老吴 发表于 2024-3-12 13:41
18层英特尔 AgileX FPGA DEVKIT - ENPIRION 官方DEMO板PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGEMolex_QSFPDD_CageMOLEX_QSFPDD_CAGEB2MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGEMolex_QSFPDD_CageMOLEX_QSFPDD_CAGED2LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D3LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D4D11ESD5V3U2UTSLP-3-7D5D11ESD5V3U2UTSLP-3-7D6D11ESD5V3U2UTSLP-3-7D7LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D8LED_0_LED_0603_BLUELEDBLUELEDLED_0603D9LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D10LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D11LED_WURTH_LED_0603_RED_LEDRED_LEDLED_0603D12LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D13LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D14LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D15TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A5p0SMDJ12ATVS_5P0SMDJ12AD16TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A5p0SMDJ12ATVS_5P0SMDJ12AD21LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D22APHB1608CGKSYKC_LED0603_4PIN_APHB1608_APHB1608CGKSYKCAPHB1608CGKSYKCLED0603_4PIN_APHB1608D23LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D24APHB1608CGKSYKC_LED0603_4PIN_APHB1608_APHB1608CGKSYKCAPHB1608CGKSYKCLED0603_4PIN_APHB1608FB1FERRITEBEAD_1_0402_220OHM220ohm402FB2FERRITEBEAD_1_0402_220OHM220ohm402FB5FERRITEBEAD_1_0402_220OHM220ohm402FB9BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB10BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB11BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB12BEAD_FERRITE_SM_0402_DNIDNI402FB13BEAD_FERRITE_SM_0402_220OHM220ohm402FB14BEAD_FERRITE_SM_0402_220OHM220ohm402FB15BEAD_FERRITE_SM_0402_220OHM220ohm402FB16BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB17BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB18BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB19BEAD_FERRITE_SM_0402_220OHM220ohm402FB20BEAD_FERRITE_SM_0402_220OHM220ohm402FB21BEAD_FERRITE_SM_0402_220OHM220ohm402FB22BEAD_FERRITE_SM_0402_220OHM220ohm402FB23BEAD_FERRITE_SM_0402_220OHM220ohm402FB24BEAD_FERRITE_SM_0402_220OHM220ohm402FB25BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB26BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB27BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB28BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB29INDUCTOR_0805_220OHM,2.0A220ohm,2.0A805FB30BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB31BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB32R2_0402_742792780742792780402FB33BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB35BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB36BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB37BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB38BEAD_FERRITE_SM_0805_80OHM@ 100MHZ80ohm@ 100Mhz805FB39R2_0402_742792780742792780402FB40BEAD_FERRITE_SM_0402_220OHM220ohm402FB41BEAD_FERRITE_SM_0402_220OHM220ohm402FB42BEAD_FERRITE_SM_0402_220OHM220ohm402FB43FERRITEBEAD_1_0402_220OHM220ohm402FB44FERRITEBEAD_1_0402_220OHM220ohm402FB45BEAD_FERRITE_SM_0402_220OHM220ohm402HW1LIGHTPIPE_P-U90-1101-T00A-BP_2_LIGHTPIPE_P-U90-1101-T00A-BP_LIGHTPIPE_P-U90-1101-T00A-BPLIGHTPIPE_P-U90-1101-T00A-BPLIGHTPIPE_P-U90-1101-T00A-BPJ1DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ2DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ3DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ4DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ52027180100_2027180100_202718010020271801002027180100J62027180100_2027180100_202718010020271801002027180100J7PCIE_BRACKET_X16_1_PCIX-16PORT_PCIE_SLOTPCIE_SlotPCIX-16PORTJ8ENET_L829-1J1T-43_2_BEL_L829-1J1T-43_ENET_L829-1J1T-43ENET_L829-1J1T-43BEL_L829-1J1T-43J9CON2_HDR2X1_100MIL_CON2CON2HDR2X1_100MILJ10MICRO_USB_CONN_MOLEX-MICRO-USB-47589-001_MICRO_USB_CONNMICRO_USB_CONNMOLEX-MICRO-USB-47589-001J11SD_SKT_1_WURTH_MICRO-SD_CARD_MICROSD_SKTMicroSD_sktWURTH_MICRO-SD_CARDJ122-767004-2_SMT38_MICTOR38PMictor38PSMT38J13MICRO_USB_CONN_MOLEX-MICRO-USB-47589-001_MICRO_USB_CONNMICRO_USB_CONNMOLEX-MICRO-USB-47589-001J14J2370247-1051MOLEX_70247-1051J15FAN_CONN_0_MOLEX_0470533000_FAN_CONNFAN_ConnMOLEX_0470533000J162X4_PCIE_ATX_1_MLX_SD-5569_8POS_RA_PCIE2X4 ATXPCIe2x4 ATXMLX_SD-5569_8POS_RAJ171X3_HDR_TH_1X3_HDR_TH_TSW-103-08-G-STSW-103-08-G-S1X3_HDR_THJ22CONNECTOR_RA_10POS_DUAL