shuszhao 发表于 2019-10-29 12:31
Netgear 网件 EAX80 AX6000规格 无线扩展器 拆解
网件EAX80支持新一代的 WiFi 6 (802.11ax) 标准,2.4G支持的最高速率为1.2Gbps,5G支持的最高速率为4.8Gbps,并且和路由器使用同一个WiFi 网络名称 (SSID),能打造覆盖整个家庭的无缝网络
https://image.koolshare.cn/attachment/forum/201910/25/103516tt91v3916xl36aso.png
▲技术规格
开箱
https://image.koolshare.cn/attachment/forum/201910/25/103558bfhbfrtrb0llrt0f.jpg
▲网件EAX80无线扩展器和网件的RAX系列无线路由器一样,采用了蓝黑色包装盒。从包装盒正面可以知道这是一款AX6000规格的网状网络扩展器
https://image.koolshare.cn/attachment/forum/201910/25/103909d7jk67ljpynwn44p.jpg
▲右侧阐述了夜鹰EAX80的优点
https://image.koolshare.cn/attachment/forum/201910/25/103947bemmajnogoa3kagk.jpg
▲利用现有路由器轻松打造Mesh WiFi 6系统
https://image.koolshare.cn/attachment/forum/201910/25/104328bunln9lne9invyte.jpg
▲包装内容和物理规格
https://image.koolshare.cn/attachment/forum/201910/25/104053qhx7i5d5dh4tai0x.jpg
▲IO接口介绍。产地越南
https://image.koolshare.cn/attachment/forum/201910/25/104612aw4r03ma0kwb2hab.jpg
▲拆开外包装,就能看到EAX80无线扩展器了
https://image.koolshare.cn/attachment/forum/201910/25/104652i1azv1t51i8ebb0r.jpg
▲全家福。EAX80无线扩展器并没有随机附赠网线
https://image.koolshare.cn/attachment/forum/201910/25/105549hmeyhfk228z77zke.jpg
▲国行EAX80的电源适配器采用国标插头
https://image.koolshare.cn/attachment/forum/201910/25/105629y73171sl7qxjskxv.jpg
▲电源适配器规格12V 3.5A
https://image.koolshare.cn/attachment/forum/201910/25/105741b2unr5ioutsupwnj.jpg
▲EAX80侧面,右下角的夜鹰logo采用烫金设计
https://image.koolshare.cn/attachment/forum/201910/25/110007wmqdj06yxjj6qkcv.jpg
▲EAX80正面,上方是IO接口指示灯所在位置,下面是WPS按钮,通电后会亮起
https://image.koolshare.cn/attachment/forum/201910/25/110115fmepbsjghjd1vhbf.jpg
▲背部IO接口一览。从上往下分别是Reaet按钮,4个千兆LAN口,一个USB3.0接口,电源直流插孔,开关按钮
https://image.koolshare.cn/attachment/forum/201910/25/110659gdo9dv3ekjzn0xuw.jpg
▲底部的铭牌
拆解
https://image.koolshare.cn/attachment/forum/201910/25/110901yzv912282oz2vegg.jpg
▲打开侧面的盖板就能看到内部的结构了
https://image.koolshare.cn/attachment/forum/201910/25/110936ksfxvfffs82e11vz.jpg
▲EAX80的顶端有四根2.4G/5G复用天线
https://image.koolshare.cn/attachment/forum/201910/25/111103d5piapyp0gfw00pm.jpg
▲将PCB主板从外壳中分离
https://image.koolshare.cn/attachment/forum/201910/25/111958b1tdso9o1dc1esus.jpg
▲PCB主板正面,覆盖正面的是一整块散热装甲,这次没有像RAX80那样采用风扇主动散热了
https://image.koolshare.cn/attachment/forum/201910/25/112042ru5mc7mllcucgda3.jpg
▲拆掉散热装甲,露出内部的金属屏蔽盖
https://image.koolshare.cn/attachment/forum/201910/25/112107jqqn99nhb4bieq4i.jpg
▲拆除金属屏蔽盖后PCB主板正面一览
https://image.koolshare.cn/attachment/forum/201910/25/112743i271b2b2elfqgqq1.jpg
▲核心部分。Soc是BCM4906,来自博通。集成双核心A53 CPU,28nm工艺,主频1.8GHz。它的左侧是K4B4G1646E-BYMA,RAM芯片,来自三星,大小512MB
https://image.koolshare.cn/attachment/forum/201910/25/113508m2dd29b8opqp5ocd.jpg
▲BCM43684,5G部分WLAN芯片,支持802.11AX,支持1024QAM,支持160Mhz频宽,支持4X4 MU-MIMO,提供高达4.8 Gbps的吞吐量。在它的下方是四个PA和LNA芯片,能够有效提升发射功率和降低噪声干扰
https://image.koolshare.cn/attachment/forum/201910/25/122912o22trdo1er0la2sb.jpg
▲第二块BCM43684,2.4部分WLAN芯片,支持802.11AX,支持1024QAM,支持4X4空间流,提供高达1.2Gbps的吞吐量。它的上方是四个PA和LNA芯片
https://image.koolshare.cn/attachment/forum/201910/25/123015gt3db9u1nj1j144q.jpg
▲拆除PCB主板背面的散热装甲
https://image.koolshare.cn/attachment/forum/201910/25/123043fnz3spk3x3mswscn.jpg
▲PCB主板背面一览
https://image.koolshare.cn/attachment/forum/201910/25/123101f9ns9uhe9ss92suc.jpg
▲W29N01HVSINA,FLASH芯片,容量大小为256MB
https://image.koolshare.cn/attachment/forum/201910/25/124118lgdt7zd9qjqyjt4j.jpg
▲芯片简单示意图
mj8abcd 发表于 2019-10-29 12:41
bidezhi7777 发表于 2019-10-29 14:22
tiny2010 发表于 2019-12-4 08:54
sun5304 发表于 2020-1-5 08:28
tianfeng988 发表于 2020-8-30 16:31
查看完整版本: Netgear 网件 EAX80 AX6000规格 无线扩展器 拆解
