GM8138S LFBGA196 +CAT6612 IPCAM demo 参考板PCB原理图
NamePart TypePCB DecalValueBAT1MS621FEFL11EMS621FEFL11ENC(MS621FEFL11E)CM61UF_10V_10%_SMD0402_2C04021uFCN1SD_SOCKET_TOP_A_PANASONICSD_STANDARD_ASD_Socket_Top_A_PanasonicCN2USB_A_RECEPTACLE_SMD_4PCN_USB_AUSB_A_SMDCN3PHONE_JACK_3.5MM_90D_DIP_3PMINIATURE_JACKPhone_JackCON1HDMI_M_0CN_HDMI_19_050_NC(CON/HDMI)CT147UF_6.3V_20%_B_CASECAP_B_352847uF,6.3VCW160.01UF_50V_20%_SMD0402C04020.01uFD1RB551V-30_SOD323SOD323RB551V-30D2RCLAMP0520B_SOT-523RCLAMP0502BNC(RClamp0520B)D3RCLAMP0520B_SOT-523RCLAMP0502BNC(RClamp0520B)D4RCLAMP0524P_SLP2510P8RCLAMP0524PNC(RClamp0524P)D5RCLAMP0524P_SLP2510P8RCLAMP0524PNC(RClamp0524P)D6RB551V-30_SOD323SOD323RB551V-30J11X8P_FEMALE_DIP_2.0SIP_8P_200NC(1X8P_2.0F)J21X8P_FEMALE_DIP_2.0SIP_8P_200NC(1X8P_2.0F)J3RJ45_0RJ45_PA6TRJ45J42X22P_FEMALE_DIP_1.27CN22X2_127NC(2X22P_1.27F)J52X20P_FEMALE_DIP_2.0CN20X2_2002X20P_2.0FJ6RCA_JACK_90D_YELLOW_DIP_2PRCA_JACKRCA_YellowJ71X2P_MALE_DIP_1.27JP2_125_I1X2P_1.25MJ82X20P_FEMALE_DIP_2.0CN20X2_2002X20P_2.0FJ91X4P_MALE_DIP_2.54SIP_4P1X4P_2.54MJ101X5P_MALE_DIP_2.54SIP_5P1X5P_2.54MJ112X10P_MALE_DIP_1.27CN10X2_1272X10P_1.27MJ121X4P_MALE_DIP_2.54SIP_4P1X4P_2.54MJ13DC_JACKPJ20_3PDC_JACKJ141X2P_MALE_DIP_2.0_2SIP_2P_200NC(1X2P_2.0M)J152X15P_FEMALE_DIP_2.0CN15X2_2002X15P_2.0FJP181X2P_MALE_DIP_2.0SIP_2P_2001X2P_2.0ML14.7UH_4.2A_20%_SMD_SB0805L_SB08054.7uHL22.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uHL32.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uHL42.2UH_1.85A_20%_SMD_SR0302L_SR03022.2uHLED3RED__SMD0603LED0603REDLED4GREEN__SMD0603LED0603GREENMIC1MIC-MICROPHONE0MICMIC-EM5BPSMIC2MIC-MICROPHONE0MICMIC-EM5BPSPB2PUSH_BOTTOM_BLUE_SMD_2PSW_SMD_2PKEY1Q1AO3415_SOT23SOT23AO3415SW1SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMDSW2SWITCH_2_PORT_SMD_4PSW_HDS402SW_SMDSW3SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMDSW4SW_SPDT3_DIPSW_SPDT3_1SW-SPDT3SW5SWITCH_4_PORT_SMD_8PSW_HDS404SW_SMDU1GM8138S_LFBGA196_SKT_4BGA196_080_SKT_39X39GM8138S_LFBGA196_SKTU6W25P80/16SOIC8_208W25Q128FVU7SPI_FLASH_SOP16SOP16_300NC(SPI_FLASH,SOP16)U8K9F1G08U0B(128MBX8)_TSOP48_0TSOP48_12X20NC(NAND FLASH K9F1G08U0B(128Mbx8))U9G5250C1T1USOT25NC(G5250C1T1U)U10IP101GRTQFN32_040+EPADIP101GRU11TS8121CTS8121CTS8121CU12CAT6612_0QFP80_050NC(IT6612)U13G9131-18T73UFSOT23G9131-18T73Uf U14AKU2002CMIC_AKU2002CNC(AKU2002C)U15AKU2002CMIC_AKU2002CNC(AKU2002C)U16IR_0ECM_A38_N3IRM3638T,3.3VU17MP1484_SOP8_0SOP8+EPADMP1482,SOP8U18G9131-28T73UF_SOT23G9131-28T73Uf U19G5699_0TDFN12_045_3X3G5699U20G9131-18T73UFSOT23G9131-18T73Uf U21G5728B_SOT25SOT25G5728BU22DS1307_SOIC8SOIC8_150NC(PT7C4307,SOIC8)Y130MHZ_CRY_30PPM_SMD5X3XTAL_SMD_50X3230MHzY2XTAL_32.768KHZ_0XTAL_127L32.768KY332.768KHZ_CRY_30PPM_SIZE_2X6XTAL_0P7L32.768KHz PCB 原理图。回复可见下载。
**** Hidden Message ***** mark一下 支持 谢谢分享GM8138S LFBGA196 +CAT6612 IPCAM demo 参考板PCB原理图