ROW_SAMTEC_TSM_105_01_DV_10PIN 2ROW VT10PIN2ROW VTSAMTEC_TSM_105_01_DVL1BEAD_FERRITE_SM_0402_742792780742792780402L2BEAD_FERRITE_SM_0402_742792780742792780402L3INDFERRITE 0603 3A/30 OHMS_IND_0603_3A, 30 OHM FB3A,30 Ohm FBIND_0603L4INDFERRITE 0603 3A/30 OHMS_IND_0603_3A, 30 OHM FB3A,30 Ohm FBIND_0603L5INDFERRITE 0603 3A/30 OHMS_IND_0603_3A, 30 OHM FB3A,30 Ohm FBIND_0603L6INDFERRITE 0603 3A/30 OHMS_IND_0603_3A, 30 OHM FB3A,30 Ohm FBIND_0603L7INDFERRITE 0603 3A/30 OHMS_IND_0603_3A, 30 OHM FB3A,30 Ohm FBIND_0603L8BEAD_FERRITE_SM_0402_742792780742792780402L9INDFERRITE 0402 300MA/220_0402_BLM15AG221SN1BLM15AG221SN1402L10INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL11INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL12INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL13INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL14INDUCTORIRON_SL1616A-R06LU_65NH65nHSL1616A-R06LUL15INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L16INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L17INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L18INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L19INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L20INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L43INDUCTOR_IND_BRC2518_22UH__22uHIND_BRC2518MTH1MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH2MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH3MNTHOLE_1_MT_HOLE_MT_HOLE_GNDMT_HOLE_GNDMT_HOLEMTH4MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH5MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH6MNTHOLE_1_MT_HOLE_MT_HOLE_GNDMT_HOLE_GNDMT_HOLEQ1NMOS_3PIN_SOT23_FDV305NFDV305NSOT23Q2NMOS_3PIN_SOT23_FDV305NFDV305NSOT23Q3NMOS_3PIN_SOT23_FDV305NFDV305NSOT23Q4NMOS_3PIN_SOT23_FDV305NFDV305NSOT23Q5PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q6PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q7PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q8PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q9PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q10PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q11PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q12PSMN1R0-30YLD_0_NFET_PSMN1R0-30YLD_PSMN1R0-30YLDPSMN1R0-30YLDNFET_PSMN1R0-30YLDQ13PWRMOSFET_EN_GSD_1_SOT23_SI2302CDS-T1-GE3SI2302CDS-T1-GE3SOT23Q24PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q25PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q26PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q27PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q28PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q29PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23S1S7PBSwitchWURTH_6X3P5_TACT_SWITCHST31SHORT_SHORT_SHORTSHORTSHORTSW1SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW2SPST4_DIPSWITCH_SMT_QUAD_DIPSWITCH4DIPSWITCH4DIPSWITCH_SMT_QUADSW3SPST4_DIPSWITCH_SMT_QUAD_DIPSWITCH4DIPSWITCH4DIPSWITCH_SMT_QUADSW4SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW5SW_SLIDE_DPDT_EG2207_SW_SLIDE_DPDTSW_SLIDE_DPDTEG2207SW6SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW7SPST4_0_DIPSWITCH_SMT_SINGLE_CVS-01TBCVS-01TBDIPSWITCH_SMT_SINGLETP1TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP2TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP3TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP4TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP5TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP10TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP12TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP13TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP16TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP17TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP18TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP19PAD_STYLE_C_PADSTYLE1_IO_TESTPAD_PCBPADS-1TESTPADPADSTYLE1U1MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U2FM6_2486A_V1.5_FBGA2486A_HEX__AGFB014R24_2486AAGFB014R24_2486AFBGA2486A_HEXU3MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U4MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U5MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U6MT25QU01GBBB_T-PBGA24_MT25QU02GCBB3E12-1SITMT25QU02GCBB3E12-1SITT-PBGA24U7KSZ9031RN_4_QFN48_KSZ9031RNKSZ9031RNQFN48U8EY1501DI-ADJ_DFN-10_EY1501DI-ADJEY1501DI-ADJDFN-10U9SN74AUP1G126DCK_SC70_TI_SN74AUP1G126DCKSN74AUP1G126DCKSC70_TIU10SN74AUP1G17DCK_SC70_TI_SN74AUP1T17DCKRSN74AUP1T17DCKRSC70_TIU11FT232R_2_QFN32-FTDI_FT232RFT232RQFN32-FTDIU12SN74AUP1G17DCK_SC70_TI_SN74AUP1T17DCKRSN74AUP1T17DCKRSC70_TIU13TPD4S012DRYR_SON6_TPD4S012DRYRTPD4S012DRYRSON6U14LSF0108PWR_TSSOP20_LSF0108PWRLSF0108PWRTSSOP20U15TPS22902BYFPR_TPS22902BYFPR_TPS22902BYFPRTPS22902BYFPRTPS22902BYFPRU16MTFC8GAKAJCN-4MIT_VFBGA-153_(S1+S2+S3)_MTFC8GAKAJCN-4M