSOIC16
U30RCA_2_RCJ-2221_RCARCJ-2221
U31SN65LVDS2DBVR_SOT23-5_SN65LVDS2SOT23-5
U33SN74LVC1G08_0_SOT23-5_SN74LVC1GSOT23-5
U35ASM1117-ADJ_SOT-223_LD1117-ADJSOT-223
U39ASM1117-ADJ_SOT-223_1117-5.0SOT-223
U40ASM1117-ADJ_SOT-223_1117-1.8SOT-223
X4CRYSTAL_HXO-3225_24.576M_OSCHXO-3225
Y3XV_CRY3225_24.576MHZ/25MHZCRY3225
:lol:lol:lol:lol 感谢分享,楼主有没有规格书工具之类的资料呢? :lol:lol:lol ddddddddddddddddd
