armclub 发表于 2018-1-15 15:16
VS100TX+EP9142+EPF025A+IP175D+MAX8505EEE  PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB800BEAD_0805_BLM21PG600SN1BLM21PG600SN1805B801BEAD_0805_BLM21PG600SN1BLM21PG600SN1805B802BEAD_0603_FERRITE120R/2AFerrite 120R/2A603B803BEAD_0805_NINI805B804BEAD_0805_NINI805CM500TRAN_HM33_0_744273_NI_744273801NI_744273801744273CM501TRAN_HM33_0_744273_NI_744273801NI_744273801744273D1LED_0_LED_TH_90_LEDLEDLED_TH_90D2LED_0_LED_TH_90_LEDLEDLED_TH_90D3LED_0_LED_TH_90_LEDLEDLED_TH_90D4BAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CSOT-23-SMALLD12BAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CSOT-23-SMALLD13LED_0603_LED_LEDLED0603_LEDD14LED_0603_LED_LEDLED0603_LEDD32LED_0603_LED_LEDLED0603_LEDD36DIODE TSBI-DIR_SOD-923_ESD7951ESD7951ST5GSOD-923D37BAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CSOT-23-SMALLD801LED_1_LEDIRTX_NI_LED_IRNI_LED_IRLEDIRTXD802BAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CSOT-23-SMALLD803LED_0603_LED_LEDLED0603_LEDESD2TRISIL_BIDIR_0603_PGB1010603-MRPGB1010603-MR603ESD3TRISIL_BIDIR_0603_PGB1010603-MRPGB1010603-MR603FB1INDUCTOR_0805_BLM21PG600SN1BLM21PG600SN1805FB274479787210_1008_74479787210744797872101008IR1PL-IRM0101-3_IRM0101_PL-IRM0101PL-IRM0101-3IRM0101J2HDMI_A_0_CON-HDMI-19_HDMI_AHDMI_ACON-HDMI-19J3CONN RECT8_0_RJ45X8_P_RJ45RJ45RJ45X8_PJ6RJ45_TRNS_0_RJ00812_RJ45_TRNSRJ45_TRNSRJ00812J11CONN JACKPWR_0_CONPWR_PWR JACKPWR JACKCONPWRJ13PHONOJACKSTEREO-15_2_SJ1-3515-CONN 3.5MM SWSJ1-3515-SMTJ500CONN RCPT5_TSW-105-S_NI_HEADERNI_HEADER 5TSW-105-SJ501PHONOJACKSTEREO-15_2_SJ1-3515-CONN 3.5MM SWSJ1-3515-SMTJ503CONN RCPT5_TSW-105-S_NI_HEAD_1NI_HEADER 5MTSW-105-SJ504PHONOJACKSTEREO-15_2_SJ1-3515-CONN 3.5MM SWSJ1-3515-SMTJ506PHONOJACKSTEREO-15_2_SJ1-3515-CONN 3.5MM SWSJ1-3515-SMTJ507HDMI_A_0_CON-HDMI-19_HDMI_AHDMI_ACON-HDMI-19J508HEADER5X2_TSW-105_HEADER 5X2MHEADER 5X2MTSW-105L1INDUCTOR_0805_10UH10uH805L2INDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AVLF4012AL3INDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AVLF4012AL4INDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AVLF4012AL5INDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AVLF4012AL6INDUCTOR_SWSM_IND_1UH/3A1uH/3ASWSM_INDL7INDUCTOR_SWSM_IND_1UH/3A1uH/3ASWSM_INDL611INDUCTOR_SWSM_IND_1UH/3A1uH/3ASWSM_INDL622INDUCTOR_DO1608C_10UH/1A10uH/1ADO1608CL623INDUCTOR_DO1608C_10UH/1A10uH/1ADO1608CL624INDUCTOR_DO1608C_NINIDO1608CL625INDUCTOR_DO1608C_NINIDO1608CL800INDUCTOR_0805_10UH10uH805LED1LED_3_0603_LED_AC_LEDLED0603_LED_ACMH1TEST POINT_MH126P_MHMHMH126PMH2TEST POINT_MH126P_MHMHMH126PMH3TEST POINT_MH126P_MHMHMH126PMH4TEST