海思HI3798MV100 挂4个DDR3 做的机顶盒PCB文件和原理图立项说明
CommentPatternQuantityComponents2.2uHLVH252A121L1052.2uHSCD0503T2L102, L10624MHz 10ppm 15pFCPX-321X2300R@100ML8058L1004.7uH/0503SCD0503T1L1084.7uHSCD0503T1L11040.2k402R31R12544081-00275CKX-3.5-01-5P1CN70151SRN8-08047RN1, 510k 1%402R31R13651k 1%402R31R120600R@100ML6031L700600R@100ML603_B1L8017.68K402R31R12675402R31R6575k 1%402R32R828, R82975R 1%402R37R804,AV-1AV1_41J800AV3-8414-DAV3V_11CN803BAR CODE AREACODE AREA1CodeAera500BC847BSOT-1231Q102CommentLF1Designator10Component_1PCBCOMPONENT_1 - DUPLICATE1U601CON2ANT_11J600DC JACKDC_JACK_B1CN100DownSW-4_KAITUO1K703EA8212/EA8213SOT23-6L1U102ESD NUESD_B1E812ESDESD_B17E700ESD-DIO NUSOD523_B1E811ESD-DIOSOD523_B17E600EWN-1601EWN-1601L1U600FCLS2012900JTFCLS20126CK600FD650SOP16/1501U700FETN-GSDSOT-1231Q8G3401SOT-1233Q100, Q101, Q705GP18B38BDFRP350-V1J700GRELED-H-21D700H1608SGH1102T_B1U800HDMI CONHDMI-RS251UO-B1CN801HI3798MV100_ATFBGA395-32-23231U1K4B4G0846A-HCK0BGA78-32-1309I4U3, U6, U20, U21LBSL04021LB12LED_4_ANODELIM-3462BG-61U701LeftSW-4_KAITUO1K702MARKMAK3M1, M2, M3MM3904 NCSOT-23P1Q701MMBT3094SOT-1231Q706MMBT3904 NUSOT-23P1Q800MP1653/MP1658SOT-6-0D50-SOT563-MV1U101MSW-6ASPSW6-T1S2NBGA169-BGA153-0_5MM1U22N5819SOD3231D801NCSOP48-20-720B1U19NU 100R402R31R717NU 1N5819SOD3231D800NU 22pF402C31C230NU 22uF/6.3V X5R805C21C159NU CON4SIP4-F(2.54)1CN802NU/10pF402C31C59NU/220pF402C31C815NU/27pF402C32C703, C704NU402C32C601, C602NU402R31R846PowerSW-4_KAITUO1K700RESETSW-V-B1K100RightSW-4_KAITUO1K705RJ45_LEDETHERNET_L_D1CN800RT9045SOP8H-50-2001U28SGM89112TSSOP16-044-0.651U801SR-BSR-A-1-B1SR1SR-BSR-B-11SR2SU0524PRCLamp0524P3E800, E801, E802SY8032_7QFN24/04041U100TF CARDSD-T-C1CN602TP-1TP-H2T100, T101UpSW-4_KAITUO1K706USB-08052USB-A-H-C2CN600, CN601 PCB 原理图 立项书,规格书。程序等。 回复可见下载
**** Hidden Message ***** 原理图 立项书,规格书。程序 什么时候能有这水平啊
回 armclub 的帖子
armclub:PCB 原理图 立项书,规格书。程序等。 回复可见下载
[内容隐藏]
images/back.gif
感谢楼主分享!!!