ITMTFC8GAKAJCN-4MITVFBGA-153U17SI5341A-A-GM_1_QFN64_9X9_SI5341_SI5341A-D10654-GMSi5341A-D10654-GMQFN64_9X9_SI5341U18SI52202-A01AGM_SI52202_SI52202-A01AGMSi52202-A01AGMSI52202U19SI510-DUALCMOS_SI510_510MCA50M0000AAGR510MCA50M0000AAGRSI510U20FXMA2102UMX_UMLP_FXMA2102UMXFXMA2102UMXUMLPU21FXMA2102UMX_UMLP_FXMA2102UMXFXMA2102UMXUMLPU22FXMA2102UMX_UMLP_FXMA2102UMXFXMA2102UMXUMLPU23MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U24MAX811_SOT-143_MAX811MAX811SOT-143U25MAX811_SOT-143_MAX811MAX811SOT-143U2610M04SCU169_BGA169-0R80-11X11_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10)_10M04SCU16910M04SCU169BGA169-0R80-11X11U27TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRTU28CY7C68013A_56QFN_QFN56_CY7C68013A_QFNCY7C68013A_QFNQFN56U29TS3A5018RSVR_0_UQFN-16_TS3A5018RSVRTS3A5018RSVRUQFN-16U3010M16SAU169_1_BGA169-0R80-11X11_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11)_10M16SA U169_110M16SAU169_1BGA169-0R80-11X11U32MAX6581_0_24TQFN-EP_MAX6581MAX658124TQFN-EPU33FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U34FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U35LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPADU36LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U37LTC4359_MSOP-8_LTC4359LTC4359MSOP-8U38FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U39FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U40LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPADU41LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U42TPS3700_DDC_TPS3700TPS3700DDCU43LTC4625EY_LGA25_LTM4625LTM4625LGA25U44EY1501DI-ADJ_DFN-11_EY1501DI-ADJEY1501di-adjDFN-11U45EY1501DI-ADJ_DFN-11_EY1501DI-ADJEY1501di-adjDFN-11U46EM2130_MODULE_1_EM2130_EM2130HEM2130HEM2130U47ED8401_1_ED8401_QFN40_ED8401ED8401ED8401_QFN40U50EY1501DI-ADJ_DFN-11_EY1501DI-ADJEY1501di-adjDFN-11U51EN5337Q_2_QFN38_EN6337QIEN6337QIQFN38U52REF1112_SOT23-3_REF1112AIDBZRREF1112AIDBZRSOT23-3U55EM2130_MODULE_1_EM2120_EM2140P01QIEM2140P01QIEM2120U56EN6362QI_2_QFN-56_EN6362QI_EN6362QIEN6362QIQFN-56_EN6362QIU57EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76U58EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76U59TPS51200_VSON-11_TPS51200TPS51200VSON-11U60TPS51200_VSON-11_TPS51200TPS51200VSON-11U61EN5337Q_2_QFN38_EN6337QIEN6337QIQFN38U62FDMC8878_VER2_FDMC8878_VER2_FDMC2514FDMC2514FDMC8878_VER2U63LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U64EY1501DI-ADJ_DFN-11_EY1501DI-ADJEY1501di-adjDFN-11U65EN6362QI_2_QFN-56_EN6362QI_EN6362QIEN6362QIQFN-56_EN6362QIU66EN5337Q_2_QFN38_EN6347QIEN6347QIQFN38U67MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U68MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U70EN5337Q_2_QFN38_EN6347QIEN6347QIQFN38U71EM2130_MODULE_1_EM2120_EM2120H01QIEM2120H01QIEM2120U729DML0451AKILF_24-VFQFPN_9DML0441AKILF9DML0441AKILF24-VFQFPNU7324AA64-I_MSOP8_24AA64-I24AA64-IMSOP8U75LMV321_SOT23-5_LMV321LMV321SOT23-5U76FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U77FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U78FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U79FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U124ER3105QI_0_12LD_DFN_ER3105DIER3105DI12LD_DFNU125LTM4657-BGA_0_LTC-BGA-49-1518_IC_LTM4657EY_LTM4657EY#PBFLTM4657EYLTC-BGA-49-1518V1VIA_1_STAR_VIA_VIA_1VIA_1STAR_VIAY1OSC_ALT_OSC7050_25MHZ25MHzOSC7050Y2CRYSTAL_SM_13_XTAL_3MMX2MM_48MHZ48MHzXTAL_3MMX2MMY3CRYSTAL_SM_13_XTAL_FA-128_25.00MHZ25.00MHzXTAL_FA-128Y4CRYSTAL_SM_13_XTAL_FA-128_24.00MHZ24.00MHzXTAL_FA-128
叱咤调频 发表于 2024-3-12 13:42
老吴 发表于 2024-3-12 13:43
PCB文件。回复可见下载
**** Hidden Message *****
孟乐意 发表于 2024-3-12 13:44
bingshuihuo 发表于 2024-3-12 13:47
aokema124 发表于 2024-3-12 14:23
cat 发表于 2024-3-12 14:37
junkyoung 发表于 2024-3-12 14:51
love欣 发表于 2024-3-12 14:55
mofise0078 发表于 2024-3-12 14:59
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 18层英特尔 AgileX FPGA DEVKIT - ENPIRION 官方DEMO板PCB文件