POINT_MH126P_MHMHMH126PPD1AG9605-2BR_AG9605-SIM_AG9605-2BAg9605-2BRAG9605-SIMPSE1AG6100_AG6100-SIM_AG6100Ag6100AG6100-SIMQ1MMBT2222A/SOT_2_SOT-23-SMALL_MMMMBT2222ASOT-23-SMALLQ10ON-MOSFET-NTR4502_0_SOT-23-FET_NTR4502SOT-23-FETQ800ON-MOSFET-NTR4502_0_SOT-23-FET_NTR4502SOT-23-FETQ801MMBT2222A/SOT_2_SOT-23-SMALL_MMMMBT2222ASOT-23-SMALLQ802MMBT2907A/SOT_0_SOT-23_MMBT2907MMBT2907ASOT-23REG1MAX1556ETB_TDFN-EP-10_MAX1556ETMAX1556ETBTDFN-EP-10REG2MAX1556ETB_TDFN-EP-10_MAX1556ETMAX1556ETBTDFN-EP-10REG3MAX8505EEE_QSOP-16_MAX8505EEEMAX8505EEEQSOP-16SW500SWDIP-8/SM_DIPSW8-SMD-M_SW DIPSW DIP-8/SMDIPSW8-SMD-MTR1H7001NL_H7001NL_80MIL_H7019FNLH7019FNLH7001NL_80MILU1VS100-SRC_BGA-196_VS100TXVS100TXBGA-196U3RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU4RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU5DS1818-10_SOT-23_DS1818-10DS1818-10SOT-23U6RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU725LC512-I-SN_SOIJ-SOIC-8_M95M02M95M02-DRMN6TPSOIJ-SOIC-8U8175C_DEMO_MII_0_PQFP-128_IP175DIP175DPQFP-128U11NC7SZ14/SOT23_SOT23-5_NC7S14M5XNC7S14M5XSOT23-5U12NC7S08/SOT23_0_SOT23-5_NC7SZ08MNC7SZ08M5XSOT23-5U13NC7SZ14/SOT23_SOT23-5_NC7S14M5XNC7S14M5XSOT23-5U14RCLAMP0524_1_UDFN-10_RCLAMP2504RCLAMP2504NUDFN-10U15RCLAMP0524_2_UDFN-10_RCLAMP2504RCLAMP2504NUDFN-10U29MAX3232_2_TSSOP-16_MAX3232CUEMAX3232CUETSSOP-16U3424CXX_1_SOIC-8_24LC08BI_PREP24LC08BI_prepSOIC-8U35EP9142_LQFP64_0_LQFP64-EP_EP914EP9142_NILQFP64-EPU36EPF025A_0_TQFP64_04_EPF025A/021EPF025A/021A_prepTQFP64_04U800AD820/SO_0_SOT23-5_ADCMP600BRJZADCMP600BRJZSOT23-5U801EP91H0_SOP14_SOIC-14_EP91H0EP91H0SOIC-14U802NC7SZ32/SOT23_0_SOT23-5_NC7SZ32NC7SZ32M5XSOT23-5U803RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU804RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU805RCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524RCLAMP0524PU806TPS60151DRVT_SON2X2-6-EP_TPS601TPS60151DRVTSON2X2-6-EPU807NC7SZ384/SOT23_0_SOT23-5_NC7SZ1NC7SZ126M5XSOT23-5U808NC7SZ32/SOT23_0_SOT23-5_NC7SZ32NC7SZ32M5XSOT23-5U80974HC74_0_TSSOP-14_MM74HC74AMTCMM74HC74AMTCTSSOP-14X1OSC8/SM_0_5X7_125MHZCMOS125MHz CMOS5X7Y1CRYSTAL_HC49_US_25MHZ25MHZHC49_USY3CRYSTAL_HC49_US_24MHZ24MHzHC49_US
armclub 发表于 2018-1-15 15:17
PCB文件共享。回复可见
**** Hidden Message *****
vickey168 发表于 2018-1-15 15:52
yangxf0120 发表于 2018-1-15 21:03
谢谢分享VS100TX+EP9142+EPF025A+IP175D+MAX8505EEEPCB文件
带刀的老鼠 发表于 2018-1-15 21:08
521lry 发表于 2018-1-15 21:21
allegro_wh 发表于 2018-1-15 21:38
学海无涯 发表于 2018-1-16 07:14
高端!
james_zhangwk 发表于 2018-1-16 08:15
longxuekai 发表于 2018-1-16 08:20
很不错的了
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: VS100TX+EP9142+EPF025A+IP175D+MAX8505EEE  PCB文件共享下载
